Not connected, Your IP: 216.73.217.175
cellulosa
Sainsbury's (account.sainsburys.co.uk)
hi guys,
Sainsbury's homepage loads fine (https://www.sainsburys.co.uk), however the login page (e.g. at the top right Login > Groceries account) which is required to access all services, returns a 403 forbidden error.
Lots of NS_BINDING_ABORTED are being returned from various GET calls in the background.
The website loads fine with the VPN is turned off.
Let me know how I can help.
20 hours ago, cellulosa said:
hi guys,
Companies that offer transactions often block VPN access, you can reach out to Sainsburys directly and ask them to whitelist or remove the AirVPN exit nodes from their blacklist but I suspect they won't be interested. Using a VPN to mask your identity with a service that you log into and that has your home address to deliver to is usually not valuable.
@cellulosa I would still contact them so it ends up somewhere in the system. While above is valid, a truthful point for VPN usage is public Wi-Fi hotspots that you should use a VPN on, hence justifying your attempt to access their website via AirVPN.
Fair point, @dIecbasC. I just have it always on but I guess it takes nothing to switch it temporarily.
Weirdly enough, even if I add the website and the various ips to `net_gateway` it still does not work.
Will do @Stalinium
Edited ... by cellulosa
On 8/4/2021 at 7:04 PM, cellulosa said:
hi guys,
It sounds like there's a problem with accessing the login page, and you're getting a weird error message.
