Not connected, Your IP: 216.73.217.142
burtTroutman
https://imgur.com/ "Sorry! We're encountering some technical difficulties. Refresh or check back in a few!"
Got the very same issue with imgur.
So, if I get this right, as long as another airvpn user will run a Tor exit on the server I'm also using, imgur won't be able to work properly ? (sigh)
As long as such a server is marked as a Tor exit, Imgur won't allow connections.
Been testing with AirVPN servers in Spain, Switzerland, and NL, all give the same result with imgur :-|
It used to work well a few months ago.
