Not connected, Your IP: 216.73.216.20
Hello.
I am running air over tor.
I have two questions:
1)tor check in eddy is ok so I connect my pc without problem. I see in my route table the tor entry node and if I check my ip it is airvpn ip.
Also ipelak show me air to be exit node so all right for me!
Question is this: where can I see ipv4 tor exit node that should be my ip??
Client area show me exit ipv4: air.
2) Anyway all app work fine but with this connecting mode TBB don't work!
Why?
Thanks to all.
We are big!
You're running AirVPN over Tor. By definition you're not supposed to see the Tor exit IP anywhere.
AFAIK, Eddie uses some features of the Tor Browser Bundle itself and I think there is no sense in establishing two Tor connections. Why do you want this, anyway? Your traffic is routed through Air through Tor, anyway.
