gajanq1
LAN connection stuck at 'Checking DNS', WIFI connection works well
As titled, when I use LAN connection, it always get stuck at 'Checking DNS'. However, WIFI connection works well.
I tried various VPN servers of different countries, all had the same results.
. 2022.06.22 00:53:37 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.22000.0, Mono/.Net: v4.0.30319
. 2022.06.22 00:53:37 - Command line arguments (1): path="home"
. 2022.06.22 00:53:38 - Reading options from C:\Users\Zanyx\AppData\Local\Eddie\default.profile
. 2022.06.22 00:53:39 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2022.06.22 00:53:39 - SSH - Version: plink 0.73 (C:\Program Files\AirVPN\plink.exe)
. 2022.06.22 00:53:39 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
I 2022.06.22 00:53:39 - Ready
. 2022.06.22 00:53:41 - Collect information about AirVPN completed
I 2022.06.22 00:53:43 - Session starting.
I 2022.06.22 00:53:44 - Checking authorization ...
. 2022.06.22 00:53:46 - Added new network interface "Eddie", Wintun version 0.12
. 2022.06.22 00:53:46 - Using WinTun network interface "Eddie (Eddie Tunnel)"
! 2022.06.22 00:53:46 - Connecting to Antares (Singapore, Singapore)
. 2022.06.22 00:53:47 - Routes, add 103.254.153.107/32 for interface "Wi-Fi (Intel(R) Wi-Fi 6 AX200 160MHz)".
. 2022.06.22 00:53:47 - Routes, add 103.254.153.107/32 for interface "Wi-Fi (Intel(R) Wi-Fi 6 AX200 160MHz)", already exists.
. 2022.06.22 00:53:47 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2022.06.22 00:53:47 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2022.06.22 00:53:47 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2022.06.22 00:53:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.06.22 00:53:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.06.22 00:53:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2022.06.22 00:53:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2022.06.22 00:53:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]103.254.153.107:443
. 2022.06.22 00:53:47 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2022.06.22 00:53:47 - OpenVPN > UDP link local: (not bound)
. 2022.06.22 00:53:47 - OpenVPN > UDP link remote: [AF_INET]103.254.153.107:443
. 2022.06.22 00:53:47 - OpenVPN > TLS: Initial packet from [AF_INET]103.254.153.107:443, sid=c920b1d2 bf140d1c
. 2022.06.22 00:53:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2022.06.22 00:53:47 - OpenVPN > VERIFY KU OK
. 2022.06.22 00:53:47 - OpenVPN > Validating certificate extended key usage
. 2022.06.22 00:53:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2022.06.22 00:53:47 - OpenVPN > VERIFY EKU OK
. 2022.06.22 00:53:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Antares, emailAddress=info@airvpn.org
. 2022.06.22 00:53:47 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2022.06.22 00:53:47 - OpenVPN > [Antares] Peer Connection Initiated with [AF_INET]103.254.153.107:443
. 2022.06.22 00:53:48 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.9.106.1,dhcp-option DNS6 fde6:7a:7d20:56a::1,tun-ipv6,route-gateway 10.9.106.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:56a::107f/64 fde6:7a:7d20:56a::1,ifconfig 10.9.106.129 255.255.255.0,peer-id 4,cipher AES-256-GCM'
. 2022.06.22 00:53:48 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2022.06.22 00:53:48 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.9.106.1'
. 2022.06.22 00:53:48 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:56a::1'
. 2022.06.22 00:53:48 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2022.06.22 00:53:48 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2022.06.22 00:53:48 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2022.06.22 00:53:48 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2022.06.22 00:53:48 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2022.06.22 00:53:48 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2022.06.22 00:53:48 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2022.06.22 00:53:48 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2022.06.22 00:53:48 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.06.22 00:53:48 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2022.06.22 00:53:48 - OpenVPN > interactive service msg_channel=0
. 2022.06.22 00:53:48 - OpenVPN > open_tun
. 2022.06.22 00:53:48 - OpenVPN > wintun device [Eddie] opened
. 2022.06.22 00:53:48 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 47 static 10.9.106.129 255.255.255.0
. 2022.06.22 00:53:48 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 47 all
. 2022.06.22 00:53:48 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 47 all
. 2022.06.22 00:53:48 - OpenVPN > IPv4 MTU set to 1500 on interface 47 using SetIpInterfaceEntry()
. 2022.06.22 00:53:48 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 47 fde6:7a:7d20:56a::107f/128 store=active
. 2022.06.22 00:53:48 - OpenVPN > add_route_ipv6(fde6:7a:7d20:56a::/64 -> fde6:7a:7d20:56a::107f metric 0) dev Eddie
. 2022.06.22 00:53:48 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:56a::/64 47 fe80::8 store=active
. 2022.06.22 00:53:48 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2022.06.22 00:53:48 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 47 all
. 2022.06.22 00:53:48 - OpenVPN > IPv6 MTU set to 1500 on interface 47 using SetIpInterfaceEntry()
. 2022.06.22 00:53:48 - OpenVPN > Initialization Sequence Completed
. 2022.06.22 00:53:48 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2022.06.22 00:53:48 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2022.06.22 00:53:48 - DNS leak protection with packet filtering enabled.
. 2022.06.22 00:53:49 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.9.106.1)
. 2022.06.22 00:53:49 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:56a::1)
. 2022.06.22 00:53:49 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.9.106.1)
. 2022.06.22 00:53:49 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fde6:7a:7d20:56a::1)
. 2022.06.22 00:53:49 - DNS IPv4 of a network adapter forced (VMware Network Adapter VMnet1, from automatic to 10.9.106.1)
. 2022.06.22 00:53:49 - DNS IPv6 of a network adapter forced (VMware Network Adapter VMnet1, from automatic to fde6:7a:7d20:56a::1)
. 2022.06.22 00:53:49 - DNS IPv4 of a network adapter forced (VMware Network Adapter VMnet8, from automatic to 10.9.106.1)
. 2022.06.22 00:53:49 - DNS IPv6 of a network adapter forced (VMware Network Adapter VMnet8, from automatic to fde6:7a:7d20:56a::1)
. 2022.06.22 00:53:50 - Routes, add 0.0.0.0/1 for interface "Eddie (Eddie Tunnel)".
. 2022.06.22 00:53:50 - Routes, add 128.0.0.0/1 for interface "Eddie (Eddie Tunnel)".
. 2022.06.22 00:53:51 - Routes, add ::/1 for interface "Eddie (Eddie Tunnel)".
. 2022.06.22 00:53:51 - Routes, add 8000::/1 for interface "Eddie (Eddie Tunnel)".
. 2022.06.22 00:53:52 - Routes, add 103.254.153.99/32 for interface "Eddie (Eddie Tunnel)".
. 2022.06.22 00:53:52 - Routes, add 2001:df1:800:a000:11::9bb9/128 for interface "Eddie (Eddie Tunnel)".
. 2022.06.22 00:53:52 - Flushing DNS
I 2022.06.22 00:53:52 - Checking DNS
. 2022.06.22 00:55:38 - Checking DNS (4° try)
. 2022.06.22 00:56:15 - Checking DNS (5° try)
E 2022.06.22 00:56:48 - Checking DNS failed, last reason: Fetch url error:Timeout was reached
. 2022.06.22 00:56:48 - OpenVPN > write UDP: Unknown error (code=10065)
. 2022.06.22 00:56:48 - Above log line repeated 17 times more
! 2022.06.22 00:56:48 - Disconnecting
. 2022.06.22 00:56:48 - Sending soft termination signal
Hi, I am still experiencing this issue if I connect using a wired connection. Do I file a bug report? Cheers.
