Not connected, Your IP: 216.73.216.183
I Keep getting connection fails at IPv6.   Would someone help me with this please?  I am a novice and any help is greatly appreciated.
2020.12.28 17:55:36 - Checking route IPv6
. 2020.12.28 17:55:56 - curl: (28) Connection timed out after 20000 milliseconds
. 2020.12.28 17:55:56 - Checking route (2° try)
. 2020.12.28 17:56:18 - curl: (28) Connection timed out after 20013 milliseconds
. 2020.12.28 17:56:18 - Checking route (3° try)
. 2020.12.28 17:56:40 - curl: (28) Connection timed out after 20001 milliseconds
E 2020.12.28 17:56:40 - Checking route IPv6 failed.
. 2020.12.28 17:56:40 - OpenVPN > Initialization Sequence Completed
! 2020.12.28 17:56:40 - Disconnecting
. 2020.12.28 17:56:40 - Routes, removed a route previously added, 213.152.161.40 for gateway 10.18.146.1
. 2020.12.28 17:56:40 - Routes, removed a route previously added, 2a00:1678:2470:44:cf2:ef3e:d71f:3810 for gateway fde6:7a:7d20:e92::1
. 2020.12.28 17:56:40 - Sending soft termination signal
. 2020.12.28 17:56:43 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.12.28 17:56:45 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.42 MASK 255.255.255.255 192.168.178.1
. 2020.12.28 17:56:45 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2020.12.28 17:56:45 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.18.146.1
. 2020.12.28 17:56:45 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.18.146.1
. 2020.12.28 17:56:45 - OpenVPN > delete_route_ipv6(::/3)
. 2020.12.28 17:56:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=7 fe80::8 store=active
. 2020.12.28 17:56:45 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2020.12.28 17:56:45 - OpenVPN > Closing TUN/TAP interface
. 2020.12.28 17:56:45 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:e92::/64)
. 2020.12.28 17:56:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:e92::/64 interface=7 fe80::8 store=active
. 2020.12.28 17:56:46 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Local Area Connection fde6:7a:7d20:e92::10c1 store=active
. 2020.12.28 17:56:47 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns Local Area Connection all
. 2020.12.28 17:56:48 - OpenVPN > TAP: DHCP address released
. 2020.12.28 17:56:48 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2020.12.28 17:56:48 - Connection terminated.
. 2020.12.28 17:56:48 - DNS leak protection with packet filtering disabled.
. 2020.12.28 17:56:48 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4
. 2020.12.28 17:56:48 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6
. 2020.12.28 17:56:51 - Waiting for latency tests (41 to go)
. 2020.12.28 17:56:52 - Waiting for latency tests (20 to go)
I 2020.12.28 17:56:55 - Checking authorization ...
! 2020.12.28 17:56:57 - Connecting to Aspidiske (Netherlands, Alblasserdam)
. 2020.12.28 17:56:57 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.12.28 17:56:57 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.12.28 17:56:57 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.12.28 17:56:57 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.28 17:56:57 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.28 17:56:57 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.28 17:56:57 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.28 17:56:57 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.197:443
. 2020.12.28 17:56:57 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.12.28 17:56:57 - OpenVPN > UDP link local: (not bound)
. 2020.12.28 17:56:57 - OpenVPN > UDP link remote: [AF_INET]134.19.179.197:443
. 2020.12.28 17:56:57 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.197:443, sid=c1536953 c15b17c2
. 2020.12.28 17:56:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.28 17:56:57 - OpenVPN > VERIFY KU OK
. 2020.12.28 17:56:57 - OpenVPN > Validating certificate extended key usage
. 2020.12.28 17:56:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.28 17:56:57 - OpenVPN > VERIFY EKU OK
. 2020.12.28 17:56:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aspidiske, emailAddress=info@airvpn.org
. 2020.12.28 17:56:58 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA
. 2020.12.28 17:56:58 - OpenVPN > [Aspidiske] Peer Connection Initiated with [AF_INET]134.19.179.197:443
. 2020.12.28 17:56:59 - OpenVPN > SENT CONTROL [Aspidiske]: 'PUSH_REQUEST' (status=1)
. 2020.12.28 17:56:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.33.146.1,dhcp-option DNS6 fde6:7a:7d20:1d92::1,tun-ipv6,route-gateway 10.33.146.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1d92::10f1/64 fde6:7a:7d20:1d92::1,ifconfig 10.33.146.243 255.255.255.0,peer-id 7,cipher AES-256-GCM'
. 2020.12.28 17:56:59 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.12.28 17:56:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.28 17:56:59 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.28 17:56:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.28 17:56:59 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.28 17:56:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.28 17:56:59 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.28 17:56:59 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.28 17:56:59 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.28 17:56:59 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.12.28 17:56:59 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.28 17:56:59 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.28 17:56:59 - OpenVPN > interactive service msg_channel=0
. 2020.12.28 17:56:59 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 I=12 HWADDR=b4:b6:86:ea:50:12
. 2020.12.28 17:56:59 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.12.28 17:56:59 - OpenVPN > GetBestInterfaceEx() returned if=12
. 2020.12.28 17:56:59 - OpenVPN > GDG6: II=12 DP=::/0 NH=fe80::9a9b:cbff:feb8:d3f
. 2020.12.28 17:56:59 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.12.28 17:56:59 - OpenVPN > ROUTE6_GATEWAY fe80::9a9b:cbff:feb8:d3f I=12
. 2020.12.28 17:56:59 - OpenVPN > open_tun
. 2020.12.28 17:56:59 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{3BEFF96D-3D6F-4BD6-8E95-BFAC01F0EADC}.tap
. 2020.12.28 17:56:59 - OpenVPN > TAP-Windows Driver Version 9.24
. 2020.12.28 17:56:59 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.33.146.0/10.33.146.243/255.255.255.0 [SUCCEEDED]
. 2020.12.28 17:56:59 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.33.146.243/255.255.255.0 on interface {3BEFF96D-3D6F-4BD6-8E95-BFAC01F0EADC} [DHCP-serv: 10.33.146.254, lease-time: 31536000]
. 2020.12.28 17:56:59 - OpenVPN > Successful ARP Flush on interface [7] {3BEFF96D-3D6F-4BD6-8E95-BFAC01F0EADC}
! 2020.12.28 17:56:59 - Disconnecting
. 2020.12.28 17:56:59 - Sending soft termination signal
. 2020.12.28 17:57:03 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=7 fde6:7a:7d20:1d92::10f1 store=active
. 2020.12.28 17:57:03 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Local Area Connection static fde6:7a:7d20:1d92::1 validate=no
. 2020.12.28 17:57:03 - Detected an OpenVPN bug (On-Link route on VPN range), autofix.
. 2020.12.28 17:57:03 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1d92::/64 -> fde6:7a:7d20:1d92::10f1 metric 0) dev Local Area Connection
. 2020.12.28 17:57:03 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1d92::/64 interface=7 fe80::8 store=active
. 2020.12.28 17:57:03 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2020.12.28 17:57:03 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.12.28 17:57:07 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2020.12.28 17:57:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 134.19.179.197 MASK 255.255.255.255 192.168.178.1
. 2020.12.28 17:57:07 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2020.12.28 17:57:07 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2020.12.28 17:57:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.33.146.1
. 2020.12.28 17:57:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.33.146.1
. 2020.12.28 17:57:07 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1d92::1 metric -1) dev Local Area Connection
. 2020.12.28 17:57:07 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=7 fe80::8 store=active
. 2020.12.28 17:57:07 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2020.12.28 17:57:07 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1d92::1 metric -1) dev Local Area Connection
. 2020.12.28 17:57:07 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=7 fe80::8 store=active
E 2020.12.28 17:57:08 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
. 2020.12.28 17:57:08 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1d92::1 metric -1) dev Local Area Connection
. 2020.12.28 17:57:08 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=7 fe80::8 store=active
. 2020.12.28 17:57:08 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2020.12.28 17:57:08 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1d92::1 metric -1) dev Local Area Connection
. 2020.12.28 17:57:08 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=7 fe80::8 store=active
. 2020.12.28 17:57:08 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4
. 2020.12.28 17:57:08 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6
. 2020.12.28 17:57:08 - DNS leak protection with packet filtering enabled.
. 2020.12.28 17:57:09 - Routes, added a new route, 134.19.179.195 for gateway 10.33.146.1
. 2020.12.28 17:57:10 - Routes, added a new route, 2a00:1678:2470:1101:6c5a:e721:17c9:92f8 for gateway fde6:7a:7d20:1d92::1
. 2020.12.28 17:57:10 - Flushing DNS
. 2020.12.28 17:57:10 - OpenVPN > Initialization Sequence Completed
. 2020.12.28 17:57:10 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 134.19.179.197 MASK 255.255.255.255 192.168.178.1
. 2020.12.28 17:57:10 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2020.12.28 17:57:10 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.33.146.1
. 2020.12.28 17:57:10 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.33.146.1
. 2020.12.28 17:57:10 - OpenVPN > delete_route_ipv6(::/3)
. 2020.12.28 17:57:10 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=7 fe80::8 store=active
. 2020.12.28 17:57:10 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2020.12.28 17:57:10 - Sending hard termination signal
. 2020.12.28 17:57:10 - OpenVPN > Closing TUN/TAP interface
. 2020.12.28 17:57:10 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1d92::/64)
. 2020.12.28 17:57:10 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1d92::/64 interface=7 fe80::8 store=active
. 2020.12.28 17:57:10 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Local Area Connection fde6:7a:7d20:1d92::10f1 store=active
. 2020.12.28 17:57:10 - Connection terminated.
. 2020.12.28 17:57:10 - DNS leak protection with packet filtering disabled.
. 2020.12.28 17:57:10 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4
. 2020.12.28 17:57:10 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6
I 2020.12.28 17:57:10 - Cancel requested.
! 2020.12.28 17:57:10 - Session terminated.
Edited ... by OpenSourcerer
Apply LOG format to logs
Why u should deactivate this on the Network ?
Just in Eddie seems to me a much better idea or ?
but at first u should "uninstall the standard driver" in advanced settings and restart eddie if this doesnt work
just block ip6  in eddie under "Networking"  and set "switch to block if issue.."
should work
some providers especially  with branded routers have hardcoded to block ip6 connections for whatever the reason is for
best regards
