strideram 11 Posted ... Unable to connect to the VPN. Keep getting same error - > Checking authorization ..., 1° try failed (curl: (7) Failed to connect to 63.33.78.166 port 80: Host unreachable) Logs attached. Eddie System/Environment Report - 07-10-2020 22:05 UTC Eddie version: 2.15.2 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Pro OS version: Microsoft Windows NT 10.0.19041.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 OpenVPN driver: TAP-Windows Adapter V9, version 9.21.2 OpenVPN: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.54.1 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Users\amith\AppData\Local\AirVPN\default.xml Data path: C:\Users\amith\AppData\Local\AirVPN Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (1 args) path="home" Network Lock Active: No Connected to VPN: No Detected DNS: 0.0.0.0, 10.28.48.1, 192.168.0.1 Test DNS IPv4: Ok Test DNS IPv6: Failed Test Ping IPv4: 17 ms Test Ping IPv6: -1 ms Test HTTP IPv4: Ok Test HTTP IPv6: Error:curl: (6) Could not resolve host: ipv6.eddie.website Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True log.file.enabled: True mode.protocol: UDP mode.port: 53 netlock.mode: windows_wfp advanced.expert: True windows.dhcp_disable: True windows.dns.force_all_interfaces: True windows.ipv6.bypass_dns: True ---------------------------- Logs: . 2020.10.08 03:19:17 - Eddie version: 2.15.2 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.19041.0, Mono/.Net: v4.0.30319 . 2020.10.08 03:19:17 - Reading options from C:\Users\amith\AppData\Local\AirVPN\default.xml . 2020.10.08 03:19:17 - Command line arguments (1): path="home" . 2020.10.08 03:19:17 - Profile path: C:\Users\amith\AppData\Local\AirVPN\default.xml . 2020.10.08 03:19:21 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2 . 2020.10.08 03:19:21 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2020.10.08 03:19:21 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2020.10.08 03:19:21 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2020.10.08 03:19:21 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe) . 2020.10.08 03:19:21 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem W 2020.10.08 03:19:22 - Recovery. Unexpected crash? . 2020.10.08 03:19:22 - Routes, remove 213.152.162.170 for gateway 10.12.140.1 failed: The route deletion failed: Element not found . 2020.10.08 03:19:23 - Routes, remove 103.254.153.99 for gateway 10.9.108.1 failed: The route deletion failed: Element not found . 2020.10.08 03:19:23 - Routes, remove 185.200.116.219 for gateway 10.15.92.1 failed: The route deletion failed: Element not found . 2020.10.08 03:19:23 - Routes, remove 103.254.153.99 for gateway 10.9.124.1 failed: The route deletion failed: Element not found . 2020.10.08 03:19:23 - Updating systems & servers data ... I 2020.10.08 03:19:23 - Ready . 2020.10.08 03:19:24 - Systems & servers data update completed I 2020.10.08 03:19:37 - Session starting. . 2020.10.08 03:19:38 - Network adapter DHCP switched to static (TP-Link Wireless USB Adapter #4) I 2020.10.08 03:19:42 - Checking authorization ... . 2020.10.08 03:19:42 - Checking authorization ..., 1° try failed (curl: (7) Failed to connect to 63.33.78.166 port 80: Host unreachable) . 2020.10.08 03:20:02 - Checking authorization ..., 2° try failed (curl: (28) Connection timed out after 20016 milliseconds) . 2020.10.08 03:20:22 - Checking authorization ..., 3° try failed (curl: (28) Connection timed out after 20016 milliseconds) . 2020.10.08 03:20:42 - Checking authorization ..., 4° try failed (curl: (28) Connection timed out after 20016 milliseconds) W 2020.10.08 03:20:42 - Authorization check failed, continue anyway (curl: (7) Failed to connect to 63.33.78.166 port 80: Host unreachable) I 2020.10.08 03:20:42 - Cancel requested. . 2020.10.08 03:20:42 - DHCP of a network adapter restored to original settings (TP-Link Wireless USB Adapter #4) ! 2020.10.08 03:20:42 - Session terminated. I 2020.10.08 03:20:48 - Session starting. . 2020.10.08 03:20:49 - Network adapter DHCP switched to static (TP-Link Wireless USB Adapter #4) I 2020.10.08 03:20:52 - Checking authorization ... . 2020.10.08 03:20:53 - Checking authorization ..., 1° try failed (curl: (7) Failed to connect to 63.33.78.166 port 80: Host unreachable) . 2020.10.08 03:21:13 - Checking authorization ..., 2° try failed (curl: (28) Connection timed out after 20015 milliseconds) . 2020.10.08 03:21:33 - Checking authorization ..., 3° try failed (curl: (28) Connection timed out after 20016 milliseconds) . 2020.10.08 03:21:53 - Checking authorization ..., 4° try failed (curl: (28) Connection timed out after 20015 milliseconds) W 2020.10.08 03:21:53 - Authorization check failed, continue anyway (curl: (7) Failed to connect to 63.33.78.166 port 80: Host unreachable) I 2020.10.08 03:21:53 - Cancel requested. . 2020.10.08 03:21:53 - DHCP of a network adapter restored to original settings (TP-Link Wireless USB Adapter #4) ! 2020.10.08 03:21:53 - Session terminated. I 2020.10.08 03:27:50 - Session starting. . 2020.10.08 03:27:52 - Network adapter DHCP switched to static (TP-Link Wireless USB Adapter #4) I 2020.10.08 03:27:55 - Checking authorization ... . 2020.10.08 03:28:15 - Checking authorization ..., 1° try failed (curl: (28) Connection timed out after 20000 milliseconds) . 2020.10.08 03:28:35 - Checking authorization ..., 2° try failed (curl: (28) Connection timed out after 20000 milliseconds) . 2020.10.08 03:28:55 - Checking authorization ..., 3° try failed (curl: (28) Connection timed out after 20016 milliseconds) . 2020.10.08 03:29:15 - Checking authorization ..., 4° try failed (curl: (28) Connection timed out after 20015 milliseconds) W 2020.10.08 03:29:15 - Authorization check failed, continue anyway (curl: (28) Connection timed out after 20000 milliseconds) I 2020.10.08 03:29:15 - Cancel requested. . 2020.10.08 03:29:16 - DHCP of a network adapter restored to original settings (TP-Link Wireless USB Adapter #4) ! 2020.10.08 03:29:16 - Session terminated. . 2020.10.08 03:30:22 - Updating systems & servers data ... . 2020.10.08 03:30:24 - Systems & servers data update completed I 2020.10.08 03:33:17 - Session starting. . 2020.10.08 03:33:19 - Network adapter DHCP switched to static (TP-Link Wireless USB Adapter #4) I 2020.10.08 03:33:22 - Checking authorization ... . 2020.10.08 03:33:23 - Checking authorization ..., 1° try failed (curl: (7) Failed to connect to 63.33.78.166 port 80: Host unreachable) . 2020.10.08 03:33:43 - Checking authorization ..., 2° try failed (curl: (28) Connection timed out after 20016 milliseconds) . 2020.10.08 03:34:03 - Checking authorization ..., 3° try failed (curl: (28) Connection timed out after 20000 milliseconds) . 2020.10.08 03:34:23 - Checking authorization ..., 4° try failed (curl: (28) Connection timed out after 20000 milliseconds) W 2020.10.08 03:34:23 - Authorization check failed, continue anyway (curl: (7) Failed to connect to 63.33.78.166 port 80: Host unreachable) I 2020.10.08 03:34:23 - Cancel requested. . 2020.10.08 03:34:23 - DHCP of a network adapter restored to original settings (TP-Link Wireless USB Adapter #4) ! 2020.10.08 03:34:23 - Session terminated. ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": false, "routes": [ { "address": "0.0.0.0\/0", "interface": "{CAFC4075-1C99-476C-839A-139A77AA6C36}", "gateway": "192.168.1.1", "metric": "46" }, { "address": "0.0.0.0\/0", "interface": "{CAFC4075-1C99-476C-839A-139A77AA6C36}", "gateway": "192.168.0.1", "metric": "45" }, { "address": "10.0.75.0\/28", "interface": "{19CB5F7D-2E17-4705-A544-B598583958F9}", "gateway": "link", "metric": "271" }, { "address": "10.0.75.1", "interface": "{19CB5F7D-2E17-4705-A544-B598583958F9}", "gateway": "link", "metric": "271" }, { "address": "10.0.75.15", "interface": "{19CB5F7D-2E17-4705-A544-B598583958F9}", "gateway": "link", "metric": "271" }, { "address": "127.0.0.0\/8", "interface": "{BBED3E08-0B41-11E3-8249-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.0.0.1", "interface": "{BBED3E08-0B41-11E3-8249-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.255.255.255", "interface": "{BBED3E08-0B41-11E3-8249-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "172.19.16.0\/20", "interface": "{F1D29738-2346-4739-932B-24EAAA2E6CE5}", "gateway": "link", "metric": "5256" }, { "address": "172.19.16.1", "interface": "{F1D29738-2346-4739-932B-24EAAA2E6CE5}", "gateway": "link", "metric": "5256" }, { "address": "172.19.31.255", "interface": "{F1D29738-2346-4739-932B-24EAAA2E6CE5}", "gateway": "link", "metric": "5256" }, { "address": "172.22.0.0\/20", "interface": "{F872F297-2EA1-410A-B9DD-16F4238EEC8D}", "gateway": "link", "metric": "271" }, { "address": "172.22.0.1", "interface": "{F872F297-2EA1-410A-B9DD-16F4238EEC8D}", "gateway": "link", "metric": "271" }, { "address": "172.22.15.255", "interface": "{F872F297-2EA1-410A-B9DD-16F4238EEC8D}", "gateway": "link", "metric": "271" }, { "address": "172.24.176.0\/20", "interface": "{EC94144E-4031-48F8-B6CE-DE9263548E53}", "gateway": "link", "metric": "271" }, { "address": "172.24.176.1", "interface": "{EC94144E-4031-48F8-B6CE-DE9263548E53}", "gateway": "link", "metric": "271" }, { "address": "172.24.191.255", "interface": "{EC94144E-4031-48F8-B6CE-DE9263548E53}", "gateway": "link", "metric": "271" }, { "address": "192.168.0.0\/24", "interface": "{CAFC4075-1C99-476C-839A-139A77AA6C36}", "gateway": "link", "metric": "301" }, { "address": "192.168.0.105", "interface": "{CAFC4075-1C99-476C-839A-139A77AA6C36}", "gateway": "link", "metric": "301" }, { "address": "192.168.0.255", "interface": "{CAFC4075-1C99-476C-839A-139A77AA6C36}", "gateway": "link", "metric": "301" }, { "address": "192.168.224.0\/20", "interface": "{ED2C3F01-881B-4AC3-A6CF-54FDEE5FAF89}", "gateway": "link", "metric": "5256" }, { "address": "192.168.224.1", "interface": "{ED2C3F01-881B-4AC3-A6CF-54FDEE5FAF89}", "gateway": "link", "metric": "5256" }, { "address": "192.168.239.255", "interface": "{ED2C3F01-881B-4AC3-A6CF-54FDEE5FAF89}", "gateway": "link", "metric": "5256" }, { "address": "224.0.0.0\/4", "interface": "{BBED3E08-0B41-11E3-8249-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "224.0.0.0\/4", "interface": "{19CB5F7D-2E17-4705-A544-B598583958F9}", "gateway": "link", "metric": "271" }, { "address": "224.0.0.0\/4", "interface": "{F1D29738-2346-4739-932B-24EAAA2E6CE5}", "gateway": "link", "metric": "5256" }, { "address": "224.0.0.0\/4", "interface": "{CAFC4075-1C99-476C-839A-139A77AA6C36}", "gateway": "link", "metric": "301" }, { "address": "224.0.0.0\/4", "interface": "{ED2C3F01-881B-4AC3-A6CF-54FDEE5FAF89}", "gateway": "link", "metric": "5256" }, { "address": "224.0.0.0\/4", "interface": "{EC94144E-4031-48F8-B6CE-DE9263548E53}", "gateway": "link", "metric": "271" }, { "address": "224.0.0.0\/4", "interface": "{F872F297-2EA1-410A-B9DD-16F4238EEC8D}", "gateway": "link", "metric": "271" }, { "address": "255.255.255.255", "interface": "{BBED3E08-0B41-11E3-8249-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "255.255.255.255", "interface": "{19CB5F7D-2E17-4705-A544-B598583958F9}", "gateway": "link", "metric": "271" }, { "address": "255.255.255.255", "interface": "{F1D29738-2346-4739-932B-24EAAA2E6CE5}", "gateway": "link", "metric": "5256" }, { "address": "255.255.255.255", "interface": "{CAFC4075-1C99-476C-839A-139A77AA6C36}", "gateway": "link", "metric": "301" }, { "address": "255.255.255.255", "interface": "{ED2C3F01-881B-4AC3-A6CF-54FDEE5FAF89}", "gateway": "link", "metric": "5256" }, { "address": "255.255.255.255", "interface": "{EC94144E-4031-48F8-B6CE-DE9263548E53}", "gateway": "link", "metric": "271" }, { "address": "255.255.255.255", "interface": "{F872F297-2EA1-410A-B9DD-16F4238EEC8D}", "gateway": "link", "metric": "271" }, { "address": "::1", "interface": "{BBED3E08-0B41-11E3-8249-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "ff00::\/8", "interface": "{BBED3E08-0B41-11E3-8249-806E6F6E6963}", "gateway": "link", "metric": "331" } ], "interfaces": [ { "friendly": "vEthernet (Default Switch)", "id": "{F872F297-2EA1-410A-B9DD-16F4238EEC8D}", "name": "vEthernet (Default Switch)", "description": "Hyper-V Virtual Ethernet Adapter #3", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "1411822", "support_ipv4": true, "support_ipv6": false, "ips": [ "172.22.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "vEthernet (DockerNAT)", "id": "{19CB5F7D-2E17-4705-A544-B598583958F9}", "name": "vEthernet (DockerNAT)", "description": "Hyper-V Virtual Ethernet Adapter #2", "type": "Ethernet", "status": "Up", "bytes_received": "0", "bytes_sent": "1648266", "support_ipv4": true, "support_ipv6": false, "ips": [ "10.0.75.1" ], "gateways": [], "bind": true, "dns4": "10.28.48.1", "dns6": null }, { "friendly": "vEthernet (VPN)", "id": "{EC94144E-4031-48F8-B6CE-DE9263548E53}", "name": "vEthernet (VPN)", "description": "Hyper-V Virtual Ethernet Adapter #4", "type": "Ethernet", "status": "Up", "bytes_received": "319433", "bytes_sent": "340587", "support_ipv4": true, "support_ipv6": false, "ips": [ "172.24.176.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 2", "id": "{E40911A0-9732-4FEC-9258-B161F705135B}", "name": "Local Area Connection* 2", "description": "Microsoft Wi-Fi Direct Virtual Adapter #2", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": false, "ips": [ "169.254.80.190" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 5", "id": "{EB45E415-64BA-47C9-8678-84D280EC308D}", "name": "Local Area Connection* 5", "description": "Microsoft Wi-Fi Direct Virtual Adapter #5", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": false, "ips": [ "169.254.196.81" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "VPN", "id": "{1EDED4AC-BC9E-475E-9E57-DF36FF3C1D9D}", "name": "VPN", "description": "TAP-Windows Adapter V9", "type": "Ethernet", "status": "Down", "bytes_received": "324849", "bytes_sent": "505175", "support_ipv4": true, "support_ipv6": false, "ips": [ "169.254.170.132" ], "gateways": [], "bind": true, "dns4": "10.28.48.1", "dns6": null }, { "friendly": "DualBandWifi", "id": "{CAFC4075-1C99-476C-839A-139A77AA6C36}", "name": "DualBandWifi", "description": "TP-Link Wireless USB Adapter #4", "type": "Wireless80211", "status": "Up", "bytes_received": "261284734", "bytes_sent": "228310645", "support_ipv4": true, "support_ipv6": false, "ips": [ "192.168.0.105" ], "gateways": [ "192.168.1.1", "192.168.0.1" ], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{BBED3E08-0B41-11E3-8249-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "vEthernet (vEthernet (Dock)", "id": "{F1D29738-2346-4739-932B-24EAAA2E6CE5}", "name": "vEthernet (vEthernet (Dock)", "description": "Hyper-V Virtual Ethernet Adapter", "type": "Ethernet", "status": "Up", "bytes_received": "1411822", "bytes_sent": "1485685", "support_ipv4": true, "support_ipv6": false, "ips": [ "172.19.16.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "vEthernet (DualBandWifi)", "id": "{ED2C3F01-881B-4AC3-A6CF-54FDEE5FAF89}", "name": "vEthernet (DualBandWifi)", "description": "Hyper-V Virtual Ethernet Adapter #5", "type": "Ethernet", "status": "Up", "bytes_received": "334874", "bytes_sent": "355670", "support_ipv4": true, "support_ipv6": false, "ips": [ "192.168.224.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv4-default-gateway": "192.168.1.1", "ipv4-default-interface": "{CAFC4075-1C99-476C-839A-139A77AA6C36}" } ---------------------------- ipconfig /all: Windows IP Configuration Host Name . . . . . . . . . . . . : chaser-pc Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Ethernet adapter vEthernet (Default Switch): Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #3 Physical Address. . . . . . . . . : 00-15-5D-03-BA-EE DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 172.22.0.1(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.240.0 Default Gateway . . . . . . . . . : NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter vEthernet (DockerNAT): Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #2 Physical Address. . . . . . . . . : 00-15-5D-01-76-00 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 10.0.75.1(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.240 Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . : 10.28.48.1 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter vEthernet (VPN): Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #4 Physical Address. . . . . . . . . : 00-15-5D-09-A6-E8 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 172.24.176.1(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.240.0 Default Gateway . . . . . . . . . : NetBIOS over Tcpip. . . . . . . . : Enabled Wireless LAN adapter Local Area Connection* 2: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2 Physical Address. . . . . . . . . : 36-E8-94-D9-CA-6A DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Local Area Connection* 5: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #5 Physical Address. . . . . . . . . : 34-E8-94-D9-CA-6A DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter VPN: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-Windows Adapter V9 Physical Address. . . . . . . . . : 00-FF-1E-DE-D4-AC DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter DualBandWifi: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TP-Link Wireless USB Adapter #4 Physical Address. . . . . . . . . : 34-E8-94-D9-CA-6A DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 192.168.0.105(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.1 192.168.0.1 DHCP Server . . . . . . . . . . . : 192.168.0.1 DNS Servers . . . . . . . . . . . : 192.168.0.1 0.0.0.0 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter vEthernet (vEthernet (Dock): Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter Physical Address. . . . . . . . . : 00-15-5D-8F-4F-5B DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 172.19.16.1(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.240.0 Default Gateway . . . . . . . . . : NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter vEthernet (DualBandWifi): Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #5 Physical Address. . . . . . . . . : 00-15-5D-CC-17-A5 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 192.168.224.1(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.240.0 Default Gateway . . . . . . . . . : NetBIOS over Tcpip. . . . . . . . : Enabled eddie-logs.txt Quote Share this post Link to post
strideram 11 Posted ... I installed the latest client version, 2.18.9 and with that version I am able to connect to the VPN. If possible, I would still like a response to understand why did it stop working with the older version. Quote Share this post Link to post
Tech Jedi Alex 1528 Posted ... There's no telling why. Generally, older versions stop working one by one because they obviously can't keep up with any changes introduced to the infrastructure. Which does not imply it's because of an infrastructure change. Could be anything. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
