internetfunghi 1 Posted ... Hello, since four days I have extremly slow connection speed when I use the Eddie client. A reinstallation of the client was notsuccessfully. Which settings in Eddie can I do to speed up my internet connection? Annexed is an actual logfile from this evening. Best regards and thank you for your support. Eddie_20201116_192828.txt Share this post Link to post
Tech Jedi Alex 1499 Posted ... In Eddie > Logs, click the lifebelt icon and paste/upload the output here. The logs alone don't always help. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
internetfunghi 1 Posted ... (edited) Sorry, here is the log: Eddie System/Environment Report - 17.11.2020 - 16:54 UTC Eddie version: 2.18.9 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Pro OS version: Microsoft Windows NT 10.0.18363.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 TUN driver: 0901: 9.24.2; wintun: Not found OpenVPN: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) Hummingbird: () SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Users\Internet\AppData\Local\Eddie\default.profile Data path: C:\Users\Internet\AppData\Local\Eddie Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (0 args) Network Lock Active: Yes, Windows Filtering Platform Connected to VPN: Yes, Orion Detected DNS: 10.25.225.1, 192.168.2.1, fde6:7a:7d20:15e1::1 Test DNS IPv4: Ok Test DNS IPv6: Ok Test Ping IPv4: 32 ms Test Ping IPv6: 33 ms Test HTTP IPv4: Ok Test HTTP IPv6: Ok Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True connect: True netlock: True mode.protocol: SSL mode.alt: 1 openvpn.custom: mssfix 1442 openvpn.sndbuf: 524288 openvpn.rcvbuf: 524288 ---------------------------- Logs: . 2020.11.17 17:45:00 - Eddie version: 2.18.9 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319 . 2020.11.17 17:45:00 - Command line arguments (0): . 2020.11.17 17:45:03 - Profile path: C:\Users\Internet\AppData\Local\Eddie\default.profile . 2020.11.17 17:45:04 - Reading options from C:\Users\Internet\AppData\Local\Eddie\default.profile . 2020.11.17 17:45:05 - Tun Driver - 0901: 9.24.2; wintun: Not found . 2020.11.17 17:45:05 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2020.11.17 17:45:05 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2020.11.17 17:45:05 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2020.11.17 17:45:05 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe) . 2020.11.17 17:45:06 - Recovery. Unexpected crash? . 2020.11.17 17:45:06 - Routes, removed an existing route, 2a00:1678:2470:21:3b20:834:517d:4493 for gateway fde6:7a:7d20:326::1 . 2020.11.17 17:45:06 - Routes, removed an existing route, 2a00:1678:2470:52:5af7:2c86:d778:b3c9 for gateway fde6:7a:7d20:86e::1 . 2020.11.17 17:45:06 - Routes, removed an existing route, 2a00:c98:2050:a007:8933:4ee2:45c5:91a8 for gateway fde6:7a:7d20:7fe::1 . 2020.11.17 17:45:07 - Routes, added a new route, 2a00:1678:2470:4a:5908:1fce:a15f:5c5a for gateway fde6:7a:7d20:190a::1 . 2020.11.17 17:45:07 - Routes, removed an existing route, 2001:ac8:20:98:1ca5:ffb5:b4c:1214 for gateway fde6:7a:7d20:170a::1 . 2020.11.17 17:45:07 - Routes, removed an existing route, 2a00:1678:2470:41:56ef:1b83:3b7c:e518 for gateway fde6:7a:7d20:14e2::1 . 2020.11.17 17:45:07 - Routes, added a new route, 2a00:1678:2470:2:8c28:93a2:b5f1:9c28 for gateway fde6:7a:7d20:422::1 . 2020.11.17 17:45:07 - Routes, added a new route, 2a00:1678:2470:5:3568:e603:2b4d:aeb6 for gateway fde6:7a:7d20:1496::1 . 2020.11.17 17:45:08 - Routes, removed an existing route, 2a00:1678:2470:35:39b:4a1e:c70f:6535 for gateway fde6:7a:7d20:fd6::1 . 2020.11.17 17:45:08 - Routes, added a new route, 2a00:1678:2470:1212:990e:c823:fcac:44b9 for gateway fde6:7a:7d20:1cc2::1 . 2020.11.17 17:45:08 - Routes, removed an existing route, 2a00:1678:2470:bbbb:2215:4536:db1a:dc40 for gateway fde6:7a:7d20:1da2::1 . 2020.11.17 17:45:08 - Routes, added a new route, 2a00:1678:2470:1616:aeb9:c892:ad0d:ba5a for gateway fde6:7a:7d20:1ea6::1 . 2020.11.17 17:45:08 - Routes, removed an existing route, 2001:ac8:20:97:d4c3:f181:d57a:8d19 for gateway fde6:7a:7d20:1566::1 . 2020.11.17 17:45:09 - Routes, added a new route, 2a00:1678:2470:5:3568:e603:2b4d:aeb6 for gateway fde6:7a:7d20:1486::1 . 2020.11.17 17:45:09 - Routes, removed an existing route, 2a00:1678:2470:44:cf2:ef3e:d71f:3810 for gateway fde6:7a:7d20:e86::1 . 2020.11.17 17:45:09 - Routes, added a new route, 2a00:1678:2470:3a:ec14:6a76:7ec2:c48b for gateway fde6:7a:7d20:1866::1 . 2020.11.17 17:45:09 - Routes, removed an existing route, 2a00:1678:2470:51:1972:243f:617d:80c8 for gateway fde6:7a:7d20:c06::1 . 2020.11.17 17:45:09 - Routes, added a new route, 2001:ac8:38:21:2473:6fcc:942d:eb92 for gateway fde6:7a:7d20:826::1 . 2020.11.17 17:45:10 - Routes, added a new route, 2a00:1678:2470:eeee:2259:2a8b:386:4b98 for gateway fde6:7a:7d20:1e02::1 . 2020.11.17 17:45:10 - Routes, removed an existing route, 2a00:1678:2470:cccc:cfb7:46af:a9e0:df91 for gateway fde6:7a:7d20:1dc2::1 . 2020.11.17 17:45:10 - Routes, added a new route, 2a00:1678:2470:22:d8a1:dc22:34fb:d6c4 for gateway fde6:7a:7d20:362::1 ! 2020.11.17 17:45:10 - Activation of Network Lock - Windows Filtering Platform I 2020.11.17 17:45:11 - Ready . 2020.11.17 17:45:11 - Collect information about AirVPN completed I 2020.11.17 17:45:12 - Session starting. . 2020.11.17 17:45:12 - Collect information about AirVPN completed . 2020.11.17 17:45:12 - Waiting for latency tests (230 to go) . 2020.11.17 17:45:14 - Waiting for latency tests (222 to go) . 2020.11.17 17:45:15 - Waiting for latency tests (217 to go) . 2020.11.17 17:45:16 - Waiting for latency tests (216 to go) . 2020.11.17 17:45:17 - Waiting for latency tests (196 to go) . 2020.11.17 17:45:20 - Waiting for latency tests (167 to go) . 2020.11.17 17:45:24 - Waiting for latency tests (140 to go) . 2020.11.17 17:45:25 - Waiting for latency tests (101 to go) . 2020.11.17 17:45:26 - Waiting for latency tests (99 to go) . 2020.11.17 17:45:28 - Waiting for latency tests (74 to go) . 2020.11.17 17:45:31 - Waiting for latency tests (52 to go) . 2020.11.17 17:45:33 - Waiting for latency tests (50 to go) . 2020.11.17 17:45:34 - Waiting for latency tests (20 to go) . 2020.11.17 17:45:35 - Waiting for latency tests (15 to go) . 2020.11.17 17:45:37 - Waiting for latency tests (13 to go) . 2020.11.17 17:45:38 - Waiting for latency tests (8 to go) . 2020.11.17 17:45:39 - Waiting for latency tests (1 to go) I 2020.11.17 17:45:40 - Checking authorization ... ! 2020.11.17 17:45:41 - Connecting to Orion (Netherlands, Alblasserdam) . 2020.11.17 17:45:41 - Routes, added a new route, 213.152.161.240 for gateway 192.168.2.1 . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k 26 Jan 2017 . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG5[ui]: Reading configuration from file C:\Users\Internet\AppData\Local\Eddie\5ba4cc6066f609318372a20c3b9224745b9fb746a734b3d4c9339eaf3275153c.tmp.ssl . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG5[ui]: UTF-8 byte order mark detected . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG6[ui]: Initializing service [openvpn] . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG5[ui]: Configuration successful . 2020.11.17 17:45:41 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2020.11.17 17:45:41 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.11.17 17:45:41 - OpenVPN > library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2020.11.17 17:45:41 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2020.11.17 17:45:41 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2020.11.17 17:45:41 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:13082 . 2020.11.17 17:45:41 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288] . 2020.11.17 17:45:41 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:13082 [nonblock] . 2020.11.17 17:45:41 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:13082 . 2020.11.17 17:45:41 - OpenVPN > TCP_CLIENT link local: (not bound) . 2020.11.17 17:45:41 - OpenVPN > TCP_CLIENT link remote: [AF_INET]127.0.0.1:13082 . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG5[0]: Service [openvpn] accepted connection from 127.0.0.1:50366 . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG6[0]: s_connect: connecting 213.152.161.240:443 . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG5[0]: s_connect: connected 213.152.161.240:443 . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG5[0]: Service [openvpn] connected remote server from 192.168.2.105:50367 . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG6[0]: SNI: sending servername: 213.152.161.240 . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG6[0]: Peer certificate not required . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG6[0]: Certificate verification disabled . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG6[0]: Client certificate not requested . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG6[0]: TLS connected: new session negotiated . 2020.11.17 17:45:41 - SSL > 2020.11.17 17:45:41 LOG6[0]: Negotiated TLSv1.2 ciphersuite ECDHE-RSA-AES256-GCM-SHA384 (256-bit encryption) . 2020.11.17 17:45:42 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:13082, sid=07ffc12f 37d412c8 . 2020.11.17 17:45:42 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.11.17 17:45:42 - OpenVPN > VERIFY KU OK . 2020.11.17 17:45:42 - OpenVPN > Validating certificate extended key usage . 2020.11.17 17:45:42 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.11.17 17:45:42 - OpenVPN > VERIFY EKU OK . 2020.11.17 17:45:42 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org . 2020.11.17 17:45:42 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2020.11.17 17:45:42 - OpenVPN > [Orion] Peer Connection Initiated with [AF_INET]127.0.0.1:13082 . 2020.11.17 17:45:44 - OpenVPN > SENT CONTROL [Orion]: 'PUSH_REQUEST' (status=1) . 2020.11.17 17:45:44 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.25.225.1,dhcp-option DNS6 fde6:7a:7d20:15e1::1,tun-ipv6,route-gateway 10.25.225.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:15e1::1051/64 fde6:7a:7d20:15e1::1,ifconfig 10.25.225.83 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2020.11.17 17:45:44 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.11.17 17:45:44 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.11.17 17:45:44 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.11.17 17:45:44 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.11.17 17:45:44 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.11.17 17:45:44 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.11.17 17:45:44 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.11.17 17:45:44 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1627 . 2020.11.17 17:45:44 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.11.17 17:45:44 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.11.17 17:45:44 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.11.17 17:45:44 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.11.17 17:45:44 - OpenVPN > interactive service msg_channel=0 . 2020.11.17 17:45:44 - OpenVPN > ROUTE_GATEWAY 192.168.2.1/255.255.255.0 I=12 HWADDR=ac:fd:ce:03:2d:48 . 2020.11.17 17:45:44 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.11.17 17:45:44 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element nicht gefunden. (code=1168) . 2020.11.17 17:45:44 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2020.11.17 17:45:44 - OpenVPN > open_tun . 2020.11.17 17:45:44 - OpenVPN > TAP-WIN32 device [LAN-Verbindung] opened: \\.\Global\{B1CF4E6D-9641-411A-AC0D-A5297D617879}.tap . 2020.11.17 17:45:44 - OpenVPN > TAP-Windows Driver Version 9.24 . 2020.11.17 17:45:44 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.25.225.0/10.25.225.83/255.255.255.0 [SUCCEEDED] . 2020.11.17 17:45:44 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.25.225.83/255.255.255.0 on interface {B1CF4E6D-9641-411A-AC0D-A5297D617879} [DHCP-serv: 10.25.225.254, lease-time: 31536000] . 2020.11.17 17:45:44 - OpenVPN > Successful ARP Flush on interface [21] {B1CF4E6D-9641-411A-AC0D-A5297D617879} . 2020.11.17 17:45:45 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=21 fde6:7a:7d20:15e1::1051 store=active . 2020.11.17 17:45:46 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns LAN-Verbindung static fde6:7a:7d20:15e1::1 validate=no . 2020.11.17 17:45:46 - OpenVPN > add_route_ipv6(fde6:7a:7d20:15e1::/64 -> fde6:7a:7d20:15e1::1051 metric 0) dev LAN-Verbindung . 2020.11.17 17:45:46 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:15e1::/64 interface=21 fe80::8 store=active . 2020.11.17 17:45:46 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.11.17 17:45:51 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2020.11.17 17:45:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.2.1 . 2020.11.17 17:45:51 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=45 and dwForwardType=4 . 2020.11.17 17:45:51 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.11.17 17:45:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.25.225.1 . 2020.11.17 17:45:51 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.11.17 17:45:51 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.11.17 17:45:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.25.225.1 . 2020.11.17 17:45:51 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.11.17 17:45:51 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.11.17 17:45:51 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:15e1::1 metric -1) dev LAN-Verbindung . 2020.11.17 17:45:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=21 fe80::8 store=active . 2020.11.17 17:45:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.11.17 17:45:51 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:15e1::1 metric -1) dev LAN-Verbindung . 2020.11.17 17:45:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=21 fe80::8 store=active . 2020.11.17 17:45:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.11.17 17:45:51 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:15e1::1 metric -1) dev LAN-Verbindung . 2020.11.17 17:45:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=21 fe80::8 store=active . 2020.11.17 17:45:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.11.17 17:45:51 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:15e1::1 metric -1) dev LAN-Verbindung . 2020.11.17 17:45:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=21 fe80::8 store=active . 2020.11.17 17:45:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.11.17 17:45:51 - Interface LAN-Verbindung metric changed from Automatic to 3, layer IPv4 . 2020.11.17 17:45:51 - Interface LAN-Verbindung metric changed from Automatic to 3, layer IPv6 . 2020.11.17 17:45:51 - DNS leak protection with packet filtering enabled. . 2020.11.17 17:45:52 - Routes, added a new route, 213.152.161.239 for gateway 10.25.225.1 . 2020.11.17 17:45:52 - Routes, added a new route, 2a00:1678:2470:48:f42c:a766:986e:eab1 for gateway fde6:7a:7d20:15e1::1 . 2020.11.17 17:45:52 - Flushing DNS I 2020.11.17 17:45:52 - Checking route IPv4 I 2020.11.17 17:45:54 - Checking route IPv6 I 2020.11.17 17:45:59 - Checking DNS ! 2020.11.17 17:45:59 - Connected. . 2020.11.17 17:45:59 - OpenVPN > Initialization Sequence Completed . 2020.11.17 17:46:41 - SSL > 2020.11.17 17:46:41 LOG6[cron]: Executing cron jobs . 2020.11.17 17:46:41 - SSL > 2020.11.17 17:46:41 LOG6[cron]: Cron jobs completed in 0 seconds ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "interface": "{5399E84E-345C-4A2C-8A3C-35275B1869AF}", "gateway": "192.168.2.1", "metric": "50" }, { "address": "0.0.0.0\/1", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "10.25.225.1", "metric": "3" }, { "address": "127.0.0.1", "interface": "{5399E84E-345C-4A2C-8A3C-35275B1869AF}", "gateway": "192.168.2.1", "metric": "50" }, { "address": "128.0.0.0\/1", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "10.25.225.1", "metric": "3" }, { "address": "213.152.161.239", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "10.25.225.1", "metric": "4" }, { "address": "213.152.161.240", "interface": "{5399E84E-345C-4A2C-8A3C-35275B1869AF}", "gateway": "192.168.2.1", "metric": "51" }, { "address": "::\/3", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fe80::8", "metric": "259" }, { "address": "2000::\/4", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fe80::8", "metric": "259" }, { "address": "2001:ac8:38:21:2473:6fcc:942d:eb92", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:826::1", "metric": "259" }, { "address": "2a00:1678:2470:2:8c28:93a2:b5f1:9c28", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:422::1", "metric": "259" }, { "address": "2a00:1678:2470:3:7777:3622:2fe6:5066", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:1ce6::1", "metric": "259" }, { "address": "2a00:1678:2470:5:3568:e603:2b4d:aeb6", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:1496::1", "metric": "259" }, { "address": "2a00:1678:2470:5:3568:e603:2b4d:aeb6", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:1486::1", "metric": "259" }, { "address": "2a00:1678:2470:7:7265:24fc:ff33:113b", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:546::1", "metric": "259" }, { "address": "2a00:1678:2470:14:8b1f:21a6:b646:bf3d", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:a06::1", "metric": "259" }, { "address": "2a00:1678:2470:22:d8a1:dc22:34fb:d6c4", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:362::1", "metric": "259" }, { "address": "2a00:1678:2470:29:26cb:b8f1:4b1:2636", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:382::1", "metric": "259" }, { "address": "2a00:1678:2470:36:13be:ff37:bd4a:7c35", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:1a3a::1", "metric": "259" }, { "address": "2a00:1678:2470:3a:ec14:6a76:7ec2:c48b", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:1866::1", "metric": "259" }, { "address": "2a00:1678:2470:48:f42c:a766:986e:eab1", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:15e1::1", "metric": "259" }, { "address": "2a00:1678:2470:4a:5908:1fce:a15f:5c5a", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:190a::1", "metric": "259" }, { "address": "2a00:1678:2470:1212:990e:c823:fcac:44b9", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:1cc2::1", "metric": "259" }, { "address": "2a00:1678:2470:1616:aeb9:c892:ad0d:ba5a", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:1ea6::1", "metric": "259" }, { "address": "2a00:1678:2470:dddd:fda2:8371:a19e:e06d", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:1e66::1", "metric": "259" }, { "address": "2a00:1678:2470:eeee:2259:2a8b:386:4b98", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fde6:7a:7d20:1e02::1", "metric": "259" }, { "address": "3000::\/4", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fe80::8", "metric": "259" }, { "address": "fc00::\/7", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fe80::8", "metric": "259" }, { "address": "fde6:7a:7d20:15e1::\/64", "interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "gateway": "fe80::8", "metric": "259" }, { "address": "2a00:1678:2470:dddd:fda2:8371:a19e:e06d", "gateway": "fde6:7a:7d20:1e66::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:3:7777:3622:2fe6:5066", "gateway": "fde6:7a:7d20:1ce6::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:7:7265:24fc:ff33:113b", "gateway": "fde6:7a:7d20:546::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:14:8b1f:21a6:b646:bf3d", "gateway": "fde6:7a:7d20:a06::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:36:13be:ff37:bd4a:7c35", "gateway": "fde6:7a:7d20:1a3a::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:29:26cb:b8f1:4b1:2636", "gateway": "fde6:7a:7d20:382::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:4a:5908:1fce:a15f:5c5a", "gateway": "fde6:7a:7d20:190a::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:2:8c28:93a2:b5f1:9c28", "gateway": "fde6:7a:7d20:422::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:5:3568:e603:2b4d:aeb6", "gateway": "fde6:7a:7d20:1496::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:1212:990e:c823:fcac:44b9", "gateway": "fde6:7a:7d20:1cc2::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:1616:aeb9:c892:ad0d:ba5a", "gateway": "fde6:7a:7d20:1ea6::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:5:3568:e603:2b4d:aeb6", "gateway": "fde6:7a:7d20:1486::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:3a:ec14:6a76:7ec2:c48b", "gateway": "fde6:7a:7d20:1866::1", "metric": "4294967295" }, { "address": "2001:ac8:38:21:2473:6fcc:942d:eb92", "gateway": "fde6:7a:7d20:826::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:eeee:2259:2a8b:386:4b98", "gateway": "fde6:7a:7d20:1e02::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:22:d8a1:dc22:34fb:d6c4", "gateway": "fde6:7a:7d20:362::1", "metric": "4294967295" }, { "address": "2a00:1678:2470:48:f42c:a766:986e:eab1", "gateway": "fde6:7a:7d20:15e1::1", "metric": "4294967295" } ], "interfaces": [ { "friendly": "LAN-Verbindung", "id": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "name": "LAN-Verbindung", "description": "TAP-Windows Adapter V9", "type": "53", "status": "Up", "bytes_received": "19912998", "bytes_sent": "1647565", "support_ipv4": true, "support_ipv6": true, "ips": [ "fde6:7a:7d20:15e1::1051", "fe80::1141:7237:8673:cd96", "10.25.225.83" ], "gateways": [ "10.25.225.1", "fe80::8", "fde6:7a:7d20:826::1", "fde6:7a:7d20:422::1", "fde6:7a:7d20:1ce6::1", "fde6:7a:7d20:1496::1", "fde6:7a:7d20:1486::1", "fde6:7a:7d20:546::1", "fde6:7a:7d20:a06::1", "fde6:7a:7d20:362::1", "fde6:7a:7d20:382::1", "fde6:7a:7d20:1a3a::1", "fde6:7a:7d20:1866::1", "fde6:7a:7d20:15e1::1", "fde6:7a:7d20:190a::1", "fde6:7a:7d20:1cc2::1", "fde6:7a:7d20:1ea6::1", "fde6:7a:7d20:1e66::1", "fde6:7a:7d20:1e02::1" ], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Ethernet", "id": "{C9E0ABD1-C57C-4D85-9C33-F944763D6F75}", "name": "Ethernet", "description": "Realtek PCIe GbE Family Controller", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": false, "ips": [ "169.254.139.46" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "LAN-Verbindung* 4", "id": "{4B61DE9B-4B7B-4FAE-BF2F-214BA57600F4}", "name": "LAN-Verbindung* 4", "description": "Microsoft Wi-Fi Direct Virtual Adapter #3", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": false, "ips": [ "169.254.71.207" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "LAN-Verbindung* 5", "id": "{E5C5664D-FCE4-4D50-B309-54D6414B6C6D}", "name": "LAN-Verbindung* 5", "description": "Microsoft Wi-Fi Direct Virtual Adapter #4", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": false, "ips": [ "169.254.126.37" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "WLAN", "id": "{5399E84E-345C-4A2C-8A3C-35275B1869AF}", "name": "WLAN", "description": "Intel(R) Dual Band Wireless-AC 7260", "type": "Wireless80211", "status": "Up", "bytes_received": "202119870", "bytes_sent": "6608532", "support_ipv4": true, "support_ipv6": false, "ips": [ "192.168.2.105" ], "gateways": [ "192.168.2.1" ], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Bluetooth-Netzwerkverbindung", "id": "{4EC4D1E4-AFE7-4A6F-8C3B-A06020D7A538}", "name": "Bluetooth-Netzwerkverbindung", "description": "Bluetooth Device (Personal Area Network)", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": false, "ips": [ "169.254.126.230" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{F61AC79C-8A9B-11E9-8EFE-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv4-default-gateway": "10.25.225.1", "ipv4-default-interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}", "ipv6-default-gateway": "fe80::8", "ipv6-default-interface": "{B1CF4E6D-9641-411A-AC0D-A5297D617879}" } ---------------------------- ipconfig /all: Windows-IP-Konfiguration Hostname . . . . . . . . . . . . : DESKTOP-0NO2P11 Prim„res DNS-Suffix . . . . . . . : Knotentyp . . . . . . . . . . . . : Hybrid IP-Routing aktiviert . . . . . . : Nein WINS-Proxy aktiviert . . . . . . : Nein DNS-Suffixsuchliste . . . . . . . : speedport.ip Unbekannter Adapter LAN-Verbindung: Verbindungsspezifisches DNS-Suffix: Beschreibung. . . . . . . . . . . : TAP-Windows Adapter V9 Physische Adresse . . . . . . . . : 00-FF-B1-CF-4E-6D DHCP aktiviert. . . . . . . . . . : Ja Autokonfiguration aktiviert . . . : Ja IPv6-Adresse. . . . . . . . . . . : fde6:7a:7d20:15e1::1051(Bevorzugt) Verbindungslokale IPv6-Adresse . : fe80::1141:7237:8673:cd96%21(Bevorzugt) IPv4-Adresse . . . . . . . . . . : 10.25.225.83(Bevorzugt) Subnetzmaske . . . . . . . . . . : 255.255.255.0 Lease erhalten. . . . . . . . . . : Dienstag, 17. November 2020 17:45:44 Lease l„uft ab. . . . . . . . . . : Mittwoch, 17. November 2021 17:45:43 Standardgateway . . . . . . . . . : DHCP-Server . . . . . . . . . . . : 10.25.225.254 DHCPv6-IAID . . . . . . . . . . . : 234946481 DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-24-8E-80-AA-14-FE-B5-C4-13-32 DNS-Server . . . . . . . . . . . : fde6:7a:7d20:15e1::1 10.25.225.1 NetBIOS ber TCP/IP . . . . . . . : Aktiviert Ethernet-Adapter Ethernet: Medienstatus. . . . . . . . . . . : Medium getrennt Verbindungsspezifisches DNS-Suffix: speedport.ip Beschreibung. . . . . . . . . . . : Realtek PCIe GbE Family Controller Physische Adresse . . . . . . . . : 14-FE-B5-C4-13-32 DHCP aktiviert. . . . . . . . . . : Ja Autokonfiguration aktiviert . . . : Ja Drahtlos-LAN-Adapter LAN-Verbindung* 4: Medienstatus. . . . . . . . . . . : Medium getrennt Verbindungsspezifisches DNS-Suffix: Beschreibung. . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #3 Physische Adresse . . . . . . . . : AC-FD-CE-03-2D-49 DHCP aktiviert. . . . . . . . . . : Ja Autokonfiguration aktiviert . . . : Ja Drahtlos-LAN-Adapter LAN-Verbindung* 5: Medienstatus. . . . . . . . . . . : Medium getrennt Verbindungsspezifisches DNS-Suffix: Beschreibung. . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4 Physische Adresse . . . . . . . . : AE-FD-CE-03-2D-48 DHCP aktiviert. . . . . . . . . . : Ja Autokonfiguration aktiviert . . . : Ja Drahtlos-LAN-Adapter WLAN: Verbindungsspezifisches DNS-Suffix: speedport.ip Beschreibung. . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 7260 Physische Adresse . . . . . . . . : AC-FD-CE-03-2D-48 DHCP aktiviert. . . . . . . . . . : Ja Autokonfiguration aktiviert . . . : Ja IPv4-Adresse . . . . . . . . . . : 192.168.2.105(Bevorzugt) Subnetzmaske . . . . . . . . . . : 255.255.255.0 Lease erhalten. . . . . . . . . . : Dienstag, 17. November 2020 17:27:37 Lease l„uft ab. . . . . . . . . . : Dienstag, 8. Dezember 2020 17:27:40 Standardgateway . . . . . . . . . : 192.168.2.1 DHCP-Server . . . . . . . . . . . : 192.168.2.1 DNS-Server . . . . . . . . . . . : 192.168.2.1 NetBIOS ber TCP/IP . . . . . . . : Aktiviert Ethernet-Adapter Bluetooth-Netzwerkverbindung: Medienstatus. . . . . . . . . . . : Medium getrennt Verbindungsspezifisches DNS-Suffix: Beschreibung. . . . . . . . . . . : Bluetooth Device (Personal Area Network) Physische Adresse . . . . . . . . : AC-FD-CE-03-2D-4C DHCP aktiviert. . . . . . . . . . : Ja Autokonfiguration aktiviert . . . : Ja Edited ... by OpenSourcerer Apply LOG format to logs Share this post Link to post
Tech Jedi Alex 1499 Posted ... Hm. Is there a particular reason you're using mssfix in this context? This in connection with SSL is a possible source of error. Try resetting protocol to automatic and not using mssfix at all. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
internetfunghi 1 Posted ... Hi, I found the cause of the speedproblem. It was the Wireless AC 7260 driver after the last Windows 10 update. Here is what I did to solve the problem: 1. Deinstallation of Eddie. 2. Deinstallation of the current driver and deactivation of the Wlan Adapter. 3. Restart of Windows. Windows installs the driver version 17.15.0.5. Don't update it to the newest Intel driver!!! 4. Reinstallation of Eddie No Speed and connection problems after login with Eddie. Hope this is helpful. BR 1 Tech Jedi Alex reacted to this Share this post Link to post
