v0les
Port Forwarding for Soulseek
Hi
I very recently took up with Airvpn after using Tunnelbear before. The reason was port forwarding specifically for Soulseek.
I have set up several pairs of ports. However Soulseek still says they are closed. When I run the TCP test I get Error 111 - 'Connection Refused'. I have attached a screenshot.1219991262_Screenshot2021-01-20at13_05_02.jpg.28242503cf2f4b884e1c0290d53afe31.jpg
The ports as forwarded to 10.7.22.13 - I don’t know what that means.
Please excuse my ignorance but how do I fix this?
It means there is nothing listening on that port. Check if SoulSeek listens on the VPN interface.
That's your in-tunnel IP address.
Can you tell me how I check if SoulSeek listens on the VPN interface?
