Not connected, Your IP: 216.73.216.117
simus
IP2Location in IPLeak?
Does IPLeak support IP2Location?
They have free IP2Location LITE database. We found their results better than existing IPLeak.
"We"?
I don't know which GeoIP service IPLeak uses. Would be good to find that out.
Quote
Service available on IPv4 and IPv6 , also on alternative ports: :8000 (IPv4,IPv6) and :62222 (IPv4,IPv6) (for detection of routing based on destination ports). Look the forum for support, feedback, API.
Data partially based on MaxMind database. Results may be cached, refer to MaxMind for more accuracy.
Based on the footer of IPLeak website (see above), I'd say IPLeak uses MaxMind's GeoIP2 data services and databases, no?
I specifically wrote this so you get a second chance to prove that you are indeed Jason Bourne, haha. :D
Jokes aside, you are right. Though, partially?
