Updater
Network lock blocks all internet
On a new installation (windows 7)
network lock seems to block the vpn connection to.
The installed Eddie version is 2.20.0
So to be able to use the vpn i need to disable the network lock what i prefer not do.
Any solutions ?
Erm… Eddie never blocked its own connections in the past. You not being able to connect must have a different source.
First things first: In Logs tab, click the lifebelt icon and paste/upload the output here.
I THINK i found the problem.
Both drop boxes in configuration >  network lock > incoming  and outgoing were on Block
I changed this to "incoming: allow"  "outgoing : block"
Are these settings correct ?
Thanks.
The fresh Windows 7 installation was so problematic i decided to delete it and start a new clean windows 10 installation.
Meanwhile i found out the above solution was wrong.
now i have the same problem on the fresh new windows 10 installation.
I downloaded the Eddie windows 10 installer.
IPV6 is disabled, from the beginning Eddie can not pass IPV6  check and keeps restarting.
Also i use Peerblock (not installed right now) who can't block  IPV6  so i prefer it disabled.
for the rest i find it so strange i have the same problem on two different windows installations.
I have added the log, perhaps someone finds the problem.
Eddie log 23-11.txt
