bind it with qbittorrent but when i do the test it shows port not open or connection timeout
any help would be nice
I think you might be binding to IP in qBittorrent. Don't bind to IPs, bind to interfaces exclusively (TAP or WinTun on Windows (could be called by its pretty name instead, something like LAN connection, in your system language), tun on Linux, utun on Mac). Otherwise, you're bound to reconfigure your torrent client everytime you connect with different parameters, as your internal IP changes based on protocol, port, server and VPN protocol used, and even in time.
To me, it looks like AirVPN Port Forwarding is down. I get the same "Connection Timed Out" for all my forwarded Ports on VPN Connection in the Netherlands.
Is this something the airvpn team could look into? Having no way to forward ports means torrent download speed are stuck around 10 KBps.
Best
Incidentally, I had VPN connections to Kitalpha the last three days and did some rare torrenting, and I cannot confirm this was the case on Kitalpha.
