flare 2 Posted ... (edited) I noticed that sometimes the dns cannot resolve common sites like reddit or for example if I open imgur with the vpn on firefox or safari, the spinner keeps spinning till I disable the VPN , then it works . Looks like there's a kind of cache poisoning or filtering because other sites work just fine . Not sure what's going on but just wanted to let you know for example (using netherland server)https://imgur.com/a/PRr9stV regards Edited ... by flare Quote Share this post Link to post
Tech Jedi Alex 1583 Posted ... Your screenshot does not confirm a DNS resolution error. Imgur is clearly shown. If it's not too much work, open the developer console with F12 on any browser (alternatively, Ctrl+Shift+Alt+I on Firefox) and switch to the Network tab. Then reload the page with Ctrl+F5. See if you get any 403 errors; these'd be indicative. 404 or a block symbol is more like adblocker. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
flare 2 Posted ... you're right it was kind of low effort post , more to collect feedback from others that might have had these strange random problems that are not blocking , just annoying doing tests with Safari that has not any adblock without the VPN works , with the vpn I get some 403 errors from the API { "data": { "error": "Imgur is temporarily over capacity. Please try again later." }, "success": false, "status": 403 } so it's the api that apparently reduces the capacity per IP , trying different servers seems to work. That does not explain why sometimes major sites (reddit, ansa etc..) appear down (404) until I change server but it helps thanks Quote Share this post Link to post
Tech Jedi Alex 1583 Posted ... 38 minutes ago, flare said: so it's the api that apparently reduces the capacity per IP , trying different servers seems to work. Hm. Still strange they use a 403 reply in such a case. Maybe it's an API-specific error code and not a HTTP code? But then why use something that can be mixed up with a valid, widely used, plausible HTTP code? All a bit strange. 42 minutes ago, flare said: That does not explain why sometimes major sites (reddit, ansa etc..) appear down (404) until I change server but it helps Indeed, these need to be analyzed separately. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
flare 2 Posted ... >Hm. Still strange they use a 403 reply I'm not very familiar with safari, I just used it because it's vanilla without plugins. The 403 error was indeed coming from the api , the http response error is 429 (Too many Requests) which makes more sense 1 Tech Jedi Alex reacted to this Quote Share this post Link to post
