Not connected, Your IP: 216.73.216.124
vpncer
Problems with eddie running in a proxy vm in qubes.
Hello, I was trying to run eddie in a proxy vm in qubes, something like "browser vm --> eddie vm --> net vm", but eddie seems to modify routing table so that proxy doesn't route traffic downstream from a "browser vm". How would I need to modify the routing table to make eddie route traffic from "browser vm" to airvpn gateway with network lock enabled?
I attached the system report of my configuration, where 10.138.37.231 is a browser vm, 10.138.35.206 is a net vm.
system report.txt
Eddie doesn't alter anything, it's OpenVPN doing the work.
Apart from that, did you try a search? Or the documentation?
