hardcopymuse@100
Eddie tries to connect but keeps restarting
As the title says...what can i do? Please help
here is my info..
Eddie System/Environment Report - 12/23/2020 - 8:07 AM UTC
Eddie version: 2.18.9
Eddie OS build: windows_x64
Eddie architecture: x64
OS type: Windows
OS name: Windows 10 Home
OS version: Microsoft Windows NT 10.0.18363.0
OS architecture: x64
Mono /.Net Framework: v4.0.30319
TUN driver: 0901: 9.24.2; wintun: Not found
OpenVPN: 2.4.8 - OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
Hummingbird:  ()
SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe)
Profile path: C:\Users\ksr75\AppData\Local\Eddie\default.profile
Data path: C:\Users\ksr75\AppData\Local\Eddie
Application path: C:\Program Files\AirVPN
Executable path: C:\Program Files\AirVPN\Eddie-UI.exe
Command line arguments: (1 args) path="home"
Network Lock Active: No
Connected to VPN: No
Detected DNS: 1.1.1.1, 10.22.22.1, 8.4.4.4, fde6:7a:7d20:1216::1
Test DNS IPv4: Ok
Test DNS IPv6: Ok
Test Ping IPv4: 254 ms
Test Ping IPv6: 348 ms
Test HTTP IPv4: Ok
Test HTTP IPv6: Ok
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
key: (omissis)
Logs:
. 2020.12.22 23:56:53 - Eddie version: 2.18.9 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319
. 2020.12.22 23:56:53 - Command line arguments (1): path="home"
. 2020.12.22 23:56:55 - Raise system privileges
. 2020.12.22 23:57:00 - Profile path: C:\Users\ksr75\AppData\Local\Eddie\default.profile
. 2020.12.22 23:57:00 - Reading options from C:\Users\ksr75\AppData\Local\Eddie\default.profile
. 2020.12.22 23:57:01 - Tun Driver - 0901: 9.24.2; wintun: Not found
. 2020.12.22 23:57:01 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2020.12.22 23:57:01 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2020.12.22 23:57:01 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2020.12.22 23:57:01 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe)
. 2020.12.22 23:57:02 - Recovery. Unexpected crash?
. 2020.12.22 23:57:02 - Routes, added a new route, 213.152.161.15 for gateway 10.30.110.1
. 2020.12.22 23:57:02 - Routes, added a new route, 2a00:1678:2470:39:ddf1:680c:a9e0:377a for gateway fde6:7a:7d20:1a6e::1
. 2020.12.22 23:57:02 - Routes, added a new route, 109.202.103.170 for gateway 10.9.78.1
. 2020.12.22 23:57:02 - Routes, added a new route, 2a00:1678:2470:7:7265:24fc:ff33:113b for gateway fde6:7a:7d20:54e::1
. 2020.12.22 23:57:02 - Routes, removed an existing route, 184.75.221.195 for gateway 10.31.110.1
. 2020.12.22 23:57:02 - Routes, removed an existing route, 184.75.221.171 for gateway 10.8.182.1
. 2020.12.22 23:57:02 - Routes, removed an existing route, 2606:6080:1001:13:a777:ff73:dfdc:3ab0 for gateway fde6:7a:7d20:4b6::1
. 2020.12.22 23:57:02 - Routes, added a new route, 199.249.230.37 for gateway 10.16.118.1
. 2020.12.22 23:57:02 - Routes, added a new route, 2620:7:6001:b0ec:2f3a:a3d0:966f:e483 for gateway fde6:7a:7d20:c76::1
. 2020.12.22 23:57:02 - Routes, added a new route, 184.75.221.115 for gateway 10.8.150.1
. 2020.12.22 23:57:02 - Routes, added a new route, 199.249.230.7 for gateway 10.22.22.1
. 2020.12.22 23:57:03 - Routes, added a new route, 2620:7:6001:40b8:ceb4:2489:665e:d101 for gateway fde6:7a:7d20:1216::1
I 2020.12.22 23:57:03 - Ready
. 2020.12.22 23:57:06 - Collect information about AirVPN completed
I 2020.12.22 23:57:28 - Session starting.
I 2020.12.22 23:57:28 - Checking authorization ...
! 2020.12.22 23:57:29 - Connecting to Chalawan (United States of America, Phoenix, Arizona)
. 2020.12.22 23:57:29 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.12.22 23:57:29 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.12.22 23:57:29 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.12.22 23:57:29 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.22 23:57:29 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.22 23:57:29 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.22 23:57:29 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.22 23:57:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]193.37.254.21:443
. 2020.12.22 23:57:29 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.12.22 23:57:29 - OpenVPN > UDP link local: (not bound)
. 2020.12.22 23:57:29 - OpenVPN > UDP link remote: [AF_INET]193.37.254.21:443
. 2020.12.22 23:57:29 - OpenVPN > TLS: Initial packet from [AF_INET]193.37.254.21:443, sid=5c811ceb 0da2eefe
. 2020.12.22 23:57:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.22 23:57:30 - OpenVPN > VERIFY KU OK
. 2020.12.22 23:57:30 - OpenVPN > Validating certificate extended key usage
. 2020.12.22 23:57:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.22 23:57:30 - OpenVPN > VERIFY EKU OK
. 2020.12.22 23:57:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Chalawan, emailAddress=info@airvpn.org
. 2020.12.22 23:57:31 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA
. 2020.12.22 23:57:31 - OpenVPN > [Chalawan] Peer Connection Initiated with [AF_INET]193.37.254.21:443
. 2020.12.22 23:57:32 - OpenVPN > SENT CONTROL [Chalawan]: 'PUSH_REQUEST' (status=1)
. 2020.12.22 23:57:32 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.29.218.1,dhcp-option DNS6 fde6:7a:7d20:19da::1,tun-ipv6,route-gateway 10.29.218.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:19da::10af/64 fde6:7a:7d20:19da::1,ifconfig 10.29.218.177 255.255.255.0,peer-id 4,cipher AES-256-GCM'
. 2020.12.22 23:57:32 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.12.22 23:57:32 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.22 23:57:32 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.22 23:57:32 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.22 23:57:32 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.22 23:57:32 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.22 23:57:32 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.22 23:57:32 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.22 23:57:32 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.22 23:57:32 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.12.22 23:57:32 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.22 23:57:32 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.22 23:57:32 - OpenVPN > interactive service msg_channel=0
. 2020.12.22 23:57:32 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=60:f2:62:89:2c:72
. 2020.12.22 23:57:32 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.12.22 23:57:32 - OpenVPN > GetBestInterfaceEx() returned if=7
. 2020.12.22 23:57:32 - OpenVPN > GDG6: II=7 DP=::/3 NH=fe80::8
. 2020.12.22 23:57:32 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.12.22 23:57:32 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=7
. 2020.12.22 23:57:32 - OpenVPN > open_tun
. 2020.12.22 23:57:32 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}.tap
. 2020.12.22 23:57:32 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.12.22 23:57:32 - OpenVPN > Exiting due to fatal error
! 2020.12.22 23:57:32 - Disconnecting
. 2020.12.22 23:57:32 - Connection terminated.
I 2020.12.22 23:57:35 - Checking authorization ...
! 2020.12.22 23:57:36 - Connecting to Agena (Canada, Toronto, Ontario)
. 2020.12.22 23:57:36 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.12.22 23:57:36 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.12.22 23:57:36 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.12.22 23:57:36 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.22 23:57:36 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.22 23:57:36 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.22 23:57:36 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.22 23:57:36 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.213:443
. 2020.12.22 23:57:36 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.12.22 23:57:36 - OpenVPN > UDP link local: (not bound)
. 2020.12.22 23:57:36 - OpenVPN > UDP link remote: [AF_INET]184.75.223.213:443
. 2020.12.22 23:57:36 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.213:443, sid=59988d60 cf6835ff
. 2020.12.22 23:57:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.22 23:57:36 - OpenVPN > VERIFY KU OK
. 2020.12.22 23:57:36 - OpenVPN > Validating certificate extended key usage
. 2020.12.22 23:57:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.22 23:57:36 - OpenVPN > VERIFY EKU OK
. 2020.12.22 23:57:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Agena, emailAddress=info@airvpn.org
. 2020.12.22 23:57:37 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA
. 2020.12.22 23:57:37 - OpenVPN > [Agena] Peer Connection Initiated with [AF_INET]184.75.223.213:443
. 2020.12.22 23:57:38 - OpenVPN > SENT CONTROL [Agena]: 'PUSH_REQUEST' (status=1)
. 2020.12.22 23:57:39 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.218.1,dhcp-option DNS6 fde6:7a:7d20:da::1,tun-ipv6,route-gateway 10.4.218.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:da::10a6/64 fde6:7a:7d20:da::1,ifconfig 10.4.218.168 255.255.255.0,peer-id 5,cipher AES-256-GCM'
. 2020.12.22 23:57:39 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.12.22 23:57:39 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.22 23:57:39 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.22 23:57:39 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.22 23:57:39 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.22 23:57:39 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.22 23:57:39 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.22 23:57:39 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.22 23:57:39 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.22 23:57:39 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.12.22 23:57:39 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.22 23:57:39 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.22 23:57:39 - OpenVPN > interactive service msg_channel=0
. 2020.12.22 23:57:39 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=60:f2:62:89:2c:72
. 2020.12.22 23:57:39 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.12.22 23:57:39 - OpenVPN > GetBestInterfaceEx() returned if=7
. 2020.12.22 23:57:39 - OpenVPN > GDG6: II=7 DP=::/3 NH=fe80::8
. 2020.12.22 23:57:39 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.12.22 23:57:39 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=7
. 2020.12.22 23:57:39 - OpenVPN > open_tun
. 2020.12.22 23:57:39 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}.tap
. 2020.12.22 23:57:39 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.12.22 23:57:39 - OpenVPN > Exiting due to fatal error
! 2020.12.22 23:57:39 - Disconnecting
. 2020.12.22 23:57:39 - Connection terminated.
I 2020.12.22 23:57:42 - Checking authorization ...
! 2020.12.22 23:57:42 - Connecting to Kajam (Netherlands, Alblasserdam)
. 2020.12.22 23:57:42 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.12.22 23:57:42 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.12.22 23:57:42 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.12.22 23:57:42 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.22 23:57:42 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.22 23:57:42 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.22 23:57:42 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.22 23:57:42 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.87:443
. 2020.12.22 23:57:42 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.12.22 23:57:42 - OpenVPN > UDP link local: (not bound)
. 2020.12.22 23:57:42 - OpenVPN > UDP link remote: [AF_INET]213.152.161.87:443
. 2020.12.22 23:57:43 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.87:443, sid=7680a271 a4264c03
. 2020.12.22 23:57:43 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.22 23:57:43 - OpenVPN > VERIFY KU OK
. 2020.12.22 23:57:43 - OpenVPN > Validating certificate extended key usage
. 2020.12.22 23:57:43 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.22 23:57:43 - OpenVPN > VERIFY EKU OK
. 2020.12.22 23:57:43 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Kajam, emailAddress=info@airvpn.org
. 2020.12.22 23:57:44 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA
. 2020.12.22 23:57:44 - OpenVPN > [Kajam] Peer Connection Initiated with [AF_INET]213.152.161.87:443
. 2020.12.22 23:57:45 - OpenVPN > SENT CONTROL [Kajam]: 'PUSH_REQUEST' (status=1)
. 2020.12.22 23:57:46 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.19.250.1,dhcp-option DNS6 fde6:7a:7d20:ffa::1,tun-ipv6,route-gateway 10.19.250.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:ffa::10f0/64 fde6:7a:7d20:ffa::1,ifconfig 10.19.250.242 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2020.12.22 23:57:46 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.12.22 23:57:46 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.22 23:57:46 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.22 23:57:46 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.22 23:57:46 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.22 23:57:46 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.22 23:57:46 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.22 23:57:46 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.22 23:57:46 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.22 23:57:46 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.12.22 23:57:46 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.22 23:57:46 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.22 23:57:46 - OpenVPN > interactive service msg_channel=0
. 2020.12.22 23:57:46 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=60:f2:62:89:2c:72
. 2020.12.22 23:57:46 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.12.22 23:57:46 - OpenVPN > GetBestInterfaceEx() returned if=7
. 2020.12.22 23:57:46 - OpenVPN > GDG6: II=7 DP=::/3 NH=fe80::8
. 2020.12.22 23:57:46 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.12.22 23:57:46 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=7
. 2020.12.22 23:57:46 - OpenVPN > open_tun
. 2020.12.22 23:57:46 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}.tap
. 2020.12.22 23:57:46 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.12.22 23:57:46 - OpenVPN > Exiting due to fatal error
! 2020.12.22 23:57:46 - Disconnecting
. 2020.12.22 23:57:46 - Connection terminated.
I 2020.12.22 23:57:49 - Checking authorization ...
! 2020.12.22 23:57:50 - Connecting to Aludra (Canada, Toronto, Ontario)
. 2020.12.22 23:57:50 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.12.22 23:57:50 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.12.22 23:57:50 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.12.22 23:57:50 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.22 23:57:50 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.22 23:57:50 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.22 23:57:50 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.22 23:57:50 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.205:443
. 2020.12.22 23:57:50 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.12.22 23:57:50 - OpenVPN > UDP link local: (not bound)
. 2020.12.22 23:57:50 - OpenVPN > UDP link remote: [AF_INET]104.254.90.205:443
. 2020.12.22 23:57:50 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.205:443, sid=bac74acc 2bcd3421
. 2020.12.22 23:57:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.22 23:57:50 - OpenVPN > VERIFY KU OK
. 2020.12.22 23:57:50 - OpenVPN > Validating certificate extended key usage
. 2020.12.22 23:57:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.22 23:57:50 - OpenVPN > VERIFY EKU OK
. 2020.12.22 23:57:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aludra, emailAddress=info@airvpn.org
. 2020.12.22 23:57:51 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA
. 2020.12.22 23:57:51 - OpenVPN > [Aludra] Peer Connection Initiated with [AF_INET]104.254.90.205:443
. 2020.12.22 23:57:52 - OpenVPN > SENT CONTROL [Aludra]: 'PUSH_REQUEST' (status=1)
. 2020.12.22 23:57:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.90.1,dhcp-option DNS6 fde6:7a:7d20:45a::1,tun-ipv6,route-gateway 10.8.90.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:45a::109a/64 fde6:7a:7d20:45a::1,ifconfig 10.8.90.156 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2020.12.22 23:57:52 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.12.22 23:57:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.22 23:57:52 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.22 23:57:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.22 23:57:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.22 23:57:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.22 23:57:52 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.22 23:57:52 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.22 23:57:52 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.22 23:57:52 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.12.22 23:57:52 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.22 23:57:52 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.22 23:57:52 - OpenVPN > interactive service msg_channel=0
. 2020.12.22 23:57:52 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=60:f2:62:89:2c:72
. 2020.12.22 23:57:52 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.12.22 23:57:52 - OpenVPN > GetBestInterfaceEx() returned if=7
. 2020.12.22 23:57:52 - OpenVPN > GDG6: II=7 DP=::/3 NH=fe80::8
. 2020.12.22 23:57:52 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.12.22 23:57:52 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=7
. 2020.12.22 23:57:52 - OpenVPN > open_tun
. 2020.12.22 23:57:52 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}.tap
. 2020.12.22 23:57:52 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.12.22 23:57:52 - OpenVPN > Exiting due to fatal error
! 2020.12.22 23:57:52 - Disconnecting
. 2020.12.22 23:57:52 - Connection terminated.
I 2020.12.22 23:57:55 - Checking authorization ...
. 2020.12.22 23:58:00 - Above log line repeated 1 times more
I 2020.12.22 23:58:00 - Cancel requested.
! 2020.12.22 23:58:00 - Session terminated.
! 2020.12.23 00:00:04 - Logged out.
I 2020.12.23 00:02:56 - Checking login ...
! 2020.12.23 00:02:57 - Logged in.
I 2020.12.23 00:03:02 - Session starting.
I 2020.12.23 00:03:02 - Checking authorization ...
! 2020.12.23 00:03:03 - Connecting to Orion (Netherlands, Alblasserdam)
. 2020.12.23 00:03:03 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.12.23 00:03:03 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.12.23 00:03:03 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.12.23 00:03:03 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:03:03 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:03:03 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:03:03 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:03:03 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.241:443
. 2020.12.23 00:03:03 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.12.23 00:03:03 - OpenVPN > UDP link local: (not bound)
. 2020.12.23 00:03:03 - OpenVPN > UDP link remote: [AF_INET]213.152.161.241:443
. 2020.12.23 00:03:04 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.241:443, sid=81fa8e7a 0f797ea5
. 2020.12.23 00:03:04 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.23 00:03:04 - OpenVPN > VERIFY KU OK
. 2020.12.23 00:03:04 - OpenVPN > Validating certificate extended key usage
. 2020.12.23 00:03:04 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.23 00:03:04 - OpenVPN > VERIFY EKU OK
. 2020.12.23 00:03:04 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org
. 2020.12.23 00:03:05 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA
. 2020.12.23 00:03:05 - OpenVPN > [Orion] Peer Connection Initiated with [AF_INET]213.152.161.241:443
. 2020.12.23 00:03:06 - OpenVPN > SENT CONTROL [Orion]: 'PUSH_REQUEST' (status=1)
. 2020.12.23 00:03:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.25.250.1,dhcp-option DNS6 fde6:7a:7d20:15fa::1,tun-ipv6,route-gateway 10.25.250.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:15fa::10ae/64 fde6:7a:7d20:15fa::1,ifconfig 10.25.250.176 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2020.12.23 00:03:06 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.12.23 00:03:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.23 00:03:06 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.23 00:03:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.23 00:03:06 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.23 00:03:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.23 00:03:06 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.23 00:03:06 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.23 00:03:06 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.23 00:03:06 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.12.23 00:03:06 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:03:06 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:03:06 - OpenVPN > interactive service msg_channel=0
. 2020.12.23 00:03:06 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=60:f2:62:89:2c:72
. 2020.12.23 00:03:06 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.12.23 00:03:06 - OpenVPN > GetBestInterfaceEx() returned if=7
. 2020.12.23 00:03:06 - OpenVPN > GDG6: II=7 DP=::/3 NH=fe80::8
. 2020.12.23 00:03:06 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.12.23 00:03:06 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=7
. 2020.12.23 00:03:06 - OpenVPN > open_tun
. 2020.12.23 00:03:06 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}.tap
. 2020.12.23 00:03:06 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.12.23 00:03:06 - OpenVPN > Exiting due to fatal error
! 2020.12.23 00:03:06 - Disconnecting
. 2020.12.23 00:03:06 - Connection terminated.
. 2020.12.23 00:03:09 - Waiting for latency tests (63 to go)
. 2020.12.23 00:03:12 - Waiting for latency tests (39 to go)
. 2020.12.23 00:03:15 - Waiting for latency tests (15 to go)
. 2020.12.23 00:03:17 - Waiting for latency tests (14 to go)
I 2020.12.23 00:03:18 - Checking authorization ...
! 2020.12.23 00:03:19 - Connecting to Sargas (Canada, Toronto, Ontario)
. 2020.12.23 00:03:19 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.12.23 00:03:19 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.12.23 00:03:19 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.12.23 00:03:19 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:03:19 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:03:19 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:03:19 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:03:19 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.197:443
. 2020.12.23 00:03:19 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.12.23 00:03:19 - OpenVPN > UDP link local: (not bound)
. 2020.12.23 00:03:19 - OpenVPN > UDP link remote: [AF_INET]184.75.223.197:443
. 2020.12.23 00:03:20 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.197:443, sid=566e42ab e9ff010a
. 2020.12.23 00:03:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.23 00:03:20 - OpenVPN > VERIFY KU OK
. 2020.12.23 00:03:20 - OpenVPN > Validating certificate extended key usage
. 2020.12.23 00:03:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.23 00:03:20 - OpenVPN > VERIFY EKU OK
. 2020.12.23 00:03:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sargas, emailAddress=info@airvpn.org
. 2020.12.23 00:03:21 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA
. 2020.12.23 00:03:21 - OpenVPN > [Sargas] Peer Connection Initiated with [AF_INET]184.75.223.197:443
. 2020.12.23 00:03:22 - OpenVPN > SENT CONTROL [Sargas]: 'PUSH_REQUEST' (status=1)
. 2020.12.23 00:03:22 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.29.58.1,dhcp-option DNS6 fde6:7a:7d20:193a::1,tun-ipv6,route-gateway 10.29.58.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:193a::108f/64 fde6:7a:7d20:193a::1,ifconfig 10.29.58.145 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2020.12.23 00:03:22 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.12.23 00:03:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.23 00:03:22 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.23 00:03:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.23 00:03:22 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.23 00:03:22 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.23 00:03:22 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.23 00:03:22 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.23 00:03:22 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.23 00:03:22 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.12.23 00:03:22 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:03:22 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:03:22 - OpenVPN > interactive service msg_channel=0
. 2020.12.23 00:03:22 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=60:f2:62:89:2c:72
. 2020.12.23 00:03:22 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.12.23 00:03:22 - OpenVPN > GetBestInterfaceEx() returned if=7
. 2020.12.23 00:03:22 - OpenVPN > GDG6: II=7 DP=::/3 NH=fe80::8
. 2020.12.23 00:03:22 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.12.23 00:03:22 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=7
. 2020.12.23 00:03:22 - OpenVPN > open_tun
. 2020.12.23 00:03:22 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}.tap
. 2020.12.23 00:03:22 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.12.23 00:03:22 - OpenVPN > Exiting due to fatal error
! 2020.12.23 00:03:22 - Disconnecting
. 2020.12.23 00:03:22 - Connection terminated.
I 2020.12.23 00:03:25 - Checking authorization ...
! 2020.12.23 00:03:26 - Connecting to Lesath (Canada, Toronto, Ontario)
. 2020.12.23 00:03:26 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.12.23 00:03:26 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.12.23 00:03:26 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.12.23 00:03:26 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:03:26 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:03:26 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:03:26 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:03:26 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.5:443
. 2020.12.23 00:03:26 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.12.23 00:03:26 - OpenVPN > UDP link local: (not bound)
. 2020.12.23 00:03:26 - OpenVPN > UDP link remote: [AF_INET]184.75.221.5:443
. 2020.12.23 00:03:27 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.5:443, sid=476a28fd cdcd3e75
. 2020.12.23 00:03:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.23 00:03:27 - OpenVPN > VERIFY KU OK
. 2020.12.23 00:03:27 - OpenVPN > Validating certificate extended key usage
. 2020.12.23 00:03:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.23 00:03:27 - OpenVPN > VERIFY EKU OK
. 2020.12.23 00:03:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Lesath, emailAddress=info@airvpn.org
. 2020.12.23 00:03:28 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA
. 2020.12.23 00:03:28 - OpenVPN > [Lesath] Peer Connection Initiated with [AF_INET]184.75.221.5:443
. 2020.12.23 00:03:29 - OpenVPN > SENT CONTROL [Lesath]: 'PUSH_REQUEST' (status=1)
. 2020.12.23 00:03:29 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.20.250.1,dhcp-option DNS6 fde6:7a:7d20:10fa::1,tun-ipv6,route-gateway 10.20.250.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:10fa::10cc/64 fde6:7a:7d20:10fa::1,ifconfig 10.20.250.206 255.255.255.0,peer-id 6,cipher AES-256-GCM'
. 2020.12.23 00:03:29 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.12.23 00:03:29 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.23 00:03:29 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.23 00:03:29 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.23 00:03:29 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.23 00:03:29 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.23 00:03:29 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.23 00:03:29 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.23 00:03:29 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.23 00:03:29 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.12.23 00:03:29 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:03:29 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:03:29 - OpenVPN > interactive service msg_channel=0
. 2020.12.23 00:03:29 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=60:f2:62:89:2c:72
. 2020.12.23 00:03:29 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.12.23 00:03:29 - OpenVPN > GetBestInterfaceEx() returned if=7
. 2020.12.23 00:03:29 - OpenVPN > GDG6: II=7 DP=::/3 NH=fe80::8
. 2020.12.23 00:03:29 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.12.23 00:03:29 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=7
. 2020.12.23 00:03:29 - OpenVPN > open_tun
. 2020.12.23 00:03:29 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}.tap
. 2020.12.23 00:03:29 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.12.23 00:03:29 - OpenVPN > Exiting due to fatal error
! 2020.12.23 00:03:29 - Disconnecting
. 2020.12.23 00:03:29 - Connection terminated.
I 2020.12.23 00:03:32 - Checking authorization ...
! 2020.12.23 00:03:33 - Connecting to Musica (Netherlands, Alblasserdam)
. 2020.12.23 00:03:33 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.12.23 00:03:33 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.12.23 00:03:33 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.12.23 00:03:33 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:03:33 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:03:33 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:03:33 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:03:33 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.251:443
. 2020.12.23 00:03:33 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.12.23 00:03:33 - OpenVPN > UDP link local: (not bound)
. 2020.12.23 00:03:33 - OpenVPN > UDP link remote: [AF_INET]213.152.161.251:443
. 2020.12.23 00:03:33 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.251:443, sid=f2808d47 c9f8654d
. 2020.12.23 00:03:33 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.23 00:03:33 - OpenVPN > VERIFY KU OK
. 2020.12.23 00:03:33 - OpenVPN > Validating certificate extended key usage
. 2020.12.23 00:03:33 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.23 00:03:33 - OpenVPN > VERIFY EKU OK
. 2020.12.23 00:03:33 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Musica, emailAddress=info@airvpn.org
. 2020.12.23 00:03:35 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA
. 2020.12.23 00:03:35 - OpenVPN > [Musica] Peer Connection Initiated with [AF_INET]213.152.161.251:443
. 2020.12.23 00:03:36 - OpenVPN > SENT CONTROL [Musica]: 'PUSH_REQUEST' (status=1)
. 2020.12.23 00:03:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.24.186.1,dhcp-option DNS6 fde6:7a:7d20:14ba::1,tun-ipv6,route-gateway 10.24.186.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:14ba::10e0/64 fde6:7a:7d20:14ba::1,ifconfig 10.24.186.226 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2020.12.23 00:03:36 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.12.23 00:03:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.23 00:03:36 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.23 00:03:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.23 00:03:36 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.23 00:03:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.23 00:03:36 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.23 00:03:36 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.23 00:03:36 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.23 00:03:36 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.12.23 00:03:36 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:03:36 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:03:36 - OpenVPN > interactive service msg_channel=0
. 2020.12.23 00:03:36 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=60:f2:62:89:2c:72
. 2020.12.23 00:03:36 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.12.23 00:03:36 - OpenVPN > GetBestInterfaceEx() returned if=7
. 2020.12.23 00:03:36 - OpenVPN > GDG6: II=7 DP=::/3 NH=fe80::8
. 2020.12.23 00:03:36 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.12.23 00:03:36 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=7
. 2020.12.23 00:03:36 - OpenVPN > open_tun
. 2020.12.23 00:03:36 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}.tap
. 2020.12.23 00:03:36 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.12.23 00:03:36 - OpenVPN > Exiting due to fatal error
! 2020.12.23 00:03:36 - Disconnecting
. 2020.12.23 00:03:36 - Connection terminated.
I 2020.12.23 00:03:39 - Checking authorization ...
. 2020.12.23 00:05:09 - Above log line repeated 22 times more
! 2020.12.23 00:05:09 - Connecting to Sheliak (Netherlands, Alblasserdam)
. 2020.12.23 00:05:09 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.12.23 00:05:09 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.12.23 00:05:09 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.12.23 00:05:09 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:05:09 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:05:09 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:05:09 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:05:09 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.186.37:443
. 2020.12.23 00:05:09 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.12.23 00:05:09 - OpenVPN > UDP link local: (not bound)
. 2020.12.23 00:05:09 - OpenVPN > UDP link remote: [AF_INET]213.152.186.37:443
. 2020.12.23 00:05:09 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.186.37:443, sid=a6bf1964 e8561bd8
. 2020.12.23 00:05:09 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.23 00:05:09 - OpenVPN > VERIFY KU OK
. 2020.12.23 00:05:09 - OpenVPN > Validating certificate extended key usage
. 2020.12.23 00:05:09 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.23 00:05:09 - OpenVPN > VERIFY EKU OK
. 2020.12.23 00:05:09 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sheliak, emailAddress=info@airvpn.org
. 2020.12.23 00:05:11 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA
. 2020.12.23 00:05:11 - OpenVPN > [Sheliak] Peer Connection Initiated with [AF_INET]213.152.186.37:443
. 2020.12.23 00:05:12 - OpenVPN > SENT CONTROL [Sheliak]: 'PUSH_REQUEST' (status=1)
. 2020.12.23 00:05:12 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.30.58.1,dhcp-option DNS6 fde6:7a:7d20:1a3a::1,tun-ipv6,route-gateway 10.30.58.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1a3a::101c/64 fde6:7a:7d20:1a3a::1,ifconfig 10.30.58.30 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2020.12.23 00:05:12 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.12.23 00:05:12 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.23 00:05:12 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.23 00:05:12 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.23 00:05:12 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.23 00:05:12 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.23 00:05:12 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.23 00:05:12 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.23 00:05:12 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.23 00:05:12 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.12.23 00:05:12 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:05:12 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:05:12 - OpenVPN > interactive service msg_channel=0
. 2020.12.23 00:05:12 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=60:f2:62:89:2c:72
. 2020.12.23 00:05:12 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.12.23 00:05:12 - OpenVPN > GetBestInterfaceEx() returned if=7
. 2020.12.23 00:05:12 - OpenVPN > GDG6: II=7 DP=::/3 NH=fe80::8
. 2020.12.23 00:05:12 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.12.23 00:05:12 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=7
. 2020.12.23 00:05:12 - OpenVPN > open_tun
. 2020.12.23 00:05:12 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}.tap
. 2020.12.23 00:05:12 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.12.23 00:05:12 - OpenVPN > Exiting due to fatal error
! 2020.12.23 00:05:12 - Disconnecting
. 2020.12.23 00:05:12 - Connection terminated.
I 2020.12.23 00:05:15 - Checking authorization ...
. 2020.12.23 00:05:24 - Above log line repeated 2 times more
! 2020.12.23 00:05:24 - Connecting to Scuti (Netherlands, Alblasserdam)
. 2020.12.23 00:05:24 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.12.23 00:05:24 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.12.23 00:05:24 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.12.23 00:05:24 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:05:24 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:05:24 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:05:24 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:05:24 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.157:443
. 2020.12.23 00:05:24 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.12.23 00:05:24 - OpenVPN > UDP link local: (not bound)
. 2020.12.23 00:05:24 - OpenVPN > UDP link remote: [AF_INET]134.19.179.157:443
. 2020.12.23 00:05:25 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.157:443, sid=bb228ed1 944058d7
. 2020.12.23 00:05:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.23 00:05:25 - OpenVPN > VERIFY KU OK
. 2020.12.23 00:05:25 - OpenVPN > Validating certificate extended key usage
. 2020.12.23 00:05:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.23 00:05:25 - OpenVPN > VERIFY EKU OK
. 2020.12.23 00:05:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Scuti, emailAddress=info@airvpn.org
. 2020.12.23 00:05:26 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA
. 2020.12.23 00:05:26 - OpenVPN > [Scuti] Peer Connection Initiated with [AF_INET]134.19.179.157:443
. 2020.12.23 00:05:27 - OpenVPN > SENT CONTROL [Scuti]: 'PUSH_REQUEST' (status=1)
. 2020.12.23 00:05:27 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.34.122.1,dhcp-option DNS6 fde6:7a:7d20:1e7a::1,tun-ipv6,route-gateway 10.34.122.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1e7a::1087/64 fde6:7a:7d20:1e7a::1,ifconfig 10.34.122.137 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2020.12.23 00:05:27 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.12.23 00:05:27 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.23 00:05:27 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.23 00:05:27 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.23 00:05:27 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.23 00:05:27 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.23 00:05:27 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.23 00:05:27 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.23 00:05:27 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.23 00:05:27 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.12.23 00:05:27 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:05:27 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:05:27 - OpenVPN > interactive service msg_channel=0
. 2020.12.23 00:05:27 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=60:f2:62:89:2c:72
. 2020.12.23 00:05:27 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.12.23 00:05:27 - OpenVPN > GetBestInterfaceEx() returned if=7
. 2020.12.23 00:05:27 - OpenVPN > GDG6: II=7 DP=::/3 NH=fe80::8
. 2020.12.23 00:05:27 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.12.23 00:05:27 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=7
. 2020.12.23 00:05:27 - OpenVPN > open_tun
. 2020.12.23 00:05:27 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}.tap
. 2020.12.23 00:05:27 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.12.23 00:05:27 - OpenVPN > Exiting due to fatal error
! 2020.12.23 00:05:27 - Disconnecting
. 2020.12.23 00:05:27 - Connection terminated.
I 2020.12.23 00:05:30 - Checking authorization ...
! 2020.12.23 00:05:31 - Connecting to Salm (Netherlands, Alblasserdam)
. 2020.12.23 00:05:31 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.12.23 00:05:31 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.12.23 00:05:31 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.12.23 00:05:31 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:05:31 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:05:31 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:05:31 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:05:31 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.22:443
. 2020.12.23 00:05:31 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.12.23 00:05:31 - OpenVPN > UDP link local: (not bound)
. 2020.12.23 00:05:31 - OpenVPN > UDP link remote: [AF_INET]213.152.161.22:443
. 2020.12.23 00:05:32 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.22:443, sid=66118c5d be220081
. 2020.12.23 00:05:32 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.23 00:05:32 - OpenVPN > VERIFY KU OK
. 2020.12.23 00:05:32 - OpenVPN > Validating certificate extended key usage
. 2020.12.23 00:05:32 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.23 00:05:32 - OpenVPN > VERIFY EKU OK
. 2020.12.23 00:05:32 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Salm, emailAddress=info@airvpn.org
. 2020.12.23 00:05:33 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA
. 2020.12.23 00:05:33 - OpenVPN > [Salm] Peer Connection Initiated with [AF_INET]213.152.161.22:443
. 2020.12.23 00:05:34 - OpenVPN > SENT CONTROL [Salm]: 'PUSH_REQUEST' (status=1)
. 2020.12.23 00:05:34 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.29.26.1,dhcp-option DNS6 fde6:7a:7d20:191a::1,tun-ipv6,route-gateway 10.29.26.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:191a::100f/64 fde6:7a:7d20:191a::1,ifconfig 10.29.26.17 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2020.12.23 00:05:34 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.12.23 00:05:34 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.23 00:05:34 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.23 00:05:34 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.23 00:05:34 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.23 00:05:34 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.23 00:05:34 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.23 00:05:34 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.23 00:05:34 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.23 00:05:34 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.12.23 00:05:34 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:05:34 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:05:34 - OpenVPN > interactive service msg_channel=0
. 2020.12.23 00:05:34 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=60:f2:62:89:2c:72
. 2020.12.23 00:05:34 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.12.23 00:05:34 - OpenVPN > GetBestInterfaceEx() returned if=7
. 2020.12.23 00:05:34 - OpenVPN > GDG6: II=7 DP=::/3 NH=fe80::8
. 2020.12.23 00:05:34 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.12.23 00:05:34 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=7
. 2020.12.23 00:05:34 - OpenVPN > open_tun
. 2020.12.23 00:05:34 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}.tap
. 2020.12.23 00:05:34 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.12.23 00:05:34 - OpenVPN > Exiting due to fatal error
! 2020.12.23 00:05:34 - Disconnecting
. 2020.12.23 00:05:34 - Connection terminated.
I 2020.12.23 00:05:38 - Checking authorization ...
! 2020.12.23 00:05:38 - Connecting to Pyxis (Netherlands, Alblasserdam)
. 2020.12.23 00:05:39 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.12.23 00:05:39 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.12.23 00:05:39 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.12.23 00:05:39 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:05:39 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:05:39 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.12.23 00:05:39 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.12.23 00:05:39 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.236:443
. 2020.12.23 00:05:39 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.12.23 00:05:39 - OpenVPN > UDP link local: (not bound)
. 2020.12.23 00:05:39 - OpenVPN > UDP link remote: [AF_INET]213.152.161.236:443
. 2020.12.23 00:05:39 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.236:443, sid=fa14240e df175771
. 2020.12.23 00:05:39 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.12.23 00:05:39 - OpenVPN > VERIFY KU OK
. 2020.12.23 00:05:39 - OpenVPN > Validating certificate extended key usage
. 2020.12.23 00:05:39 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.12.23 00:05:39 - OpenVPN > VERIFY EKU OK
. 2020.12.23 00:05:39 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Pyxis, emailAddress=info@airvpn.org
. 2020.12.23 00:05:40 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-CHACHA20-POLY1305, 4096 bit RSA
. 2020.12.23 00:05:40 - OpenVPN > [Pyxis] Peer Connection Initiated with [AF_INET]213.152.161.236:443
. 2020.12.23 00:05:41 - OpenVPN > SENT CONTROL [Pyxis]: 'PUSH_REQUEST' (status=1)
. 2020.12.23 00:05:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.27.154.1,dhcp-option DNS6 fde6:7a:7d20:179a::1,tun-ipv6,route-gateway 10.27.154.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:179a::1053/64 fde6:7a:7d20:179a::1,ifconfig 10.27.154.85 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2020.12.23 00:05:41 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.12.23 00:05:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.12.23 00:05:41 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.12.23 00:05:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.12.23 00:05:41 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.12.23 00:05:41 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.12.23 00:05:41 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.12.23 00:05:41 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.12.23 00:05:41 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.12.23 00:05:41 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.12.23 00:05:41 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:05:41 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.12.23 00:05:41 - OpenVPN > interactive service msg_channel=0
. 2020.12.23 00:05:41 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=60:f2:62:89:2c:72
. 2020.12.23 00:05:41 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.12.23 00:05:41 - OpenVPN > GetBestInterfaceEx() returned if=7
. 2020.12.23 00:05:41 - OpenVPN > GDG6: II=7 DP=::/3 NH=fe80::8
. 2020.12.23 00:05:41 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.12.23 00:05:41 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=7
. 2020.12.23 00:05:41 - OpenVPN > open_tun
. 2020.12.23 00:05:41 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}.tap
. 2020.12.23 00:05:41 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.12.23 00:05:41 - OpenVPN > Exiting due to fatal error
! 2020.12.23 00:05:41 - Disconnecting
. 2020.12.23 00:05:41 - Connection terminated.
I 2020.12.23 00:05:44 - Checking authorization ...
. 2020.12.23 00:06:31 - Above log line repeated 11 times more
I 2020.12.23 00:06:31 - Cancel requested.
! 2020.12.23 00:06:31 - Session terminated.
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": true,
    "routes": [
            "address": "0.0.0.0\/0",
            "interface": "{7D4AECEA-CE4A-404F-BD38-06F20CA7B9D5}",
            "gateway": "192.168.1.1",
            "metric": "40"
            "address": "0.0.0.0\/1",
            "interface": "{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}",
            "gateway": "10.22.22.1",
            "metric": "25"
            "address": "10.22.22.0\/24",
            "gateway": "link",
            "metric": "281"
            "address": "10.22.22.151",
            "gateway": "link",
            "metric": "281"
            "address": "10.22.22.255",
            "gateway": "link",
            "metric": "281"
            "address": "109.202.103.170",
            "gateway": "10.9.78.1",
            "metric": "26"
            "address": "127.0.0.0\/8",
            "interface": "{D5062F58-5F9C-11E9-816A-806E6F6E6963}",
            "gateway": "link",
            "metric": "331"
            "address": "127.0.0.1",
            "gateway": "link",
            "metric": "331"
            "address": "127.255.255.255",
            "gateway": "link",
            "metric": "331"
            "address": "128.0.0.0\/1",
            "metric": "25"
            "address": "184.75.221.115",
            "gateway": "10.8.150.1",
            "metric": "26"
            "address": "192.168.1.0\/24",
            "gateway": "link",
            "metric": "296"
            "address": "192.168.1.233",
            "gateway": "link",
            "metric": "296"
            "address": "192.168.1.255",
            "gateway": "link",
            "metric": "296"
            "address": "199.249.230.7",
            "metric": "26"
            "address": "199.249.230.9",
            "metric": "40"
            "address": "199.249.230.37",
            "gateway": "10.16.118.1",
            "metric": "26"
            "address": "213.152.161.15",
            "gateway": "10.30.110.1",
            "metric": "26"
            "address": "224.0.0.0\/4",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "296"
            "address": "255.255.255.255",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "296"
            "address": "::\/3",
            "gateway": "fe80::8",
            "metric": "281"
            "address": "::1",
            "gateway": "link",
            "metric": "331"
            "address": "2000::\/4",
            "metric": "281"
            "address": "2620:7:6001:40b8:ceb4:2489:665e:d101",
            "gateway": "fde6:7a:7d20:1216::1",
            "metric": "281"
            "address": "2620:7:6001:b0ec:2f3a:a3d0:966f:e483",
            "gateway": "fde6:7a:7d20:c76::1",
            "metric": "281"
            "address": "2a00:1678:2470:7:7265:24fc:ff33:113b",
            "gateway": "fde6:7a:7d20:54e::1",
            "metric": "281"
            "address": "2a00:1678:2470:39:ddf1:680c:a9e0:377a",
            "gateway": "fde6:7a:7d20:1a6e::1",
            "metric": "281"
            "address": "3000::\/4",
            "metric": "281"
            "address": "fc00::\/7",
            "metric": "281"
            "address": "fde6:7a:7d20:1216::\/64",
            "metric": "281"
            "address": "fde6:7a:7d20:1216::1095",
            "gateway": "link",
            "metric": "281"
            "address": "fe80::\/64",
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "296"
            "address": "fe80::1c9b:2db3:99d1:4f8a",
            "gateway": "link",
            "metric": "281"
            "address": "fe80::fc06:7055:9af0:2811",
            "gateway": "link",
            "metric": "296"
            "address": "ff00::\/8",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "281"
            "gateway": "link",
            "metric": "296"
            "metric": "4294967295"
    "interfaces": [
            "friendly": "Ethernet",
            "id": "{23BD8360-BBE0-4974-A3CA-65A2ECBF7102}",
            "name": "Ethernet",
            "description": "Realtek Gaming GbE Family Controller",
            "type": "Ethernet",
            "status": "Down",
            "bytes_received": "0",
            "bytes_sent": "0",
            "ips": [
                "fe80::392c:4c6c:55b2:6481",
                "169.254.100.129"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Local Area Connection",
            "id": "{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}",
            "name": "Local Area Connection",
            "description": "TAP-Windows Adapter V9",
            "type": "53",
            "status": "Up",
            "bytes_received": "208259749900",
            "bytes_sent": "5648293784",
            "ips": [
                "10.22.22.151"
            "gateways": [
                "10.22.22.1",
                "10.9.78.1",
                "10.8.150.1",
                "10.16.118.1",
                "10.30.110.1",
                "fe80::8",
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Local Area Connection* 1",
            "id": "{875F994A-1BB2-4FC6-A553-BC377F6C3974}",
            "name": "Local Area Connection* 1",
            "description": "Microsoft Wi-Fi Direct Virtual Adapter",
            "type": "Wireless80211",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::2026:7fcd:c3da:cfc0",
                "169.254.207.192"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Local Area Connection* 2",
            "id": "{EE0CEA1E-54EE-4EC5-A447-298B9218E716}",
            "name": "Local Area Connection* 2",
            "description": "Microsoft Wi-Fi Direct Virtual Adapter #2",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::b4a1:d93:d0c6:25e6",
                "169.254.37.230"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Wi-Fi",
            "id": "{7D4AECEA-CE4A-404F-BD38-06F20CA7B9D5}",
            "name": "Wi-Fi",
            "description": "Intel(R) Wi-Fi 6 AX200 160MHz",
            "status": "Up",
            "bytes_received": "41354657",
            "bytes_sent": "2897744",
            "ips": [
                "192.168.1.233"
            "gateways": [
                "192.168.1.1"
            "bind": true,
            "dns4": "1.1.1.1,8.4.4.4",
            "dns6": null
            "friendly": "Loopback Pseudo-Interface 1",
            "id": "{D5062F58-5F9C-11E9-816A-806E6F6E6963}",
            "name": "Loopback Pseudo-Interface 1",
            "description": "Software Loopback Interface 1",
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
    "ipv4-default-gateway": "10.22.22.1",
    "ipv4-default-interface": "{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}",
    "ipv6-default-gateway": "fe80::8",
    "ipv6-default-interface": "{31F942F8-AF8F-4E99-91D1-F54DA368BCA0}"
ipconfig /all:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : LAPTOP-8R0606M8
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Realtek Gaming GbE Family Controller
   Physical Address. . . . . . . . . : E8-D8-D1-DD-C4-A3
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Unknown adapter Local Area Connection:
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-31-F9-42-F8
   IPv6 Address. . . . . . . . . . . : fde6:7a:7d20:1216::1095(Preferred)
   Link-local IPv6 Address . . . . . : fe80::1c9b:2db3:99d1:4f8a%7(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.22.22.151(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Tuesday, December 22, 2020 11:20:11 AM
   Lease Expires . . . . . . . . . . : Wednesday, December 22, 2021 11:36:51 PM
   Default Gateway . . . . . . . . . :
   DHCP Server . . . . . . . . . . . : 10.22.22.254
   DHCPv6 IAID . . . . . . . . . . . : 67174193
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-25-EF-FA-CC-E8-D8-D1-DD-C4-A3
   DNS Servers . . . . . . . . . . . : fde6:7a:7d20:1216::1
                                       10.22.22.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Wireless LAN adapter Local Area Connection* 1:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physical Address. . . . . . . . . : 60-F2-62-89-2C-73
Wireless LAN adapter Local Area Connection* 2:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
   Physical Address. . . . . . . . . : 62-F2-62-89-2C-72
Wireless LAN adapter Wi-Fi:
   Description . . . . . . . . . . . : Intel(R) Wi-Fi 6 AX200 160MHz
   Physical Address. . . . . . . . . : 60-F2-62-89-2C-72
   Link-local IPv6 Address . . . . . : fe80::fc06:7055:9af0:2811%10(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.233(Preferred)
   Lease Obtained. . . . . . . . . . : Tuesday, December 22, 2020 11:46:24 PM
   Lease Expires . . . . . . . . . . : Wednesday, December 23, 2020 11:46:24 PM
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 123794018
   DNS Servers . . . . . . . . . . . : 1.1.1.1
                                       8.4.4.4
Edited ... by OpenSourcerer
Apply LOG format to system report
The TAP adapter seems to be connected. Please reboot Windows and try again.
