adfdsfGYYy53
is there an issue with server xuange?
That's too bad. Hope you get it fixed! All the best! ❤️ 🤗
Quote
Certainly not:
Quote
Online: 16408 users - 80520 Mbit/s total BW
Thank you.
I curious as to why I am unable to connect to this one server now. I get a result when the latency tests are run, but cannot connect to that one server.
Would you have any suggestions as to where I should focus my energies to research this? Below are some lines from my log file, in case they may help:
These were generated in an attempt to manually connect to that specific server through the GUI.
I 2021.05.09 07:39:18 - Session starting.
I 2021.05.09 07:39:18 - Checking authorization ...
! 2021.05.09 07:39:19 - Connecting to Xuange (Switzerland, Zurich)
. 2021.05.09 07:39:19 - Elevated: Command:process_openvpn
. 2021.05.09 07:39:19 - OpenVPN > OpenVPN 2.4.7 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Apr 27 2021
. 2021.05.09 07:39:19 - OpenVPN > library versions: OpenSSL 1.1.1f  31 Mar 2020, LZO 2.10
. 2021.05.09 07:39:19 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.09 07:39:19 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.09 07:39:19 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.09 07:39:19 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.09 07:39:19 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]79.142.69.162:443
. 2021.05.09 07:39:19 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2021.05.09 07:39:19 - OpenVPN > UDP link local: (not bound)
. 2021.05.09 07:39:19 - OpenVPN > UDP link remote: [AF_INET]79.142.69.162:443
. 2021.05.09 07:39:51 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2021.05.09 07:39:51 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2021.05.09 07:39:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
I have the same issue with xuange.
I 2021.05.14 20:02:03 - Session starting.
I 2021.05.14 20:02:03 - Checking authorization ...
! 2021.05.14 20:02:03 - Connecting to Xuange (Switzerland, Zurich)
. 2021.05.14 20:02:04 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2021.05.14 20:02:04 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2021.05.14 20:02:04 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2021.05.14 20:02:04 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.14 20:02:04 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.14 20:02:04 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.14 20:02:04 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.14 20:02:04 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]79.142.69.162:443
. 2021.05.14 20:02:04 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2021.05.14 20:02:04 - OpenVPN > UDP link local: (not bound)
. 2021.05.14 20:02:04 - OpenVPN > UDP link remote: [AF_INET]79.142.69.162:443
. 2021.05.14 20:02:36 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2021.05.14 20:02:36 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2021.05.14 20:02:40 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2021.05.14 20:02:40 - Disconnecting
