My eddie is updated 2.19.7. My win10 is a updated Win10Pro.
Whenever I'm connected via VPN, I get a ton of request time outs. I'm saying like 20-30% are request time outs. Probably 10%. I don't have a monitoring software to check it. Anyone else ahving this issue?
Can you please try changing the protocol? It's in Eddie Preferences > Protocols. Untick Automatic and select TCP/443 for example.
So I suspect something on your network meters UDP traffic. I'd start with your router, see if there are firewall settings active that limit UDP traffic. Could be something like "UDP flood protection" or "QoS" or something. Basically, anything doing something with UDP should be turned off for testing.
