gamuza
Stuck with "Checking IPv4"
Hi, I just downloaded the program, but when I choose a server it gets stuck in "checking IPv4." These are the logs. Anybody knows how to fix this?
Thanks!
! 2021.04.22 18:59:19 - Connecting to Libra (United States of America, Atlanta, Georgia)
. 2021.04.22 18:59:20 - OpenVPN > OpenVPN 2.5.1 x86_64-apple-darwin19.5.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD] built on Mar  9 2021
. 2021.04.22 18:59:20 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2021.04.22 18:59:20 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.04.22 18:59:20 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.04.22 18:59:20 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.04.22 18:59:20 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.04.22 18:59:20 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.69:443
. 2021.04.22 18:59:20 - OpenVPN > Socket Buffers: R=[786896->262144] S=[9216->262144]
. 2021.04.22 18:59:20 - OpenVPN > UDP link local: (not bound)
. 2021.04.22 18:59:20 - OpenVPN > UDP link remote: [AF_INET]64.42.179.69:443
. 2021.04.22 18:59:20 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.69:443, sid=6acc667d 9ca89c94
. 2021.04.22 18:59:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.04.22 18:59:20 - OpenVPN > VERIFY KU OK
. 2021.04.22 18:59:20 - OpenVPN > Validating certificate extended key usage
. 2021.04.22 18:59:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.04.22 18:59:20 - OpenVPN > VERIFY EKU OK
. 2021.04.22 18:59:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Libra, emailAddress=info@airvpn.org
. 2021.04.22 18:59:20 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.04.22 18:59:20 - OpenVPN > [Libra] Peer Connection Initiated with [AF_INET]64.42.179.69:443
. 2021.04.22 18:59:20 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2021.04.22 18:59:20 - OpenVPN > route: writing to routing socket: File exists
. 2021.04.22 18:59:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.23.14.1,dhcp-option DNS6 fde6:7a:7d20:130e::1,tun-ipv6,route-gateway 10.23.14.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:130e::10d2/64 fde6:7a:7d20:130e::1,ifconfig 10.23.14.212 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2021.04.22 18:59:20 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.04.22 18:59:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.04.22 18:59:20 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.04.22 18:59:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.04.22 18:59:20 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.04.22 18:59:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.04.22 18:59:20 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.04.22 18:59:20 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.04.22 18:59:20 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.04.22 18:59:20 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.04.22 18:59:20 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.04.22 18:59:20 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.04.22 18:59:20 - OpenVPN > ROUTE_GATEWAY 192.168.43.1/255.255.255.0 IFACE=en0 HWADDR=a4:83:e7:1f:e8:90
. 2021.04.22 18:59:20 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.04.22 18:59:20 - OpenVPN > ROUTE6_GATEWAY fe80::5ab1:fff:fe6c:586e IFACE=en0
. 2021.04.22 18:59:20 - OpenVPN > Opened utun device utun4
. 2021.04.22 18:59:20 - OpenVPN > /sbin/ifconfig utun4 delete
. 2021.04.22 18:59:20 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2021.04.22 18:59:20 - OpenVPN > /sbin/ifconfig utun4 10.23.14.212 10.23.14.212 netmask 255.255.255.0 mtu 1500 up
. 2021.04.22 18:59:20 - OpenVPN > /sbin/route add -net 10.23.14.0 10.23.14.212 255.255.255.0
. 2021.04.22 18:59:20 - OpenVPN > add net 10.23.14.0: gateway 10.23.14.212
. 2021.04.22 18:59:20 - OpenVPN > /sbin/ifconfig utun4 inet6 fde6:7a:7d20:130e::10d2/64 mtu 1500 up
. 2021.04.22 18:59:20 - OpenVPN > add_route_ipv6(fde6:7a:7d20:130e::/64 -> fde6:7a:7d20:130e::10d2 metric 0) dev utun4
. 2021.04.22 18:59:20 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:130e:: -prefixlen 64 -iface utun4
. 2021.04.22 18:59:20 - OpenVPN > add net fde6:7a:7d20:130e::: gateway utun4: File exists
. 2021.04.22 18:59:20 - OpenVPN > /sbin/route add -net 64.42.179.69 192.168.43.1 255.255.255.255
. 2021.04.22 18:59:20 - OpenVPN > add net 64.42.179.69: gateway 192.168.43.1
. 2021.04.22 18:59:20 - OpenVPN > /sbin/route add -net 0.0.0.0 10.23.14.1 128.0.0.0
. 2021.04.22 18:59:20 - OpenVPN > add net 0.0.0.0: gateway 10.23.14.1
. 2021.04.22 18:59:20 - OpenVPN > /sbin/route add -net 128.0.0.0 10.23.14.1 128.0.0.0
. 2021.04.22 18:59:20 - OpenVPN > add net 128.0.0.0: gateway 10.23.14.1
. 2021.04.22 18:59:20 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:130e::1 metric -1) dev utun4
. 2021.04.22 18:59:20 - OpenVPN > /sbin/route add -inet6 :: -prefixlen 3 -iface utun4
. 2021.04.22 18:59:20 - OpenVPN > add net ::: gateway utun4
. 2021.04.22 18:59:20 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:130e::1 metric -1) dev utun4
. 2021.04.22 18:59:20 - OpenVPN > /sbin/route add -inet6 2000:: -prefixlen 4 -iface utun4
. 2021.04.22 18:59:20 - OpenVPN > add net 2000::: gateway utun4
. 2021.04.22 18:59:20 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:130e::1 metric -1) dev utun4
. 2021.04.22 18:59:20 - OpenVPN > /sbin/route add -inet6 3000:: -prefixlen 4 -iface utun4
. 2021.04.22 18:59:20 - OpenVPN > add net 3000::: gateway utun4
. 2021.04.22 18:59:20 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:130e::1 metric -1) dev utun4
. 2021.04.22 18:59:20 - OpenVPN > /sbin/route add -inet6 fc00:: -prefixlen 7 -iface utun4
. 2021.04.22 18:59:20 - OpenVPN > add net fc00::: gateway utun4
. 2021.04.22 18:59:20 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.23.14.1, fde6:7a:7d20:130e::1)
. 2021.04.22 18:59:20 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.23.14.1, fde6:7a:7d20:130e::1)
. 2021.04.22 18:59:20 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.23.14.1, fde6:7a:7d20:130e::1)
. 2021.04.22 18:59:20 - Routes, added a new route, 64.42.179.67 for gateway 10.23.14.1
. 2021.04.22 18:59:20 - Routes, added a new route, 2605:9f80:6000:81:290c:19de:1964:88cd for gateway fde6:7a:7d20:130e::1
. 2021.04.22 18:59:20 - Flushing DNS
. 2021.04.22 18:59:20 - Flush DNS via dscacheutil
. 2021.04.22 18:59:20 - Flush DNS via nDNSResponder
I 2021.04.22 18:59:20 - Checking route IPv4
. 2021.04.22 19:04:21 - Fetch url error:Timeout was reached
. 2021.04.22 19:04:21 - OpenVPN > Initialization Sequence Completed
! 2021.04.22 19:04:21 - Disconnecting
. 2021.04.22 19:04:21 - Routes, removed a route previously added, 64.42.179.67 for gateway 10.23.14.1
. 2021.04.22 19:04:21 - Routes, removed a route previously added, 2605:9f80:6000:81:290c:19de:1964:88cd for gateway fde6:7a:7d20:130e::1
. 2021.04.22 19:04:21 - Sending soft termination signal
. 2021.04.22 19:04:21 - OpenVPN > event_wait : Interrupted system call (code=4)
. 2021.04.22 19:04:21 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2021.04.22 19:04:26 - OpenVPN > /sbin/route delete -net 64.42.179.69 192.168.43.1 255.255.255.255
. 2021.04.22 19:04:26 - OpenVPN > delete net 64.42.179.69: gateway 192.168.43.1
. 2021.04.22 19:04:26 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.23.14.1 128.0.0.0
. 2021.04.22 19:04:26 - OpenVPN > delete net 0.0.0.0: gateway 10.23.14.1
. 2021.04.22 19:04:26 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.23.14.1 128.0.0.0
. 2021.04.22 19:04:26 - OpenVPN > delete net 128.0.0.0: gateway 10.23.14.1
. 2021.04.22 19:04:26 - OpenVPN > delete_route_ipv6(::/3)
. 2021.04.22 19:04:26 - OpenVPN > /sbin/route delete -inet6 :: -prefixlen 3 -iface utun4
. 2021.04.22 19:04:26 - OpenVPN > delete net ::: gateway utun4
. 2021.04.22 19:04:26 - OpenVPN > delete_route_ipv6(2000::/4)
. 2021.04.22 19:04:26 - OpenVPN > /sbin/route delete -inet6 2000:: -prefixlen 4 -iface utun4
. 2021.04.22 19:04:26 - OpenVPN > delete net 2000::: gateway utun4
. 2021.04.22 19:04:26 - OpenVPN > delete_route_ipv6(3000::/4)
. 2021.04.22 19:04:26 - OpenVPN > /sbin/route delete -inet6 3000:: -prefixlen 4 -iface utun4
. 2021.04.22 19:04:26 - OpenVPN > delete net 3000::: gateway utun4
. 2021.04.22 19:04:26 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2021.04.22 19:04:26 - OpenVPN > /sbin/route delete -inet6 fc00:: -prefixlen 7 -iface utun4
. 2021.04.22 19:04:26 - OpenVPN > delete net fc00::: gateway utun4
. 2021.04.22 19:04:26 - OpenVPN > Closing TUN/TAP interface
. 2021.04.22 19:04:26 - OpenVPN > /sbin/route delete -inet6 fde6:7a:7d20:130e::10d2
. 2021.04.22 19:04:26 - OpenVPN > delete host fde6:7a:7d20:130e::10d2
. 2021.04.22 19:04:26 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2021.04.22 19:04:26 - Connection terminated.
. 2021.04.22 19:04:26 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2021.04.22 19:04:26 - DNS of a network adapter restored to original settings (Bluetooth PAN, to Automatic)
. 2021.04.22 19:04:26 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
I 2021.04.22 19:04:26 - Cancel requested.
! 2021.04.22 19:04:26 - Session terminated.
