globetrotterdk 0 Posted ... I am trying to get AirVPN to work with GhostBSD. GhostBSD has a GUI OpenVPN Administration widget (?) I have downloaded the necessary .ovpn file as well as the individual certificates. Unfortunately, while I am getting a green indicator, a visit to mullvad.net tells me that only my authentic location is detected. What am I doing wrong? General protocol - udp device - tun remote - se.vpn.airdns.org verbosity level - 3 port - 433 Certificate SSL/TLS client active CA: /path/to/file/ Cert: /path/to/file/ Key: /paath/to/file/ Tls-Auth: /path/to/file/ Options No Bind Persist Key Persist Tun Quote Share this post Link to post
OpenSourcerer 1487 Posted ... That Pull option is not set, I believe it corresponds to --pull which is a necessity. --pull This option must be used on a client which is connecting to a multi-client server. It indicates to OpenVPN that it should accept options pushed by the server, provided they are part of the legal set of pushable options (note that the --pull option is implied by --client ). Not sure if your app implies --client. I'd say, try ticking Pull. 1 globetrotterdk reacted to this Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
globetrotterdk 0 Posted ... That solved the connection problem, however "connection check" at mullvad.net shows leaking DNS servers and leaking WebRTC IPs... I will try posting a new topic tomorrow, if I don't get that sorted. Quote Share this post Link to post
OpenSourcerer 1487 Posted ... Nah, you can stay here with that. Be advised that OpenVPN is not responsible for adjusting global system-wide DNS; as such, it does not edit /etc/resolv.conf, use resolvectl or other means to alter DNS settings. It only sets the DNS servers of the tunnel interface (received with --pull). It also doesn't touch the configuration of other applications, like a firewall or a browser to block or disable WebRTC. It's, in the strictest UNIX manner, a software doing one thing great, which is building a tunnel to a VPN server. There are funny options like --block-outside-dns, but I'm not sure why it's there if it only works on Windows. Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
