RYFA
I need to reinstall tap driver which of these options does airvpn/eddie need to work.
I need to reinstall the windows tap driver so i went to th install folder and ran tap windows exe which of these options are required for the airvpn/eddie to work properly?
Thanks for your help.
You need the tunnel adapter, which is 1.
TAP utilities contain programs and scripts to create more adapters or remove them, I believe. Could be useful.
TAP SDK might be a collection of source code header files or something for development with the TAP adapter. Unimportant in your case.
