ochrdrgn
Configure hummingbird for Tor
I haven't been able to locate a post regarding the configuration of the hummingbird client for use with tor. I've configured the torrc file. I wasn't 100% sure if the hummingbird options `--proxy-host`, `--proxy-password`, etc.. were where I should start tinkering and toggling. I know in the Eddie Client GUI you have a selection for "Tor" in connection preferences, but after downloading Eddie it seems macOS Big Sur has broken the UI. Unable to click, type, or do anything so I'm hoping hummingbird has the configurability or options to tunnel through tor. Any suggestions?
Edited ... by ochrdrgn
AFAIK, VPN over Tor is an Eddie feature.
Crud. Well thank you very much for the info
