DealerMan
ANSWERED Reconnection woes every 3 seconds
I'm stumped over how to fix this.  The log states to uncheck the Force usage of old Tap driver, but it's not checked.  A few days ago, I decided to check it, and it connected.  It won't do that now, even after checking/unchecking it, choosing network lock, and connect to recommended server/choose from the list.  Any help is greatly appreciated!
Here is the latest log from 5 minutes ago:
I 2022.06.20 16:54:51 - Session starting.
I 2022.06.20 16:54:51 - Checking authorization ...
W 2022.06.20 16:54:52 - Deprecated: please uncheck Preferences > Advanced > Force usage of old Tap driver
. 2022.06.20 16:54:52 - Using Tap0901 network interface "Eddie (TAP-Windows Adapter V9 #2)"
! 2022.06.20 16:54:52 - Connecting to Regulus (Canada, Toronto, Ontario)
E 2022.06.20 16:54:52 - OpenVPN > Error: Exception: Not supported OpenVPN config: file not found
! 2022.06.20 16:54:52 - Disconnecting
. 2022.06.20 16:54:52 - Connection terminated.
I 2022.06.20 16:54:55 - Checking authorization ...
W 2022.06.20 16:54:56 - Deprecated: please uncheck Preferences > Advanced > Force usage of old Tap driver
. 2022.06.20 16:54:56 - Using Tap0901 network interface "Eddie (TAP-Windows Adapter V9 #2)"
! 2022.06.20 16:54:56 - Connecting to Nahn (Canada, Vancouver)
E 2022.06.20 16:54:56 - OpenVPN > Error: Exception: Not supported OpenVPN config: file not found
! 2022.06.20 16:54:56 - Disconnecting
. 2022.06.20 16:54:56 - Connection terminated.
I 2022.06.20 16:54:59 - Cancel requested.
! 2022.06.20 16:54:59 - Session terminated.
I notice this behaviour when I leave airvpn open and connected and close the lid, then open, then close... Try to quit the application and re-open it, or re-install it.
Finally figured it out. A malware program I use was interfering with my connection. As soon as it was uninstalled, it worked just fine.
Fridaynet, thank you for responding as well. 👍
