Not connected, Your IP: 216.73.217.13
Hi everyone.
While in my home network I have no connection problems, at work I cannot connect through airvpn.
I use Eddie-ui (2.18.9) on debian stable.
I tried to connect through UDP and TCP as well.
This is the log:
. 2020.09.15 13:53:18 - Eddie version: 2.18.9 / linux_x64, System: Linux, Name: Debian GNU/Linux 10 \n \l, Version: Linux mousy 4.19.0-10-amd64 #1 SMP Debian 4.19.132-1 (2020-07-24) x86_64 GNU/Linux, Mono/.Net: 5.18.0.240 (Debian 5.18.0.240+dfsg-3 Wed Apr 17 16:37:36 UTC 2019); Framework: v4.0.30319
. 2020.09.15 13:53:18 - Command line arguments (2): path.resources="/usr/share/eddie-ui" path.exec="/usr/bin/eddie-ui"
. 2020.09.15 13:53:18 - Raise system privileges
. 2020.09.15 13:53:25 - Profile path: /home/leo/.config/eddie/default.profile
. 2020.09.15 13:53:26 - Reading options from /home/leo/.config/eddie/default.profile
. 2020.09.15 13:53:26 - Tun Driver - /dev/net/tun
. 2020.09.15 13:53:26 - OpenVPN - Version: 2.4.7 - OpenSSL 1.1.1d  10 Sep 2019, LZO 2.10 (/sbin/openvpn)
. 2020.09.15 13:53:26 - SSH - Version: OpenSSH_7.9p1 Debian-10+deb10u2, OpenSSL 1.1.1d  10 Sep 2019 (/usr/bin/ssh)
. 2020.09.15 13:53:26 - SSL - Version: stunnel 5.50 (/usr/bin/stunnel4)
. 2020.09.15 13:53:26 - curl - Version: 7.64.0 (/usr/bin/curl)
! 2020.09.15 13:53:26 - Activation of Network Lock - Linux iptables
I 2020.09.15 13:53:27 - Ready
. 2020.09.15 13:53:28 - Collect information about AirVPN completed
I 2020.09.15 13:53:31 - Session starting.
. 2020.09.15 13:53:31 - Waiting for latency tests (232 to go)
. 2020.09.15 13:53:33 - Waiting for latency tests (231 to go)
. 2020.09.15 13:53:34 - Waiting for latency tests (229 to go)
. 2020.09.15 13:53:35 - Waiting for latency tests (219 to go)
. 2020.09.15 13:53:36 - Waiting for latency tests (218 to go)
. 2020.09.15 13:53:37 - Waiting for latency tests (215 to go)
. 2020.09.15 13:53:41 - Waiting for latency tests (198 to go)
. 2020.09.15 13:53:43 - Waiting for latency tests (196 to go)
. 2020.09.15 13:53:44 - Waiting for latency tests (194 to go)
. 2020.09.15 13:53:45 - Waiting for latency tests (190 to go)
Any advice?
Thanks a lot,
l3o
Well, that's practically the definition of "the problem lies with your workplace". Try OpenVPN over SSL, it will look kinda like normal HTTPS traffic to your network admins.
Thank you so much for the valuable information. I'll try tomorrow at work :)
Cheers l3o
