Woffel
Eddie doesn't work anymore after changing provider
Hello and good evening!
I have been an Airvpn customer for over 3 years and used to use Eddie with Windows 7 without any problems. After changing the provider from Telekom to DNS.NET (FTTH from Berlin, Germany) Eddie no longer works. The connection to the servers is handled and connected downstream. Always negative.
The Fritzbox 7530 is used as a router. Laptop is in the DMZ, no firewall works.
The provider does not block ports on request.
IPv6 is not attempted. And I think that is where the problem lies.
I am very important about any help!
Attached is the log.
Thanks, Frank
Eddie System/Environment Report - 30.10.2020 - 20:27 UTC
Eddie version: 2.18.9
Eddie OS build: windows_x64
Eddie architecture: x64
OS type: Windows
OS name: Windows 7 Professional
OS version: Microsoft Windows NT 6.1.7601 Service Pack 1
OS architecture: x64
Mono /.Net Framework: v4.0.30319
TUN driver: 0901: 9.24.5; wintun: 0.8
OpenVPN: 2.4.8 - OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
Hummingbird:  ()
SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe)
Profile path: C:\Users\PaPa\AppData\Local\Eddie\default.profile
Data path: C:\Users\PaPa\AppData\Local\Eddie
Application path: C:\Program Files\AirVPN
Executable path: C:\Program Files\AirVPN\Eddie-UI.exe
Command line arguments: (1 args) path="home"
Network Lock Active: No
Connected to VPN: No
Detected DNS: 192.168.1.1
Test DNS IPv4: Ok
Test DNS IPv6: Ok
Test Ping IPv4: 27 ms
Test Ping IPv6: 26 ms
Test HTTP IPv4: Ok
Test HTTP IPv6: Ok
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
Logs:
. 2020.10.30 21:15:28 - Eddie version: 2.18.9 / windows_x64, System: Windows, Name: Windows 7 Professional, Version: Microsoft Windows NT 6.1.7601 Service Pack 1, Mono/.Net: v4.0.30319
. 2020.10.30 21:15:28 - Command line arguments (1): path="home"
. 2020.10.30 21:15:29 - Profile path: C:\Users\PaPa\AppData\Local\Eddie\default.profile
. 2020.10.30 21:15:29 - Profile options not found, using defaults.
. 2020.10.30 21:15:30 - Tun Driver - 0901: 9.24.5; wintun: 0.8
. 2020.10.30 21:15:30 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2020.10.30 21:15:30 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2020.10.30 21:15:30 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2020.10.30 21:15:30 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe)
I 2020.10.30 21:15:31 - Ready
. 2020.10.30 21:15:32 - Collect information about AirVPN completed
I 2020.10.30 21:15:48 - Checking login ...
! 2020.10.30 21:15:48 - Logged in.
I 2020.10.30 21:15:51 - Session starting.
. 2020.10.30 21:15:51 - Waiting for latency tests (140 to go)
. 2020.10.30 21:15:53 - Waiting for latency tests (115 to go)
. 2020.10.30 21:15:54 - Waiting for latency tests (83 to go)
. 2020.10.30 21:15:55 - Waiting for latency tests (45 to go)
. 2020.10.30 21:15:56 - Waiting for latency tests (43 to go)
. 2020.10.30 21:15:59 - Waiting for latency tests (15 to go)
I 2020.10.30 21:16:00 - Checking authorization ...
! 2020.10.30 21:16:00 - Connecting to Mirach (Netherlands, Alblasserdam)
. 2020.10.30 21:16:01 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.10.30 21:16:01 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2020.10.30 21:16:01 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.10.30 21:16:01 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.10.30 21:16:01 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.10.30 21:16:01 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.10.30 21:16:01 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.10.30 21:16:01 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.71:443
. 2020.10.30 21:16:01 - OpenVPN > Socket Buffers: R=[8192->262144] S=[64512->262144]
. 2020.10.30 21:16:01 - OpenVPN > UDP link local: (not bound)
. 2020.10.30 21:16:01 - OpenVPN > UDP link remote: [AF_INET]213.152.162.71:443
. 2020.10.30 21:16:01 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.71:443, sid=3e0749c2 05face0a
. 2020.10.30 21:16:01 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.10.30 21:16:01 - OpenVPN > VERIFY KU OK
. 2020.10.30 21:16:01 - OpenVPN > Validating certificate extended key usage
. 2020.10.30 21:16:01 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.10.30 21:16:01 - OpenVPN > VERIFY EKU OK
. 2020.10.30 21:16:01 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Mirach, emailAddress=info@airvpn.org
. 2020.10.30 21:16:01 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.10.30 21:16:01 - OpenVPN > [Mirach] Peer Connection Initiated with [AF_INET]213.152.162.71:443
. 2020.10.30 21:16:02 - OpenVPN > SENT CONTROL [Mirach]: 'PUSH_REQUEST' (status=1)
. 2020.10.30 21:16:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.24.38.1,dhcp-option DNS6 fde6:7a:7d20:1426::1,tun-ipv6,route-gateway 10.24.38.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1426::1067/64 fde6:7a:7d20:1426::1,ifconfig 10.24.38.105 255.255.255.0,peer-id 4,cipher AES-256-GCM'
. 2020.10.30 21:16:02 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.10.30 21:16:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.10.30 21:16:02 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.10.30 21:16:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.10.30 21:16:02 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.10.30 21:16:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.10.30 21:16:02 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.10.30 21:16:02 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.10.30 21:16:02 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.10.30 21:16:02 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.10.30 21:16:02 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.10.30 21:16:02 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.10.30 21:16:02 - OpenVPN > interactive service msg_channel=0
. 2020.10.30 21:16:02 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=14 HWADDR=0c:8b:fd:d5:8d:33
. 2020.10.30 21:16:02 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.10.30 21:16:02 - OpenVPN > GetBestInterfaceEx() returned if=14
. 2020.10.30 21:16:02 - OpenVPN > GDG6: II=14 DP=::/0 NH=fe80::2e3a:fdff:fec3:8ddf
. 2020.10.30 21:16:02 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.10.30 21:16:02 - OpenVPN > ROUTE6_GATEWAY fe80::2e3a:fdff:fec3:8ddf I=14
. 2020.10.30 21:16:02 - OpenVPN > open_tun
. 2020.10.30 21:16:03 - OpenVPN > TAP-WIN32 device [OpenVPN TAP-Windows6] opened: \\.\Global\{41BF0F28-FD17-4524-8F1D-F3A76FFC5C0B}.tap
. 2020.10.30 21:16:03 - OpenVPN > TAP-Windows Driver Version 9.24
. 2020.10.30 21:16:03 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.24.38.0/10.24.38.105/255.255.255.0 [SUCCEEDED]
. 2020.10.30 21:16:03 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.24.38.105/255.255.255.0 on interface {41BF0F28-FD17-4524-8F1D-F3A76FFC5C0B} [DHCP-serv: 10.24.38.254, lease-time: 31536000]
. 2020.10.30 21:16:03 - OpenVPN > Successful ARP Flush on interface [24] {41BF0F28-FD17-4524-8F1D-F3A76FFC5C0B}
. 2020.10.30 21:16:03 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=24 fde6:7a:7d20:1426::1067 store=active
. 2020.10.30 21:16:05 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns OpenVPN TAP-Windows6 static fde6:7a:7d20:1426::1 validate=no
. 2020.10.30 21:16:05 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1426::/64 -> fde6:7a:7d20:1426::1067 metric 0) dev OpenVPN TAP-Windows6
. 2020.10.30 21:16:05 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1426::/64 interface=24 fe80::8 store=active
. 2020.10.30 21:16:05 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.10.30 21:16:11 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2020.10.30 21:16:11 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.71 MASK 255.255.255.255 192.168.1.1
. 2020.10.30 21:16:11 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2020.10.30 21:16:11 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2020.10.30 21:16:11 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.24.38.1
. 2020.10.30 21:16:11 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2020.10.30 21:16:11 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.24.38.1
. 2020.10.30 21:16:11 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1426::1 metric -1) dev OpenVPN TAP-Windows6
. 2020.10.30 21:16:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=24 fe80::8 store=active
. 2020.10.30 21:16:11 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.10.30 21:16:11 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1426::1 metric -1) dev OpenVPN TAP-Windows6
. 2020.10.30 21:16:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=24 fe80::8 store=active
. 2020.10.30 21:16:11 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1426::1 metric -1) dev OpenVPN TAP-Windows6
. 2020.10.30 21:16:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=24 fe80::8 store=active
. 2020.10.30 21:16:11 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1426::1 metric -1) dev OpenVPN TAP-Windows6
. 2020.10.30 21:16:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=24 fe80::8 store=active
. 2020.10.30 21:16:11 - Interface OpenVPN TAP-Windows6 metric changed from Automatic to 3, layer IPv4
. 2020.10.30 21:16:11 - Interface OpenVPN TAP-Windows6 metric changed from Automatic to 3, layer IPv6
. 2020.10.30 21:16:11 - DNS leak protection with packet filtering enabled.
. 2020.10.30 21:16:12 - Routes, added a new route, 213.152.162.69 for gateway 10.24.38.1
. 2020.10.30 21:16:12 - Routes, added a new route, 2a00:1678:2470:27:719f:6202:5933:2cf for gateway fde6:7a:7d20:1426::1
. 2020.10.30 21:16:12 - Flushing DNS
I 2020.10.30 21:16:12 - Checking route IPv4
. 2020.10.30 21:16:32 - curl: (28) Operation timed out after 20008 milliseconds with 0 out of 0 bytes received
. 2020.10.30 21:16:32 - Checking route (2° try)
. 2020.10.30 21:16:53 - curl: (28) Operation timed out after 20009 milliseconds with 0 out of 0 bytes received
. 2020.10.30 21:16:53 - Checking route (3° try)
. 2020.10.30 21:17:15 - curl: (28) Operation timed out after 20003 milliseconds with 0 out of 0 bytes received
E 2020.10.30 21:17:15 - Checking route IPv4 failed.
. 2020.10.30 21:17:15 - OpenVPN > Initialization Sequence Completed
! 2020.10.30 21:17:15 - Disconnecting
. 2020.10.30 21:17:15 - Routes, removed a route previously added, 213.152.162.69 for gateway 10.24.38.1
. 2020.10.30 21:17:16 - Routes, removed a route previously added, 2a00:1678:2470:27:719f:6202:5933:2cf for gateway fde6:7a:7d20:1426::1
. 2020.10.30 21:17:16 - Sending soft termination signal
. 2020.10.30 21:17:19 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.10.30 21:17:23 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.162.71 MASK 255.255.255.255 192.168.1.1
. 2020.10.30 21:17:23 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2020.10.30 21:17:23 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.24.38.1
. 2020.10.30 21:17:23 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.24.38.1
. 2020.10.30 21:17:23 - OpenVPN > delete_route_ipv6(::/3)
. 2020.10.30 21:17:23 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=24 fe80::8 store=active
. 2020.10.30 21:17:23 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.10.30 21:17:23 - OpenVPN > delete_route_ipv6(2000::/4)
. 2020.10.30 21:17:23 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=24 fe80::8 store=active
. 2020.10.30 21:17:23 - OpenVPN > delete_route_ipv6(3000::/4)
. 2020.10.30 21:17:23 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=24 fe80::8 store=active
. 2020.10.30 21:17:23 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2020.10.30 21:17:23 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=24 fe80::8 store=active
. 2020.10.30 21:17:23 - OpenVPN > Closing TUN/TAP interface
. 2020.10.30 21:17:23 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1426::/64)
. 2020.10.30 21:17:23 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1426::/64 interface=24 fe80::8 store=active
. 2020.10.30 21:17:24 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address OpenVPN TAP-Windows6 fde6:7a:7d20:1426::1067 store=active
. 2020.10.30 21:17:25 - Sending hard termination signal
. 2020.10.30 21:17:25 - Connection terminated.
. 2020.10.30 21:17:25 - DNS leak protection with packet filtering disabled.
. 2020.10.30 21:17:25 - Interface OpenVPN TAP-Windows6 metric restored from 3 to Automatic, layer IPv4
. 2020.10.30 21:17:25 - Interface OpenVPN TAP-Windows6 metric restored from 3 to Automatic, layer IPv6
I 2020.10.30 21:17:29 - Checking authorization ...
! 2020.10.30 21:17:29 - Connecting to Tarazed (Netherlands, Alblasserdam)
. 2020.10.30 21:17:29 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.10.30 21:17:29 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2020.10.30 21:17:29 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.10.30 21:17:29 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.10.30 21:17:29 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.10.30 21:17:29 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.10.30 21:17:29 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.10.30 21:17:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.135:443
. 2020.10.30 21:17:29 - OpenVPN > Socket Buffers: R=[8192->262144] S=[64512->262144]
. 2020.10.30 21:17:29 - OpenVPN > UDP link local: (not bound)
. 2020.10.30 21:17:29 - OpenVPN > UDP link remote: [AF_INET]213.152.161.135:443
. 2020.10.30 21:17:29 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.135:443, sid=f876370d 3e7b3fd7
. 2020.10.30 21:17:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.10.30 21:17:30 - OpenVPN > VERIFY KU OK
. 2020.10.30 21:17:30 - OpenVPN > Validating certificate extended key usage
. 2020.10.30 21:17:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.10.30 21:17:30 - OpenVPN > VERIFY EKU OK
. 2020.10.30 21:17:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tarazed, emailAddress=info@airvpn.org
. 2020.10.30 21:17:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.10.30 21:17:30 - OpenVPN > [Tarazed] Peer Connection Initiated with [AF_INET]213.152.161.135:443
. 2020.10.30 21:17:31 - OpenVPN > SENT CONTROL [Tarazed]: 'PUSH_REQUEST' (status=1)
. 2020.10.30 21:17:32 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.31.38.1,dhcp-option DNS6 fde6:7a:7d20:1b26::1,tun-ipv6,route-gateway 10.31.38.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1b26::10b0/64 fde6:7a:7d20:1b26::1,ifconfig 10.31.38.178 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2020.10.30 21:17:32 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.10.30 21:17:32 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.10.30 21:17:32 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.10.30 21:17:32 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.10.30 21:17:32 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.10.30 21:17:32 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.10.30 21:17:32 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.10.30 21:17:32 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.10.30 21:17:32 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.10.30 21:17:32 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.10.30 21:17:32 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.10.30 21:17:32 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.10.30 21:17:32 - OpenVPN > interactive service msg_channel=0
. 2020.10.30 21:17:32 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=14 HWADDR=0c:8b:fd:d5:8d:33
. 2020.10.30 21:17:32 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.10.30 21:17:32 - OpenVPN > GetBestInterfaceEx() returned if=14
. 2020.10.30 21:17:32 - OpenVPN > GDG6: II=14 DP=::/0 NH=fe80::2e3a:fdff:fec3:8ddf
. 2020.10.30 21:17:32 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.10.30 21:17:32 - OpenVPN > ROUTE6_GATEWAY fe80::2e3a:fdff:fec3:8ddf I=14
. 2020.10.30 21:17:32 - OpenVPN > open_tun
. 2020.10.30 21:17:32 - OpenVPN > TAP-WIN32 device [OpenVPN TAP-Windows6] opened: \\.\Global\{41BF0F28-FD17-4524-8F1D-F3A76FFC5C0B}.tap
. 2020.10.30 21:17:32 - OpenVPN > TAP-Windows Driver Version 9.24
. 2020.10.30 21:17:32 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.31.38.0/10.31.38.178/255.255.255.0 [SUCCEEDED]
. 2020.10.30 21:17:32 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.31.38.178/255.255.255.0 on interface {41BF0F28-FD17-4524-8F1D-F3A76FFC5C0B} [DHCP-serv: 10.31.38.254, lease-time: 31536000]
. 2020.10.30 21:17:32 - OpenVPN > Successful ARP Flush on interface [24] {41BF0F28-FD17-4524-8F1D-F3A76FFC5C0B}
. 2020.10.30 21:17:33 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=24 fde6:7a:7d20:1b26::10b0 store=active
. 2020.10.30 21:17:34 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns OpenVPN TAP-Windows6 static fde6:7a:7d20:1b26::1 validate=no
. 2020.10.30 21:17:34 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1b26::/64 -> fde6:7a:7d20:1b26::10b0 metric 0) dev OpenVPN TAP-Windows6
. 2020.10.30 21:17:34 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1b26::/64 interface=24 fe80::8 store=active
. 2020.10.30 21:17:34 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.10.30 21:17:39 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2020.10.30 21:17:39 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.135 MASK 255.255.255.255 192.168.1.1
. 2020.10.30 21:17:39 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2020.10.30 21:17:39 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2020.10.30 21:17:39 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.31.38.1
. 2020.10.30 21:17:39 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2020.10.30 21:17:39 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.31.38.1
. 2020.10.30 21:17:39 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1b26::1 metric -1) dev OpenVPN TAP-Windows6
. 2020.10.30 21:17:39 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=24 fe80::8 store=active
. 2020.10.30 21:17:39 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.10.30 21:17:39 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1b26::1 metric -1) dev OpenVPN TAP-Windows6
. 2020.10.30 21:17:39 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=24 fe80::8 store=active
. 2020.10.30 21:17:39 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1b26::1 metric -1) dev OpenVPN TAP-Windows6
. 2020.10.30 21:17:39 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=24 fe80::8 store=active
. 2020.10.30 21:17:39 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1b26::1 metric -1) dev OpenVPN TAP-Windows6
. 2020.10.30 21:17:39 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=24 fe80::8 store=active
. 2020.10.30 21:17:39 - Interface OpenVPN TAP-Windows6 metric changed from Automatic to 3, layer IPv4
. 2020.10.30 21:17:39 - Interface OpenVPN TAP-Windows6 metric changed from Automatic to 3, layer IPv6
. 2020.10.30 21:17:39 - DNS leak protection with packet filtering enabled.
. 2020.10.30 21:17:40 - Routes, added a new route, 213.152.161.133 for gateway 10.31.38.1
. 2020.10.30 21:17:40 - Routes, added a new route, 2a00:1678:2470:4:6cea:a07e:e6f3:db56 for gateway fde6:7a:7d20:1b26::1
. 2020.10.30 21:17:40 - Flushing DNS
I 2020.10.30 21:17:40 - Checking route IPv4
. 2020.10.30 21:18:00 - curl: (28) Operation timed out after 20005 milliseconds with 0 out of 0 bytes received
. 2020.10.30 21:18:00 - Checking route (2° try)
. 2020.10.30 21:18:21 - curl: (28) Operation timed out after 20004 milliseconds with 0 out of 0 bytes received
. 2020.10.30 21:18:21 - OpenVPN > Initialization Sequence Completed
! 2020.10.30 21:18:21 - Disconnecting
. 2020.10.30 21:18:21 - Routes, removed a route previously added, 213.152.161.133 for gateway 10.31.38.1
. 2020.10.30 21:18:22 - Routes, removed a route previously added, 2a00:1678:2470:4:6cea:a07e:e6f3:db56 for gateway fde6:7a:7d20:1b26::1
. 2020.10.30 21:18:22 - Sending soft termination signal
. 2020.10.30 21:18:25 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.10.30 21:18:28 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.135 MASK 255.255.255.255 192.168.1.1
. 2020.10.30 21:18:28 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2020.10.30 21:18:28 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.31.38.1
. 2020.10.30 21:18:28 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.31.38.1
. 2020.10.30 21:18:28 - OpenVPN > delete_route_ipv6(::/3)
. 2020.10.30 21:18:28 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=24 fe80::8 store=active
. 2020.10.30 21:18:28 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.10.30 21:18:28 - OpenVPN > delete_route_ipv6(2000::/4)
. 2020.10.30 21:18:28 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=24 fe80::8 store=active
. 2020.10.30 21:18:28 - OpenVPN > delete_route_ipv6(3000::/4)
. 2020.10.30 21:18:28 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=24 fe80::8 store=active
. 2020.10.30 21:18:28 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2020.10.30 21:18:28 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=24 fe80::8 store=active
. 2020.10.30 21:18:28 - OpenVPN > Closing TUN/TAP interface
. 2020.10.30 21:18:28 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1b26::/64)
. 2020.10.30 21:18:28 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1b26::/64 interface=24 fe80::8 store=active
. 2020.10.30 21:18:29 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address OpenVPN TAP-Windows6 fde6:7a:7d20:1b26::10b0 store=active
. 2020.10.30 21:18:31 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns OpenVPN TAP-Windows6 all
. 2020.10.30 21:18:31 - OpenVPN > TAP: DHCP address released
. 2020.10.30 21:18:31 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2020.10.30 21:18:31 - Connection terminated.
. 2020.10.30 21:18:31 - DNS leak protection with packet filtering disabled.
. 2020.10.30 21:18:31 - Interface OpenVPN TAP-Windows6 metric restored from 3 to Automatic, layer IPv4
. 2020.10.30 21:18:31 - Interface OpenVPN TAP-Windows6 metric restored from 3 to Automatic, layer IPv6
I 2020.10.30 21:18:31 - Cancel requested.
! 2020.10.30 21:18:31 - Session terminated.
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": true,
    "routes": [
            "address": "0.0.0.0\/0",
            "interface": "{77EBD527-E835-4300-8D08-86EC4E9773C3}",
            "gateway": "192.168.1.1",
            "metric": "10"
            "address": "::\/0",
            "gateway": "fe80::2e3a:fdff:fec3:8ddf",
            "metric": "266"
            "address": "2002:d456:3bb3::\/56",
            "metric": "266"
            "address": "2a00:1678:2470:45:bdb5:db2e:a1d3:520f",
            "gateway": "fde6:7a:7d20:c32::1",
            "metric": "4294967295"
            "address": "2a00:1678:2470:51:1972:243f:617d:80c8",
            "gateway": "fde6:7a:7d20:c12::1",
            "address": "2a00:1678:2470:39:ddf1:680c:a9e0:377a",
            "gateway": "fde6:7a:7d20:1a72::1",
            "address": "2a00:1678:2470:2a:4b7c:f79c:87e:8029",
            "gateway": "fde6:7a:7d20:db6::1",
    "interfaces": [
            "friendly": "OpenVPN TAP-Windows6",
            "id": "{41BF0F28-FD17-4524-8F1D-F3A76FFC5C0B}",
            "name": "OpenVPN TAP-Windows6",
            "description": "TAP-Windows Adapter V9",
            "type": "53",
            "status": "Down",
            "bytes_received": "30029",
            "bytes_sent": "184767",
            "ips": [
                "fe80::101c:6286:eed7:c6ed",
                "169.254.198.237"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "OpenVPN Wintun",
            "id": "{7EFD7523-27F9-4812-BE04-9E6A79B18EA6}",
            "name": "OpenVPN Wintun",
            "description": "Wintun Userspace Tunnel",
            "type": "53",
            "status": "Down",
            "bytes_received": "0",
            "bytes_sent": "0",
            "ips": [
                "fe80::75d5:23e3:69dc:b7e4",
                "169.254.183.228"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Drahtlosnetzwerkverbindung",
            "id": "{77EBD527-E835-4300-8D08-86EC4E9773C3}",
            "name": "Drahtlosnetzwerkverbindung",
            "description": "Intel(R) Dual Band Wireless-AC 7260",
            "type": "Wireless80211",
            "status": "Up",
            "bytes_received": "7072175",
            "bytes_sent": "2442895",
            "ips": [
                "2002:d456:3bb3:0:408b:e400:2ecd:8fc6",
                "2002:d456:3bb3:0:adc8:44ad:6fee:3f1d",
                "fe80::408b:e400:2ecd:8fc6",
                "192.168.1.30"
            "gateways": [
                "192.168.1.1",
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "LAN-Verbindung",
            "id": "{8BCFECB9-051A-4B2A-A82C-CE5C0B23D055}",
            "name": "LAN-Verbindung",
            "description": "Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.20)",
            "type": "Ethernet",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::51bc:a109:d24:a2ef",
                "169.254.162.239"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Loopback Pseudo-Interface 1",
            "id": "{846EE342-7039-11DE-9D20-806E6F6E6963}",
            "name": "Loopback Pseudo-Interface 1",
            "description": "Software Loopback Interface 1",
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "isatap.fritz.box",
            "id": "{63903EE7-526A-44EE-BA05-657FE05476D7}",
            "name": "isatap.fritz.box",
            "description": "Microsoft-ISATAP-Adapter",
            "type": "Tunnel",
            "status": "Down",
            "bytes_sent": "0",
            "support_ipv4": false,
            "ips": [
                "fe80::5efe:192.168.1.30"
            "gateways": [],
            "bind": true,
            "dns4": null,
            "dns6": null
            "friendly": "isatap.{41BF0F28-FD17-4524-8F1D-F3A76FFC5C0B}",
            "id": "{1BC38B9F-5123-494B-984B-71AFA60E7861}",
            "name": "isatap.{41BF0F28-FD17-4524-8F1D-F3A76FFC5C0B}",
            "description": "Microsoft-ISATAP-Adapter #2",
            "type": "Tunnel",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [],
            "gateways": [],
            "bind": false,
            "dns4": null,
            "dns6": null
            "friendly": "Teredo Tunneling Pseudo-Interface",
            "id": "{3A2C005F-5CB0-49A7-8FFB-22435B6AD4DE}",
            "name": "Teredo Tunneling Pseudo-Interface",
            "description": "Teredo Tunneling Pseudo-Interface",
            "type": "Tunnel",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::100:7f:fffe"
            "gateways": [],
            "bind": true,
            "dns4": null,
            "dns6": null
    "ipv4-default-gateway": "192.168.1.1",
    "ipv4-default-interface": "{77EBD527-E835-4300-8D08-86EC4E9773C3}",
    "ipv6-default-gateway": "fe80::2e3a:fdff:fec3:8ddf",
    "ipv6-default-interface": "{77EBD527-E835-4300-8D08-86EC4E9773C3}"
ipconfig /all:
Windows-IP-Konfiguration
   Hostname  . . . . . . . . . . . . : PaPa-Medion
   Prim„res DNS-Suffix . . . . . . . :
   Knotentyp . . . . . . . . . . . . : Hybrid
   IP-Routing aktiviert  . . . . . . : Nein
   WINS-Proxy aktiviert  . . . . . . : Nein
   DNS-Suffixsuchliste . . . . . . . : fritz.box
Unbekannter Adapter OpenVPN TAP-Windows6:
   Medienstatus. . . . . . . . . . . : Medium getrennt
   Verbindungsspezifisches DNS-Suffix:
   Beschreibung. . . . . . . . . . . : TAP-Windows Adapter V9
   Physikalische Adresse . . . . . . : 00-FF-41-BF-0F-28
   DHCP aktiviert. . . . . . . . . . : Ja
   Autokonfiguration aktiviert . . . : Ja
Unbekannter Adapter OpenVPN Wintun:
   Beschreibung. . . . . . . . . . . : Wintun Userspace Tunnel
   DHCP aktiviert. . . . . . . . . . : Nein
Drahtlos-LAN-Adapter Drahtlosnetzwerkverbindung:
   Verbindungsspezifisches DNS-Suffix: fritz.box
   Beschreibung. . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 7260
   Physikalische Adresse . . . . . . : 0C-8B-FD-D5-8D-33
   IPv6-Adresse. . . . . . . . . . . : 2002:d456:3bb3:0:408b:e400:2ecd:8fc6(Bevorzugt)
   Tempor„re IPv6-Adresse. . . . . . : 2002:d456:3bb3:0:adc8:44ad:6fee:3f1d(Bevorzugt)
   Verbindungslokale IPv6-Adresse  . : fe80::408b:e400:2ecd:8fc6%14(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 192.168.1.30(Bevorzugt)
   Subnetzmaske  . . . . . . . . . . : 255.255.255.0
   Lease erhalten. . . . . . . . . . : Freitag, 30. Oktober 2020 21:09:00
   Lease l„uft ab. . . . . . . . . . : Montag, 9. November 2020 21:08:59
   Standardgateway . . . . . . . . . : fe80::2e3a:fdff:fec3:8ddf%14
                                       192.168.1.1
   DHCP-Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6-IAID . . . . . . . . . . . : 453807101
   DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-1D-D6-A5-18-E8-40-F2-1A-85-DC
   DNS-Server  . . . . . . . . . . . : 192.168.1.1
   NetBIOS ber TCP/IP . . . . . . . : Aktiviert
Ethernet-Adapter LAN-Verbindung:
   Beschreibung. . . . . . . . . . . : Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.20)
   Physikalische Adresse . . . . . . : E8-40-F2-1A-85-DC
Tunneladapter isatap.fritz.box:
   Beschreibung. . . . . . . . . . . : Microsoft-ISATAP-Adapter
   Physikalische Adresse . . . . . . : 00-00-00-00-00-00-00-E0
Tunneladapter isatap.{41BF0F28-FD17-4524-8F1D-F3A76FFC5C0B}:
   Beschreibung. . . . . . . . . . . : Microsoft-ISATAP-Adapter #2
Tunneladapter Teredo Tunneling Pseudo-Interface:
   Beschreibung. . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
The problem is with your Tap-adapter. Disable/Uninstall the one you have and install a new one or let Eddie install a new one.
On Fritzbox dilemma...Mr. giganerd may be able to help you out.
Thanks.
ok , first I will reinstall the TAP driver.
2nd waiting for mr. giganerd from germany. fellow-countryman hehe
It's 3:00 AM here, so I'm going to assume I'm dreaming. Dreaming that someone on the forums wrote there is actually FTTH in a German city. When I wake up, it won't be there. You will see. I… I just… need to go to bed… that's all… you will see. 🤪
Oh no. It was not a dream.
Anyway, the probability of the problem being the Fritz!Box is low. Follow Mr. Flx's steps and see if it solves this. :)
You've also got wintun installed, but no OpenVPN/Eddie version capable of using it. You could try the wintun adapter, maybe that helps.
Thank you for the answers. I uninstalled the TAP driver and also EDDIE. Reinstalled both. Unfortunately no success. EDDIE cannot establish a connection to any server. For a short time you can see the TAP windows adapter 9 in the network settings but without an internet connection. Does anyone have any idea what I can do? Am grateful for any help!
Eddie will install it for you if there isn't one available.
Unless you are Gestapo/Mosad or NSA etc. you cannot do that. :) Connect to the server without first connecting through your ISP.
I can see you trying to connect over Wi-Fi on dns.net(Hetzner).
Disable/Re-enable your Wi-Fi main adapter so Wi-Fi works. And disable that darn windows firewall for private/public.
Thanks Flx
The darn windows firewall is now down. I ve reenable the wifi adapter. But EDDIE dont work. The software stuck on the message: Checking route IPv4. Then it is canceled and a new server is selected and the game starts over. What about the settings? Change something just what? Thanks again for your effort.
Is your Wi-Fi working without VPN?
Do a short-search around the forum. You are not the only one that got this "Checking route" error.
@giganerd aka @OpenSourcerer is better schooled in "Eddie matters".  You'll get a better answer on what to do next.
I don't use Eddie software.
Yes without any problems.
I searched the forum for various error messages. IPv4, tunnel driver, DNS block etc. Tried everything once. I was also able to establish a connection to a server once, but during the check I found that the trial download was not carried out via the VPN server but actually unprotected via the normal connection of the ISP.
Yes he changed his name. Why not. Let's see if he can help.
By the way, I installed the software of other well-known VPN providers. Monthly account. What the hell. And what I can say: The VPN access works immediately without any problems. So it's definitely up to EDDIE. I wouldn't leave AIRVPN because of that. Many greetings, Woffel
Thank you very much for your efforts. It didn't help at all because I can't establish a VPN connection with EDDIE. For whatever reason. I hereby give up and let my account expire. Sorry but there are many other VPN providers. It was a good time here but I will be gone. Don't be mad at me. I wish you all the best, stay healthy and protect the internet.
Thanks says F.
I hope that during your stay here you realized at some point that these are the community forums, and that answer quality varies. I truly hope you tried the ticket system, because that's the professional support you also subscribe to, so to say. So you giving up doesn't leave me with a good feeling about a fellow contryman, as you put it. :)
