Denise6363 1 Posted ... I'm trying to run Eddie with low privilage user (sudo /usr/bin/eddie-ui)it's working fine and connecting to my pre-configured default server...THE PROBLEM IS THAT, IT'S NOT SHOWING THE GUI, I MEAN NOT SHOWING THE APP ITSELF... But i found out that it's working by visiting whoer.net to check my assign IP.....WHY IS IT NOT SHOWING GUI on low privilage account... because if i login as root it'll show up the GUI app where i can change server and modify settings..... Quote Share this post Link to post
Tech Jedi Alex 1525 Posted ... 55 minutes ago, Denise6363 said: I'm trying to run Eddie with low privilage user (sudo /usr/bin/eddie-ui) That command is absolutely not low privilege, it executes /usr/bin/eddie-ui as root. You can try running /usr/bin/eddie-ui in a terminal as your user, without sudo, and see if any Eddie or Mono errors appear. But first I'd stop Eddie from launching automatically because it looks like it. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
