Not connected, Your IP: 216.73.216.141
atoir
Big Bandwidth difference between tun0 and eth0 without network lock
Using a bittorrent client I see on the Overview tab in Eddie that the bandwidth isn't the same by a large amount without network lock.
With network lock, it's ok.
You can see the screenshot attached.
Does it means that without network lock a part of my traffic doesn't go throught the VPN ?
I've gone to ipleak.net and there, everything is normal with or without network lock...
am I missing something ?
Thanks !
I don't now....
But is it normal that I have to route for 0.0.0.0 ?
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         10.30.251.1     128.0.0.0       UG    0      0        0 tun0
0.0.0.0         192.168.0.1     0.0.0.0         UG    100    0        0 eth0
5 hours ago, atoir said:
I don't now....
I assume no. So in qBittorrent settings > Advanced, set Bind to interface to tun0.
And a route with a destination and mask of 0.0.0.0 denotes a default gateway entry. It's essential to have that, otherwise nothing would be able to connect anywhere.
