KovaKovi 4 Posted ... Hello! I'm following this description (link) to make a VPN Proxy VM in Qubes OS. Unfortunately when it says to check the connection, i can't figure out how to do it. This is what i did and got an error: 1. In the VPN Proxy VM opened a terminal 2. The .ovpn file is here /rw/config/vpn/Airvpn_Europe_TCP-443-Entry3.ovpn 3. In the terminal from /home/user i use the command: openvpn --cd /rw/config/vpn --config Airvpn_Europe_TCP-443-Entry3.ovpn Unfortunately i get an error: Option error: Unrecognized or missing or extra parameter(s) in Airvpn_Europe_TCP-443-Entry3.ovpn:19: data-ciphers (2.4.7) Use --help for more information. openvpn version (debian-10): 2.4.7-1 I downloaded the .ovpn file like this: Config Generator > choosing Linux as my OS, IPv4 only for IP layer exit and IPv4 as Connect with IP layer, tick the Advenced Mode, selecting OpenVPN version >=2.5, choosing OpenVPN TCP 443 tls-crypt, tls1.2 as the protocol and tick By Continents > Europe and finally generating and downloading the .ovpn config file, where i changed eurpe3.vpn... to europe3.all.vpn.... Could someone help me out how can i check the connection with openvpn CLI? Thanks any help you can provide! Share this post Link to post
Tech Jedi Alex 1535 Posted ... The error should be apparent to you, no knowledge required. You select OpenVPN version >= 2.5, yet your OpenVPN version is 2.4.7. The latter doesn't know the data-ciphers directive as it's new in 2.5. 1 KovaKovi reacted to this Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
KovaKovi 4 Posted ... Thanks @OpenSourcerer! I just wanted to write that I realized my mistake... 1 Tech Jedi Alex reacted to this Share this post Link to post
