1dvy
Port forwarding with external IP.
Hello gentlemen,
I have a problem with port forwarding.
Let's say I reserved port xxx via the AirVPN website. The internal port is identical.
When I run telnet over port xxx using the internal IP - I get the connection. The TCP test on the website also succeeds.
However, when I telnet over port xxx using the mapped external IP address - it times out.
I also ran nmap on the external IP, but the only opened ports were 53 DNS, and three nginx ports 89, 843, and 880.
I tried using different ports, connecting to different servers, but no luck.
Don't know why you did this – it's connecting to a port local to your host :D it's like connecting to 127.0.0.1 or ::1.
The other though is unexpected. Does nc also not connect? Does the application you want the port to be forwarded for connect?
Yeah, just to make sure that indeed a piece of software was binding to the port and that no firewalls were in the way.
So after some time I just tried the telnet again and it worked perfectly with an external IP.
One more thing I realised, as mentioned everywhere on the site if you are to connect to the mentioned port, don't do it on the device from which you are connected to the VPN.
Ah, yes. :)
Good that it works now. Enjoy!
