andeby 7 Posted ... So the combination of WinTun and network lock seems to just not work. Is this a known problem? Is there a workaround, or a planned fix for this? If I use WinTun and try to enable network lock, I am unable to access any websites at all. Quote Share this post Link to post
Tech Jedi Alex 1531 Posted ... Connect and engage Network Lock with wintun, then in Logs tab click the lifebelt icon and paste/upload the output here. Thank you. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
andeby 7 Posted ... Eddie System/Environment Report - 28/05/21 - 16:54 UTC Eddie version: 2.20.0 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Pro OS version: Microsoft Windows NT 10.0.19042.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 TUN driver: 0901: 9.24.2; wintun: Not found OpenVPN: 2.5.1 - OpenSSL 1.1.1j 16 Feb 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) Hummingbird: () ---------------------------- SSH: plink 0.73 Build platform: 64-bit x86 Windows Compiler: clang 7.0.0 (tags/RELEASE_700/final), emulating Visual Studio 2013 (12.0), _MSC_VER=1800 Source commit: 745ed3ad3beaf52fc623827e770b3a068b238dd5 (C:\Program Files\AirVPN\plink.exe) ---------------------------- SSL: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe) Profile path: C:\Users\User\AppData\Local\Eddie\default.profile Data path: C:\Users\User\AppData\Local\Eddie Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (1 args) path="home" Network Lock Active: Yes, Windows Filtering Platform Connected to VPN: Yes, Ophiuchus Detected DNS: fde6:7a:7d20:15ce::1, 10.25.206.1, 192.168.0.1 Test DNS IPv4: Ok Test DNS IPv6: Ok Test Ping IPv4: 51 ms Test Ping IPv6: Failed Test HTTP IPv4: Ok Test HTTP IPv6: Ok Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True mode.protocol: UDP mode.alt: 2 dns.check: False advanced.check.route: False windows.wintun: True ---------------------------- Logs: . 2021.05.28 14:11:30 - Eddie version: 2.20.0 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.19042.0, Mono/.Net: v4.0.30319 . 2021.05.28 14:11:30 - Command line arguments (1): path="home" . 2021.05.28 14:11:31 - Profile path: C:\Users\Anders\AppData\Local\Eddie\default.profile . 2021.05.28 14:11:31 - Reading options from C:\Users\Anders\AppData\Local\Eddie\default.profile . 2021.05.28 14:11:34 - Tun Driver - 0901: 9.24.2; wintun: Not found . 2021.05.28 14:11:34 - OpenVPN - Version: 2.5.1 - OpenSSL 1.1.1j 16 Feb 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2021.05.28 14:11:34 - SSH - Version: plink 0.73 . 2021.05.28 14:11:34 - Build platform: 64-bit x86 Windows . 2021.05.28 14:11:34 - Compiler: clang 7.0.0 (tags/RELEASE_700/final), emulating Visual Studio 2013 (12.0), _MSC_VER=1800 . 2021.05.28 14:11:34 - Source commit: 745ed3ad3beaf52fc623827e770b3a068b238dd5 (C:\Program Files\AirVPN\plink.exe) . 2021.05.28 14:11:34 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe) . 2021.05.28 14:11:34 - Recovery. Unexpected crash? . 2021.05.28 14:11:35 - Routes, added a new route, 2001:ac8:38:21:2473:6fcc:942d:eb92 for gateway fde6:7a:7d20:82e::1 I 2021.05.28 14:11:35 - Ready . 2021.05.28 14:11:36 - Collect information about AirVPN completed ! 2021.05.28 14:13:27 - Activation of Network Lock - Windows Filtering Platform I 2021.05.28 14:13:29 - Session starting. I 2021.05.28 14:13:30 - Checking authorization ... ! 2021.05.28 14:13:30 - Installing tunnel driver wintun . 2021.05.28 14:13:50 - Cannot find tunnel adapter of driver wintun, try install. ! 2021.05.28 14:13:54 - Connecting to Ophiuchus (Norway, Oslo) . 2021.05.28 14:13:54 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021 . 2021.05.28 14:13:54 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2021.05.28 14:13:54 - OpenVPN > library versions: OpenSSL 1.1.1j 16 Feb 2021, LZO 2.10 . 2021.05.28 14:13:54 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.28 14:13:54 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.28 14:13:54 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.28 14:13:54 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.28 14:13:54 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.206.225.61:443 . 2021.05.28 14:13:54 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.05.28 14:13:54 - OpenVPN > UDP link local: (not bound) . 2021.05.28 14:13:54 - OpenVPN > UDP link remote: [AF_INET]185.206.225.61:443 . 2021.05.28 14:13:54 - OpenVPN > TLS: Initial packet from [AF_INET]185.206.225.61:443, sid=55677513 8ab27ccb . 2021.05.28 14:13:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.05.28 14:13:54 - OpenVPN > VERIFY KU OK . 2021.05.28 14:13:54 - OpenVPN > Validating certificate extended key usage . 2021.05.28 14:13:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.05.28 14:13:54 - OpenVPN > VERIFY EKU OK . 2021.05.28 14:13:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ophiuchus, emailAddress=info@airvpn.org . 2021.05.28 14:13:54 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.05.28 14:13:54 - OpenVPN > [Ophiuchus] Peer Connection Initiated with [AF_INET]185.206.225.61:443 . 2021.05.28 14:13:54 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.25.206.1,dhcp-option DNS6 fde6:7a:7d20:15ce::1,tun-ipv6,route-gateway 10.25.206.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:15ce::1056/64 fde6:7a:7d20:15ce::1,ifconfig 10.25.206.88 255.255.255.0,peer-id 4,cipher AES-256-GCM' . 2021.05.28 14:13:54 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.05.28 14:13:54 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.05.28 14:13:54 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.05.28 14:13:54 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.05.28 14:13:54 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.05.28 14:13:54 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.05.28 14:13:54 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.05.28 14:13:54 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.05.28 14:13:54 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.05.28 14:13:54 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.05.28 14:13:54 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 14:13:54 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 14:13:54 - OpenVPN > interactive service msg_channel=0 . 2021.05.28 14:13:54 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=46 HWADDR=a4:34:d9:ee:ab:60 . 2021.05.28 14:13:54 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2021.05.28 14:13:54 - OpenVPN > GetBestInterfaceEx() returned if=46 . 2021.05.28 14:13:54 - OpenVPN > GDG6: II=46 DP=::/0 NH=fe80::5aef:68ff:fe0c:facb . 2021.05.28 14:13:54 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0 . 2021.05.28 14:13:54 - OpenVPN > ROUTE6_GATEWAY fe80::5aef:68ff:fe0c:facb I=46 . 2021.05.28 14:13:54 - OpenVPN > open_tun . 2021.05.28 14:13:54 - OpenVPN > wintun device [Local Area Connection 2] opened . 2021.05.28 14:13:54 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 77 static 10.25.206.88 255.255.255.0 . 2021.05.28 14:13:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 77 all . 2021.05.28 14:13:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns 77 static 10.25.206.1 validate=no . 2021.05.28 14:13:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 77 all . 2021.05.28 14:13:55 - OpenVPN > IPv4 MTU set to 1500 on interface 77 using SetIpInterfaceEntry() . 2021.05.28 14:13:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 77 fde6:7a:7d20:15ce::1056/128 store=active . 2021.05.28 14:13:55 - OpenVPN > add_route_ipv6(fde6:7a:7d20:15ce::/64 -> fde6:7a:7d20:15ce::1056 metric 0) dev Local Area Connection 2 . 2021.05.28 14:13:55 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:15ce::/64 77 fe80::8 store=active . 2021.05.28 14:13:55 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:13:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 77 all . 2021.05.28 14:13:55 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 77 static fde6:7a:7d20:15ce::1 validate=no . 2021.05.28 14:13:55 - OpenVPN > IPv6 MTU set to 1500 on interface 77 using SetIpInterfaceEntry() . 2021.05.28 14:13:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 185.206.225.61 MASK 255.255.255.255 192.168.0.1 . 2021.05.28 14:13:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2021.05.28 14:13:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 14:13:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 14:13:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4 . 2021.05.28 14:13:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 14:13:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 14:13:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4 . 2021.05.28 14:13:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 14:13:55 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection 2 . 2021.05.28 14:13:55 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 77 fe80::8 store=active . 2021.05.28 14:13:55 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:13:56 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection 2 . 2021.05.28 14:13:56 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 77 fe80::8 store=active . 2021.05.28 14:13:56 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:13:56 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection 2 . 2021.05.28 14:13:56 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 77 fe80::8 store=active . 2021.05.28 14:13:56 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:13:56 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection 2 . 2021.05.28 14:13:56 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 77 fe80::8 store=active . 2021.05.28 14:13:56 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:13:56 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4 . 2021.05.28 14:13:56 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6 . 2021.05.28 14:13:56 - DNS leak protection with packet filtering enabled. . 2021.05.28 14:13:57 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:15ce::1) . 2021.05.28 14:13:57 - DNS IPv4 of a network adapter forced (vEthernet (Default Switch), from automatic to 10.25.206.1) . 2021.05.28 14:13:57 - DNS IPv6 of a network adapter forced (vEthernet (Default Switch), from automatic to fde6:7a:7d20:15ce::1) . 2021.05.28 14:13:57 - Routes, added a new route, 185.206.225.59 for gateway 10.25.206.1 . 2021.05.28 14:13:58 - Routes, added a new route, 2001:ac8:38:4:7c0c:6c0f:4ea7:49b9 for gateway fde6:7a:7d20:15ce::1 . 2021.05.28 14:13:58 - Flushing DNS ! 2021.05.28 14:13:58 - Connected. . 2021.05.28 14:13:58 - OpenVPN > Initialization Sequence Completed ! 2021.05.28 14:14:23 - Disconnecting . 2021.05.28 14:14:23 - Routes, removed a route previously added, 185.206.225.59 for gateway 10.25.206.1 . 2021.05.28 14:14:23 - Routes, removed a route previously added, 2001:ac8:38:4:7c0c:6c0f:4ea7:49b9 for gateway fde6:7a:7d20:15ce::1 . 2021.05.28 14:14:23 - Sending soft termination signal . 2021.05.28 14:14:26 - OpenVPN > SIGTERM received, sending exit notification to peer . 2021.05.28 14:14:28 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 185.206.225.61 MASK 255.255.255.255 192.168.0.1 . 2021.05.28 14:14:28 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 14:14:28 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 14:14:28 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 14:14:28 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 14:14:28 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 14:14:28 - OpenVPN > delete_route_ipv6(::/3) . 2021.05.28 14:14:28 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 77 fe80::8 store=active . 2021.05.28 14:14:28 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:14:28 - OpenVPN > delete_route_ipv6(2000::/4) . 2021.05.28 14:14:28 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 77 fe80::8 store=active . 2021.05.28 14:14:28 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:14:28 - OpenVPN > delete_route_ipv6(3000::/4) . 2021.05.28 14:14:28 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 77 fe80::8 store=active . 2021.05.28 14:14:28 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:14:28 - OpenVPN > delete_route_ipv6(fc00::/7) . 2021.05.28 14:14:28 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 77 fe80::8 store=active . 2021.05.28 14:14:28 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:14:28 - OpenVPN > Closing TUN/TAP interface . 2021.05.28 14:14:28 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 77 all . 2021.05.28 14:14:28 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:15ce::/64) . 2021.05.28 14:14:28 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:15ce::/64 77 fe80::8 store=active . 2021.05.28 14:14:28 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 77 fde6:7a:7d20:15ce::1056 store=active . 2021.05.28 14:14:28 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete dns 77 all . 2021.05.28 14:14:29 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 77 10.25.206.88 store=active . 2021.05.28 14:14:29 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2021.05.28 14:14:29 - Connection terminated. . 2021.05.28 14:14:29 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 2, to automatic) . 2021.05.28 14:14:29 - DNS IPv4 of a network adapter restored to original settings (vEthernet (Default Switch), to automatic) . 2021.05.28 14:14:30 - DNS IPv6 of a network adapter restored to original settings (vEthernet (Default Switch), to automatic) . 2021.05.28 14:14:30 - DNS leak protection with packet filtering disabled. . 2021.05.28 14:14:30 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4 . 2021.05.28 14:14:30 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6 . 2021.05.28 14:14:30 - Flushing DNS ! 2021.05.28 14:14:30 - Session terminated. ! 2021.05.28 14:14:35 - Deactivation of Network Lock ! 2021.05.28 14:15:00 - Activation of Network Lock - Windows Filtering Platform I 2021.05.28 14:15:00 - Session starting. I 2021.05.28 14:15:01 - Checking authorization ... ! 2021.05.28 14:15:02 - Connecting to Ophiuchus (Norway, Oslo) . 2021.05.28 14:15:02 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021 . 2021.05.28 14:15:02 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2021.05.28 14:15:02 - OpenVPN > library versions: OpenSSL 1.1.1j 16 Feb 2021, LZO 2.10 . 2021.05.28 14:15:02 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.28 14:15:02 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.28 14:15:02 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.28 14:15:02 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.28 14:15:02 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.206.225.61:443 . 2021.05.28 14:15:02 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.05.28 14:15:02 - OpenVPN > UDP link local: (not bound) . 2021.05.28 14:15:02 - OpenVPN > UDP link remote: [AF_INET]185.206.225.61:443 . 2021.05.28 14:15:02 - OpenVPN > TLS: Initial packet from [AF_INET]185.206.225.61:443, sid=aab6b9e8 520bbc02 . 2021.05.28 14:15:02 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.05.28 14:15:02 - OpenVPN > VERIFY KU OK . 2021.05.28 14:15:02 - OpenVPN > Validating certificate extended key usage . 2021.05.28 14:15:02 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.05.28 14:15:02 - OpenVPN > VERIFY EKU OK . 2021.05.28 14:15:02 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ophiuchus, emailAddress=info@airvpn.org . 2021.05.28 14:15:02 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.05.28 14:15:02 - OpenVPN > [Ophiuchus] Peer Connection Initiated with [AF_INET]185.206.225.61:443 . 2021.05.28 14:15:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.25.206.1,dhcp-option DNS6 fde6:7a:7d20:15ce::1,tun-ipv6,route-gateway 10.25.206.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:15ce::1056/64 fde6:7a:7d20:15ce::1,ifconfig 10.25.206.88 255.255.255.0,peer-id 4,cipher AES-256-GCM' . 2021.05.28 14:15:02 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.05.28 14:15:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.05.28 14:15:02 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.05.28 14:15:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.05.28 14:15:03 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.05.28 14:15:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.05.28 14:15:03 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.05.28 14:15:03 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.05.28 14:15:03 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.05.28 14:15:03 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.05.28 14:15:03 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 14:15:03 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 14:15:03 - OpenVPN > interactive service msg_channel=0 . 2021.05.28 14:15:03 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=46 HWADDR=a4:34:d9:ee:ab:60 . 2021.05.28 14:15:03 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2021.05.28 14:15:03 - OpenVPN > GetBestInterfaceEx() returned if=46 . 2021.05.28 14:15:03 - OpenVPN > GDG6: II=46 DP=::/0 NH=fe80::5aef:68ff:fe0c:facb . 2021.05.28 14:15:03 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0 . 2021.05.28 14:15:03 - OpenVPN > ROUTE6_GATEWAY fe80::5aef:68ff:fe0c:facb I=46 . 2021.05.28 14:15:03 - OpenVPN > open_tun . 2021.05.28 14:15:03 - OpenVPN > tap-windows6 device [Local Area Connection] opened . 2021.05.28 14:15:03 - OpenVPN > TAP-Windows Driver Version 9.24 . 2021.05.28 14:15:03 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.25.206.0/10.25.206.88/255.255.255.0 [SUCCEEDED] . 2021.05.28 14:15:03 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.25.206.88/255.255.255.0 on interface {899279BA-5B82-468B-A454-74B2116490FE} [DHCP-serv: 10.25.206.254, lease-time: 31536000] . 2021.05.28 14:15:03 - OpenVPN > Successful ARP Flush on interface [31] {899279BA-5B82-468B-A454-74B2116490FE} . 2021.05.28 14:15:04 - OpenVPN > IPv4 MTU set to 1500 on interface 31 using SetIpInterfaceEntry() . 2021.05.28 14:15:04 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 31 fde6:7a:7d20:15ce::1056/128 store=active . 2021.05.28 14:15:04 - OpenVPN > add_route_ipv6(fde6:7a:7d20:15ce::/64 -> fde6:7a:7d20:15ce::1056 metric 0) dev Local Area Connection . 2021.05.28 14:15:04 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:15ce::/64 31 fe80::8 store=active . 2021.05.28 14:15:04 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:15:04 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 31 all . 2021.05.28 14:15:04 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 31 static fde6:7a:7d20:15ce::1 validate=no . 2021.05.28 14:15:04 - OpenVPN > IPv6 MTU set to 1500 on interface 31 using SetIpInterfaceEntry() . 2021.05.28 14:15:09 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2021.05.28 14:15:09 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 185.206.225.61 MASK 255.255.255.255 192.168.0.1 . 2021.05.28 14:15:09 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2021.05.28 14:15:09 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 14:15:09 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 14:15:09 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.05.28 14:15:09 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 14:15:09 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 14:15:09 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.05.28 14:15:09 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 14:15:09 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection . 2021.05.28 14:15:09 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 31 fe80::8 store=active . 2021.05.28 14:15:09 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:15:09 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection . 2021.05.28 14:15:09 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 31 fe80::8 store=active . 2021.05.28 14:15:09 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:15:09 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection . 2021.05.28 14:15:09 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 31 fe80::8 store=active . 2021.05.28 14:15:09 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:15:09 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection . 2021.05.28 14:15:09 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 31 fe80::8 store=active . 2021.05.28 14:15:09 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 14:15:09 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2021.05.28 14:15:09 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6 . 2021.05.28 14:15:09 - DNS leak protection with packet filtering enabled. . 2021.05.28 14:15:10 - DNS IPv4 of a network adapter forced (Local Area Connection, from automatic to 10.25.206.1) . 2021.05.28 14:15:10 - DNS IPv6 of a network adapter forced (Local Area Connection, from automatic to fde6:7a:7d20:15ce::1) . 2021.05.28 14:15:10 - DNS IPv4 of a network adapter forced (vEthernet (Default Switch), from automatic to 10.25.206.1) . 2021.05.28 14:15:10 - DNS IPv6 of a network adapter forced (vEthernet (Default Switch), from automatic to fde6:7a:7d20:15ce::1) . 2021.05.28 14:15:11 - Routes, added a new route, 185.206.225.59 for gateway 10.25.206.1 . 2021.05.28 14:15:11 - Routes, added a new route, 2001:ac8:38:4:7c0c:6c0f:4ea7:49b9 for gateway fde6:7a:7d20:15ce::1 . 2021.05.28 14:15:11 - Flushing DNS ! 2021.05.28 14:15:11 - Connected. . 2021.05.28 14:15:11 - OpenVPN > Initialization Sequence Completed . 2021.05.28 14:41:37 - Collect information about AirVPN completed . 2021.05.28 15:14:26 - Above log line repeated 1 times more . 2021.05.28 15:14:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.05.28 15:14:26 - OpenVPN > VERIFY KU OK . 2021.05.28 15:14:26 - OpenVPN > Validating certificate extended key usage . 2021.05.28 15:14:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.05.28 15:14:26 - OpenVPN > VERIFY EKU OK . 2021.05.28 15:14:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ophiuchus, emailAddress=info@airvpn.org . 2021.05.28 15:14:26 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 15:14:26 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 15:14:26 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.05.28 18:20:16 - OpenVPN > [Ophiuchus] Inactivity timeout (--ping-restart), restarting . 2021.05.28 18:20:16 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting . 2021.05.28 18:20:16 - OpenVPN > Restart pause, 5 second(s) ! 2021.05.28 18:20:17 - Disconnecting . 2021.05.28 18:20:18 - Routes, removed a route previously added, 185.206.225.59 for gateway 10.25.206.1 . 2021.05.28 18:20:19 - Routes, removed a route previously added, 2001:ac8:38:4:7c0c:6c0f:4ea7:49b9 for gateway fde6:7a:7d20:15ce::1 . 2021.05.28 18:20:19 - Sending soft termination signal . 2021.05.28 18:20:21 - Collect information about AirVPN completed . 2021.05.28 18:20:22 - Connection terminated. . 2021.05.28 18:20:22 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection, to automatic) . 2021.05.28 18:20:22 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection, to automatic) . 2021.05.28 18:20:23 - DNS IPv4 of a network adapter restored to original settings (vEthernet (Default Switch), to automatic) . 2021.05.28 18:20:23 - DNS IPv6 of a network adapter restored to original settings (vEthernet (Default Switch), to automatic) . 2021.05.28 18:20:23 - DNS leak protection with packet filtering disabled. . 2021.05.28 18:20:23 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 . 2021.05.28 18:20:23 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6 . 2021.05.28 18:20:23 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 185.206.225.61 MASK 255.255.255.255 192.168.0.1 . 2021.05.28 18:20:23 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 18:20:23 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 18:20:23 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 18:20:23 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 18:20:23 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 18:20:23 - OpenVPN > delete_route_ipv6(::/3) . 2021.05.28 18:20:23 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 31 fe80::8 store=active . 2021.05.28 18:20:23 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:20:23 - OpenVPN > delete_route_ipv6(2000::/4) . 2021.05.28 18:20:23 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 31 fe80::8 store=active . 2021.05.28 18:20:23 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:20:23 - OpenVPN > delete_route_ipv6(3000::/4) . 2021.05.28 18:20:23 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 31 fe80::8 store=active . 2021.05.28 18:20:23 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:20:23 - OpenVPN > delete_route_ipv6(fc00::/7) . 2021.05.28 18:20:23 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 31 fe80::8 store=active . 2021.05.28 18:20:23 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:20:23 - OpenVPN > Closing TUN/TAP interface . 2021.05.28 18:20:23 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 31 all . 2021.05.28 18:20:23 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:15ce::/64) . 2021.05.28 18:20:23 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:15ce::/64 31 fe80::8 store=active . 2021.05.28 18:20:23 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 31 fde6:7a:7d20:15ce::1056 store=active . 2021.05.28 18:20:23 - OpenVPN > TAP: DHCP address released . 2021.05.28 18:20:23 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting . 2021.05.28 18:20:26 - Waiting for latency tests (241 to go) . 2021.05.28 18:20:27 - Waiting for latency tests (217 to go) . 2021.05.28 18:20:30 - Waiting for latency tests (216 to go) . 2021.05.28 18:46:26 - Waiting for latency tests (235 to go) . 2021.05.28 18:46:28 - Waiting for latency tests (234 to go) . 2021.05.28 18:46:29 - Waiting for latency tests (228 to go) . 2021.05.28 18:46:30 - Waiting for latency tests (224 to go) . 2021.05.28 18:46:32 - Waiting for latency tests (217 to go) . 2021.05.28 18:46:33 - Waiting for latency tests (216 to go) . 2021.05.28 18:46:34 - Waiting for latency tests (194 to go) . 2021.05.28 18:46:35 - Waiting for latency tests (182 to go) . 2021.05.28 18:46:36 - Waiting for latency tests (140 to go) . 2021.05.28 18:46:37 - Waiting for latency tests (117 to go) . 2021.05.28 18:46:41 - Waiting for latency tests (68 to go) . 2021.05.28 18:46:42 - Waiting for latency tests (67 to go) . 2021.05.28 18:46:44 - Waiting for latency tests (41 to go) . 2021.05.28 18:46:45 - Waiting for latency tests (20 to go) I 2021.05.28 18:46:46 - Checking authorization ... W 2021.05.28 18:46:47 - Authorization check failed, continue anyway (Fetch url error:Couldn't connect to server) ! 2021.05.28 18:46:47 - Connecting to Nash (Netherlands, Alblasserdam) . 2021.05.28 18:46:47 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021 . 2021.05.28 18:46:47 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2021.05.28 18:46:47 - OpenVPN > library versions: OpenSSL 1.1.1j 16 Feb 2021, LZO 2.10 . 2021.05.28 18:46:47 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.28 18:46:47 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.28 18:46:47 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.28 18:46:47 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.28 18:46:47 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.27:443 . 2021.05.28 18:46:47 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.05.28 18:46:47 - OpenVPN > UDP link local: (not bound) . 2021.05.28 18:46:47 - OpenVPN > UDP link remote: [AF_INET]213.152.161.27:443 . 2021.05.28 18:46:50 - OpenVPN > write UDP: Unknown error (code=10051) . 2021.05.28 18:46:54 - Above log line repeated 1 times more . 2021.05.28 18:46:54 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.27:443, sid=6e9329f2 a89a8c99 . 2021.05.28 18:46:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.05.28 18:46:54 - OpenVPN > VERIFY KU OK . 2021.05.28 18:46:54 - OpenVPN > Validating certificate extended key usage . 2021.05.28 18:46:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.05.28 18:46:54 - OpenVPN > VERIFY EKU OK . 2021.05.28 18:46:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Nash, emailAddress=info@airvpn.org . 2021.05.28 18:46:55 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.05.28 18:46:55 - OpenVPN > [Nash] Peer Connection Initiated with [AF_INET]213.152.161.27:443 . 2021.05.28 18:46:55 - OpenVPN > SENT CONTROL [Nash]: 'PUSH_REQUEST' (status=1) . 2021.05.28 18:46:55 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.24.238.1,dhcp-option DNS6 fde6:7a:7d20:14ee::1,tun-ipv6,route-gateway 10.24.238.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:14ee::101a/64 fde6:7a:7d20:14ee::1,ifconfig 10.24.238.28 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2021.05.28 18:46:55 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.05.28 18:46:55 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.05.28 18:46:55 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.05.28 18:46:55 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.05.28 18:46:55 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.05.28 18:46:55 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.05.28 18:46:55 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.05.28 18:46:55 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.05.28 18:46:55 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.05.28 18:46:55 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.05.28 18:46:55 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 18:46:55 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 18:46:55 - OpenVPN > interactive service msg_channel=0 . 2021.05.28 18:46:55 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=46 HWADDR=a4:34:d9:ee:ab:60 . 2021.05.28 18:46:55 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2021.05.28 18:46:55 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2021.05.28 18:46:55 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2021.05.28 18:46:55 - OpenVPN > open_tun . 2021.05.28 18:46:56 - OpenVPN > tap-windows6 device [Local Area Connection] opened . 2021.05.28 18:46:56 - OpenVPN > TAP-Windows Driver Version 9.24 . 2021.05.28 18:46:56 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.24.238.0/10.24.238.28/255.255.255.0 [SUCCEEDED] . 2021.05.28 18:46:56 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.24.238.28/255.255.255.0 on interface {899279BA-5B82-468B-A454-74B2116490FE} [DHCP-serv: 10.24.238.254, lease-time: 31536000] . 2021.05.28 18:46:56 - OpenVPN > Successful ARP Flush on interface [31] {899279BA-5B82-468B-A454-74B2116490FE} . 2021.05.28 18:46:56 - OpenVPN > IPv4 MTU set to 1500 on interface 31 using SetIpInterfaceEntry() . 2021.05.28 18:46:56 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 31 fde6:7a:7d20:14ee::101a/128 store=active . 2021.05.28 18:46:56 - OpenVPN > add_route_ipv6(fde6:7a:7d20:14ee::/64 -> fde6:7a:7d20:14ee::101a metric 0) dev Local Area Connection . 2021.05.28 18:46:56 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:14ee::/64 31 fe80::8 store=active . 2021.05.28 18:46:56 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:46:56 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 31 all . 2021.05.28 18:46:56 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 31 static fde6:7a:7d20:14ee::1 validate=no . 2021.05.28 18:46:57 - OpenVPN > IPv6 MTU set to 1500 on interface 31 using SetIpInterfaceEntry() . 2021.05.28 18:47:02 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2021.05.28 18:47:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.27 MASK 255.255.255.255 192.168.0.1 . 2021.05.28 18:47:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4 . 2021.05.28 18:47:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 18:47:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.24.238.1 . 2021.05.28 18:47:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.05.28 18:47:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 18:47:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.24.238.1 . 2021.05.28 18:47:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.05.28 18:47:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 18:47:02 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:14ee::1 metric -1) dev Local Area Connection . 2021.05.28 18:47:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 31 fe80::8 store=active . 2021.05.28 18:47:02 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:47:02 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:14ee::1 metric -1) dev Local Area Connection . 2021.05.28 18:47:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 31 fe80::8 store=active . 2021.05.28 18:47:02 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:47:02 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:14ee::1 metric -1) dev Local Area Connection . 2021.05.28 18:47:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 31 fe80::8 store=active . 2021.05.28 18:47:02 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:47:02 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:14ee::1 metric -1) dev Local Area Connection . 2021.05.28 18:47:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 31 fe80::8 store=active . 2021.05.28 18:47:02 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:47:02 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2021.05.28 18:47:02 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6 . 2021.05.28 18:47:02 - DNS leak protection with packet filtering enabled. . 2021.05.28 18:47:03 - DNS IPv4 of a network adapter forced (Local Area Connection, from automatic to 10.24.238.1) . 2021.05.28 18:47:04 - DNS IPv6 of a network adapter forced (Local Area Connection, from automatic to fde6:7a:7d20:14ee::1) . 2021.05.28 18:47:04 - DNS IPv4 of a network adapter forced (vEthernet (Default Switch), from automatic to 10.24.238.1) . 2021.05.28 18:47:04 - DNS IPv6 of a network adapter forced (vEthernet (Default Switch), from automatic to fde6:7a:7d20:14ee::1) . 2021.05.28 18:47:04 - Routes, added a new route, 213.152.161.25 for gateway 10.24.238.1 . 2021.05.28 18:47:04 - Routes, added a new route, 2a00:1678:2470:41:56ef:1b83:3b7c:e518 for gateway fde6:7a:7d20:14ee::1 . 2021.05.28 18:47:04 - Flushing DNS ! 2021.05.28 18:47:05 - Connected. . 2021.05.28 18:47:05 - OpenVPN > Initialization Sequence Completed ! 2021.05.28 18:47:06 - Disconnecting . 2021.05.28 18:47:06 - Routes, removed a route previously added, 213.152.161.25 for gateway 10.24.238.1 . 2021.05.28 18:47:07 - Routes, removed a route previously added, 2a00:1678:2470:41:56ef:1b83:3b7c:e518 for gateway fde6:7a:7d20:14ee::1 . 2021.05.28 18:47:07 - Sending soft termination signal . 2021.05.28 18:47:10 - OpenVPN > SIGTERM received, sending exit notification to peer . 2021.05.28 18:47:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.27 MASK 255.255.255.255 192.168.0.1 . 2021.05.28 18:47:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 18:47:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.24.238.1 . 2021.05.28 18:47:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 18:47:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.24.238.1 . 2021.05.28 18:47:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 18:47:12 - OpenVPN > delete_route_ipv6(::/3) . 2021.05.28 18:47:12 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 31 fe80::8 store=active . 2021.05.28 18:47:12 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:47:12 - OpenVPN > delete_route_ipv6(2000::/4) . 2021.05.28 18:47:12 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 31 fe80::8 store=active . 2021.05.28 18:47:12 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:47:12 - OpenVPN > delete_route_ipv6(3000::/4) . 2021.05.28 18:47:12 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 31 fe80::8 store=active . 2021.05.28 18:47:12 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:47:12 - OpenVPN > delete_route_ipv6(fc00::/7) . 2021.05.28 18:47:12 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 31 fe80::8 store=active . 2021.05.28 18:47:12 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:47:12 - OpenVPN > Closing TUN/TAP interface . 2021.05.28 18:47:12 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 31 all . 2021.05.28 18:47:12 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:14ee::/64) . 2021.05.28 18:47:12 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:14ee::/64 31 fe80::8 store=active . 2021.05.28 18:47:12 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 31 fde6:7a:7d20:14ee::101a store=active . 2021.05.28 18:47:13 - OpenVPN > TAP: DHCP address released . 2021.05.28 18:47:13 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2021.05.28 18:47:13 - Connection terminated. . 2021.05.28 18:47:13 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection, to automatic) . 2021.05.28 18:47:13 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection, to automatic) . 2021.05.28 18:47:13 - DNS IPv4 of a network adapter restored to original settings (vEthernet (Default Switch), to automatic) . 2021.05.28 18:47:14 - DNS IPv6 of a network adapter restored to original settings (vEthernet (Default Switch), to automatic) . 2021.05.28 18:47:14 - DNS leak protection with packet filtering disabled. . 2021.05.28 18:47:14 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 . 2021.05.28 18:47:14 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6 . 2021.05.28 18:47:14 - Flushing DNS ! 2021.05.28 18:47:14 - Session terminated. ! 2021.05.28 18:47:15 - Deactivation of Network Lock ! 2021.05.28 18:47:29 - Activation of Network Lock - Windows Filtering Platform I 2021.05.28 18:47:30 - Session starting. I 2021.05.28 18:47:31 - Checking authorization ... ! 2021.05.28 18:47:32 - Installing tunnel driver wintun . 2021.05.28 18:47:37 - Cannot find tunnel adapter of driver wintun, try install. ! 2021.05.28 18:47:40 - Connecting to Nash (Netherlands, Alblasserdam) . 2021.05.28 18:47:40 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021 . 2021.05.28 18:47:40 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2021.05.28 18:47:40 - OpenVPN > library versions: OpenSSL 1.1.1j 16 Feb 2021, LZO 2.10 . 2021.05.28 18:47:40 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.28 18:47:40 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.28 18:47:40 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.28 18:47:40 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.28 18:47:40 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.27:443 . 2021.05.28 18:47:40 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.05.28 18:47:40 - OpenVPN > UDP link local: (not bound) . 2021.05.28 18:47:40 - OpenVPN > UDP link remote: [AF_INET]213.152.161.27:443 . 2021.05.28 18:47:40 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.27:443, sid=14c3ab1e b87593aa . 2021.05.28 18:47:40 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.05.28 18:47:40 - OpenVPN > VERIFY KU OK . 2021.05.28 18:47:40 - OpenVPN > Validating certificate extended key usage . 2021.05.28 18:47:40 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.05.28 18:47:40 - OpenVPN > VERIFY EKU OK . 2021.05.28 18:47:40 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Nash, emailAddress=info@airvpn.org . 2021.05.28 18:47:40 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.05.28 18:47:40 - OpenVPN > [Nash] Peer Connection Initiated with [AF_INET]213.152.161.27:443 . 2021.05.28 18:47:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.24.238.1,dhcp-option DNS6 fde6:7a:7d20:14ee::1,tun-ipv6,route-gateway 10.24.238.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:14ee::101a/64 fde6:7a:7d20:14ee::1,ifconfig 10.24.238.28 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2021.05.28 18:47:41 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.05.28 18:47:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.05.28 18:47:41 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.05.28 18:47:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.05.28 18:47:41 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.05.28 18:47:41 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.05.28 18:47:41 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.05.28 18:47:41 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.05.28 18:47:41 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.05.28 18:47:41 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.05.28 18:47:41 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 18:47:41 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 18:47:41 - OpenVPN > interactive service msg_channel=0 . 2021.05.28 18:47:41 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=46 HWADDR=a4:34:d9:ee:ab:60 . 2021.05.28 18:47:41 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2021.05.28 18:47:41 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2021.05.28 18:47:41 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2021.05.28 18:47:41 - OpenVPN > open_tun . 2021.05.28 18:47:41 - OpenVPN > wintun device [Local Area Connection 2] opened . 2021.05.28 18:47:41 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 73 static 10.24.238.28 255.255.255.0 . 2021.05.28 18:47:41 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 73 all . 2021.05.28 18:47:41 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns 73 static 10.24.238.1 validate=no . 2021.05.28 18:47:41 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 73 all . 2021.05.28 18:47:41 - OpenVPN > IPv4 MTU set to 1500 on interface 73 using SetIpInterfaceEntry() . 2021.05.28 18:47:41 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 73 fde6:7a:7d20:14ee::101a/128 store=active . 2021.05.28 18:47:42 - OpenVPN > add_route_ipv6(fde6:7a:7d20:14ee::/64 -> fde6:7a:7d20:14ee::101a metric 0) dev Local Area Connection 2 . 2021.05.28 18:47:42 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:14ee::/64 73 fe80::8 store=active . 2021.05.28 18:47:42 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:47:42 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 73 all . 2021.05.28 18:47:42 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 73 static fde6:7a:7d20:14ee::1 validate=no . 2021.05.28 18:47:42 - OpenVPN > IPv6 MTU set to 1500 on interface 73 using SetIpInterfaceEntry() . 2021.05.28 18:47:42 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.27 MASK 255.255.255.255 192.168.0.1 . 2021.05.28 18:47:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4 . 2021.05.28 18:47:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 18:47:42 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.24.238.1 . 2021.05.28 18:47:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4 . 2021.05.28 18:47:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 18:47:42 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.24.238.1 . 2021.05.28 18:47:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4 . 2021.05.28 18:47:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 18:47:42 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:14ee::1 metric -1) dev Local Area Connection 2 . 2021.05.28 18:47:42 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 73 fe80::8 store=active . 2021.05.28 18:47:42 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:47:42 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:14ee::1 metric -1) dev Local Area Connection 2 . 2021.05.28 18:47:42 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 73 fe80::8 store=active . 2021.05.28 18:47:42 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:47:42 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:14ee::1 metric -1) dev Local Area Connection 2 . 2021.05.28 18:47:42 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 73 fe80::8 store=active . 2021.05.28 18:47:42 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:47:42 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:14ee::1 metric -1) dev Local Area Connection 2 . 2021.05.28 18:47:42 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 73 fe80::8 store=active . 2021.05.28 18:47:42 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:47:43 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4 . 2021.05.28 18:47:43 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6 . 2021.05.28 18:47:43 - DNS leak protection with packet filtering enabled. . 2021.05.28 18:47:43 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:14ee::1) . 2021.05.28 18:47:44 - DNS IPv4 of a network adapter forced (vEthernet (Default Switch), from automatic to 10.24.238.1) . 2021.05.28 18:47:44 - DNS IPv6 of a network adapter forced (vEthernet (Default Switch), from automatic to fde6:7a:7d20:14ee::1) . 2021.05.28 18:47:44 - Routes, added a new route, 213.152.161.25 for gateway 10.24.238.1 . 2021.05.28 18:47:44 - Routes, added a new route, 2a00:1678:2470:41:56ef:1b83:3b7c:e518 for gateway fde6:7a:7d20:14ee::1 . 2021.05.28 18:47:44 - Flushing DNS ! 2021.05.28 18:47:44 - Connected. . 2021.05.28 18:47:44 - OpenVPN > Initialization Sequence Completed . 2021.05.28 18:48:07 - ping 1 . 2021.05.28 18:48:07 - ping 2 W . 2021.05.28 18:48:07 - ping 2 WE ! 2021.05.28 18:48:59 - Disconnecting . 2021.05.28 18:48:59 - Routes, removed a route previously added, 213.152.161.25 for gateway 10.24.238.1 . 2021.05.28 18:49:00 - Routes, removed a route previously added, 2a00:1678:2470:41:56ef:1b83:3b7c:e518 for gateway fde6:7a:7d20:14ee::1 . 2021.05.28 18:49:00 - Sending soft termination signal . 2021.05.28 18:49:03 - OpenVPN > SIGTERM received, sending exit notification to peer . 2021.05.28 18:49:05 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.27 MASK 255.255.255.255 192.168.0.1 . 2021.05.28 18:49:05 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 18:49:05 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.24.238.1 . 2021.05.28 18:49:05 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 18:49:05 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.24.238.1 . 2021.05.28 18:49:05 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 18:49:05 - OpenVPN > delete_route_ipv6(::/3) . 2021.05.28 18:49:05 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 73 fe80::8 store=active . 2021.05.28 18:49:05 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:49:05 - OpenVPN > delete_route_ipv6(2000::/4) . 2021.05.28 18:49:05 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 73 fe80::8 store=active . 2021.05.28 18:49:05 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:49:05 - OpenVPN > delete_route_ipv6(3000::/4) . 2021.05.28 18:49:05 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 73 fe80::8 store=active . 2021.05.28 18:49:05 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:49:06 - OpenVPN > delete_route_ipv6(fc00::/7) . 2021.05.28 18:49:06 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 73 fe80::8 store=active . 2021.05.28 18:49:06 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:49:06 - OpenVPN > Closing TUN/TAP interface . 2021.05.28 18:49:06 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 73 all . 2021.05.28 18:49:06 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:14ee::/64) . 2021.05.28 18:49:06 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:14ee::/64 73 fe80::8 store=active . 2021.05.28 18:49:06 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 73 fde6:7a:7d20:14ee::101a store=active . 2021.05.28 18:49:06 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete dns 73 all . 2021.05.28 18:49:06 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 73 10.24.238.28 store=active . 2021.05.28 18:49:07 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2021.05.28 18:49:07 - Connection terminated. . 2021.05.28 18:49:07 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 2, to automatic) . 2021.05.28 18:49:07 - DNS IPv4 of a network adapter restored to original settings (vEthernet (Default Switch), to automatic) . 2021.05.28 18:49:07 - DNS IPv6 of a network adapter restored to original settings (vEthernet (Default Switch), to automatic) . 2021.05.28 18:49:07 - DNS leak protection with packet filtering disabled. . 2021.05.28 18:49:08 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4 . 2021.05.28 18:49:08 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6 . 2021.05.28 18:49:08 - Flushing DNS ! 2021.05.28 18:49:08 - Session terminated. E 2021.05.28 18:49:27 - The system cannot find the file specified I 2021.05.28 18:49:41 - Session starting. I 2021.05.28 18:49:42 - Checking authorization ... ! 2021.05.28 18:49:42 - Connecting to Ophiuchus (Norway, Oslo) . 2021.05.28 18:49:43 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021 . 2021.05.28 18:49:43 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2021.05.28 18:49:43 - OpenVPN > library versions: OpenSSL 1.1.1j 16 Feb 2021, LZO 2.10 . 2021.05.28 18:49:43 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.28 18:49:43 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.28 18:49:43 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.28 18:49:43 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.28 18:49:43 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.206.225.61:443 . 2021.05.28 18:49:43 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.05.28 18:49:43 - OpenVPN > UDP link local: (not bound) . 2021.05.28 18:49:43 - OpenVPN > UDP link remote: [AF_INET]185.206.225.61:443 . 2021.05.28 18:49:43 - OpenVPN > TLS: Initial packet from [AF_INET]185.206.225.61:443, sid=7cedd277 7d2762c6 . 2021.05.28 18:49:43 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.05.28 18:49:43 - OpenVPN > VERIFY KU OK . 2021.05.28 18:49:43 - OpenVPN > Validating certificate extended key usage . 2021.05.28 18:49:43 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.05.28 18:49:43 - OpenVPN > VERIFY EKU OK . 2021.05.28 18:49:43 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ophiuchus, emailAddress=info@airvpn.org . 2021.05.28 18:49:43 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.05.28 18:49:43 - OpenVPN > [Ophiuchus] Peer Connection Initiated with [AF_INET]185.206.225.61:443 . 2021.05.28 18:49:43 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.25.206.1,dhcp-option DNS6 fde6:7a:7d20:15ce::1,tun-ipv6,route-gateway 10.25.206.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:15ce::1056/64 fde6:7a:7d20:15ce::1,ifconfig 10.25.206.88 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2021.05.28 18:49:43 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.05.28 18:49:43 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.05.28 18:49:43 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.05.28 18:49:43 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.05.28 18:49:43 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.05.28 18:49:43 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.05.28 18:49:43 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.05.28 18:49:43 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.05.28 18:49:43 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.05.28 18:49:43 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.05.28 18:49:43 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 18:49:43 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 18:49:43 - OpenVPN > interactive service msg_channel=0 . 2021.05.28 18:49:43 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=46 HWADDR=a4:34:d9:ee:ab:60 . 2021.05.28 18:49:43 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2021.05.28 18:49:43 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2021.05.28 18:49:43 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2021.05.28 18:49:43 - OpenVPN > open_tun . 2021.05.28 18:49:44 - OpenVPN > tap-windows6 device [Local Area Connection] opened . 2021.05.28 18:49:44 - OpenVPN > TAP-Windows Driver Version 9.24 . 2021.05.28 18:49:44 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.25.206.0/10.25.206.88/255.255.255.0 [SUCCEEDED] . 2021.05.28 18:49:44 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.25.206.88/255.255.255.0 on interface {899279BA-5B82-468B-A454-74B2116490FE} [DHCP-serv: 10.25.206.254, lease-time: 31536000] . 2021.05.28 18:49:44 - OpenVPN > Successful ARP Flush on interface [31] {899279BA-5B82-468B-A454-74B2116490FE} . 2021.05.28 18:49:44 - OpenVPN > IPv4 MTU set to 1500 on interface 31 using SetIpInterfaceEntry() . 2021.05.28 18:49:44 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 31 fde6:7a:7d20:15ce::1056/128 store=active . 2021.05.28 18:49:44 - OpenVPN > add_route_ipv6(fde6:7a:7d20:15ce::/64 -> fde6:7a:7d20:15ce::1056 metric 0) dev Local Area Connection . 2021.05.28 18:49:44 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:15ce::/64 31 fe80::8 store=active . 2021.05.28 18:49:44 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:49:44 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 31 all . 2021.05.28 18:49:44 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 31 static fde6:7a:7d20:15ce::1 validate=no . 2021.05.28 18:49:44 - OpenVPN > IPv6 MTU set to 1500 on interface 31 using SetIpInterfaceEntry() . 2021.05.28 18:49:49 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2021.05.28 18:49:49 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 185.206.225.61 MASK 255.255.255.255 192.168.0.1 . 2021.05.28 18:49:49 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4 . 2021.05.28 18:49:49 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 18:49:49 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 18:49:49 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.05.28 18:49:49 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 18:49:49 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 18:49:49 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.05.28 18:49:49 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 18:49:49 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection . 2021.05.28 18:49:49 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 31 fe80::8 store=active . 2021.05.28 18:49:49 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:49:49 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection . 2021.05.28 18:49:49 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 31 fe80::8 store=active . 2021.05.28 18:49:49 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:49:49 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection . 2021.05.28 18:49:49 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 31 fe80::8 store=active . 2021.05.28 18:49:49 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:49:49 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection . 2021.05.28 18:49:49 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 31 fe80::8 store=active . 2021.05.28 18:49:49 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:49:49 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2021.05.28 18:49:49 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6 . 2021.05.28 18:49:49 - DNS leak protection with packet filtering enabled. . 2021.05.28 18:49:50 - DNS IPv4 of a network adapter forced (Local Area Connection, from automatic to 10.25.206.1) . 2021.05.28 18:49:50 - DNS IPv6 of a network adapter forced (Local Area Connection, from automatic to fde6:7a:7d20:15ce::1) . 2021.05.28 18:49:50 - DNS IPv4 of a network adapter forced (vEthernet (Default Switch), from automatic to 10.25.206.1) . 2021.05.28 18:49:50 - DNS IPv6 of a network adapter forced (vEthernet (Default Switch), from automatic to fde6:7a:7d20:15ce::1) . 2021.05.28 18:49:51 - Routes, added a new route, 185.206.225.59 for gateway 10.25.206.1 . 2021.05.28 18:49:51 - Routes, added a new route, 2001:ac8:38:4:7c0c:6c0f:4ea7:49b9 for gateway fde6:7a:7d20:15ce::1 . 2021.05.28 18:49:51 - Flushing DNS ! 2021.05.28 18:49:51 - Connected. . 2021.05.28 18:49:51 - OpenVPN > Initialization Sequence Completed . 2021.05.28 18:50:19 - Collect information about AirVPN completed ! 2021.05.28 18:52:45 - Disconnecting . 2021.05.28 18:52:45 - Routes, removed a route previously added, 185.206.225.59 for gateway 10.25.206.1 . 2021.05.28 18:52:46 - Routes, removed a route previously added, 2001:ac8:38:4:7c0c:6c0f:4ea7:49b9 for gateway fde6:7a:7d20:15ce::1 . 2021.05.28 18:52:46 - Sending soft termination signal . 2021.05.28 18:52:49 - OpenVPN > SIGTERM received, sending exit notification to peer . 2021.05.28 18:52:51 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 185.206.225.61 MASK 255.255.255.255 192.168.0.1 . 2021.05.28 18:52:51 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 18:52:51 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 18:52:51 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 18:52:51 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 18:52:51 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.28 18:52:51 - OpenVPN > delete_route_ipv6(::/3) . 2021.05.28 18:52:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 31 fe80::8 store=active . 2021.05.28 18:52:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:52:51 - OpenVPN > delete_route_ipv6(2000::/4) . 2021.05.28 18:52:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 31 fe80::8 store=active . 2021.05.28 18:52:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:52:51 - OpenVPN > delete_route_ipv6(3000::/4) . 2021.05.28 18:52:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 31 fe80::8 store=active . 2021.05.28 18:52:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:52:51 - OpenVPN > delete_route_ipv6(fc00::/7) . 2021.05.28 18:52:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 31 fe80::8 store=active . 2021.05.28 18:52:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:52:51 - OpenVPN > Closing TUN/TAP interface . 2021.05.28 18:52:51 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 31 all . 2021.05.28 18:52:51 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:15ce::/64) . 2021.05.28 18:52:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:15ce::/64 31 fe80::8 store=active . 2021.05.28 18:52:51 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 31 fde6:7a:7d20:15ce::1056 store=active . 2021.05.28 18:52:51 - OpenVPN > TAP: DHCP address released . 2021.05.28 18:52:51 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2021.05.28 18:52:52 - Connection terminated. . 2021.05.28 18:52:52 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection, to automatic) . 2021.05.28 18:52:52 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection, to automatic) . 2021.05.28 18:52:52 - DNS IPv4 of a network adapter restored to original settings (vEthernet (Default Switch), to automatic) . 2021.05.28 18:52:52 - DNS IPv6 of a network adapter restored to original settings (vEthernet (Default Switch), to automatic) . 2021.05.28 18:52:52 - DNS leak protection with packet filtering disabled. . 2021.05.28 18:52:52 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 . 2021.05.28 18:52:52 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6 . 2021.05.28 18:52:52 - Flushing DNS ! 2021.05.28 18:52:53 - Session terminated. I 2021.05.28 18:53:28 - Session starting. I 2021.05.28 18:53:29 - Checking authorization ... ! 2021.05.28 18:53:29 - Installing tunnel driver wintun . 2021.05.28 18:53:34 - Cannot find tunnel adapter of driver wintun, try install. ! 2021.05.28 18:53:37 - Connecting to Ophiuchus (Norway, Oslo) . 2021.05.28 18:53:37 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021 . 2021.05.28 18:53:37 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2021.05.28 18:53:37 - OpenVPN > library versions: OpenSSL 1.1.1j 16 Feb 2021, LZO 2.10 . 2021.05.28 18:53:37 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.28 18:53:37 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.28 18:53:37 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.28 18:53:37 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.28 18:53:37 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.206.225.61:443 . 2021.05.28 18:53:37 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.05.28 18:53:37 - OpenVPN > UDP link local: (not bound) . 2021.05.28 18:53:37 - OpenVPN > UDP link remote: [AF_INET]185.206.225.61:443 . 2021.05.28 18:53:37 - OpenVPN > TLS: Initial packet from [AF_INET]185.206.225.61:443, sid=756e86b7 23921ee2 . 2021.05.28 18:53:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.05.28 18:53:38 - OpenVPN > VERIFY KU OK . 2021.05.28 18:53:38 - OpenVPN > Validating certificate extended key usage . 2021.05.28 18:53:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.05.28 18:53:38 - OpenVPN > VERIFY EKU OK . 2021.05.28 18:53:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ophiuchus, emailAddress=info@airvpn.org . 2021.05.28 18:53:38 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.05.28 18:53:38 - OpenVPN > [Ophiuchus] Peer Connection Initiated with [AF_INET]185.206.225.61:443 . 2021.05.28 18:53:38 - OpenVPN > SENT CONTROL [Ophiuchus]: 'PUSH_REQUEST' (status=1) . 2021.05.28 18:53:38 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.25.206.1,dhcp-option DNS6 fde6:7a:7d20:15ce::1,tun-ipv6,route-gateway 10.25.206.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:15ce::1056/64 fde6:7a:7d20:15ce::1,ifconfig 10.25.206.88 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2021.05.28 18:53:38 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.05.28 18:53:38 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.05.28 18:53:38 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.05.28 18:53:38 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.05.28 18:53:38 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.05.28 18:53:38 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.05.28 18:53:38 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.05.28 18:53:38 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.05.28 18:53:38 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.05.28 18:53:38 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.05.28 18:53:38 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 18:53:38 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.28 18:53:38 - OpenVPN > interactive service msg_channel=0 . 2021.05.28 18:53:38 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=46 HWADDR=a4:34:d9:ee:ab:60 . 2021.05.28 18:53:38 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2021.05.28 18:53:38 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2021.05.28 18:53:38 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2021.05.28 18:53:38 - OpenVPN > open_tun . 2021.05.28 18:53:38 - OpenVPN > wintun device [Local Area Connection] opened . 2021.05.28 18:53:38 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 31 static 10.25.206.88 255.255.255.0 . 2021.05.28 18:53:38 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 31 all . 2021.05.28 18:53:38 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns 31 static 10.25.206.1 validate=no . 2021.05.28 18:53:38 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 31 all . 2021.05.28 18:53:39 - OpenVPN > IPv4 MTU set to 1500 on interface 31 using SetIpInterfaceEntry() . 2021.05.28 18:53:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 31 fde6:7a:7d20:15ce::1056/128 store=active . 2021.05.28 18:53:39 - OpenVPN > add_route_ipv6(fde6:7a:7d20:15ce::/64 -> fde6:7a:7d20:15ce::1056 metric 0) dev Local Area Connection . 2021.05.28 18:53:39 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:15ce::/64 31 fe80::8 store=active . 2021.05.28 18:53:39 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:53:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 31 all . 2021.05.28 18:53:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 31 static fde6:7a:7d20:15ce::1 validate=no . 2021.05.28 18:53:39 - OpenVPN > IPv6 MTU set to 1500 on interface 31 using SetIpInterfaceEntry() . 2021.05.28 18:53:39 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 185.206.225.61 MASK 255.255.255.255 192.168.0.1 . 2021.05.28 18:53:39 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4 . 2021.05.28 18:53:39 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 18:53:39 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 18:53:39 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4 . 2021.05.28 18:53:39 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 18:53:39 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.25.206.1 . 2021.05.28 18:53:39 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4 . 2021.05.28 18:53:39 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.28 18:53:39 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection . 2021.05.28 18:53:39 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 31 fe80::8 store=active . 2021.05.28 18:53:39 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:53:39 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection . 2021.05.28 18:53:39 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 31 fe80::8 store=active . 2021.05.28 18:53:39 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:53:39 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection . 2021.05.28 18:53:39 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 31 fe80::8 store=active . 2021.05.28 18:53:39 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:53:40 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:15ce::1 metric -1) dev Local Area Connection . 2021.05.28 18:53:40 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 31 fe80::8 store=active . 2021.05.28 18:53:40 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.28 18:53:40 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2021.05.28 18:53:40 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6 . 2021.05.28 18:53:40 - DNS leak protection with packet filtering enabled. . 2021.05.28 18:53:41 - DNS IPv6 of a network adapter forced (Local Area Connection, from automatic to fde6:7a:7d20:15ce::1) . 2021.05.28 18:53:41 - DNS IPv4 of a network adapter forced (vEthernet (Default Switch), from automatic to 10.25.206.1) . 2021.05.28 18:53:41 - DNS IPv6 of a network adapter forced (vEthernet (Default Switch), from automatic to fde6:7a:7d20:15ce::1) . 2021.05.28 18:53:41 - Routes, added a new route, 185.206.225.59 for gateway 10.25.206.1 . 2021.05.28 18:53:41 - Routes, added a new route, 2001:ac8:38:4:7c0c:6c0f:4ea7:49b9 for gateway fde6:7a:7d20:15ce::1 . 2021.05.28 18:53:41 - Flushing DNS ! 2021.05.28 18:53:41 - Connected. . 2021.05.28 18:53:42 - OpenVPN > Initialization Sequence Completed . 2021.05.28 18:54:00 - ping 1 . 2021.05.28 18:54:00 - ping 2 W . 2021.05.28 18:54:00 - ping 2 WE ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "interface": "{F61B866A-7695-48E2-B71F-404A6F57974A}", "gateway": "192.168.0.1", "metric": "40" }, { "address": "0.0.0.0\/1", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "10.25.206.1", "metric": "3" }, { "address": "10.25.206.0\/24", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "link", "metric": "259" }, { "address": "10.25.206.88", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "link", "metric": "259" }, { "address": "10.25.206.255", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "link", "metric": "259" }, { "address": "127.0.0.0\/8", "interface": "{AC106931-177A-11E8-9758-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.0.0.1", "interface": "{AC106931-177A-11E8-9758-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.255.255.255", "interface": "{AC106931-177A-11E8-9758-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "128.0.0.0\/1", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "10.25.206.1", "metric": "3" }, { "address": "172.22.16.0\/20", "interface": "{D3726F1C-96D0-4311-B690-D0C7E6F51EC7}", "gateway": "link", "metric": "271" }, { "address": "172.22.16.1", "interface": "{D3726F1C-96D0-4311-B690-D0C7E6F51EC7}", "gateway": "link", "metric": "271" }, { "address": "172.22.31.255", "interface": "{D3726F1C-96D0-4311-B690-D0C7E6F51EC7}", "gateway": "link", "metric": "271" }, { "address": "185.206.225.59", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "10.25.206.1", "metric": "4" }, { "address": "185.206.225.61", "interface": "{F61B866A-7695-48E2-B71F-404A6F57974A}", "gateway": "192.168.0.1", "metric": "40" }, { "address": "192.168.0.0\/24", "interface": "{F61B866A-7695-48E2-B71F-404A6F57974A}", "gateway": "link", "metric": "296" }, { "address": "192.168.0.178", "interface": "{F61B866A-7695-48E2-B71F-404A6F57974A}", "gateway": "link", "metric": "296" }, { "address": "192.168.0.255", "interface": "{F61B866A-7695-48E2-B71F-404A6F57974A}", "gateway": "link", "metric": "296" }, { "address": "224.0.0.0\/4", "interface": "{AC106931-177A-11E8-9758-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "224.0.0.0\/4", "interface": "{F61B866A-7695-48E2-B71F-404A6F57974A}", "gateway": "link", "metric": "296" }, { "address": "224.0.0.0\/4", "interface": "{D3726F1C-96D0-4311-B690-D0C7E6F51EC7}", "gateway": "link", "metric": "271" }, { "address": "224.0.0.0\/4", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "link", "metric": "259" }, { "address": "255.255.255.255", "interface": "{AC106931-177A-11E8-9758-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "255.255.255.255", "interface": "{F61B866A-7695-48E2-B71F-404A6F57974A}", "gateway": "link", "metric": "296" }, { "address": "255.255.255.255", "interface": "{D3726F1C-96D0-4311-B690-D0C7E6F51EC7}", "gateway": "link", "metric": "271" }, { "address": "255.255.255.255", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "link", "metric": "259" }, { "address": "::\/3", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "fe80::8", "metric": "259" }, { "address": "::1", "interface": "{AC106931-177A-11E8-9758-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "2000::\/4", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "fe80::8", "metric": "259" }, { "address": "2001:ac8:38:4:7c0c:6c0f:4ea7:49b9", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "fde6:7a:7d20:15ce::1", "metric": "259" }, { "address": "3000::\/4", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "fe80::8", "metric": "259" }, { "address": "fc00::\/7", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "fe80::8", "metric": "259" }, { "address": "fde6:7a:7d20:15ce::\/64", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "fe80::8", "metric": "259" }, { "address": "fde6:7a:7d20:15ce::1056", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "link", "metric": "259" }, { "address": "fe80::\/64", "interface": "{F61B866A-7695-48E2-B71F-404A6F57974A}", "gateway": "link", "metric": "296" }, { "address": "fe80::\/64", "interface": "{D3726F1C-96D0-4311-B690-D0C7E6F51EC7}", "gateway": "link", "metric": "271" }, { "address": "fe80::\/64", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "link", "metric": "259" }, { "address": "fe80::872:6495:1a7e:17d", "interface": "{D3726F1C-96D0-4311-B690-D0C7E6F51EC7}", "gateway": "link", "metric": "271" }, { "address": "fe80::3c66:f791:243d:be52", "interface": "{F61B866A-7695-48E2-B71F-404A6F57974A}", "gateway": "link", "metric": "296" }, { "address": "fe80::e08a:6d1f:e496:f72a", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "link", "metric": "259" }, { "address": "ff00::\/8", "interface": "{AC106931-177A-11E8-9758-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "ff00::\/8", "interface": "{F61B866A-7695-48E2-B71F-404A6F57974A}", "gateway": "link", "metric": "296" }, { "address": "ff00::\/8", "interface": "{D3726F1C-96D0-4311-B690-D0C7E6F51EC7}", "gateway": "link", "metric": "271" }, { "address": "ff00::\/8", "interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "gateway": "link", "metric": "259" }, { "address": "2001:ac8:38:4:7c0c:6c0f:4ea7:49b9", "gateway": "fde6:7a:7d20:15ce::1", "metric": "4294967295" } ], "interfaces": [ { "friendly": "Local Area Connection", "id": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "name": "Local Area Connection", "description": "Wintun Userspace Tunnel", "type": "Virtual", "status": "Up", "bytes_received": "20124", "bytes_sent": "34969", "support_ipv4": true, "support_ipv6": true, "ips": [ "fde6:7a:7d20:15ce::1056", "fe80::e08a:6d1f:e496:f72a", "10.25.206.88" ], "gateways": [ "10.25.206.1", "fe80::8", "fde6:7a:7d20:15ce::1" ], "bind": true, "dns4": "10.25.206.1", "dns6": null }, { "friendly": "Ethernet", "id": "{C1657F91-894D-4238-8C58-C16FB9657A74}", "name": "Ethernet", "description": "Intel(R) Ethernet Connection I219-V", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::2495:364e:3ef7:3d6d", "169.254.61.109" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "vEthernet (Default Switch)", "id": "{D3726F1C-96D0-4311-B690-D0C7E6F51EC7}", "name": "vEthernet (Default Switch)", "description": "Hyper-V Virtual Ethernet Adapter", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "846336", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::872:6495:1a7e:17d", "172.22.16.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 13", "id": "{753EEEC6-4144-4472-A882-2CE386F4A174}", "name": "Local Area Connection* 13", "description": "Microsoft Wi-Fi Direct Virtual Adapter #3", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::447c:8ba6:841b:b47c", "169.254.180.124" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 14", "id": "{778D1526-1E9C-4495-94C1-65765ABFB0E2}", "name": "Local Area Connection* 14", "description": "Microsoft Wi-Fi Direct Virtual Adapter #4", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::1949:bfc0:a370:520f", "169.254.82.15" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Wi-Fi", "id": "{F61B866A-7695-48E2-B71F-404A6F57974A}", "name": "Wi-Fi", "description": "Intel(R) Dual Band Wireless-AC 8260", "type": "Wireless80211", "status": "Up", "bytes_received": "5056524", "bytes_sent": "1765374", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::3c66:f791:243d:be52", "192.168.0.178" ], "gateways": [ "192.168.0.1" ], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{AC106931-177A-11E8-9758-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Cellular", "id": "{74E23C97-6612-405D-9454-71C443BB7B0E}", "name": "Cellular", "description": "Generic Mobile Broadband Adapter", "type": "Wwanpp", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::bde8:6541:b92f:60ff", "169.254.96.255" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv4-default-gateway": "10.25.206.1", "ipv4-default-interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}", "ipv6-default-gateway": "fe80::8", "ipv6-default-interface": "{9BED2579-6A40-49A1-933C-A86E9179BA39}" } ---------------------------- ipconfig /all: Windows IP Configuration Host Name . . . . . . . . . . . . : DESKTOP-CTBD4MG Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : lyse.net Unknown adapter Local Area Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Wintun Userspace Tunnel Physical Address. . . . . . . . . : DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : fde6:7a:7d20:15ce::1056(Preferred) Link-local IPv6 Address . . . . . : fe80::e08a:6d1f:e496:f72a%31(Preferred) IPv4 Address. . . . . . . . . . . : 10.25.206.88(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . : fde6:7a:7d20:15ce::1 10.25.206.1 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Ethernet: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) Ethernet Connection I219-V Physical Address. . . . . . . . . : <took this out> DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter vEthernet (Default Switch): Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter Physical Address. . . . . . . . . : 00-15-5D-36-AC-E5 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::872:6495:1a7e:17d%69(Preferred) IPv4 Address. . . . . . . . . . . : 172.22.16.1(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.240.0 Default Gateway . . . . . . . . . : DHCPv6 IAID . . . . . . . . . . . : 1157633373 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-E3-DD-88-A4-34-D9-EE-AB-60 DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1 fec0:0:0:ffff::2%1 fec0:0:0:ffff::3%1 NetBIOS over Tcpip. . . . . . . . : Enabled Wireless LAN adapter Local Area Connection* 13: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #3 Physical Address. . . . . . . . . : A4-34-D9-EE-AB-61 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Local Area Connection* 14: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4 Physical Address. . . . . . . . . : A6-34-D9-EE-AB-60 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Wi-Fi: Connection-specific DNS Suffix . : lyse.net Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 8260 Physical Address. . . . . . . . . : <took this out> DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::3c66:f791:243d:be52%46(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.0.178(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Friday, May 28, 2021 18:46:52 Lease Expires . . . . . . . . . . : Saturday, May 29, 2021 18:49:39 Default Gateway . . . . . . . . . : 192.168.0.1 DHCP Server . . . . . . . . . . . : 192.168.0.1 DHCPv6 IAID . . . . . . . . . . . : 77870297 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-20-E3-DD-88-A4-34-D9-EE-AB-60 DNS Servers . . . . . . . . . . . : 192.168.0.1 NetBIOS over Tcpip. . . . . . . . : Enabled Mobile Broadband adapter Cellular: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Generic Mobile Broadband Adapter Physical Address. . . . . . . . . : <took this out> DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Quote Share this post Link to post
Tech Jedi Alex 1531 Posted ... Hmm. It looks normal. Should work. Out of sheer curiosity: Can you try the same with a wired connection? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
andeby 7 Posted ... 9 hours ago, OpenSourcerer said: Hmm. It looks normal. Should work. Out of sheer curiosity: Can you try the same with a wired connection? Yes. Same behavior with a wired connection on a desktop computer. I am also noticing that if I do try to use wintun with network lock, even if I uninstall the wintun driver and go back to the normal tunnel, I will have to restart AirVPN or the problem persists. When I get the problem, websites do not seem to even attempt to load. The "no access" message displays immediately. Quote Share this post Link to post
Tech Jedi Alex 1531 Posted ... Hm. Not sure what to recommend you. Maybe contact professional support via ticket? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
