I am trying to switch from PIA to AirVPN due to port forwarding features. I had PIA functioning perfectly, however after the initial configuration of openvpn client for AirVPN it doesn't seem to be pulling an IP address. The only thing that I wasn't able to do during the setup was select " Client Certificate = [ AirVPN_CERT ▼]" The only option was either none (user/password) or webConfigurator.
Any suggestions? Thank you.
You should correctly import your certificate under system > certificate manager > certificates section of (OPN+pf)Sense.
