Just in the past few days, I have been getting stuck disconnecting.  I can connect to the server fine, then it loses connection.  It then says "disconnecting" but gets stuck.  There's no internet connection while it says disconnecting.  I am unable to force quite.  I have to restart computer to get it working again.  I tried updating eddie to the latest 2.19.7 but it still is happening.  Any help would be appreciated.
Here's a log:
Eddie System/Environment Report - 2/26/2021 - 5:11 AM UTC
Eddie version: 2.19.7
Eddie OS build: windows_x64
Eddie architecture: x64
OS type: Windows
OS name: Windows 7 Home Premium
OS version: Microsoft Windows NT 6.1.7601 Service Pack 1
OS architecture: x64
Mono /.Net Framework: v4.0.30319
TUN driver: 0901: 9.21.2; wintun: Not found
OpenVPN: 2.5.0 - OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
Hummingbird:  ()
SSH:
plink 0.73
Build platform: 64-bit x86 Windows
Compiler: clang 7.0.0 (tags/RELEASE_700/final), emulating Visual Studio 2013 (12.0), _MSC_VER=1800
Source commit: 745ed3ad3beaf52fc623827e770b3a068b238dd5 (C:\Program Files\AirVPN\plink.exe)
SSL: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
Profile path: C:\Users\hen3ry\AppData\Local\Eddie\default.profile
Data path: C:\Users\hen3ry\AppData\Local\Eddie
Application path: C:\Program Files\AirVPN
Executable path: C:\Program Files\AirVPN\Eddie-UI.exe
Command line arguments: (1 args) path="home"
Network Lock Active: No
Connected to VPN: No
Detected DNS: 10.25.47.1, 10.0.0.1
Test DNS IPv4: Failed
Test DNS IPv6: Failed
Test Ping IPv4: 93 ms
Test Ping IPv6: Failed
Test HTTP IPv4: Ok
Test HTTP IPv6: Error: Fetch url error:Couldn't connect to server
Test HTTPS: Error: Fetch url error:Couldn't resolve host name
login: (omissis)
password: (omissis)
remember: True
mode.protocol: TCP
mode.alt: 2
network.entry.iplayer: ipv4-only
openvpn.sndbuf: 262144
openvpn.rcvbuf: 262144
windows.disable_driver_upgrade: True
windows.ipv6.bypass_dns: True
Logs:
. 2021.02.25 23:53:40 - Eddie version: 2.19.7 / windows_x64, System: Windows, Name: Windows 7 Home Premium, Version: Microsoft Windows NT 6.1.7601 Service Pack 1, Mono/.Net: v4.0.30319
. 2021.02.25 23:53:40 - Command line arguments (1): path="home"
. 2021.02.25 23:53:45 - Profile path: C:\Users\hen3ry\AppData\Local\Eddie\default.profile
. 2021.02.25 23:53:45 - Reading options from C:\Users\hen3ry\AppData\Local\Eddie\default.profile
. 2021.02.25 23:53:47 - Tun Driver - 0901: 9.21.2; wintun: Not found
. 2021.02.25 23:53:47 - OpenVPN - Version: 2.5.0 - OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2021.02.25 23:53:47 - SSH - Version: plink 0.73
. 2021.02.25 23:53:47 -     Build platform: 64-bit x86 Windows
. 2021.02.25 23:53:47 -     Compiler: clang 7.0.0 (tags/RELEASE_700/final), emulating Visual Studio 2013 (12.0), _MSC_VER=1800
. 2021.02.25 23:53:47 -     Source commit: 745ed3ad3beaf52fc623827e770b3a068b238dd5 (C:\Program Files\AirVPN\plink.exe)
. 2021.02.25 23:53:47 - SSL - Version: stunnel 5.56 (C:\Program Files\AirVPN\stunnel.exe)
. 2021.02.25 23:53:48 - Recovery. Unexpected crash?
. 2021.02.25 23:53:48 - Routes, removed an existing route, 104.254.90.187 for gateway 10.28.79.1
. 2021.02.25 23:53:48 - Routes, removed an existing route, 2606:6080:2001:5:48ec:2d6:cc35:3864 for gateway fde6:7a:7d20:184f::1
. 2021.02.25 23:53:48 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 3, to automatic)
I 2021.02.25 23:53:49 - Ready
. 2021.02.25 23:53:50 - Collect information about AirVPN completed
I 2021.02.25 23:53:55 - Session starting.
I 2021.02.25 23:53:55 - Checking authorization ...
! 2021.02.25 23:53:56 - Connecting to Dimidium (United States of America, New York City)
. 2021.02.25 23:53:56 - OpenVPN > OpenVPN 2.5.0 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 28 2020
. 2021.02.25 23:53:56 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2021.02.25 23:53:56 - OpenVPN > library versions: OpenSSL 1.1.1h  22 Sep 2020, LZO 2.10
. 2021.02.25 23:53:56 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.25 23:53:56 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.25 23:53:56 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.02.25 23:53:56 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.02.25 23:53:56 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.228.19.149:443
. 2021.02.25 23:53:56 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2021.02.25 23:53:56 - OpenVPN > Attempting to establish TCP connection with [AF_INET]185.228.19.149:443 [nonblock]
. 2021.02.25 23:53:56 - OpenVPN > TCP connection established with [AF_INET]185.228.19.149:443
. 2021.02.25 23:53:56 - OpenVPN > TCP_CLIENT link local: (not bound)
. 2021.02.25 23:53:56 - OpenVPN > TCP_CLIENT link remote: [AF_INET]185.228.19.149:443
. 2021.02.25 23:53:56 - OpenVPN > TLS: Initial packet from [AF_INET]185.228.19.149:443, sid=b8ad410c 0048c225
. 2021.02.25 23:53:56 - OpenVPN > VERIFY KU OK
. 2021.02.25 23:53:56 - OpenVPN > Validating certificate extended key usage
. 2021.02.25 23:53:56 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.02.25 23:53:56 - OpenVPN > VERIFY EKU OK
. 2021.02.25 23:53:56 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Dimidium, emailAddress=info@airvpn.org
. 2021.02.25 23:53:57 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.02.25 23:53:57 - OpenVPN > [Dimidium] Peer Connection Initiated with [AF_INET]185.228.19.149:443
. 2021.02.25 23:53:57 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.25.47.1,dhcp-option DNS6 fde6:7a:7d20:152f::1,tun-ipv6,route-gateway 10.25.47.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:152f::1006/64 fde6:7a:7d20:152f::1,ifconfig 10.25.47.8 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2021.02.25 23:53:57 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.02.25 23:53:57 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:152f::1'
. 2021.02.25 23:53:57 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.02.25 23:53:57 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.02.25 23:53:57 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.02.25 23:53:57 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.02.25 23:53:57 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.02.25 23:53:57 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.02.25 23:53:57 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627
. 2021.02.25 23:53:57 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.02.25 23:53:57 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.02.25 23:53:57 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.25 23:53:57 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.02.25 23:53:57 - OpenVPN > interactive service msg_channel=0
. 2021.02.25 23:53:57 - OpenVPN > ROUTE_GATEWAY 10.0.0.1/255.255.255.0 I=20 HWADDR=4c:ed:fb:b4:46:ec
. 2021.02.25 23:53:57 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.02.25 23:53:57 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found.   (code=1168)
. 2021.02.25 23:53:57 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2021.02.25 23:53:57 - OpenVPN > open_tun
. 2021.02.25 23:53:57 - OpenVPN > CreateFile failed on tap-windows6 device: \\.\Global\{F76A27ED-0717-4962-AE16-81D893C42463}.tap
. 2021.02.25 23:53:58 - OpenVPN > tap-windows6 device [Local Area Connection 3] opened
. 2021.02.25 23:53:58 - OpenVPN > TAP-Windows Driver Version 9.21
. 2021.02.25 23:53:58 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.25.47.0/10.25.47.8/255.255.255.0 [SUCCEEDED]
. 2021.02.25 23:53:58 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.25.47.8/255.255.255.0 on interface {223C300C-03A7-4A3C-8CA6-CF831AC427D8} [DHCP-serv: 10.25.47.254, lease-time: 31536000]
. 2021.02.25 23:53:58 - OpenVPN > Successful ARP Flush on interface [22] {223C300C-03A7-4A3C-8CA6-CF831AC427D8}
. 2021.02.25 23:53:58 - OpenVPN > IPv4 MTU set to 1500 on interface 22 using SetIpInterfaceEntry()
. 2021.02.25 23:53:58 - OpenVPN > NETSH: C:\windows\system32\netsh.exe interface ipv6 set address 22 fde6:7a:7d20:152f::1006/128 store=active
. 2021.02.25 23:53:59 - OpenVPN > add_route_ipv6(fde6:7a:7d20:152f::/64 -> fde6:7a:7d20:152f::1006 metric 0) dev Local Area Connection 3
. 2021.02.25 23:53:59 - OpenVPN > C:\windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:152f::/64 22 fe80::8 store=active
. 2021.02.25 23:53:59 - OpenVPN > env_block: add PATH=C:\windows\System32;C:\windows;C:\windows\System32\Wbem
. 2021.02.25 23:54:00 - OpenVPN > NETSH: C:\windows\system32\netsh.exe interface ipv6 delete dns 22 all
. 2021.02.25 23:54:00 - OpenVPN > IPv6 MTU set to 1500 on interface 22 using SetIpInterfaceEntry()
. 2021.02.25 23:54:05 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.02.25 23:54:05 - OpenVPN > C:\windows\system32\route.exe ADD 185.228.19.149 MASK 255.255.255.255 10.0.0.1
. 2021.02.25 23:54:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2021.02.25 23:54:05 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.02.25 23:54:05 - OpenVPN > C:\windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.25.47.1
. 2021.02.25 23:54:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2021.02.25 23:54:05 - OpenVPN > C:\windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.25.47.1
. 2021.02.25 23:54:05 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:152f::1 metric -1) dev Local Area Connection 3
. 2021.02.25 23:54:05 - OpenVPN > C:\windows\system32\netsh.exe interface ipv6 add route ::/3 22 fe80::8 store=active
. 2021.02.25 23:54:05 - OpenVPN > env_block: add PATH=C:\windows\System32;C:\windows;C:\windows\System32\Wbem
. 2021.02.25 23:54:05 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:152f::1 metric -1) dev Local Area Connection 3
. 2021.02.25 23:54:05 - OpenVPN > C:\windows\system32\netsh.exe interface ipv6 add route 2000::/4 22 fe80::8 store=active
. 2021.02.25 23:54:05 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:152f::1 metric -1) dev Local Area Connection 3
. 2021.02.25 23:54:05 - OpenVPN > C:\windows\system32\netsh.exe interface ipv6 add route 3000::/4 22 fe80::8 store=active
. 2021.02.25 23:54:05 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:152f::1 metric -1) dev Local Area Connection 3
. 2021.02.25 23:54:05 - OpenVPN > C:\windows\system32\netsh.exe interface ipv6 add route fc00::/7 22 fe80::8 store=active
. 2021.02.25 23:54:05 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv4
. 2021.02.25 23:54:06 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv6
. 2021.02.25 23:54:06 - DNS leak protection with packet filtering enabled.
. 2021.02.25 23:54:06 - DNS IPv4 of a network adapter forced (Local Area Connection 3, from automatic to 10.25.47.1)
. 2021.02.25 23:54:06 - Routes, added a new route, 185.228.19.147 for gateway 10.25.47.1
. 2021.02.25 23:54:06 - Routes, added a new route, 2602:fe90:100:1d:3609:9c86:a398:2347 for gateway fde6:7a:7d20:152f::1
. 2021.02.25 23:54:06 - Flushing DNS
I 2021.02.25 23:54:07 - Checking route IPv4
I 2021.02.25 23:54:09 - Checking route IPv6
I 2021.02.25 23:54:14 - Checking DNS
! 2021.02.25 23:54:15 - Connected.
. 2021.02.25 23:54:16 - OpenVPN > Initialization Sequence Completed
. 2021.02.25 23:56:18 - OpenVPN > [Dimidium] Inactivity timeout (--ping-restart), restarting
. 2021.02.25 23:56:18 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2021.02.25 23:56:18 - OpenVPN > Restart pause, 5 second(s)
! 2021.02.25 23:56:18 - Disconnecting
. 2021.02.25 23:56:18 - Routes, removed a route previously added, 185.228.19.147 for gateway 10.25.47.1
. 2021.02.25 23:56:19 - Routes, removed a route previously added, 2602:fe90:100:1d:3609:9c86:a398:2347 for gateway fde6:7a:7d20:152f::1
. 2021.02.25 23:56:19 - Sending soft termination signal
. 2021.02.25 23:56:23 - OpenVPN > C:\windows\system32\route.exe DELETE 185.228.19.149 MASK 255.255.255.255 10.0.0.1
. 2021.02.25 23:56:23 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2021.02.25 23:56:23 - OpenVPN > C:\windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.25.47.1
. 2021.02.25 23:56:23 - OpenVPN > C:\windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.25.47.1
. 2021.02.25 23:56:23 - OpenVPN > delete_route_ipv6(::/3)
. 2021.02.25 23:56:23 - OpenVPN > C:\windows\system32\netsh.exe interface ipv6 delete route ::/3 22 fe80::8 store=active
. 2021.02.25 23:56:23 - OpenVPN > env_block: add PATH=C:\windows\System32;C:\windows;C:\windows\System32\Wbem
. 2021.02.25 23:56:23 - OpenVPN > delete_route_ipv6(2000::/4)
. 2021.02.25 23:56:23 - OpenVPN > C:\windows\system32\netsh.exe interface ipv6 delete route 2000::/4 22 fe80::8 store=active
. 2021.02.25 23:56:23 - OpenVPN > delete_route_ipv6(3000::/4)
. 2021.02.25 23:56:23 - OpenVPN > C:\windows\system32\netsh.exe interface ipv6 delete route 3000::/4 22 fe80::8 store=active
. 2021.02.25 23:56:24 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2021.02.25 23:56:24 - OpenVPN > C:\windows\system32\netsh.exe interface ipv6 delete route fc00::/7 22 fe80::8 store=active
. 2021.02.25 23:56:24 - OpenVPN > env_block: add PATH=C:\windows\System32;C:\windows;C:\windows\System32\Wbem
. 2021.02.25 23:56:24 - OpenVPN > Closing TUN/TAP interface
. 2021.02.25 23:56:24 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:152f::/64)
. 2021.02.25 23:56:24 - OpenVPN > C:\windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:152f::/64 22 fe80::8 store=active
. 2021.02.25 23:56:25 - OpenVPN > NETSH: C:\windows\system32\netsh.exe interface ipv6 delete address 22 fde6:7a:7d20:152f::1006 store=active
. 2021.02.25 23:56:25 - OpenVPN > TAP: DHCP address released
. 2021.02.25 23:56:28 - Sending hard termination signal
. 2021.02.26 00:11:26 - Above log line repeated 89 times more
. 2021.02.26 00:11:26 - ping 1
. 2021.02.26 00:11:26 - ping 2 W
. 2021.02.26 00:11:26 - ping 2 WE
. 2021.02.26 00:11:28 - Sending hard termination signal
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": true,
    "routes": [
            "address": "0.0.0.0\/0",
            "interface": "{3AADB7AD-DBBE-4D00-BF7C-91C992FD7CDC}",
            "gateway": "10.0.0.1",
            "metric": "10"
            "address": "10.0.0.0\/24",
            "gateway": "link",
            "metric": "266"
            "address": "10.0.0.8",
            "gateway": "link",
            "metric": "266"
            "address": "10.0.0.255",
            "gateway": "link",
            "metric": "266"
            "address": "127.0.0.0\/8",
            "interface": "{846EE342-7039-11DE-9D20-806E6F6E6963}",
            "gateway": "link",
            "metric": "306"
            "address": "127.0.0.1",
            "gateway": "link",
            "metric": "306"
            "address": "127.255.255.255",
            "gateway": "link",
            "metric": "306"
            "address": "169.254.0.0\/16",
            "interface": "{223C300C-03A7-4A3C-8CA6-CF831AC427D8}",
            "gateway": "link",
            "metric": "259"
            "address": "169.254.186.221",
            "gateway": "link",
            "metric": "259"
            "address": "169.254.255.255",
            "gateway": "link",
            "metric": "259"
            "address": "224.0.0.0\/4",
            "gateway": "link",
            "metric": "306"
            "gateway": "link",
            "metric": "259"
            "gateway": "link",
            "metric": "266"
            "address": "255.255.255.255",
            "gateway": "link",
            "metric": "306"
            "gateway": "link",
            "metric": "259"
            "gateway": "link",
            "metric": "266"
            "address": "::1",
            "gateway": "link",
            "metric": "306"
            "address": "fe80::\/64",
            "gateway": "link",
            "metric": "259"
            "gateway": "link",
            "metric": "266"
            "address": "fe80::49f1:9c15:1f29:e03d",
            "gateway": "link",
            "metric": "266"
            "address": "fe80::60ad:ab3e:709b:badd",
            "gateway": "link",
            "metric": "259"
            "address": "ff00::\/8",
            "gateway": "link",
            "metric": "306"
            "gateway": "link",
            "metric": "259"
            "gateway": "link",
            "metric": "266"
            "address": "2606:6080:2001:7:8e6:43a8:fb13:2f6d",
            "gateway": "fde6:7a:7d20:458::1",
            "metric": "4294967295"
    "interfaces": [
            "friendly": "Local Area Connection 3",
            "id": "{223C300C-03A7-4A3C-8CA6-CF831AC427D8}",
            "name": "Local Area Connection 3",
            "description": "TAP-Windows Adapter V9 #2",
            "type": "Ethernet",
            "status": "Up",
            "bytes_received": "3732803",
            "bytes_sent": "784461",
            "ips": [
                "169.254.186.221"
            "gateways": [],
            "bind": true,
            "dns4": "10.25.47.1",
            "dns6": null
            "friendly": "Wireless Network Connection 5",
            "id": "{B5C1AE1A-4723-46A0-84F4-7334201BFFDB}",
            "name": "Wireless Network Connection 5",
            "description": "Microsoft Virtual WiFi Miniport Adapter #3",
            "type": "Wireless80211",
            "status": "Down",
            "bytes_received": "0",
            "bytes_sent": "0",
            "ips": [
                "fe80::957a:3042:2928:7b25",
                "169.254.123.37"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Wireless Network Connection 4",
            "id": "{3AADB7AD-DBBE-4D00-BF7C-91C992FD7CDC}",
            "name": "Wireless Network Connection 4",
            "description": "ASUS USB-AC53 Nano USB Wieless adapter",
            "status": "Up",
            "bytes_received": "8433641",
            "bytes_sent": "1602610",
            "ips": [
                "10.0.0.8"
            "gateways": [
                "10.0.0.1"
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Bluetooth Network Connection",
            "id": "{1AA07080-6FEC-4FFB-9E68-E51F81452FB7}",
            "name": "Bluetooth Network Connection",
            "description": "Bluetooth Device (Personal Area Network)",
            "type": "Ethernet",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::8030:a165:6b46:31b7",
                "169.254.49.183"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Loopback Pseudo-Interface 1",
            "id": "{846EE342-7039-11DE-9D20-806E6F6E6963}",
            "name": "Loopback Pseudo-Interface 1",
            "description": "Software Loopback Interface 1",
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "isatap.{223C300C-03A7-4A3C-8CA6-CF831AC427D8}",
            "id": "{FB623047-E4C8-4451-BFF1-B61DF799FA00}",
            "name": "isatap.{223C300C-03A7-4A3C-8CA6-CF831AC427D8}",
            "description": "Microsoft ISATAP Adapter #2",
            "type": "Tunnel",
            "status": "Down",
            "bytes_sent": "0",
            "support_ipv4": false,
            "ips": [
                "fe80::5efe:169.254.186.221"
            "gateways": [],
            "bind": true,
            "dns4": null,
            "dns6": null
            "friendly": "isatap.{3AADB7AD-DBBE-4D00-BF7C-91C992FD7CDC}",
            "id": "{938370A3-BD92-4884-B5D6-DD92D4BCF5F6}",
            "name": "isatap.{3AADB7AD-DBBE-4D00-BF7C-91C992FD7CDC}",
            "description": "Microsoft ISATAP Adapter #3",
            "type": "Tunnel",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::5efe:10.0.0.8"
            "gateways": [],
            "bind": true,
            "dns4": null,
            "dns6": null
            "friendly": "Teredo Tunneling Pseudo-Interface",
            "id": "{76D456E0-51EE-4A75-B5D5-76188D3BB878}",
            "name": "Teredo Tunneling Pseudo-Interface",
            "description": "Teredo Tunneling Pseudo-Interface",
            "type": "Tunnel",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::100:7f:fffe"
            "gateways": [],
            "bind": true,
            "dns4": null,
            "dns6": null
    "ipv4-default-gateway": "10.0.0.1",
    "ipv4-default-interface": "{3AADB7AD-DBBE-4D00-BF7C-91C992FD7CDC}"
ipconfig /all:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Hen3ry
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 3:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : TAP-Windows Adapter V9 #2
   Physical Address. . . . . . . . . : 00-FF-22-3C-30-0C
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::60ad:ab3e:709b:badd%22(Preferred)
   Autoconfiguration IPv4 Address. . : 169.254.186.221(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.0.0
   Default Gateway . . . . . . . . . :
   DHCPv6 IAID . . . . . . . . . . . : 587267874
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-37-6B-41-E8-03-9A-B1-D0-BC
   DNS Servers . . . . . . . . . . . : 10.25.47.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Wireless Network Connection 5:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter #3
   Physical Address. . . . . . . . . : 4C-ED-FB-B4-46-EC
Wireless LAN adapter Wireless Network Connection 4:
   Description . . . . . . . . . . . : ASUS USB-AC53 Nano USB Wieless adapter
   Link-local IPv6 Address . . . . . : fe80::49f1:9c15:1f29:e03d%20(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.0.0.8(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Thursday, February 25, 2021 11:47:16 PM
   Lease Expires . . . . . . . . . . : Friday, February 26, 2021 11:47:21 PM
   Default Gateway . . . . . . . . . : 10.0.0.1
   DHCP Server . . . . . . . . . . . : 10.0.0.1
   DHCPv6 IAID . . . . . . . . . . . : 508358139
   DNS Servers . . . . . . . . . . . : 10.0.0.1
Ethernet adapter Bluetooth Network Connection:
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
   Physical Address. . . . . . . . . : C4-85-08-15-97-43
Tunnel adapter isatap.{223C300C-03A7-4A3C-8CA6-CF831AC427D8}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.{3AADB7AD-DBBE-4D00-BF7C-91C992FD7CDC}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
