In a PowerShell:
> Copy-Item "C:\Users\username\AppData\Local\Eddie\default.profile" -Destination \path\to\where\the\portable\version\is\
Or in words, copy the default.profile file from C:\Users\username\AppData\Local\Eddie\default.profile to where the portable version is.
C:\Users\username\AppData\Local\ is not Eddie Directory. I guess its the default.profile inside my old portable Version.
What is about the AirVPN.xml ??
Regards
Firefox
Yes, it's that.
Wait. Where did you find that?
1 hour ago, firefox1970 said:
Inside the old Eddie portable Version
Okay, weird. I haven't seen this XML since at least v2.16.3. In any case, should be automatically converted to the new format.
