89039sa
Network lock disables kvm networks
I'm using virt-manager and all my created networks stop working when i enable the network lock. Is there some script I could run to renable the networks with the network lock enabled?
You don't need scripts for this, just a few firewall exceptions. NetLock allows connections to AirVPN servers and, depending on the config, to/from your local network only and blocks everything else. To allow the network libvirt opens, something like this in Eddie Preferences > Routes will help:
IP/Host/Range: <the network range libvirt is configured to use>
When connected: Outside the tunnel
Notes: <some description for you, it's not processed>
