zorozbaloch 0 Posted ... (edited) hello im new user my vpn is connected but internet stop working after connecting of vpn i tired both openvpn and Eddie-UI for windows 10 please help? My Logs . 2020.09.27 05:12:36 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2020.09.27 05:12:36 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.09.27 05:12:36 - OpenVPN > library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2020.09.27 05:12:36 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.09.27 05:12:36 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.09.27 05:12:36 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.09.27 05:12:36 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.09.27 05:12:36 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.205:443 . 2020.09.27 05:12:36 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.09.27 05:12:36 - OpenVPN > UDP link local: (not bound) . 2020.09.27 05:12:36 - OpenVPN > UDP link remote: [AF_INET]104.254.90.205:443 . 2020.09.27 05:12:36 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.205:443, sid=740d11bb b9eef0e5 . 2020.09.27 05:12:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.09.27 05:12:36 - OpenVPN > VERIFY KU OK . 2020.09.27 05:12:36 - OpenVPN > Validating certificate extended key usage . 2020.09.27 05:12:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.09.27 05:12:36 - OpenVPN > VERIFY EKU OK . 2020.09.27 05:12:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Aludra, emailAddress=info@airvpn.org . 2020.09.27 05:12:37 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2020.09.27 05:12:37 - OpenVPN > [Aludra] Peer Connection Initiated with [AF_INET]104.254.90.205:443 . 2020.09.27 05:12:38 - OpenVPN > SENT CONTROL [Aludra]: 'PUSH_REQUEST' (status=1) . 2020.09.27 05:12:38 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.8.78.1,dhcp-option DNS6 fde6:7a:7d20:44e::1,tun-ipv6,route-gateway 10.8.78.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:44e::10a3/64 fde6:7a:7d20:44e::1,ifconfig 10.8.78.165 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2020.09.27 05:12:38 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.09.27 05:12:38 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.09.27 05:12:38 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.09.27 05:12:38 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.09.27 05:12:38 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.09.27 05:12:38 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.09.27 05:12:38 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.09.27 05:12:38 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.09.27 05:12:38 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.09.27 05:12:38 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.09.27 05:12:38 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.09.27 05:12:38 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.09.27 05:12:38 - OpenVPN > interactive service msg_channel=0 . 2020.09.27 05:12:38 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=18 HWADDR=30:9c:23:e7:62:73 . 2020.09.27 05:12:38 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.09.27 05:12:38 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2020.09.27 05:12:38 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2020.09.27 05:12:38 - OpenVPN > open_tun . 2020.09.27 05:12:38 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{A53F324F-789E-4C47-BA35-5E59092E2A73}.tap . 2020.09.27 05:12:38 - OpenVPN > TAP-Windows Driver Version 9.24 . 2020.09.27 05:12:38 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.8.78.0/10.8.78.165/255.255.255.0 [SUCCEEDED] . 2020.09.27 05:12:38 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.8.78.165/255.255.255.0 on interface {A53F324F-789E-4C47-BA35-5E59092E2A73} [DHCP-serv: 10.8.78.254, lease-time: 31536000] . 2020.09.27 05:12:38 - OpenVPN > Successful ARP Flush on interface [17] {A53F324F-789E-4C47-BA35-5E59092E2A73} . 2020.09.27 05:12:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=17 fde6:7a:7d20:44e::10a3 store=active . 2020.09.27 05:12:40 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Local Area Connection 2 static fde6:7a:7d20:44e::1 validate=no . 2020.09.27 05:12:40 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2020.09.27 05:12:40 - OpenVPN > add_route_ipv6(fde6:7a:7d20:44e::/64 -> fde6:7a:7d20:44e::10a3 metric 0) dev Local Area Connection 2 . 2020.09.27 05:12:40 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:44e::/64 interface=17 fe80::8 store=active . 2020.09.27 05:12:40 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.27 05:12:45 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2020.09.27 05:12:45 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 104.254.90.205 MASK 255.255.255.255 192.168.0.1 . 2020.09.27 05:12:45 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2020.09.27 05:12:45 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.09.27 05:12:45 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.8.78.1 . 2020.09.27 05:12:45 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.09.27 05:12:45 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.09.27 05:12:45 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.8.78.1 . 2020.09.27 05:12:45 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.09.27 05:12:45 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.09.27 05:12:45 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:44e::1 metric -1) dev Local Area Connection 2 . 2020.09.27 05:12:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=17 fe80::8 store=active . 2020.09.27 05:12:45 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.27 05:12:45 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:44e::1 metric -1) dev Local Area Connection 2 . 2020.09.27 05:12:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=17 fe80::8 store=active . 2020.09.27 05:12:45 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.27 05:12:45 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:44e::1 metric -1) dev Local Area Connection 2 . 2020.09.27 05:12:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=17 fe80::8 store=active . 2020.09.27 05:12:45 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.27 05:12:45 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:44e::1 metric -1) dev Local Area Connection 2 . 2020.09.27 05:12:45 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=17 fe80::8 store=active . 2020.09.27 05:12:45 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.09.27 05:12:45 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4 . 2020.09.27 05:12:45 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6 . 2020.09.27 05:12:45 - DNS leak protection with packet filtering enabled. . 2020.09.27 05:12:46 - Routes, added a new route, 104.254.90.203 for gateway 10.8.78.1 . 2020.09.27 05:12:47 - Routes, added a new route, 2606:6080:2001:7:8e6:43a8:fb13:2f6d for gateway fde6:7a:7d20:44e::1 . 2020.09.27 05:12:47 - Flushing DNS I 2020.09.27 05:12:47 - Checking route IPv4 I 2020.09.27 05:12:48 - Checking route IPv6 I 2020.09.27 05:12:52 - Checking DNS ! 2020.09.27 05:12:55 - Connected. . 2020.09.27 05:12:55 - OpenVPN > Initialization Sequence Completed Edited ... by giganerd Apply LOG format to logs Quote Share this post Link to post
Tech Jedi Alex 1585 Posted ... @zorozbaloch Welcome to AirVPN. When connected, go to Eddie's Logs tab instead, click the lifebelt icon on the right and paste or upload the output here. This gives us much more info to work with and troubleshoot. Thank you! Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
bluesjunior 54 Posted ... Did you okay it through your Firewall and Anti-Virus?. Quote Share this post Link to post
Flx 81 Posted ... See if this will help---->>> Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
