marjoramoregano
Problem with portforwarding and SoulseekQt
OS: Windows 10 latest
Firewall: Windows Firewall (soulseek is enabled both in private and public networks)
Client: Eddie 2.18.9 portable
I port forwarded 3 ports, one for Qbittorrent  (it's working fine with the TCP test) and with canyouseeme(dot)org.  My two adjacent ports for SoulseekQt (listening+obfuscated) are still closed. Tried this both via TCP or UDP in OpenVPN client and in the eddie client.
Hi, how did you do the test?
Did you have SoulseekQt running when you did the test?
You might know it but just in case, ports show open when there is an app listening to them on the other side and not for the fact of being redirected to your device.
