IPV4 Test Not Reachable
This started last week.
"DNS address  1 server 81 errors"  Help?
. 2021.01.09 08:22:48 - Eddie version: 2.16.3 / linux_x64, System: Linux, Name: Linux Mint 19.3 Tricia \n \l, Version: Linux rode-GA-MA78LM-S2H 5.4.0-58-generic #64~18.04.1-Ubuntu SMP Wed Dec 9 17:11:11 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux, Mono/.Net: 4.6.2 (Debian 4.6.2.7+dfsg-1ubuntu1); Framework: v4.0.30319
. 2021.01.09 08:22:49 - Reading options from /home/rode/.airvpn/default.xml
. 2021.01.09 08:22:50 - Command line arguments (5): path="/home/rode/.airvpn" path.resources="/usr/share/eddie-ui" path.exec="/usr/bin/eddie-ui" console.mode="none" linux.dbus="unix:path=/run/user/1000/bus"
. 2021.01.09 08:22:50 - Profile path: /home/rode/.airvpn/default.xml
. 2021.01.09 08:22:51 - OpenVPN Driver - Found, /dev/net/tun
. 2021.01.09 08:22:51 - OpenVPN - Version: 2.4.4 - OpenSSL 1.1.1  11 Sep 2018, LZO 2.08 (/usr/sbin/openvpn)
. 2021.01.09 08:22:51 - SSH - Version: OpenSSH_7.6p1 Ubuntu-4ubuntu0.3, OpenSSL 1.0.2n  7 Dec 2017 (/usr/bin/ssh)
. 2021.01.09 08:22:51 - SSL - Version: stunnel 5.44 (/usr/bin/stunnel4)
. 2021.01.09 08:22:51 - curl - Version: 7.58.0 (/usr/bin/curl)
. 2021.01.09 08:22:51 - Certification Authorities: /usr/share/eddie-ui/cacert.pem
W 2021.01.09 08:22:51 - Recovery. Unexpected crash?
. 2021.01.09 08:22:51 - Routes, removed a route previously added, 184.75.221.179 for gateway 10.28.162.1
. 2021.01.09 08:22:51 - DNS of the system restored to original settings (Rename method)
! 2021.01.09 08:22:51 - Deactivation of Network Lock
! 2021.01.09 08:22:51 - Activation of Network Lock - Linux iptables
. 2021.01.09 08:22:52 - Updating systems & servers data ...
. 2021.01.09 08:23:25 - Cannot retrieve systems & servers data. (curl: (7) Couldn't connect to server)
I 2021.01.09 08:23:25 - Ready
I 2021.01.09 08:24:02 - Session starting.
I 2021.01.09 08:24:02 - Checking authorization ...
! 2021.01.09 08:24:02 - Connecting to Titawin (Canada, Vancouver)
. 2021.01.09 08:24:02 - OpenVPN > OpenVPN 2.4.4 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on May 14 2019
. 2021.01.09 08:24:02 - OpenVPN > library versions: OpenSSL 1.1.1  11 Sep 2018, LZO 2.08
. 2021.01.09 08:24:02 - Connection to OpenVPN Management Interface
. 2021.01.09 08:24:02 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2021.01.09 08:24:03 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.01.09 08:24:03 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.01.09 08:24:03 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.01.09 08:24:03 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.01.09 08:24:03 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]192.30.89.61:443
. 2021.01.09 08:24:03 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2021.01.09 08:24:03 - OpenVPN > UDP link local: (not bound)
. 2021.01.09 08:24:03 - OpenVPN > UDP link remote: [AF_INET]192.30.89.61:443
. 2021.01.09 08:24:03 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2021.01.09 08:24:03 - OpenVPN > TLS: Initial packet from [AF_INET]192.30.89.61:443, sid=2684c325 4a1a8ac2
. 2021.01.09 08:24:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.01.09 08:24:03 - OpenVPN > VERIFY KU OK
. 2021.01.09 08:24:03 - OpenVPN > Validating certificate extended key usage
. 2021.01.09 08:24:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.01.09 08:24:03 - OpenVPN > VERIFY EKU OK
. 2021.01.09 08:24:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Titawin, emailAddress=info@airvpn.org
. 2021.01.09 08:24:03 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.01.09 08:24:03 - OpenVPN > [Titawin] Peer Connection Initiated with [AF_INET]192.30.89.61:443
. 2021.01.09 08:24:04 - OpenVPN > SENT CONTROL [Titawin]: 'PUSH_REQUEST' (status=1)
. 2021.01.09 08:24:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.20.66.1,dhcp-option DNS6 fde6:7a:7d20:1042::1,tun-ipv6,route-gateway 10.20.66.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1042::1020/64 fde6:7a:7d20:1042::1,ifconfig 10.20.66.34 255.255.255.0,peer-id 6,cipher AES-256-GCM'
. 2021.01.09 08:24:04 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.01.09 08:24:04 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1042::1'
. 2021.01.09 08:24:04 - OpenVPN > Pushed option removed by filter: 'tun-ipv6'
. 2021.01.09 08:24:04 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:1042::1020/64 fde6:7a:7d20:1042::1'
. 2021.01.09 08:24:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.01.09 08:24:04 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.01.09 08:24:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.01.09 08:24:04 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.01.09 08:24:04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.01.09 08:24:04 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.01.09 08:24:04 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.01.09 08:24:04 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.01.09 08:24:04 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.01.09 08:24:04 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.01.09 08:24:04 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.01.09 08:24:04 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 IFACE=wlx503eaab13361 HWADDR=50:3e:aa:b1:33:61
. 2021.01.09 08:24:04 - OpenVPN > TUN/TAP device tun0 opened
. 2021.01.09 08:24:04 - OpenVPN > TUN/TAP TX queue length set to 100
. 2021.01.09 08:24:04 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2021.01.09 08:24:04 - OpenVPN > /sbin/ip link set dev tun0 up mtu 1500
. 2021.01.09 08:24:04 - OpenVPN > /sbin/ip addr add dev tun0 10.20.66.34/24 broadcast 10.20.66.255
. 2021.01.09 08:24:09 - OpenVPN > /sbin/ip route add 192.30.89.61/32 via 192.168.0.1
. 2021.01.09 08:24:09 - OpenVPN > /sbin/ip route add 0.0.0.0/1 via 10.20.66.1
. 2021.01.09 08:24:09 - OpenVPN > /sbin/ip route add 128.0.0.0/1 via 10.20.66.1
. 2021.01.09 08:24:09 - /etc/resolv.conf moved to /etc/resolv.conf.eddie as backup
. 2021.01.09 08:24:09 - DNS of the system updated to VPN DNS (Rename method: /etc/resolv.conf generated)
. 2021.01.09 08:24:09 - Routes, added a new route, 192.30.89.59 for gateway 10.20.66.1
. 2021.01.09 08:24:09 - Unable to compute route for 2606:9580:100:d:2bd7:c37b:24c2:c069: IPv6 VPN gateway not available.
. 2021.01.09 08:24:09 - Flushing DNS
I 2021.01.09 08:24:22 - Checking route IPv4
I 2021.01.09 08:24:23 - Checking DNS
! 2021.01.09 08:24:23 - Connected.
. 2021.01.09 08:24:23 - OpenVPN > Initialization Sequence Completed
. 2021.01.09 08:25:08 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #226 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2021.01.09 08:33:38 - Above log line repeated 1015 times more
. 2021.01.09 08:33:38 - Updating systems & servers data ...
W 2021.01.09 08:33:40 - Special Christmas deal: save up to 68%
W 2021.01.09 08:33:40 -     send a gift to a friend or give yourself the gift of privacy
. 2021.01.09 08:33:43 - Systems & servers data update completed
Edited ... by OpenSourcerer
Apply LOG format to logs
Some yellow flags in your logs. Please upgrade to at least 2.18.9, then try again. If it still does not work, try to connect, then click the lifebelt icon in Logs tab and paste or upload the output here. Thanks :)
