Cadenza 0 Posted ... So I have a server on OVH that I RDP to with AirVPN between. However every 20-30 minutes it will drop any connection that is port forwarded. I can restore them by connecting over IPMI and restarting AirVPN however! Quote Hide Cadenza's signature Hide all signatures 🐻🐻🐻 Share this post Link to post
Tech Jedi Alex 1499 Posted ... Decribe the drop. And, are you by any chance connecting with other devices somewhere? Do the OpenVPN logs say that the connection was lost, then reestablished? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Cadenza 0 Posted ... On 5/16/2022 at 12:28 PM, OpenSourcerer said: Decribe the drop. And, are you by any chance connecting with other devices somewhere? Do the OpenVPN logs say that the connection was lost, then reestablished? Nope! The last log message when I tried to connect was just "collect information about AirVPN" it was made 2 hours before now. So it doesn't seem to be logging anything! Quote Hide Cadenza's signature Hide all signatures 🐻🐻🐻 Share this post Link to post
Tech Jedi Alex 1499 Posted ... 50 minutes ago, Cadenza said: So it doesn't seem to be logging anything! I've got a very hard time believing that, unless you're not even connected, verbosity has been turned down drastically (for which there is no setting in Eddie's GUI, so unlikely) or Eddie was restarted. There must be hourly messages about rekeying due to Forward Secrecy – when you're connected, that is. We can only have clearance with a system report which you can find in the Logs tab: Click the lifebelt icon right of the logs (don't pay attention to them here, they will be part of the system report), then paste/upload the contents in the appearing window by using one of the buttons. Thanks. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Cadenza 0 Posted ... My bad sorry the time on the server was a bit behind so it appeared as 12PM at 2PM and so on. Eddie_20220517_142005.txt Quote Hide Cadenza's signature Hide all signatures 🐻🐻🐻 Share this post Link to post
Tech Jedi Alex 1499 Posted ... . 2022.05.15 12:28:52 - OpenVPN > write_wintun(): ring is full This kind of messages is very new to me unfortunately. Unsure if this is related to OpenVPN buffer sizes, even more unsure what the problem is exactly. They do seem to appear around Bad Packet ID errors which are well known around here on the other hand. Still, I can only guess. Some quick searches suggest to try OpenVPN beta releases but those suggestions are from 2020… I can imagine the drops being a consequence of these quickly repeating errors. Buffers filling up and the tun interface unable to exchange data anymore, so keepalives time out and the connection is assumed to be dead. Are these drops happening only when you use the connection (heavily) or can they also happen if you don't do anything at all? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Cadenza 0 Posted ... They happen just at random as far as I can tell! A bit ago I had RDP running in the background and just popped in to check the server and noticed it was disconnected. Had to log in over IPMI and restart AirVPN. The same issue applies to other protocols such as SSH. Quote Hide Cadenza's signature Hide all signatures 🐻🐻🐻 Share this post Link to post
Tech Jedi Alex 1499 Posted ... Okay. Can you try TAP instead of wintun? Unfortunately I don't remember where to set this in Eddie, but you can check a box somewhere in Preferences to use wintun instead of TAP. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Seebarschtian 5 Posted ... 21 hours ago, OpenSourcerer said: Unfortunately I don't remember where to set this in Eddie, but you can check a box somewhere in Preferences to use wintun instead of TAP. It should be the following path: Settings -> Advanced -> right box "Microsoft Windows Only" -> Force usage of old Tap driver 1 Tech Jedi Alex reacted to this Quote Share this post Link to post
Cadenza 0 Posted ... Tried this for a while and the issue still occurs. Quote Hide Cadenza's signature Hide all signatures 🐻🐻🐻 Share this post Link to post
Tech Jedi Alex 1499 Posted ... 11 hours ago, Cadenza said: Tried this for a while and the issue still occurs. Keep in mind that, since you're using TAP, the error messages are different. As such, new logs or even a system report makes sense. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
