Not connected, Your IP: 216.73.216.7
I recently moved and have a new ISP.  Since then, websites have not been loading while the VPN is active even though qbittorrent still works. Here is my system info:
Eddie System/Environment Report - 6/11/2021 - 5:28 PM UTC
Eddie version: 2.20.0
Eddie OS build: windows_x64
Eddie architecture: x64
OS type: Windows
OS name: Windows 8.1 Pro
OS version: Microsoft Windows NT 6.3.9600.0
OS architecture: x64
Mono /.Net Framework: v4.0.30319
TUN driver: 0901: 9.24.2; wintun: Not found
OpenVPN: 2.5.1 - OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
Hummingbird:  ()
SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
Profile path: C:\Users\Dobson\AppData\Local\Eddie\default.profile
Data path: C:\Users\Dobson\AppData\Local\Eddie
Application path: C:\Program Files\AirVPN
Executable path: C:\Program Files\AirVPN\Eddie-UI.exe
Command line arguments: (1 args) path="home"
Network Lock Active: No
Connected to VPN: No
Detected DNS: 2600:1700:1f10:5510::1, 192.168.1.254
Test DNS IPv4: Ok
Test DNS IPv6: Ok
Test Ping IPv4: 102 ms
Test Ping IPv6: 100 ms
Test HTTP IPv4: Ok
Test HTTP IPv6: Ok
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
netlock: True
servers.scoretype: Latency
areas.whitelist: us
dns.servers: 10.4.0.1,10.5.0.1
netlock.allow_dns: True
gui.tray_minimized: False
Logs:
. 2021.06.11 13:10:34 - Eddie version: 2.20.0 / windows_x64, System: Windows, Name: Windows 8.1 Pro, Version: Microsoft Windows NT 6.3.9600.0, Mono/.Net: v4.0.30319
. 2021.06.11 13:10:34 - Command line arguments (1): path="home"
. 2021.06.11 13:10:35 - Profile path: C:\Users\Dobson\AppData\Local\Eddie\default.profile
. 2021.06.11 13:10:36 - Reading options from C:\Users\Dobson\AppData\Local\Eddie\default.profile
. 2021.06.11 13:10:37 - Tun Driver - 0901: 9.24.2; wintun: Not found
. 2021.06.11 13:10:37 - OpenVPN - Version: 2.5.1 - OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2021.06.11 13:10:37 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2021.06.11 13:10:37 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2021.06.11 13:10:38 - Recovery. Unexpected crash?
. 2021.06.11 13:10:38 - Routes, added a new route, 107.167.244.83 for gateway 10.28.138.1
. 2021.06.11 13:10:38 - Routes, added a new route, 193.37.254.11 for gateway 10.33.106.1
. 2021.06.11 13:10:39 - Routes, removed an existing route, 199.249.223.130 for gateway 10.9.170.1
. 2021.06.11 13:10:39 - Routes, removed an existing route, 193.37.254.27 for gateway 10.32.10.1
. 2021.06.11 13:10:39 - Above log line repeated 1 times more
. 2021.06.11 13:10:39 - Routes, added a new route, 107.167.244.67 for gateway 10.6.170.1
! 2021.06.11 13:10:39 - Activation of Network Lock - Windows Filtering Platform
I 2021.06.11 13:10:40 - Ready
. 2021.06.11 13:10:44 - Collect information about AirVPN completed
I 2021.06.11 13:10:48 - Session starting.
I 2021.06.11 13:10:48 - Checking authorization ...
! 2021.06.11 13:10:48 - Connecting to Hercules (United States of America, Atlanta, Georgia)
. 2021.06.11 13:10:49 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2021.06.11 13:10:49 - OpenVPN > Windows version 6.3 (Windows 8.1) 64bit
. 2021.06.11 13:10:49 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2021.06.11 13:10:49 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.06.11 13:10:49 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.06.11 13:10:49 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.06.11 13:10:49 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.06.11 13:10:49 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.61:443
. 2021.06.11 13:10:49 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2021.06.11 13:10:49 - OpenVPN > UDP link local: (not bound)
. 2021.06.11 13:10:49 - OpenVPN > UDP link remote: [AF_INET]64.42.179.61:443
. 2021.06.11 13:10:49 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.61:443, sid=792b95a4 72b84583
. 2021.06.11 13:10:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.06.11 13:10:49 - OpenVPN > VERIFY KU OK
. 2021.06.11 13:10:49 - OpenVPN > Validating certificate extended key usage
. 2021.06.11 13:10:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.06.11 13:10:49 - OpenVPN > VERIFY EKU OK
. 2021.06.11 13:10:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hercules, emailAddress=info@airvpn.org
. 2021.06.11 13:10:49 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.06.11 13:10:49 - OpenVPN > [Hercules] Peer Connection Initiated with [AF_INET]64.42.179.61:443
. 2021.06.11 13:10:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.22.246.1,dhcp-option DNS6 fde6:7a:7d20:12f6::1,tun-ipv6,route-gateway 10.22.246.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:12f6::1053/64 fde6:7a:7d20:12f6::1,ifconfig 10.22.246.85 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2021.06.11 13:10:49 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.06.11 13:10:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.06.11 13:10:49 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.06.11 13:10:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.06.11 13:10:49 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.06.11 13:10:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.06.11 13:10:49 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.06.11 13:10:49 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.06.11 13:10:49 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.06.11 13:10:49 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.06.11 13:10:49 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.06.11 13:10:49 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.06.11 13:10:49 - OpenVPN > interactive service msg_channel=0
. 2021.06.11 13:10:49 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 I=9 HWADDR=44:af:28:37:39:85
. 2021.06.11 13:10:49 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.06.11 13:10:49 - OpenVPN > GetBestInterfaceEx() returned if=9
. 2021.06.11 13:10:49 - OpenVPN > GDG6: II=9 DP=::/0 NH=fe80::feae:34ff:fe37:f8c0
. 2021.06.11 13:10:49 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2021.06.11 13:10:49 - OpenVPN > ROUTE6_GATEWAY fe80::feae:34ff:fe37:f8c0 I=9
. 2021.06.11 13:10:49 - OpenVPN > open_tun
. 2021.06.11 13:10:50 - OpenVPN > tap-windows6 device [Local Area Connection] opened
. 2021.06.11 13:10:50 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.06.11 13:10:50 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.22.246.0/10.22.246.85/255.255.255.0 [SUCCEEDED]
. 2021.06.11 13:10:50 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.22.246.85/255.255.255.0 on interface {AA3FBE9B-E983-4E45-9A9D-9D372FDF5737} [DHCP-serv: 10.22.246.254, lease-time: 31536000]
. 2021.06.11 13:10:50 - OpenVPN > Successful ARP Flush on interface [3] {AA3FBE9B-E983-4E45-9A9D-9D372FDF5737}
. 2021.06.11 13:10:50 - OpenVPN > IPv4 MTU set to 1500 on interface 3 using SetIpInterfaceEntry()
. 2021.06.11 13:10:50 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address 3 fde6:7a:7d20:12f6::1053/128 store=active
. 2021.06.11 13:10:50 - OpenVPN > add_route_ipv6(fde6:7a:7d20:12f6::/64 -> fde6:7a:7d20:12f6::1053 metric 0) dev Local Area Connection
. 2021.06.11 13:10:50 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:12f6::/64 3 fe80::8 store=active
. 2021.06.11 13:10:50 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2021.06.11 13:10:50 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 3 all
. 2021.06.11 13:10:50 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns 3 static fde6:7a:7d20:12f6::1 validate=no
. 2021.06.11 13:10:50 - OpenVPN > IPv6 MTU set to 1500 on interface 3 using SetIpInterfaceEntry()
. 2021.06.11 13:10:55 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.06.11 13:10:55 - OpenVPN > C:\Windows\system32\route.exe ADD 64.42.179.61 MASK 255.255.255.255 192.168.1.254
. 2021.06.11 13:10:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.06.11 13:10:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.06.11 13:10:55 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.22.246.1
. 2021.06.11 13:10:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2021.06.11 13:10:55 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.22.246.1
. 2021.06.11 13:10:55 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:12f6::1 metric -1) dev Local Area Connection
. 2021.06.11 13:10:55 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 3 fe80::8 store=active
. 2021.06.11 13:10:55 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2021.06.11 13:10:55 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:12f6::1 metric -1) dev Local Area Connection
. 2021.06.11 13:10:55 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 3 fe80::8 store=active
. 2021.06.11 13:10:55 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:12f6::1 metric -1) dev Local Area Connection
. 2021.06.11 13:10:55 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 3 fe80::8 store=active
. 2021.06.11 13:10:55 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:12f6::1 metric -1) dev Local Area Connection
. 2021.06.11 13:10:55 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 3 fe80::8 store=active
. 2021.06.11 13:10:55 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4
. 2021.06.11 13:10:55 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6
. 2021.06.11 13:10:55 - DNS leak protection with packet filtering enabled.
. 2021.06.11 13:10:56 - DNS IPv4 of a network adapter forced (Local Area Connection, from automatic to 10.4.0.1, 10.5.0.1)
. 2021.06.11 13:10:56 - Routes, added a new route, 64.42.179.59 for gateway 10.22.246.1
. 2021.06.11 13:10:56 - Routes, added a new route, 2605:9f80:6000:80:fc8c:43ee:267e:97ab for gateway fde6:7a:7d20:12f6::1
. 2021.06.11 13:10:56 - Flushing DNS
I 2021.06.11 13:10:56 - Checking route IPv4
I 2021.06.11 13:10:57 - Checking route IPv6
! 2021.06.11 13:11:01 - Connected.
. 2021.06.11 13:11:01 - OpenVPN > Initialization Sequence Completed
! 2021.06.11 13:12:47 - Disconnecting
. 2021.06.11 13:12:47 - Routes, removed a route previously added, 64.42.179.59 for gateway 10.22.246.1
. 2021.06.11 13:12:47 - Routes, removed a route previously added, 2605:9f80:6000:80:fc8c:43ee:267e:97ab for gateway fde6:7a:7d20:12f6::1
. 2021.06.11 13:12:47 - Sending soft termination signal
. 2021.06.11 13:12:50 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2021.06.11 13:12:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 64.42.179.61 MASK 255.255.255.255 192.168.1.254
. 2021.06.11 13:12:52 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.06.11 13:12:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.22.246.1
. 2021.06.11 13:12:52 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.22.246.1
. 2021.06.11 13:12:52 - OpenVPN > delete_route_ipv6(::/3)
. 2021.06.11 13:12:52 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 3 fe80::8 store=active
. 2021.06.11 13:12:52 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2021.06.11 13:12:52 - OpenVPN > delete_route_ipv6(2000::/4)
. 2021.06.11 13:12:52 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 3 fe80::8 store=active
. 2021.06.11 13:12:52 - OpenVPN > delete_route_ipv6(3000::/4)
. 2021.06.11 13:12:52 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 3 fe80::8 store=active
. 2021.06.11 13:12:52 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2021.06.11 13:12:52 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 3 fe80::8 store=active
. 2021.06.11 13:12:52 - OpenVPN > Closing TUN/TAP interface
. 2021.06.11 13:12:52 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 3 all
. 2021.06.11 13:12:52 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:12f6::/64)
. 2021.06.11 13:12:52 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:12f6::/64 3 fe80::8 store=active
. 2021.06.11 13:12:52 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 3 fde6:7a:7d20:12f6::1053 store=active
. 2021.06.11 13:12:53 - OpenVPN > TAP: DHCP address released
. 2021.06.11 13:12:53 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2021.06.11 13:12:53 - Connection terminated.
. 2021.06.11 13:12:53 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection, to automatic)
. 2021.06.11 13:12:53 - DNS leak protection with packet filtering disabled.
. 2021.06.11 13:12:53 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4
. 2021.06.11 13:12:53 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6
. 2021.06.11 13:12:53 - Flushing DNS
! 2021.06.11 13:12:53 - Session terminated.
! 2021.06.11 13:12:54 - Deactivation of Network Lock
! 2021.06.11 13:15:12 - Activation of Network Lock - Windows Filtering Platform
I 2021.06.11 13:15:13 - Session starting.
I 2021.06.11 13:15:14 - Checking authorization ...
! 2021.06.11 13:15:14 - Connecting to Hercules (United States of America, Atlanta, Georgia)
. 2021.06.11 13:15:14 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2021.06.11 13:15:14 - OpenVPN > Windows version 6.3 (Windows 8.1) 64bit
. 2021.06.11 13:15:14 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2021.06.11 13:15:14 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.06.11 13:15:14 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.06.11 13:15:14 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.06.11 13:15:14 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.06.11 13:15:14 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.61:443
. 2021.06.11 13:15:14 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2021.06.11 13:15:14 - OpenVPN > UDP link local: (not bound)
. 2021.06.11 13:15:14 - OpenVPN > UDP link remote: [AF_INET]64.42.179.61:443
. 2021.06.11 13:15:14 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.61:443, sid=882e4d8a 59eda4a7
. 2021.06.11 13:15:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.06.11 13:15:14 - OpenVPN > VERIFY KU OK
. 2021.06.11 13:15:14 - OpenVPN > Validating certificate extended key usage
. 2021.06.11 13:15:14 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.06.11 13:15:14 - OpenVPN > VERIFY EKU OK
. 2021.06.11 13:15:14 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hercules, emailAddress=info@airvpn.org
. 2021.06.11 13:15:14 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.06.11 13:15:14 - OpenVPN > [Hercules] Peer Connection Initiated with [AF_INET]64.42.179.61:443
. 2021.06.11 13:15:15 - OpenVPN > SENT CONTROL [Hercules]: 'PUSH_REQUEST' (status=1)
. 2021.06.11 13:15:15 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.22.246.1,dhcp-option DNS6 fde6:7a:7d20:12f6::1,tun-ipv6,route-gateway 10.22.246.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:12f6::1053/64 fde6:7a:7d20:12f6::1,ifconfig 10.22.246.85 255.255.255.0,peer-id 7,cipher AES-256-GCM'
. 2021.06.11 13:15:15 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.06.11 13:15:15 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.06.11 13:15:15 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.06.11 13:15:15 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.06.11 13:15:15 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.06.11 13:15:15 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.06.11 13:15:15 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.06.11 13:15:15 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.06.11 13:15:15 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.06.11 13:15:15 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.06.11 13:15:15 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.06.11 13:15:15 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.06.11 13:15:15 - OpenVPN > interactive service msg_channel=0
. 2021.06.11 13:15:15 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 I=9 HWADDR=44:af:28:37:39:85
. 2021.06.11 13:15:15 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.06.11 13:15:15 - OpenVPN > GetBestInterfaceEx() returned if=9
. 2021.06.11 13:15:15 - OpenVPN > GDG6: II=9 DP=::/0 NH=fe80::feae:34ff:fe37:f8c0
. 2021.06.11 13:15:15 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2021.06.11 13:15:15 - OpenVPN > ROUTE6_GATEWAY fe80::feae:34ff:fe37:f8c0 I=9
. 2021.06.11 13:15:15 - OpenVPN > open_tun
. 2021.06.11 13:15:15 - OpenVPN > tap-windows6 device [Local Area Connection] opened
. 2021.06.11 13:15:15 - OpenVPN > TAP-Windows Driver Version 9.24
. 2021.06.11 13:15:15 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.22.246.0/10.22.246.85/255.255.255.0 [SUCCEEDED]
. 2021.06.11 13:15:15 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.22.246.85/255.255.255.0 on interface {AA3FBE9B-E983-4E45-9A9D-9D372FDF5737} [DHCP-serv: 10.22.246.254, lease-time: 31536000]
. 2021.06.11 13:15:15 - OpenVPN > Successful ARP Flush on interface [3] {AA3FBE9B-E983-4E45-9A9D-9D372FDF5737}
. 2021.06.11 13:15:15 - OpenVPN > IPv4 MTU set to 1500 on interface 3 using SetIpInterfaceEntry()
. 2021.06.11 13:15:15 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address 3 fde6:7a:7d20:12f6::1053/128 store=active
. 2021.06.11 13:15:15 - OpenVPN > add_route_ipv6(fde6:7a:7d20:12f6::/64 -> fde6:7a:7d20:12f6::1053 metric 0) dev Local Area Connection
. 2021.06.11 13:15:15 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:12f6::/64 3 fe80::8 store=active
. 2021.06.11 13:15:15 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2021.06.11 13:15:15 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 3 all
. 2021.06.11 13:15:15 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns 3 static fde6:7a:7d20:12f6::1 validate=no
. 2021.06.11 13:15:16 - OpenVPN > IPv6 MTU set to 1500 on interface 3 using SetIpInterfaceEntry()
. 2021.06.11 13:15:20 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.06.11 13:15:20 - OpenVPN > C:\Windows\system32\route.exe ADD 64.42.179.61 MASK 255.255.255.255 192.168.1.254
. 2021.06.11 13:15:20 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2021.06.11 13:15:20 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.06.11 13:15:20 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.22.246.1
. 2021.06.11 13:15:20 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2021.06.11 13:15:20 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.22.246.1
. 2021.06.11 13:15:20 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:12f6::1 metric -1) dev Local Area Connection
. 2021.06.11 13:15:20 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 3 fe80::8 store=active
. 2021.06.11 13:15:20 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2021.06.11 13:15:20 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:12f6::1 metric -1) dev Local Area Connection
. 2021.06.11 13:15:20 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 3 fe80::8 store=active
. 2021.06.11 13:15:20 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:12f6::1 metric -1) dev Local Area Connection
. 2021.06.11 13:15:20 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 3 fe80::8 store=active
. 2021.06.11 13:15:20 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:12f6::1 metric -1) dev Local Area Connection
. 2021.06.11 13:15:20 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 3 fe80::8 store=active
. 2021.06.11 13:15:20 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4
. 2021.06.11 13:15:20 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6
. 2021.06.11 13:15:20 - DNS leak protection with packet filtering enabled.
. 2021.06.11 13:15:21 - DNS IPv4 of a network adapter forced (Local Area Connection, from automatic to 10.4.0.1, 10.5.0.1)
. 2021.06.11 13:15:21 - Routes, added a new route, 64.42.179.59 for gateway 10.22.246.1
. 2021.06.11 13:15:21 - Routes, added a new route, 2605:9f80:6000:80:fc8c:43ee:267e:97ab for gateway fde6:7a:7d20:12f6::1
. 2021.06.11 13:15:21 - Flushing DNS
I 2021.06.11 13:15:21 - Checking route IPv4
I 2021.06.11 13:15:22 - Checking route IPv6
! 2021.06.11 13:15:26 - Connected.
. 2021.06.11 13:15:26 - OpenVPN > Initialization Sequence Completed
! 2021.06.11 13:24:15 - Disconnecting
. 2021.06.11 13:24:15 - Routes, removed a route previously added, 64.42.179.59 for gateway 10.22.246.1
. 2021.06.11 13:24:15 - Routes, removed a route previously added, 2605:9f80:6000:80:fc8c:43ee:267e:97ab for gateway fde6:7a:7d20:12f6::1
. 2021.06.11 13:24:15 - Sending soft termination signal
. 2021.06.11 13:24:18 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2021.06.11 13:24:20 - OpenVPN > C:\Windows\system32\route.exe DELETE 64.42.179.61 MASK 255.255.255.255 192.168.1.254
. 2021.06.11 13:24:20 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.06.11 13:24:20 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.22.246.1
. 2021.06.11 13:24:20 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.22.246.1
. 2021.06.11 13:24:20 - OpenVPN > delete_route_ipv6(::/3)
. 2021.06.11 13:24:20 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 3 fe80::8 store=active
. 2021.06.11 13:24:20 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2021.06.11 13:24:20 - OpenVPN > delete_route_ipv6(2000::/4)
. 2021.06.11 13:24:20 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 3 fe80::8 store=active
. 2021.06.11 13:24:20 - OpenVPN > delete_route_ipv6(3000::/4)
. 2021.06.11 13:24:20 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 3 fe80::8 store=active
. 2021.06.11 13:24:20 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2021.06.11 13:24:20 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 3 fe80::8 store=active
. 2021.06.11 13:24:20 - OpenVPN > Closing TUN/TAP interface
. 2021.06.11 13:24:20 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 3 all
. 2021.06.11 13:24:21 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:12f6::/64)
. 2021.06.11 13:24:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:12f6::/64 3 fe80::8 store=active
. 2021.06.11 13:24:21 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address 3 fde6:7a:7d20:12f6::1053 store=active
. 2021.06.11 13:24:21 - OpenVPN > TAP: DHCP address released
. 2021.06.11 13:24:21 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2021.06.11 13:24:21 - Connection terminated.
. 2021.06.11 13:24:21 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection, to automatic)
. 2021.06.11 13:24:21 - DNS leak protection with packet filtering disabled.
. 2021.06.11 13:24:21 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4
. 2021.06.11 13:24:21 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6
. 2021.06.11 13:24:21 - Flushing DNS
! 2021.06.11 13:24:21 - Session terminated.
! 2021.06.11 13:24:27 - Deactivation of Network Lock
. 2021.06.11 13:24:33 - ping 1
. 2021.06.11 13:24:34 - ping 2 W
. 2021.06.11 13:24:34 - ping 2 WE
. 2021.06.11 13:28:15 - ping 1
. 2021.06.11 13:28:15 - ping 2 W
. 2021.06.11 13:28:15 - ping 2 WE
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": true,
    "routes": [
            "address": "0.0.0.0\/0",
            "interface": "{3D4C6E24-D5BE-4F0B-A383-7818664162A2}",
            "gateway": "192.168.1.254",
            "metric": "30"
            "address": "127.0.0.0\/8",
            "interface": "{A7A9DAF8-7AC9-11EB-824E-806E6F6E6963}",
            "gateway": "link",
            "metric": "306"
            "address": "127.0.0.1",
            "gateway": "link",
            "metric": "306"
            "address": "127.255.255.255",
            "gateway": "link",
            "metric": "306"
            "address": "169.254.0.0\/16",
            "gateway": "link",
            "metric": "311"
            "address": "169.254.255.255",
            "gateway": "link",
            "metric": "286"
            "address": "192.168.1.0\/24",
            "gateway": "link",
            "metric": "286"
            "address": "192.168.1.93",
            "gateway": "link",
            "metric": "286"
            "address": "192.168.1.255",
            "gateway": "link",
            "metric": "286"
            "address": "224.0.0.0\/4",
            "gateway": "link",
            "metric": "306"
            "gateway": "link",
            "metric": "286"
            "address": "255.255.255.255",
            "gateway": "link",
            "metric": "306"
            "gateway": "link",
            "metric": "286"
            "address": "::\/0",
            "gateway": "fe80::feae:34ff:fe37:f8c0",
            "metric": "286"
            "address": "::1",
            "gateway": "link",
            "metric": "306"
            "address": "2001::\/32",
            "interface": "{E776AEB5-9061-4800-B5F4-7B7BCE90BF12}",
            "gateway": "link",
            "metric": "306"
            "address": "2001:0:17dd:defa:c3c:d10:3f57:fea2",
            "gateway": "link",
            "metric": "306"
            "address": "2600:1700:1f10:5510::\/60",
            "metric": "46"
            "address": "2600:1700:1f10:5510::\/64",
            "gateway": "link",
            "metric": "286"
            "address": "2600:1700:1f10:5510::49",
            "gateway": "link",
            "metric": "286"
            "address": "2600:1700:1f10:5510:846:c021:bae4:df89",
            "gateway": "link",
            "metric": "286"
            "address": "2600:1700:1f10:5510:3419:c7a8:7499:f383",
            "gateway": "link",
            "metric": "286"
            "address": "fe80::\/64",
            "gateway": "link",
            "metric": "286"
            "gateway": "link",
            "metric": "306"
            "address": "fe80::c3c:d10:3f57:fea2",
            "gateway": "link",
            "metric": "306"
            "address": "fe80::3419:c7a8:7499:f383",
            "gateway": "link",
            "metric": "286"
            "address": "ff00::\/8",
            "gateway": "link",
            "metric": "306"
            "gateway": "link",
            "metric": "286"
            "gateway": "link",
            "metric": "306"
    "interfaces": [
            "friendly": "Ethernet 2",
            "id": "{F7620C16-B99A-458E-936C-C4DC764F1D9A}",
            "name": "Ethernet 2",
            "description": "Realtek PCIe GBE Family Controller",
            "type": "Ethernet",
            "status": "Down",
            "bytes_received": "0",
            "bytes_sent": "0",
            "ips": [
                "fe80::7530:79a1:db2:3730",
                "169.254.55.48"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Ethernet",
            "id": "{DBE78E3B-93FB-417C-BAF7-28E80020F075}",
            "name": "Ethernet",
            "description": "Kaspersky Security Data Escort Adapter",
            "type": "Ethernet",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::407f:890d:2d10:c072",
                "169.254.192.114"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Local Area Connection* 4",
            "id": "{DF96D348-2BB4-46A5-AABC-34738949EF97}",
            "name": "Local Area Connection* 4",
            "description": "Microsoft Wi-Fi Direct Virtual Adapter",
            "type": "Wireless80211",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::8c48:4ebb:b095:e6e9",
                "169.254.230.233"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Wi-Fi 2",
            "id": "{3D4C6E24-D5BE-4F0B-A383-7818664162A2}",
            "name": "Wi-Fi 2",
            "description": "Intel(R) Dual Band Wireless-AC 7265",
            "status": "Up",
            "bytes_received": "2110980697",
            "bytes_sent": "91458904",
            "ips": [
                "192.168.1.93"
            "gateways": [
                "192.168.1.254",
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Bluetooth Network Connection 2",
            "id": "{5B008366-39BC-489D-AED8-98D516CCF0E9}",
            "name": "Bluetooth Network Connection 2",
            "description": "Bluetooth Device (Personal Area Network) #2",
            "type": "Ethernet",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::80ef:b6b4:9e28:b903",
                "169.254.185.3"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Local Area Connection",
            "id": "{AA3FBE9B-E983-4E45-9A9D-9D372FDF5737}",
            "name": "Local Area Connection",
            "description": "TAP-Windows Adapter V9",
            "type": "Virtual",
            "status": "Down",
            "bytes_received": "262917185",
            "bytes_sent": "16065652",
            "ips": [
                "fe80::99fe:165a:c132:687",
                "169.254.6.135"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Loopback Pseudo-Interface 1",
            "id": "{A7A9DAF8-7AC9-11EB-824E-806E6F6E6963}",
            "name": "Loopback Pseudo-Interface 1",
            "description": "Software Loopback Interface 1",
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Teredo Tunneling Pseudo-Interface",
            "id": "{E776AEB5-9061-4800-B5F4-7B7BCE90BF12}",
            "name": "Teredo Tunneling Pseudo-Interface",
            "description": "Teredo Tunneling Pseudo-Interface",
            "type": "Tunnel",
            "status": "Up",
            "bytes_received": "2128",
            "bytes_sent": "125720",
            "support_ipv4": false,
            "ips": [
            "gateways": [],
            "bind": true,
            "dns4": null,
            "dns6": null
            "friendly": "isatap.attlocal.net",
            "id": "{65FB8B66-0F39-4FDF-8A5A-6A4374BECABA}",
            "name": "isatap.attlocal.net",
            "description": "Microsoft ISATAP Adapter #2",
            "type": "Tunnel",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::5efe:192.168.1.93"
            "gateways": [],
            "bind": true,
            "dns4": null,
            "dns6": null
    "ipv4-default-gateway": "192.168.1.254",
    "ipv4-default-interface": "{3D4C6E24-D5BE-4F0B-A383-7818664162A2}",
    "ipv6-default-gateway": "fe80::feae:34ff:fe37:f8c0",
    "ipv6-default-interface": "{3D4C6E24-D5BE-4F0B-A383-7818664162A2}"
ipconfig /all:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : CRISPR
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : attlocal.net
Ethernet adapter Ethernet 2:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 70-85-C2-06-0A-16
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet:
   Description . . . . . . . . . . . : Kaspersky Security Data Escort Adapter
   Physical Address. . . . . . . . . : 00-FF-DB-E7-8E-3B
Wireless LAN adapter Local Area Connection* 4:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physical Address. . . . . . . . . : 44-AF-28-37-39-86
Wireless LAN adapter Wi-Fi 2:
   Connection-specific DNS Suffix  . : attlocal.net
   Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 7265
   Physical Address. . . . . . . . . : 44-AF-28-37-39-85
   IPv6 Address. . . . . . . . . . . : 2600:1700:1f10:5510::49(Preferred)
   Lease Obtained. . . . . . . . . . : Friday, June 11, 2021 1:01:51 PM
   Lease Expires . . . . . . . . . . : Friday, June 11, 2021 2:01:55 PM
   IPv6 Address. . . . . . . . . . . : 2600:1700:1f10:5510:3419:c7a8:7499:f383(Preferred)
   Temporary IPv6 Address. . . . . . : 2600:1700:1f10:5510:846:c021:bae4:df89(Preferred)
   Link-local IPv6 Address . . . . . : fe80::3419:c7a8:7499:f383%9(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.93(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Thursday, June 10, 2021 11:27:17 AM
   Lease Expires . . . . . . . . . . : Saturday, June 12, 2021 1:10:20 PM
   Default Gateway . . . . . . . . . : fe80::feae:34ff:fe37:f8c0%9
                                       192.168.1.254
   DHCP Server . . . . . . . . . . . : 192.168.1.254
   DHCPv6 IAID . . . . . . . . . . . : 306491176
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-28-0A-B9-3D-44-AF-28-37-39-85
   DNS Servers . . . . . . . . . . . : 2600:1700:1f10:5510::1
                                       192.168.1.254
   NetBIOS over Tcpip. . . . . . . . : Enabled
   Connection-specific DNS Suffix Search List :
                                       attlocal.net
Ethernet adapter Bluetooth Network Connection 2:
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) #2
   Physical Address. . . . . . . . . : 44-AF-28-37-39-89
Unknown adapter Local Area Connection:
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-AA-3F-BE-9B
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
   IPv6 Address. . . . . . . . . . . : 2001:0:17dd:defa:c3c:d10:3f57:fea2(Preferred)
   Link-local IPv6 Address . . . . . : fe80::c3c:d10:3f57:fea2%13(Preferred)
   DHCPv6 IAID . . . . . . . . . . . : 520093696
   NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.attlocal.net:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
I have tried updating Eddie and changing the Network Lock to Windows only but it did not solve the problem.  Any help is appreciated!
Edited ... by OpenSourcerer
Apply LOG format to system report, delete duplicate log posting
These are totally unnecessary with Eddie. Reset this setting and try again.
