xm6g6
BlueStacks not wanting to connect via VPN
Just in case you don't know, BlueStacks is an android emulator for Windows. I run BlueStacks while doing other things because they have a weekly sweepstakes and a every-two-hours sweepstakes where you can win gift codes for Google Play, Steam, Amazon, and a few others. In the last two months, before AirVPN, I've won about fifteen of the every-two-hours codes, at five dollars each at either Google Play or Steam.
Today I actually won TWO of them, one at five dollars (which I sadly missed, you only get ninety minutes to claim them and I was afk) and the other was ten dollars (the first one higher than five dollars!). Sadly, I learned this Please note, you must be logged into your Google account in order to use Play and Win and must not use a VPN while participating in it.
So I lost the money.
Is there any way to run BlueStacks and have it circumvent the VPN and connect directly to my ISP?
Currently not directly, no. But you can try your luck with one of these guides.
What? No. I'm suggesting to read especially the last guide detailing how to route only certain programs via VPN using source address routing, such as a torrent client in the first guide.
See? That's why I asked for clarification and didn't make assumptions :D
