Quote
system_pause_vpn_when_screen_is_off: true
In Settings > System, disable Pause VPN when screen is off.
The VPN locks up after a keepalive timeout occurs. To make it a little more robust and if you're on Android 8+, consider using Android's Always-On VPN. This feature makes it so that there is no traffic unless specified VPN apps established a VPN tunnel. Then you can disable the VPN Lock setting in Eddie. This enables Eddie to freely reconnect whenever the connection is lost.
Yes, should be in Connections/Wireless/Network > VPN/Advanced Settings > Always-On VPN. Depends heavily on which flavor of Android you're running. It's somewhere else on LineageOS than on Samsung OneUI than on Xiaomi MIUI.
Thank you.
