rickrick 0 Posted ... before connecting with airvpn if I run a check at dnsleaktest.com I get a list ip addresses including this one 146.185.236.26 after connecting to airvpn with network lock on and i run a test on dnsleakest.com I get this ip address again 146.185.236.26 and only this one If I run a test on ipleak.net I get two servers showing my ip addresses as the same as the server I have chosen in airvpn but the dns showing is this one again 146.185.236.26 and one the same except for the last number am I leaking anything. I have just updated airvpn eddie to the latest version and before this had no issues except 10 minutes to discconnect from airvpn which is why I changed, hope this all means something to somone Im not expert Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... 12 hours ago, rickrick said: 146.185.236.26 This doesn't look like any VPN server AirVPN is operating. What's your OS? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
rickrick 0 Posted ... hi windows ten, but ive had to wind back to eddie 2.16.3 where I had no dns leak but now I seem to have them again. any ideas, Im afraid I cannot understand the instructions to down load openvpn. so Im stuck there too Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... First, upgrade again to 2.18.9, then connect like you normally would. After this, go to the Logs tab and click the lifebelt icon. Paste or upload the output here. This will give us more info on your setup, Eddie settings and the logs are there as well. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
rickrick 0 Posted ... (edited) firstly I appreciate your assistance here is that log file from the little lifesaver icon but this connection failed after taking forever to get there, if you want a nother successful one I cant send it when I ahve it Eddie System/Environment Report - 30/07/2020 - 5:46 PM UTC Eddie version: 2.18.9 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Home OS version: Microsoft Windows NT 10.0.18363.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 TUN driver: 0901: 9.21.2; wintun: Not found OpenVPN: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) Hummingbird: () SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Users\rod\AppData\Local\Eddie\default.profile Data path: C:\Users\rod\AppData\Local\Eddie Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (1 args) path="home" Network Lock Active: Yes, Windows Filtering Platform Connected to VPN: No Detected DNS: 8.8.4.4, 8.8.8.8 Test DNS IPv4: Failed Test DNS IPv6: Failed Test Ping IPv4: 306 ms Test Ping IPv6: -1 ms Test HTTP IPv4: Ok Test HTTP IPv6: Error:curl: (7) Failed to connect to 2a03:b0c0:2:d0::11b4:6001 port 80: Network unreachable Test HTTPS: Error:curl: (6) Could not resolve host: eddie.website ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True servers.whitelist: bd4a4dbd393ee075bfbf2d8a6d019a37c376899d58b37f002d76119a081b0048,9ed77884ba296cb2814189cf6280124360e3ce8e93bb497086a24c01e2d26dca log.level.debug: True openvpn.custom: block-outside-dns ---------------------------- Logs: . 2020.07.31 03:37:55 - Eddie version: 2.18.9 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319 . 2020.07.31 03:37:55 - Command line arguments (1): path="home" . 2020.07.31 03:37:59 - Profile path: C:\Users\rod\AppData\Local\Eddie\default.profile . 2020.07.31 03:38:01 - Reading options from C:\Users\rod\AppData\Local\Eddie\default.profile . 2020.07.31 03:38:02 - Shell(1) of 'C:\Windows\system32\route.exe', 2 args: '-4';'PRINT'; . 2020.07.31 03:38:03 - Shell(1) done in 1141 ms, exit: 0, out: '=========================================================================== . 2020.07.31 03:38:03 - Interface List . 2020.07.31 03:38:03 - 4...00 ac 45 d7 92 aa ......VPN Client Adapter - VPN96 . 2020.07.31 03:38:03 - 12...f8 0f 41 bb d3 68 ......Realtek PCIe GBE Family Controller . 2020.07.31 03:38:03 - 21...1a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #4 . 2020.07.31 03:38:03 - 25...2a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #5 . 2020.07.31 03:38:03 - 22...00 ff af 84 6c 22 ......TAP-Windows Adapter V9 . 2020.07.31 03:38:03 - 24...28 e3 47 de 15 e4 ......Qualcomm Atheros AR5BWB222 Wireless Network Adapter . 2020.07.31 03:38:03 - 3...28 e3 47 de 2b e2 ......Bluetooth Device (Personal Area Network) . 2020.07.31 03:38:03 - 1...........................Software Loopback Interface 1 . 2020.07.31 03:38:03 - =========================================================================== . 2020.07.31 03:38:03 - IPv4 Route Table . 2020.07.31 03:38:03 - =========================================================================== . 2020.07.31 03:38:03 - Active Routes: . 2020.07.31 03:38:03 - Network Destination Netmask Gateway Interface Metric . 2020.07.31 03:38:03 - 0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.149 40 . 2020.07.31 03:38:03 - 127.0.0.0 255.0.0.0 On-link 127.0.0.1 331 . 2020.07.31 03:38:03 - 127.0.0.1 255.255.255.255 On-link 127.0.0.1 331 . 2020.07.31 03:38:03 - 127.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.07.31 03:38:03 - 192.168.0.0 255.255.255.0 On-link 192.168.0.149 296 . 2020.07.31 03:38:03 - 192.168.0.149 255.255.255.255 On-link 192.168.0.149 296 . 2020.07.31 03:38:03 - 192.168.0.255 255.255.255.255 On-link 192.168.0.149 296 . 2020.07.31 03:38:03 - 224.0.0.0 240.0.0.0 On-link 127.0.0.1 331 . 2020.07.31 03:38:03 - 224.0.0.0 240.0.0.0 On-link 192.168.0.149 296 . 2020.07.31 03:38:03 - 255.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.07.31 03:38:03 - 255.255.255.255 255.255.255.255 On-link 192.168.0.149 296 . 2020.07.31 03:38:03 - =========================================================================== . 2020.07.31 03:38:03 - Persistent Routes: . 2020.07.31 03:38:03 - None' . 2020.07.31 03:38:03 - Shell(2) of 'C:\Windows\system32\route.exe', 2 args: '-6';'PRINT'; . 2020.07.31 03:38:04 - Shell(2) done in 328 ms, exit: 0, out: '=========================================================================== . 2020.07.31 03:38:04 - Interface List . 2020.07.31 03:38:04 - 4...00 ac 45 d7 92 aa ......VPN Client Adapter - VPN96 . 2020.07.31 03:38:04 - 12...f8 0f 41 bb d3 68 ......Realtek PCIe GBE Family Controller . 2020.07.31 03:38:04 - 21...1a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #4 . 2020.07.31 03:38:04 - 25...2a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #5 . 2020.07.31 03:38:04 - 22...00 ff af 84 6c 22 ......TAP-Windows Adapter V9 . 2020.07.31 03:38:04 - 24...28 e3 47 de 15 e4 ......Qualcomm Atheros AR5BWB222 Wireless Network Adapter . 2020.07.31 03:38:04 - 3...28 e3 47 de 2b e2 ......Bluetooth Device (Personal Area Network) . 2020.07.31 03:38:04 - 1...........................Software Loopback Interface 1 . 2020.07.31 03:38:04 - =========================================================================== . 2020.07.31 03:38:04 - IPv6 Route Table . 2020.07.31 03:38:04 - =========================================================================== . 2020.07.31 03:38:04 - Active Routes: . 2020.07.31 03:38:04 - If Metric Network Destination Gateway . 2020.07.31 03:38:04 - 1 331 ::1/128 On-link . 2020.07.31 03:38:04 - 1 331 ff00::/8 On-link . 2020.07.31 03:38:04 - =========================================================================== . 2020.07.31 03:38:04 - Persistent Routes: . 2020.07.31 03:38:04 - If Metric Network Destination Gateway . 2020.07.31 03:38:04 - 0 4294967295 2606:9580:100:d:2bd7:c37b:24c2:c069/128 . 2020.07.31 03:38:04 - fde6:7a:7d20:104a::1 . 2020.07.31 03:38:04 - 0 4294967295 2a00:1678:2470:13:df5e:761a:e1d:cd0a/128 . 2020.07.31 03:38:04 - fde6:7a:7d20:1a8a::1 . 2020.07.31 03:38:04 - 0 4294967295 2606:9580:100:a:ee16:9283:a03e:5f18/128 . 2020.07.31 03:38:04 - fde6:7a:7d20:bea::1 . 2020.07.31 03:38:04 - 0 4294967295 2a00:1678:2470:dddd:fda2:8371:a19e:e06d/128 . 2020.07.31 03:38:04 - fde6:7a:7d20:1e72::1 . 2020.07.31 03:38:04 - ===========================================================================' . 2020.07.31 03:38:07 - Elevated: Command:wfp . 2020.07.31 03:38:22 - Shell(3) of 'C:\Program Files\AirVPN\openvpn.exe', 1 args: '--version'; . 2020.07.31 03:38:23 - Shell(3) done in 985 ms, exit: 1, out: 'OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2020.07.31 03:38:23 - library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2020.07.31 03:38:23 - Windows version 6.2 (Windows 8 or greater) 64bit . 2020.07.31 03:38:23 - Originally developed by James Yonan . 2020.07.31 03:38:23 - Copyright (C) 2002-2018 OpenVPN Inc <sales@openvpn.net> . 2020.07.31 03:38:23 - Compile time defines: enable_async_push=no enable_comp_stub=no enable_crypto=yes enable_crypto_ofb_cfb=yes enable_debug=yes enable_def_auth=yes enable_dlopen=unknown enable_dlopen_self=unknown enable_dlopen_self_static=unknown enable_fast_install=needless enable_fragment=yes enable_iproute2=no enable_libtool_lock=yes enable_lz4=yes enable_lzo=yes enable_management=yes enable_multihome=yes enable_pam_dlopen=no enable_pedantic=no enable_pf=yes enable_pkcs11=yes enable_plugin_auth_pam=no enable_plugin_down_root=no enable_plugins=yes enable_port_share=yes enable_selinux=no enable_server=yes enable_shared=yes enable_shared_with_static_runtimes=yes enable_small=no enable_static=yes enable_strict=no enable_strict_options=no enable_systemd=no enable_werror=no enable_win32_dll=yes enable_x509_alt_username=no with_aix_soname=aix with_crypto_library=openssl with_gnu_ld=yes with_mem_check=no with_special_build= with_sysroot=no' . 2020.07.31 03:38:23 - Shell(4) of 'C:\Program Files\AirVPN\plink.exe', 1 args: '-V'; . 2020.07.31 03:38:24 - Shell(4) done in 657 ms, exit: 1, out: 'plink: Release 0.67' . 2020.07.31 03:38:24 - Shell(5) of 'C:\Program Files\AirVPN\stunnel.exe', 1 args: '-version'; . 2020.07.31 03:38:25 - Shell(5) done in 1062 ms, exit: 0, err: 'stunnel 5.40 on x86-pc-mingw32-gnu platform . 2020.07.31 03:38:25 - Compiled/running with OpenSSL 1.0.2k 26 Jan 2017 . 2020.07.31 03:38:25 - Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI . 2020.07.31 03:38:25 - Global options: . 2020.07.31 03:38:25 - RNDbytes = 64 . 2020.07.31 03:38:25 - RNDoverwrite = yes . 2020.07.31 03:38:25 - taskbar = yes . 2020.07.31 03:38:25 - Service-level options: . 2020.07.31 03:38:25 - ciphers = HIGH:!DH:!aNULL:!SSLv2 . 2020.07.31 03:38:25 - curve = prime256v1 . 2020.07.31 03:38:25 - debug = notice . 2020.07.31 03:38:25 - logId = sequential . 2020.07.31 03:38:25 - options = NO_SSLv2 . 2020.07.31 03:38:25 - options = NO_SSLv3 . 2020.07.31 03:38:25 - sessionCacheSize = 1000 . 2020.07.31 03:38:25 - sessionCacheTimeout = 300 seconds . 2020.07.31 03:38:25 - stack = 65536 bytes . 2020.07.31 03:38:25 - TIMEOUTbusy = 300 seconds . 2020.07.31 03:38:25 - TIMEOUTclose = 60 seconds . 2020.07.31 03:38:25 - TIMEOUTconnect = 10 seconds . 2020.07.31 03:38:25 - TIMEOUTidle = 43200 seconds . 2020.07.31 03:38:25 - verify = none' . 2020.07.31 03:38:25 - Shell(6) of 'C:\Program Files\AirVPN\curl.exe', 1 args: '--version'; . 2020.07.31 03:38:26 - Shell(6) done in 859 ms, exit: 0, out: 'curl 7.68.0 (x86_64-pc-win32) libcurl/7.68.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 WinIDN libssh2/1.9.0 nghttp2/1.40.0 . 2020.07.31 03:38:26 - Release-Date: 2020-01-08 . 2020.07.31 03:38:26 - Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtsp scp sftp smb smbs smtp smtps telnet tftp . 2020.07.31 03:38:26 - Features: AsynchDNS HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile MultiSSL NTLM SPNEGO SSL SSPI TLS-SRP brotli libz' . 2020.07.31 03:38:26 - Tun Driver - 0901: 9.21.2; wintun: Not found . 2020.07.31 03:38:26 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2020.07.31 03:38:26 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2020.07.31 03:38:26 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2020.07.31 03:38:26 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe) . 2020.07.31 03:38:26 - Elevated: Command:wfp . 2020.07.31 03:38:32 - Recovery. Unexpected crash? W 2020.07.31 03:38:32 - Routes, add 134.19.179.163 for gateway 10.34.18.1 failed: Network interface no more available. I 2020.07.31 03:38:34 - Ready . 2020.07.31 03:38:36 - Collect information about AirVPN completed ! 2020.07.31 03:39:01 - Activation of Network Lock - Windows Filtering Platform . 2020.07.31 03:39:01 - Elevated: Command:wfp . 2020.07.31 03:39:03 - Above log line repeated 45 times more I 2020.07.31 03:39:03 - Session starting. I 2020.07.31 03:39:04 - Checking authorization ... . 2020.07.31 03:39:04 - Elevated: Command:wfp . 2020.07.31 03:39:06 - Above log line repeated 11 times more W 2020.07.31 03:39:06 - Tunnel driver 0901 will be upgraded, from 9.21.2 to 9.24.2. ! 2020.07.31 03:39:29 - Connecting to Melnick (Netherlands, Alblasserdam) . 2020.07.31 03:39:29 - Elevated: Command:wfp . 2020.07.31 03:39:29 - Above log line repeated 5 times more . 2020.07.31 03:39:29 - Elevated: Command:process_openvpn . 2020.07.31 03:39:30 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2020.07.31 03:39:30 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.07.31 03:39:30 - OpenVPN > library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2020.07.31 03:39:30 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.07.31 03:39:30 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.07.31 03:39:30 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.07.31 03:39:30 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.07.31 03:39:30 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.165:443 . 2020.07.31 03:39:30 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.07.31 03:39:30 - OpenVPN > UDP link local: (not bound) . 2020.07.31 03:39:30 - OpenVPN > UDP link remote: [AF_INET]134.19.179.165:443 . 2020.07.31 03:39:31 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.165:443, sid=121e37ca dcb65817 . 2020.07.31 03:39:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.07.31 03:39:31 - OpenVPN > VERIFY KU OK . 2020.07.31 03:39:31 - OpenVPN > Validating certificate extended key usage . 2020.07.31 03:39:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.07.31 03:39:31 - OpenVPN > VERIFY EKU OK . 2020.07.31 03:39:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Melnick, emailAddress=info@airvpn.org . 2020.07.31 03:39:33 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2020.07.31 03:39:33 - OpenVPN > [Melnick] Peer Connection Initiated with [AF_INET]134.19.179.165:443 . 2020.07.31 03:39:35 - OpenVPN > SENT CONTROL [Melnick]: 'PUSH_REQUEST' (status=1) . 2020.07.31 03:39:35 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.34.18.1,dhcp-option DNS6 fde6:7a:7d20:1e12::1,tun-ipv6,route-gateway 10.34.18.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1e12::10dd/64 fde6:7a:7d20:1e12::1,ifconfig 10.34.18.223 255.255.255.0,peer-id 6,cipher AES-256-GCM' . 2020.07.31 03:39:35 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.07.31 03:39:35 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.07.31 03:39:35 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.07.31 03:39:35 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.07.31 03:39:35 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.07.31 03:39:35 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.07.31 03:39:35 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.07.31 03:39:35 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.07.31 03:39:35 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.07.31 03:39:35 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.07.31 03:39:35 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.07.31 03:39:35 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.07.31 03:39:35 - OpenVPN > interactive service msg_channel=0 . 2020.07.31 03:39:35 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=24 HWADDR=28:e3:47:de:15:e4 . 2020.07.31 03:39:35 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.07.31 03:39:35 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2020.07.31 03:39:35 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2020.07.31 03:39:35 - OpenVPN > open_tun . 2020.07.31 03:39:38 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}.tap . 2020.07.31 03:39:38 - OpenVPN > TAP-Windows Driver Version 9.24 . 2020.07.31 03:39:38 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.34.18.0/10.34.18.223/255.255.255.0 [SUCCEEDED] . 2020.07.31 03:39:38 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.34.18.223/255.255.255.0 on interface {EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE} [DHCP-serv: 10.34.18.254, lease-time: 31536000] . 2020.07.31 03:39:38 - OpenVPN > Successful ARP Flush on interface [22] {EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE} . 2020.07.31 03:39:38 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=22 fde6:7a:7d20:1e12::10dd store=active . 2020.07.31 03:39:50 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Local Area Connection static fde6:7a:7d20:1e12::1 validate=no . 2020.07.31 03:39:50 - Shell(7) of 'C:\Windows\system32\route.exe', 2 args: '-6';'PRINT'; . 2020.07.31 03:39:51 - Shell(7) done in 1265 ms, exit: 0, out: '=========================================================================== . 2020.07.31 03:39:51 - Interface List . 2020.07.31 03:39:51 - 4...00 ac 45 d7 92 aa ......VPN Client Adapter - VPN96 . 2020.07.31 03:39:51 - 12...f8 0f 41 bb d3 68 ......Realtek PCIe GBE Family Controller . 2020.07.31 03:39:51 - 22...00 ff ee 35 32 f9 ......TAP-Windows Adapter V9 . 2020.07.31 03:39:51 - 21...1a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #4 . 2020.07.31 03:39:51 - 25...2a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #5 . 2020.07.31 03:39:51 - 24...28 e3 47 de 15 e4 ......Qualcomm Atheros AR5BWB222 Wireless Network Adapter . 2020.07.31 03:39:51 - 3...28 e3 47 de 2b e2 ......Bluetooth Device (Personal Area Network) . 2020.07.31 03:39:51 - 1...........................Software Loopback Interface 1 . 2020.07.31 03:39:51 - =========================================================================== . 2020.07.31 03:39:51 - IPv6 Route Table . 2020.07.31 03:39:51 - =========================================================================== . 2020.07.31 03:39:51 - Active Routes: . 2020.07.31 03:39:51 - If Metric Network Destination Gateway . 2020.07.31 03:39:51 - 1 331 ::1/128 On-link . 2020.07.31 03:39:51 - 22 281 fde6:7a:7d20:1e12::/64 On-link . 2020.07.31 03:39:51 - 22 281 fde6:7a:7d20:1e12::/64 fe80::8 . 2020.07.31 03:39:51 - 22 281 fde6:7a:7d20:1e12::10dd/128 . 2020.07.31 03:39:51 - On-link . 2020.07.31 03:39:51 - 22 281 fe80::/64 On-link . 2020.07.31 03:39:51 - 22 281 fe80::f460:966:8fd9:760/128 . 2020.07.31 03:39:51 - On-link . 2020.07.31 03:39:51 - 1 331 ff00::/8 On-link . 2020.07.31 03:39:51 - 22 281 ff00::/8 On-link . 2020.07.31 03:39:51 - =========================================================================== . 2020.07.31 03:39:51 - Persistent Routes: . 2020.07.31 03:39:51 - None' . 2020.07.31 03:39:51 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2020.07.31 03:39:51 - Elevated: Command:windows-workaround-25139 . 2020.07.31 03:39:52 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1e12::/64 -> fde6:7a:7d20:1e12::10dd metric 0) dev Local Area Connection . 2020.07.31 03:39:52 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1e12::/64 interface=22 fe80::8 store=active . 2020.07.31 03:39:52 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 03:39:54 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2020.07.31 03:39:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 134.19.179.165 MASK 255.255.255.255 192.168.0.1 . 2020.07.31 03:39:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4 . 2020.07.31 03:39:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.07.31 03:39:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.34.18.1 . 2020.07.31 03:39:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.07.31 03:39:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.07.31 03:39:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.34.18.1 . 2020.07.31 03:39:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.07.31 03:39:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.07.31 03:39:54 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1e12::1 metric -1) dev Local Area Connection . 2020.07.31 03:39:54 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=22 fe80::8 store=active . 2020.07.31 03:39:54 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 03:39:56 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1e12::1 metric -1) dev Local Area Connection . 2020.07.31 03:39:56 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=22 fe80::8 store=active . 2020.07.31 03:39:56 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 03:39:58 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1e12::1 metric -1) dev Local Area Connection . 2020.07.31 03:39:58 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=22 fe80::8 store=active . 2020.07.31 03:39:58 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 03:40:00 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1e12::1 metric -1) dev Local Area Connection . 2020.07.31 03:40:00 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=22 fe80::8 store=active . 2020.07.31 03:40:00 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 03:40:03 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2020.07.31 03:40:03 - Elevated: Command:set-interface-metric . 2020.07.31 03:40:03 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6 . 2020.07.31 03:40:03 - Elevated: Command:set-interface-metric . 2020.07.31 03:40:03 - Elevated: Command:wfp . 2020.07.31 03:41:18 - Above log line repeated 5 times more . 2020.07.31 03:41:18 - DNS leak protection with packet filtering enabled. . 2020.07.31 03:41:19 - Shell(8) of 'C:\Windows\system32\route.exe', 2 args: '-4';'PRINT'; . 2020.07.31 03:41:20 - Shell(8) done in 843 ms, exit: 0, out: '=========================================================================== . 2020.07.31 03:41:20 - Interface List . 2020.07.31 03:41:20 - 4...00 ac 45 d7 92 aa ......VPN Client Adapter - VPN96 . 2020.07.31 03:41:20 - 22...00 ff ee 35 32 f9 ......TAP-Windows Adapter V9 . 2020.07.31 03:41:20 - 12...f8 0f 41 bb d3 68 ......Realtek PCIe GBE Family Controller . 2020.07.31 03:41:20 - 21...1a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #4 . 2020.07.31 03:41:20 - 25...2a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #5 . 2020.07.31 03:41:20 - 24...28 e3 47 de 15 e4 ......Qualcomm Atheros AR5BWB222 Wireless Network Adapter . 2020.07.31 03:41:20 - 3...28 e3 47 de 2b e2 ......Bluetooth Device (Personal Area Network) . 2020.07.31 03:41:20 - 1...........................Software Loopback Interface 1 . 2020.07.31 03:41:20 - =========================================================================== . 2020.07.31 03:41:20 - IPv4 Route Table . 2020.07.31 03:41:20 - =========================================================================== . 2020.07.31 03:41:20 - Active Routes: . 2020.07.31 03:41:20 - Network Destination Netmask Gateway Interface Metric . 2020.07.31 03:41:20 - 0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.149 40 . 2020.07.31 03:41:20 - 0.0.0.0 128.0.0.0 10.34.18.1 10.34.18.223 3 . 2020.07.31 03:41:20 - 10.34.18.0 255.255.255.0 On-link 10.34.18.223 259 . 2020.07.31 03:41:20 - 10.34.18.223 255.255.255.255 On-link 10.34.18.223 259 . 2020.07.31 03:41:20 - 10.34.18.255 255.255.255.255 On-link 10.34.18.223 259 . 2020.07.31 03:41:20 - 127.0.0.0 255.0.0.0 On-link 127.0.0.1 331 . 2020.07.31 03:41:20 - 127.0.0.1 255.255.255.255 On-link 127.0.0.1 331 . 2020.07.31 03:41:20 - 127.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.07.31 03:41:20 - 128.0.0.0 128.0.0.0 10.34.18.1 10.34.18.223 3 . 2020.07.31 03:41:20 - 134.19.179.165 255.255.255.255 192.168.0.1 192.168.0.149 40 . 2020.07.31 03:41:20 - 192.168.0.0 255.255.255.0 On-link 192.168.0.149 296 . 2020.07.31 03:41:20 - 192.168.0.149 255.255.255.255 On-link 192.168.0.149 296 . 2020.07.31 03:41:20 - 192.168.0.255 255.255.255.255 On-link 192.168.0.149 296 . 2020.07.31 03:41:20 - 224.0.0.0 240.0.0.0 On-link 127.0.0.1 331 . 2020.07.31 03:41:20 - 224.0.0.0 240.0.0.0 On-link 192.168.0.149 296 . 2020.07.31 03:41:20 - 224.0.0.0 240.0.0.0 On-link 10.34.18.223 259 . 2020.07.31 03:41:20 - 255.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.07.31 03:41:20 - 255.255.255.255 255.255.255.255 On-link 192.168.0.149 296 . 2020.07.31 03:41:20 - 255.255.255.255 255.255.255.255 On-link 10.34.18.223 259 . 2020.07.31 03:41:20 - =========================================================================== . 2020.07.31 03:41:20 - Persistent Routes: . 2020.07.31 03:41:20 - None' . 2020.07.31 03:41:20 - Shell(9) of 'C:\Windows\system32\route.exe', 2 args: '-6';'PRINT'; . 2020.07.31 03:41:20 - Shell(9) done in 282 ms, exit: 0, out: '=========================================================================== . 2020.07.31 03:41:20 - Interface List . 2020.07.31 03:41:20 - 4...00 ac 45 d7 92 aa ......VPN Client Adapter - VPN96 . 2020.07.31 03:41:20 - 22...00 ff ee 35 32 f9 ......TAP-Windows Adapter V9 . 2020.07.31 03:41:20 - 12...f8 0f 41 bb d3 68 ......Realtek PCIe GBE Family Controller . 2020.07.31 03:41:20 - 21...1a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #4 . 2020.07.31 03:41:20 - 25...2a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #5 . 2020.07.31 03:41:20 - 24...28 e3 47 de 15 e4 ......Qualcomm Atheros AR5BWB222 Wireless Network Adapter . 2020.07.31 03:41:20 - 3...28 e3 47 de 2b e2 ......Bluetooth Device (Personal Area Network) . 2020.07.31 03:41:20 - 1...........................Software Loopback Interface 1 . 2020.07.31 03:41:20 - =========================================================================== . 2020.07.31 03:41:20 - IPv6 Route Table . 2020.07.31 03:41:20 - =========================================================================== . 2020.07.31 03:41:20 - Active Routes: . 2020.07.31 03:41:20 - If Metric Network Destination Gateway . 2020.07.31 03:41:20 - 22 259 ::/3 fe80::8 . 2020.07.31 03:41:20 - 1 331 ::1/128 On-link . 2020.07.31 03:41:20 - 22 259 2000::/4 fe80::8 . 2020.07.31 03:41:20 - 22 259 3000::/4 fe80::8 . 2020.07.31 03:41:20 - 22 259 fc00::/7 fe80::8 . 2020.07.31 03:41:20 - 22 259 fde6:7a:7d20:1e12::/64 fe80::8 . 2020.07.31 03:41:20 - 22 259 fde6:7a:7d20:1e12::10dd/128 . 2020.07.31 03:41:20 - On-link . 2020.07.31 03:41:20 - 22 259 fe80::/64 On-link . 2020.07.31 03:41:20 - 22 259 fe80::f460:966:8fd9:760/128 . 2020.07.31 03:41:20 - On-link . 2020.07.31 03:41:20 - 1 331 ff00::/8 On-link . 2020.07.31 03:41:20 - 22 259 ff00::/8 On-link . 2020.07.31 03:41:20 - =========================================================================== . 2020.07.31 03:41:20 - Persistent Routes: . 2020.07.31 03:41:20 - None' . 2020.07.31 03:41:21 - Elevated: Command:route . 2020.07.31 03:41:22 - Routes, added a new route, 134.19.179.163 for gateway 10.34.18.1 . 2020.07.31 03:41:22 - Elevated: Command:route . 2020.07.31 03:41:23 - Routes, added a new route, 2a00:1678:2470:eeee:2259:2a8b:386:4b98 for gateway fde6:7a:7d20:1e12::1 . 2020.07.31 03:41:23 - Flushing DNS . 2020.07.31 03:41:23 - Elevated: Command:dns-flush . 2020.07.31 03:41:25 - Shell(10) of 'C:\Windows\system32\ipconfig.exe', 1 args: '/flushdns'; . 2020.07.31 03:41:25 - Shell(10) done in 281 ms, exit: 0, out: 'Windows IP Configuration . 2020.07.31 03:41:25 - Successfully flushed the DNS Resolver Cache.' I 2020.07.31 03:41:25 - Checking route IPv4 . 2020.07.31 03:41:25 - Elevated: Command:wfp . 2020.07.31 03:42:54 - Above log line repeated 11 times more . 2020.07.31 03:42:54 - curl: (28) Operation timed out after 20001 milliseconds with 0 out of 0 bytes received - Stack: at Eddie.Core.Tools.Curl.Fetch(HttpRequest request) . 2020.07.31 03:42:54 - at Eddie.Core.Engine.FetchUrlXml(HttpRequest request) . 2020.07.31 03:42:54 - at Eddie.Core.Threads.Session.ConnectedStep() . 2020.07.31 03:42:54 - Checking route (2° try) . 2020.07.31 03:42:55 - Elevated: Command:wfp . 2020.07.31 03:42:57 - Above log line repeated 11 times more I 2020.07.31 03:42:57 - Checking route IPv6 . 2020.07.31 03:42:57 - Elevated: Command:wfp . 2020.07.31 03:43:17 - Above log line repeated 11 times more . 2020.07.31 03:43:17 - curl: (28) Connection timed out after 20000 milliseconds - Stack: at Eddie.Core.Tools.Curl.Fetch(HttpRequest request) . 2020.07.31 03:43:17 - at Eddie.Core.Engine.FetchUrlXml(HttpRequest request) . 2020.07.31 03:43:17 - at Eddie.Core.Threads.Session.ConnectedStep() . 2020.07.31 03:43:17 - Checking route (2° try) . 2020.07.31 03:43:18 - Elevated: Command:wfp . 2020.07.31 03:43:38 - Above log line repeated 11 times more . 2020.07.31 03:43:38 - curl: (28) Connection timed out after 20000 milliseconds - Stack: at Eddie.Core.Tools.Curl.Fetch(HttpRequest request) . 2020.07.31 03:43:38 - at Eddie.Core.Engine.FetchUrlXml(HttpRequest request) . 2020.07.31 03:43:38 - at Eddie.Core.Threads.Session.ConnectedStep() . 2020.07.31 03:43:38 - Checking route (3° try) . 2020.07.31 03:43:40 - Elevated: Command:wfp . 2020.07.31 03:44:00 - Above log line repeated 11 times more . 2020.07.31 03:44:00 - curl: (28) Connection timed out after 20001 milliseconds - Stack: at Eddie.Core.Tools.Curl.Fetch(HttpRequest request) . 2020.07.31 03:44:00 - at Eddie.Core.Engine.FetchUrlXml(HttpRequest request) . 2020.07.31 03:44:00 - at Eddie.Core.Threads.Session.ConnectedStep() E 2020.07.31 03:44:00 - Checking route IPv6 failed. . 2020.07.31 03:44:00 - OpenVPN > Initialization Sequence Completed ! 2020.07.31 03:44:00 - Disconnecting . 2020.07.31 03:44:01 - Elevated: Command:route . 2020.07.31 03:44:01 - Routes, removed a route previously added, 134.19.179.163 for gateway 10.34.18.1 . 2020.07.31 03:44:02 - Elevated: Command:route . 2020.07.31 03:44:03 - Routes, removed a route previously added, 2a00:1678:2470:eeee:2259:2a8b:386:4b98 for gateway fde6:7a:7d20:1e12::1 . 2020.07.31 03:44:03 - Sending soft termination signal . 2020.07.31 03:44:03 - Elevated: Command:kill . 2020.07.31 03:44:06 - OpenVPN > SIGTERM received, sending exit notification to peer . 2020.07.31 03:44:08 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 134.19.179.165 MASK 255.255.255.255 192.168.0.1 . 2020.07.31 03:44:08 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2020.07.31 03:44:08 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.34.18.1 . 2020.07.31 03:44:08 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2020.07.31 03:44:08 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.34.18.1 . 2020.07.31 03:44:08 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2020.07.31 03:44:08 - OpenVPN > delete_route_ipv6(::/3) . 2020.07.31 03:44:08 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 interface=22 fe80::8 store=active . 2020.07.31 03:44:08 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 03:44:09 - OpenVPN > delete_route_ipv6(2000::/4) . 2020.07.31 03:44:09 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=22 fe80::8 store=active . 2020.07.31 03:44:09 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 03:44:09 - OpenVPN > delete_route_ipv6(3000::/4) . 2020.07.31 03:44:09 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=22 fe80::8 store=active . 2020.07.31 03:44:09 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 03:44:09 - OpenVPN > delete_route_ipv6(fc00::/7) . 2020.07.31 03:44:09 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=22 fe80::8 store=active . 2020.07.31 03:44:10 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 03:44:10 - OpenVPN > Closing TUN/TAP interface . 2020.07.31 03:44:10 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1e12::/64) . 2020.07.31 03:44:10 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1e12::/64 interface=22 fe80::8 store=active . 2020.07.31 03:44:11 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Local Area Connection fde6:7a:7d20:1e12::10dd store=active . 2020.07.31 03:44:12 - Sending hard termination signal . 2020.07.31 03:44:12 - Elevated: Command:kill . 2020.07.31 03:44:12 - Connection terminated. . 2020.07.31 03:44:12 - Elevated: Command:wfp . 2020.07.31 03:45:37 - Above log line repeated 5 times more . 2020.07.31 03:45:37 - DNS leak protection with packet filtering disabled. . 2020.07.31 03:45:37 - Elevated: Command:wfp . 2020.07.31 03:45:37 - Above log line repeated 5 times more . 2020.07.31 03:45:37 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 . 2020.07.31 03:45:37 - Elevated: Command:set-interface-metric . 2020.07.31 03:45:37 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6 . 2020.07.31 03:45:37 - Elevated: Command:set-interface-metric . 2020.07.31 03:45:37 - Elevated: Command:wfp . 2020.07.31 03:46:25 - Above log line repeated 59 times more I 2020.07.31 03:46:25 - Checking authorization ... . 2020.07.31 03:46:25 - Elevated: Command:wfp . 2020.07.31 03:46:27 - Above log line repeated 11 times more ! 2020.07.31 03:46:27 - Connecting to Miram (Netherlands, Alblasserdam) . 2020.07.31 03:46:27 - Elevated: Command:wfp . 2020.07.31 03:46:27 - Above log line repeated 5 times more . 2020.07.31 03:46:27 - Elevated: Command:process_openvpn . 2020.07.31 03:46:28 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2020.07.31 03:46:28 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.07.31 03:46:28 - OpenVPN > library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2020.07.31 03:46:28 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.07.31 03:46:28 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.07.31 03:46:28 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.07.31 03:46:28 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.07.31 03:46:28 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.91:443 . 2020.07.31 03:46:28 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.07.31 03:46:28 - OpenVPN > UDP link local: (not bound) . 2020.07.31 03:46:28 - OpenVPN > UDP link remote: [AF_INET]213.152.162.91:443 . 2020.07.31 03:46:28 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.91:443, sid=09c1476c 208a8671 . 2020.07.31 03:46:28 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.07.31 03:46:28 - OpenVPN > VERIFY KU OK . 2020.07.31 03:46:28 - OpenVPN > Validating certificate extended key usage . 2020.07.31 03:46:28 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.07.31 03:46:28 - OpenVPN > VERIFY EKU OK . 2020.07.31 03:46:28 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Miram, emailAddress=info@airvpn.org . 2020.07.31 03:46:31 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2020.07.31 03:46:31 - OpenVPN > [Miram] Peer Connection Initiated with [AF_INET]213.152.162.91:443 . 2020.07.31 03:46:32 - OpenVPN > SENT CONTROL [Miram]: 'PUSH_REQUEST' (status=1) . 2020.07.31 03:46:32 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.24.82.1,dhcp-option DNS6 fde6:7a:7d20:1452::1,tun-ipv6,route-gateway 10.24.82.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1452::10d4/64 fde6:7a:7d20:1452::1,ifconfig 10.24.82.214 255.255.255.0,peer-id 4,cipher AES-256-GCM' . 2020.07.31 03:46:32 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.07.31 03:46:32 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.07.31 03:46:32 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.07.31 03:46:32 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.07.31 03:46:32 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.07.31 03:46:32 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.07.31 03:46:32 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.07.31 03:46:32 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.07.31 03:46:32 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.07.31 03:46:32 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.07.31 03:46:32 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.07.31 03:46:32 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.07.31 03:46:32 - OpenVPN > interactive service msg_channel=0 . 2020.07.31 03:46:32 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=24 HWADDR=28:e3:47:de:15:e4 . 2020.07.31 03:46:32 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.07.31 03:46:32 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2020.07.31 03:46:32 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2020.07.31 03:46:32 - OpenVPN > open_tun . 2020.07.31 03:46:33 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}.tap . 2020.07.31 03:46:33 - OpenVPN > TAP-Windows Driver Version 9.24 . 2020.07.31 03:46:33 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.24.82.0/10.24.82.214/255.255.255.0 [SUCCEEDED] . 2020.07.31 03:46:33 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.24.82.214/255.255.255.0 on interface {EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE} [DHCP-serv: 10.24.82.254, lease-time: 31536000] . 2020.07.31 03:46:33 - OpenVPN > Successful ARP Flush on interface [22] {EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE} . 2020.07.31 03:46:34 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=22 fde6:7a:7d20:1452::10d4 store=active . 2020.07.31 03:46:35 - Elevated: Command:wfp ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "gateway": "192.168.0.1", "metric": "40" }, { "address": "10.24.82.0\/24", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "281" }, { "address": "10.24.82.214", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "281" }, { "address": "10.24.82.255", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "281" }, { "address": "127.0.0.0\/8", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.0.0.1", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.255.255.255", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "192.168.0.0\/24", "interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "gateway": "link", "metric": "296" }, { "address": "192.168.0.149", "interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "gateway": "link", "metric": "296" }, { "address": "192.168.0.255", "interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "gateway": "link", "metric": "296" }, { "address": "224.0.0.0\/4", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "224.0.0.0\/4", "interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "gateway": "link", "metric": "296" }, { "address": "224.0.0.0\/4", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "281" }, { "address": "255.255.255.255", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "255.255.255.255", "interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "gateway": "link", "metric": "296" }, { "address": "255.255.255.255", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "281" }, { "address": "::1", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "fde6:7a:7d20:1452::\/64", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "fe80::8", "metric": "281" }, { "address": "fde6:7a:7d20:1452::10d4", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "281" }, { "address": "fe80::\/64", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "281" }, { "address": "fe80::f460:966:8fd9:760", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "281" }, { "address": "ff00::\/8", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "ff00::\/8", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "281" } ], "interfaces": [ { "friendly": "VPN96 - VPN Client", "id": "{2CBB5D18-06F3-40A1-BFAE-FE0687C6D5BA}", "name": "VPN96 - VPN Client", "description": "VPN Client Adapter - VPN96", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::602a:bec0:388d:6f21", "169.254.111.33" ], "gateways": [], "bind": true, "dns4": "10.34.114.1", "dns6": null }, { "friendly": "Ethernet", "id": "{5D29846A-28C9-4A31-A208-90C56266A50F}", "name": "Ethernet", "description": "Realtek PCIe GBE Family Controller", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::9006:9fe:5c0b:9a00", "169.254.154.0" ], "gateways": [], "bind": true, "dns4": "10.34.114.1", "dns6": null }, { "friendly": "Local Area Connection", "id": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "name": "Local Area Connection", "description": "TAP-Windows Adapter V9", "type": "53", "status": "Up", "bytes_received": "84794", "bytes_sent": "172851", "support_ipv4": true, "support_ipv6": true, "ips": [ "fde6:7a:7d20:1452::10d4", "fe80::f460:966:8fd9:760", "10.24.82.214" ], "gateways": [ "fe80::8" ], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 5", "id": "{A1F6AC17-5C77-4690-B3CC-722AB45D1515}", "name": "Local Area Connection* 5", "description": "Microsoft Wi-Fi Direct Virtual Adapter #4", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::2586:2944:f4ee:f301", "169.254.243.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 6", "id": "{E731BB16-67D2-42FA-B185-5E9A6CBE52C2}", "name": "Local Area Connection* 6", "description": "Microsoft Wi-Fi Direct Virtual Adapter #5", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::78e5:4fd3:e881:7e3c", "169.254.126.60" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Wi-Fi", "id": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "name": "Wi-Fi", "description": "Qualcomm Atheros AR5BWB222 Wireless Network Adapter", "type": "Wireless80211", "status": "Up", "bytes_received": "2303018580", "bytes_sent": "117677996", "support_ipv4": true, "support_ipv6": false, "ips": [ "192.168.0.149" ], "gateways": [ "192.168.0.1" ], "bind": true, "dns4": "8.8.8.8,8.8.4.4", "dns6": null }, { "friendly": "Bluetooth Network Connection", "id": "{18F00174-4165-4FA6-89D1-7D002635BD53}", "name": "Bluetooth Network Connection", "description": "Bluetooth Device (Personal Area Network)", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::15da:f5ea:ced5:b7a1", "169.254.183.161" ], "gateways": [], "bind": true, "dns4": "10.34.114.1", "dns6": null }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv6-default-gateway": "fe80::8", "ipv6-default-interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "ipv4-default-gateway": "192.168.0.1", "ipv4-default-interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}" } ---------------------------- ipconfig /all: Windows IP Configuration Host Name . . . . . . . . . . . . : rodnew Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : gateway Ethernet adapter VPN96 - VPN Client: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : VPN Client Adapter - VPN96 Physical Address. . . . . . . . . : 00-AC-45-D7-92-AA DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter Ethernet: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller Physical Address. . . . . . . . . : F8-0F-41-BB-D3-68 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Unknown adapter Local Area Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-Windows Adapter V9 Physical Address. . . . . . . . . : 00-FF-EE-35-32-F9 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : fde6:7a:7d20:1452::10d4(Preferred) Link-local IPv6 Address . . . . . : fe80::f460:966:8fd9:760%22(Preferred) IPv4 Address. . . . . . . . . . . : 10.24.82.214(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Friday, 31 July 2020 3:46:32 AM Lease Expires . . . . . . . . . . : Saturday, 31 July 2021 3:46:32 AM Default Gateway . . . . . . . . . : DHCP Server . . . . . . . . . . . : 10.24.82.254 DHCPv6 IAID . . . . . . . . . . . : 369164270 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-C8-8A-89-F8-0F-41-BB-D3-68 DNS Servers . . . . . . . . . . . : fde6:7a:7d20:1452::1 10.24.82.1 NetBIOS over Tcpip. . . . . . . . : Enabled Wireless LAN adapter Local Area Connection* 5: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4 Physical Address. . . . . . . . . : 1A-E3-47-DE-15-E4 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Local Area Connection* 6: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #5 Physical Address. . . . . . . . . : 2A-E3-47-DE-15-E4 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Wi-Fi: Connection-specific DNS Suffix . : gateway Description . . . . . . . . . . . : Qualcomm Atheros AR5BWB222 Wireless Network Adapter Physical Address. . . . . . . . . : 28-E3-47-DE-15-E4 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 192.168.0.149(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Friday, 31 July 2020 2:12:10 AM Lease Expires . . . . . . . . . . : Friday, 31 July 2020 4:36:29 AM Default Gateway . . . . . . . . . : 192.168.0.1 DHCP Server . . . . . . . . . . . : 192.168.0.1 DNS Servers . . . . . . . . . . . : 8.8.8.8 8.8.4.4 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Bluetooth Network Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) Physical Address. . . . . . . . . : 28-E3-47-DE-2B-E2 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Edited ... by giganerd Apply LOG format to logs Quote Share this post Link to post
rickrick 0 Posted ... hi im sorry I Cant get a working connection Im afraid so taht log will have to do hope it tells you something Quote Share this post Link to post
rickrick 0 Posted ... (edited) hi sorry I did get a connection that time here is the new report Eddie System/Environment Report - 30/07/2020 - 6:11 PM UTC Eddie version: 2.18.9 Eddie OS build: windows_x64 Eddie architecture: x64 OS type: Windows OS name: Windows 10 Home OS version: Microsoft Windows NT 10.0.18363.0 OS architecture: x64 Mono /.Net Framework: v4.0.30319 TUN driver: 0901: 9.24.2; wintun: Not found OpenVPN: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) Hummingbird: () SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe) SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe) Profile path: C:\Users\rod\AppData\Local\Eddie\default.profile Data path: C:\Users\rod\AppData\Local\Eddie Application path: C:\Program Files\AirVPN Executable path: C:\Program Files\AirVPN\Eddie-UI.exe Command line arguments: (1 args) path="home" Network Lock Active: Yes, Windows Filtering Platform Connected to VPN: Yes, Melnick Detected DNS: 10.34.18.1, 8.8.4.4, 8.8.8.8, fde6:7a:7d20:1e12::1 Test DNS IPv4: Ok Test DNS IPv6: Ok Test Ping IPv4: 312 ms Test Ping IPv6: 313 ms Test HTTP IPv4: Ok Test HTTP IPv6: Ok Test HTTPS: Ok ---------------------------- Important options not at defaults: login: (omissis) password: (omissis) remember: True servers.whitelist: bd4a4dbd393ee075bfbf2d8a6d019a37c376899d58b37f002d76119a081b0048,9ed77884ba296cb2814189cf6280124360e3ce8e93bb497086a24c01e2d26dca log.level.debug: True openvpn.custom: block-outside-dns ---------------------------- Logs: . 2020.07.31 04:02:09 - Eddie version: 2.18.9 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319 . 2020.07.31 04:02:09 - Command line arguments (1): path="home" . 2020.07.31 04:02:11 - Profile path: C:\Users\rod\AppData\Local\Eddie\default.profile . 2020.07.31 04:02:12 - Reading options from C:\Users\rod\AppData\Local\Eddie\default.profile . 2020.07.31 04:02:13 - Shell(1) of 'C:\Windows\system32\route.exe', 2 args: '-4';'PRINT'; . 2020.07.31 04:02:13 - Shell(1) done in 453 ms, exit: 0, out: '=========================================================================== . 2020.07.31 04:02:13 - Interface List . 2020.07.31 04:02:13 - 4...00 ac 45 d7 92 aa ......VPN Client Adapter - VPN96 . 2020.07.31 04:02:13 - 12...f8 0f 41 bb d3 68 ......Realtek PCIe GBE Family Controller . 2020.07.31 04:02:13 - 22...00 ff ee 35 32 f9 ......TAP-Windows Adapter V9 . 2020.07.31 04:02:13 - 21...1a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #4 . 2020.07.31 04:02:13 - 25...2a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #5 . 2020.07.31 04:02:13 - 24...28 e3 47 de 15 e4 ......Qualcomm Atheros AR5BWB222 Wireless Network Adapter . 2020.07.31 04:02:13 - 3...28 e3 47 de 2b e2 ......Bluetooth Device (Personal Area Network) . 2020.07.31 04:02:13 - 1...........................Software Loopback Interface 1 . 2020.07.31 04:02:13 - =========================================================================== . 2020.07.31 04:02:13 - IPv4 Route Table . 2020.07.31 04:02:13 - =========================================================================== . 2020.07.31 04:02:13 - Active Routes: . 2020.07.31 04:02:13 - Network Destination Netmask Gateway Interface Metric . 2020.07.31 04:02:13 - 0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.149 40 . 2020.07.31 04:02:13 - 127.0.0.0 255.0.0.0 On-link 127.0.0.1 331 . 2020.07.31 04:02:13 - 127.0.0.1 255.255.255.255 On-link 127.0.0.1 331 . 2020.07.31 04:02:13 - 127.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.07.31 04:02:13 - 192.168.0.0 255.255.255.0 On-link 192.168.0.149 296 . 2020.07.31 04:02:13 - 192.168.0.149 255.255.255.255 On-link 192.168.0.149 296 . 2020.07.31 04:02:13 - 192.168.0.255 255.255.255.255 On-link 192.168.0.149 296 . 2020.07.31 04:02:13 - 224.0.0.0 240.0.0.0 On-link 127.0.0.1 331 . 2020.07.31 04:02:13 - 224.0.0.0 240.0.0.0 On-link 192.168.0.149 296 . 2020.07.31 04:02:13 - 255.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.07.31 04:02:13 - 255.255.255.255 255.255.255.255 On-link 192.168.0.149 296 . 2020.07.31 04:02:13 - =========================================================================== . 2020.07.31 04:02:13 - Persistent Routes: . 2020.07.31 04:02:13 - None' . 2020.07.31 04:02:13 - Shell(2) of 'C:\Windows\system32\route.exe', 2 args: '-6';'PRINT'; . 2020.07.31 04:02:13 - Shell(2) done in 172 ms, exit: 0, out: '=========================================================================== . 2020.07.31 04:02:13 - Interface List . 2020.07.31 04:02:13 - 4...00 ac 45 d7 92 aa ......VPN Client Adapter - VPN96 . 2020.07.31 04:02:13 - 12...f8 0f 41 bb d3 68 ......Realtek PCIe GBE Family Controller . 2020.07.31 04:02:13 - 22...00 ff ee 35 32 f9 ......TAP-Windows Adapter V9 . 2020.07.31 04:02:13 - 21...1a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #4 . 2020.07.31 04:02:13 - 25...2a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #5 . 2020.07.31 04:02:13 - 24...28 e3 47 de 15 e4 ......Qualcomm Atheros AR5BWB222 Wireless Network Adapter . 2020.07.31 04:02:13 - 3...28 e3 47 de 2b e2 ......Bluetooth Device (Personal Area Network) . 2020.07.31 04:02:13 - 1...........................Software Loopback Interface 1 . 2020.07.31 04:02:13 - =========================================================================== . 2020.07.31 04:02:13 - IPv6 Route Table . 2020.07.31 04:02:13 - =========================================================================== . 2020.07.31 04:02:13 - Active Routes: . 2020.07.31 04:02:13 - If Metric Network Destination Gateway . 2020.07.31 04:02:13 - 1 331 ::1/128 On-link . 2020.07.31 04:02:13 - 1 331 ff00::/8 On-link . 2020.07.31 04:02:13 - =========================================================================== . 2020.07.31 04:02:13 - Persistent Routes: . 2020.07.31 04:02:13 - None' . 2020.07.31 04:02:16 - Elevated: Command:wfp . 2020.07.31 04:02:16 - Shell(3) of 'C:\Program Files\AirVPN\openvpn.exe', 1 args: '--version'; . 2020.07.31 04:02:17 - Shell(3) done in 313 ms, exit: 1, out: 'OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2020.07.31 04:02:17 - library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2020.07.31 04:02:17 - Windows version 6.2 (Windows 8 or greater) 64bit . 2020.07.31 04:02:17 - Originally developed by James Yonan . 2020.07.31 04:02:17 - Copyright (C) 2002-2018 OpenVPN Inc <sales@openvpn.net> . 2020.07.31 04:02:17 - Compile time defines: enable_async_push=no enable_comp_stub=no enable_crypto=yes enable_crypto_ofb_cfb=yes enable_debug=yes enable_def_auth=yes enable_dlopen=unknown enable_dlopen_self=unknown enable_dlopen_self_static=unknown enable_fast_install=needless enable_fragment=yes enable_iproute2=no enable_libtool_lock=yes enable_lz4=yes enable_lzo=yes enable_management=yes enable_multihome=yes enable_pam_dlopen=no enable_pedantic=no enable_pf=yes enable_pkcs11=yes enable_plugin_auth_pam=no enable_plugin_down_root=no enable_plugins=yes enable_port_share=yes enable_selinux=no enable_server=yes enable_shared=yes enable_shared_with_static_runtimes=yes enable_small=no enable_static=yes enable_strict=no enable_strict_options=no enable_systemd=no enable_werror=no enable_win32_dll=yes enable_x509_alt_username=no with_aix_soname=aix with_crypto_library=openssl with_gnu_ld=yes with_mem_check=no with_special_build= with_sysroot=no' . 2020.07.31 04:02:17 - Shell(4) of 'C:\Program Files\AirVPN\plink.exe', 1 args: '-V'; . 2020.07.31 04:02:17 - Shell(4) done in 219 ms, exit: 1, out: 'plink: Release 0.67' . 2020.07.31 04:02:17 - Shell(5) of 'C:\Program Files\AirVPN\stunnel.exe', 1 args: '-version'; . 2020.07.31 04:02:17 - Shell(5) done in 422 ms, exit: 0, err: 'stunnel 5.40 on x86-pc-mingw32-gnu platform . 2020.07.31 04:02:17 - Compiled/running with OpenSSL 1.0.2k 26 Jan 2017 . 2020.07.31 04:02:17 - Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI . 2020.07.31 04:02:17 - Global options: . 2020.07.31 04:02:17 - RNDbytes = 64 . 2020.07.31 04:02:17 - RNDoverwrite = yes . 2020.07.31 04:02:17 - taskbar = yes . 2020.07.31 04:02:17 - Service-level options: . 2020.07.31 04:02:17 - ciphers = HIGH:!DH:!aNULL:!SSLv2 . 2020.07.31 04:02:17 - curve = prime256v1 . 2020.07.31 04:02:17 - debug = notice . 2020.07.31 04:02:17 - logId = sequential . 2020.07.31 04:02:17 - options = NO_SSLv2 . 2020.07.31 04:02:17 - options = NO_SSLv3 . 2020.07.31 04:02:17 - sessionCacheSize = 1000 . 2020.07.31 04:02:17 - sessionCacheTimeout = 300 seconds . 2020.07.31 04:02:17 - stack = 65536 bytes . 2020.07.31 04:02:17 - TIMEOUTbusy = 300 seconds . 2020.07.31 04:02:17 - TIMEOUTclose = 60 seconds . 2020.07.31 04:02:17 - TIMEOUTconnect = 10 seconds . 2020.07.31 04:02:17 - TIMEOUTidle = 43200 seconds . 2020.07.31 04:02:17 - verify = none' . 2020.07.31 04:02:17 - Shell(6) of 'C:\Program Files\AirVPN\curl.exe', 1 args: '--version'; . 2020.07.31 04:02:18 - Shell(6) done in 203 ms, exit: 0, out: 'curl 7.68.0 (x86_64-pc-win32) libcurl/7.68.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 WinIDN libssh2/1.9.0 nghttp2/1.40.0 . 2020.07.31 04:02:18 - Release-Date: 2020-01-08 . 2020.07.31 04:02:18 - Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtsp scp sftp smb smbs smtp smtps telnet tftp . 2020.07.31 04:02:18 - Features: AsynchDNS HTTP2 HTTPS-proxy IDN IPv6 Kerberos Largefile MultiSSL NTLM SPNEGO SSL SSPI TLS-SRP brotli libz' . 2020.07.31 04:02:18 - Tun Driver - 0901: 9.24.2; wintun: Not found . 2020.07.31 04:02:18 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2020.07.31 04:02:18 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2020.07.31 04:02:18 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2020.07.31 04:02:18 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe) . 2020.07.31 04:02:18 - Elevated: Command:wfp W 2020.07.31 04:02:22 - Windows WFP, recovery of pending rules. . 2020.07.31 04:02:22 - Recovery. Unexpected crash? ! 2020.07.31 04:02:22 - Deactivation of Network Lock I 2020.07.31 04:02:24 - Ready . 2020.07.31 04:02:26 - Collect information about AirVPN completed ! 2020.07.31 04:02:31 - Activation of Network Lock - Windows Filtering Platform . 2020.07.31 04:02:31 - Elevated: Command:wfp . 2020.07.31 04:02:33 - Above log line repeated 45 times more ! 2020.07.31 04:02:33 - Deactivation of Network Lock . 2020.07.31 04:02:33 - Elevated: Command:wfp . 2020.07.31 04:08:06 - Above log line repeated 45 times more ! 2020.07.31 04:08:06 - Activation of Network Lock - Windows Filtering Platform . 2020.07.31 04:08:06 - Elevated: Command:wfp . 2020.07.31 04:08:27 - Above log line repeated 45 times more I 2020.07.31 04:08:27 - Session starting. I 2020.07.31 04:08:30 - Checking authorization ... . 2020.07.31 04:08:30 - Elevated: Command:wfp . 2020.07.31 04:08:33 - Above log line repeated 11 times more ! 2020.07.31 04:08:33 - Connecting to Melnick (Netherlands, Alblasserdam) . 2020.07.31 04:08:33 - Elevated: Command:wfp . 2020.07.31 04:08:33 - Above log line repeated 5 times more . 2020.07.31 04:08:33 - Elevated: Command:process_openvpn . 2020.07.31 04:08:35 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019 . 2020.07.31 04:08:35 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2020.07.31 04:08:35 - OpenVPN > library versions: OpenSSL 1.1.0l 10 Sep 2019, LZO 2.10 . 2020.07.31 04:08:35 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.07.31 04:08:35 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.07.31 04:08:35 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2020.07.31 04:08:35 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2020.07.31 04:08:35 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.165:443 . 2020.07.31 04:08:35 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2020.07.31 04:08:35 - OpenVPN > UDP link local: (not bound) . 2020.07.31 04:08:35 - OpenVPN > UDP link remote: [AF_INET]134.19.179.165:443 . 2020.07.31 04:08:36 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.165:443, sid=18174d19 ff6ccea8 . 2020.07.31 04:08:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2020.07.31 04:08:36 - OpenVPN > VERIFY KU OK . 2020.07.31 04:08:36 - OpenVPN > Validating certificate extended key usage . 2020.07.31 04:08:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2020.07.31 04:08:36 - OpenVPN > VERIFY EKU OK . 2020.07.31 04:08:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Melnick, emailAddress=info@airvpn.org . 2020.07.31 04:08:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2020.07.31 04:08:38 - OpenVPN > [Melnick] Peer Connection Initiated with [AF_INET]134.19.179.165:443 . 2020.07.31 04:08:40 - OpenVPN > SENT CONTROL [Melnick]: 'PUSH_REQUEST' (status=1) . 2020.07.31 04:08:40 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.34.18.1,dhcp-option DNS6 fde6:7a:7d20:1e12::1,tun-ipv6,route-gateway 10.34.18.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1e12::10dd/64 fde6:7a:7d20:1e12::1,ifconfig 10.34.18.223 255.255.255.0,peer-id 5,cipher AES-256-GCM' . 2020.07.31 04:08:40 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2020.07.31 04:08:40 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2020.07.31 04:08:40 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2020.07.31 04:08:40 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2020.07.31 04:08:40 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2020.07.31 04:08:40 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2020.07.31 04:08:40 - OpenVPN > OPTIONS IMPORT: peer-id set . 2020.07.31 04:08:40 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2020.07.31 04:08:40 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2020.07.31 04:08:40 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2020.07.31 04:08:40 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.07.31 04:08:40 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2020.07.31 04:08:40 - OpenVPN > interactive service msg_channel=0 . 2020.07.31 04:08:40 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=24 HWADDR=28:e3:47:de:15:e4 . 2020.07.31 04:08:40 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2020.07.31 04:08:40 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168) . 2020.07.31 04:08:40 - OpenVPN > ROUTE6: default_gateway=UNDEF . 2020.07.31 04:08:40 - OpenVPN > open_tun . 2020.07.31 04:08:42 - Elevated: Command:wfp . 2020.07.31 04:08:43 - Above log line repeated 5 times more . 2020.07.31 04:08:43 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}.tap . 2020.07.31 04:08:43 - OpenVPN > TAP-Windows Driver Version 9.24 . 2020.07.31 04:08:43 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.34.18.0/10.34.18.223/255.255.255.0 [SUCCEEDED] . 2020.07.31 04:08:43 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.34.18.223/255.255.255.0 on interface {EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE} [DHCP-serv: 10.34.18.254, lease-time: 31536000] . 2020.07.31 04:08:43 - OpenVPN > Successful ARP Flush on interface [22] {EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE} . 2020.07.31 04:08:43 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=22 fde6:7a:7d20:1e12::10dd store=active . 2020.07.31 04:08:44 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Local Area Connection static fde6:7a:7d20:1e12::1 validate=no . 2020.07.31 04:08:46 - Shell(7) of 'C:\Windows\system32\route.exe', 2 args: '-6';'PRINT'; . 2020.07.31 04:08:47 - Shell(7) done in 1109 ms, exit: 0, out: '=========================================================================== . 2020.07.31 04:08:47 - Interface List . 2020.07.31 04:08:47 - 4...00 ac 45 d7 92 aa ......VPN Client Adapter - VPN96 . 2020.07.31 04:08:47 - 12...f8 0f 41 bb d3 68 ......Realtek PCIe GBE Family Controller . 2020.07.31 04:08:47 - 22...00 ff ee 35 32 f9 ......TAP-Windows Adapter V9 . 2020.07.31 04:08:47 - 21...1a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #4 . 2020.07.31 04:08:47 - 25...2a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #5 . 2020.07.31 04:08:47 - 24...28 e3 47 de 15 e4 ......Qualcomm Atheros AR5BWB222 Wireless Network Adapter . 2020.07.31 04:08:47 - 3...28 e3 47 de 2b e2 ......Bluetooth Device (Personal Area Network) . 2020.07.31 04:08:47 - 1...........................Software Loopback Interface 1 . 2020.07.31 04:08:47 - =========================================================================== . 2020.07.31 04:08:47 - IPv6 Route Table . 2020.07.31 04:08:47 - =========================================================================== . 2020.07.31 04:08:47 - Active Routes: . 2020.07.31 04:08:47 - If Metric Network Destination Gateway . 2020.07.31 04:08:47 - 1 331 ::1/128 On-link . 2020.07.31 04:08:47 - 22 281 fde6:7a:7d20:1e12::/64 On-link . 2020.07.31 04:08:47 - 22 281 fde6:7a:7d20:1e12::/64 fe80::8 . 2020.07.31 04:08:47 - 22 281 fde6:7a:7d20:1e12::10dd/128 . 2020.07.31 04:08:47 - On-link . 2020.07.31 04:08:47 - 22 281 fe80::/64 On-link . 2020.07.31 04:08:47 - 22 281 fe80::f460:966:8fd9:760/128 . 2020.07.31 04:08:47 - On-link . 2020.07.31 04:08:47 - 1 331 ff00::/8 On-link . 2020.07.31 04:08:47 - 22 281 ff00::/8 On-link . 2020.07.31 04:08:47 - =========================================================================== . 2020.07.31 04:08:47 - Persistent Routes: . 2020.07.31 04:08:47 - None' . 2020.07.31 04:08:47 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2020.07.31 04:08:47 - Elevated: Command:windows-workaround-25139 . 2020.07.31 04:08:49 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1e12::/64 -> fde6:7a:7d20:1e12::10dd metric 0) dev Local Area Connection . 2020.07.31 04:08:49 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1e12::/64 interface=22 fe80::8 store=active . 2020.07.31 04:08:49 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 04:08:50 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2020.07.31 04:08:50 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 134.19.179.165 MASK 255.255.255.255 192.168.0.1 . 2020.07.31 04:08:50 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4 . 2020.07.31 04:08:50 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.07.31 04:08:50 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.34.18.1 . 2020.07.31 04:08:50 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.07.31 04:08:50 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.07.31 04:08:50 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.34.18.1 . 2020.07.31 04:08:50 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2020.07.31 04:08:50 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2020.07.31 04:08:50 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1e12::1 metric -1) dev Local Area Connection . 2020.07.31 04:08:50 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=22 fe80::8 store=active . 2020.07.31 04:08:50 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 04:08:50 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1e12::1 metric -1) dev Local Area Connection . 2020.07.31 04:08:50 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=22 fe80::8 store=active . 2020.07.31 04:08:50 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 04:08:51 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1e12::1 metric -1) dev Local Area Connection . 2020.07.31 04:08:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=22 fe80::8 store=active . 2020.07.31 04:08:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 04:08:51 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1e12::1 metric -1) dev Local Area Connection . 2020.07.31 04:08:51 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=22 fe80::8 store=active . 2020.07.31 04:08:51 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2020.07.31 04:08:52 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2020.07.31 04:08:52 - Elevated: Command:set-interface-metric . 2020.07.31 04:08:52 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6 . 2020.07.31 04:08:52 - Elevated: Command:set-interface-metric . 2020.07.31 04:08:52 - Elevated: Command:wfp . 2020.07.31 04:09:52 - Above log line repeated 5 times more . 2020.07.31 04:09:52 - DNS leak protection with packet filtering enabled. . 2020.07.31 04:09:52 - Shell(8) of 'C:\Windows\system32\route.exe', 2 args: '-4';'PRINT'; . 2020.07.31 04:09:53 - Shell(8) done in 766 ms, exit: 0, out: '=========================================================================== . 2020.07.31 04:09:53 - Interface List . 2020.07.31 04:09:53 - 4...00 ac 45 d7 92 aa ......VPN Client Adapter - VPN96 . 2020.07.31 04:09:53 - 22...00 ff ee 35 32 f9 ......TAP-Windows Adapter V9 . 2020.07.31 04:09:53 - 12...f8 0f 41 bb d3 68 ......Realtek PCIe GBE Family Controller . 2020.07.31 04:09:53 - 21...1a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #4 . 2020.07.31 04:09:53 - 25...2a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #5 . 2020.07.31 04:09:53 - 24...28 e3 47 de 15 e4 ......Qualcomm Atheros AR5BWB222 Wireless Network Adapter . 2020.07.31 04:09:53 - 3...28 e3 47 de 2b e2 ......Bluetooth Device (Personal Area Network) . 2020.07.31 04:09:53 - 1...........................Software Loopback Interface 1 . 2020.07.31 04:09:53 - =========================================================================== . 2020.07.31 04:09:53 - IPv4 Route Table . 2020.07.31 04:09:53 - =========================================================================== . 2020.07.31 04:09:53 - Active Routes: . 2020.07.31 04:09:53 - Network Destination Netmask Gateway Interface Metric . 2020.07.31 04:09:53 - 0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.149 40 . 2020.07.31 04:09:53 - 0.0.0.0 128.0.0.0 10.34.18.1 10.34.18.223 3 . 2020.07.31 04:09:53 - 10.34.18.0 255.255.255.0 On-link 10.34.18.223 259 . 2020.07.31 04:09:53 - 10.34.18.223 255.255.255.255 On-link 10.34.18.223 259 . 2020.07.31 04:09:53 - 10.34.18.255 255.255.255.255 On-link 10.34.18.223 259 . 2020.07.31 04:09:53 - 127.0.0.0 255.0.0.0 On-link 127.0.0.1 331 . 2020.07.31 04:09:53 - 127.0.0.1 255.255.255.255 On-link 127.0.0.1 331 . 2020.07.31 04:09:53 - 127.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.07.31 04:09:53 - 128.0.0.0 128.0.0.0 10.34.18.1 10.34.18.223 3 . 2020.07.31 04:09:53 - 134.19.179.165 255.255.255.255 192.168.0.1 192.168.0.149 40 . 2020.07.31 04:09:53 - 192.168.0.0 255.255.255.0 On-link 192.168.0.149 296 . 2020.07.31 04:09:53 - 192.168.0.149 255.255.255.255 On-link 192.168.0.149 296 . 2020.07.31 04:09:53 - 192.168.0.255 255.255.255.255 On-link 192.168.0.149 296 . 2020.07.31 04:09:53 - 224.0.0.0 240.0.0.0 On-link 127.0.0.1 331 . 2020.07.31 04:09:53 - 224.0.0.0 240.0.0.0 On-link 192.168.0.149 296 . 2020.07.31 04:09:53 - 224.0.0.0 240.0.0.0 On-link 10.34.18.223 259 . 2020.07.31 04:09:53 - 255.255.255.255 255.255.255.255 On-link 127.0.0.1 331 . 2020.07.31 04:09:53 - 255.255.255.255 255.255.255.255 On-link 192.168.0.149 296 . 2020.07.31 04:09:53 - 255.255.255.255 255.255.255.255 On-link 10.34.18.223 259 . 2020.07.31 04:09:53 - =========================================================================== . 2020.07.31 04:09:53 - Persistent Routes: . 2020.07.31 04:09:53 - None' . 2020.07.31 04:09:53 - Shell(9) of 'C:\Windows\system32\route.exe', 2 args: '-6';'PRINT'; . 2020.07.31 04:09:53 - Shell(9) done in 187 ms, exit: 0, out: '=========================================================================== . 2020.07.31 04:09:53 - Interface List . 2020.07.31 04:09:53 - 4...00 ac 45 d7 92 aa ......VPN Client Adapter - VPN96 . 2020.07.31 04:09:53 - 22...00 ff ee 35 32 f9 ......TAP-Windows Adapter V9 . 2020.07.31 04:09:53 - 12...f8 0f 41 bb d3 68 ......Realtek PCIe GBE Family Controller . 2020.07.31 04:09:53 - 21...1a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #4 . 2020.07.31 04:09:53 - 25...2a e3 47 de 15 e4 ......Microsoft Wi-Fi Direct Virtual Adapter #5 . 2020.07.31 04:09:53 - 24...28 e3 47 de 15 e4 ......Qualcomm Atheros AR5BWB222 Wireless Network Adapter . 2020.07.31 04:09:53 - 3...28 e3 47 de 2b e2 ......Bluetooth Device (Personal Area Network) . 2020.07.31 04:09:53 - 1...........................Software Loopback Interface 1 . 2020.07.31 04:09:53 - =========================================================================== . 2020.07.31 04:09:53 - IPv6 Route Table . 2020.07.31 04:09:53 - =========================================================================== . 2020.07.31 04:09:53 - Active Routes: . 2020.07.31 04:09:53 - If Metric Network Destination Gateway . 2020.07.31 04:09:53 - 22 259 ::/3 fe80::8 . 2020.07.31 04:09:53 - 1 331 ::1/128 On-link . 2020.07.31 04:09:53 - 22 259 2000::/4 fe80::8 . 2020.07.31 04:09:53 - 22 259 3000::/4 fe80::8 . 2020.07.31 04:09:53 - 22 259 fc00::/7 fe80::8 . 2020.07.31 04:09:53 - 22 259 fde6:7a:7d20:1e12::/64 fe80::8 . 2020.07.31 04:09:53 - 22 259 fde6:7a:7d20:1e12::10dd/128 . 2020.07.31 04:09:53 - On-link . 2020.07.31 04:09:53 - 22 259 fe80::/64 On-link . 2020.07.31 04:09:53 - 22 259 fe80::f460:966:8fd9:760/128 . 2020.07.31 04:09:53 - On-link . 2020.07.31 04:09:53 - 1 331 ff00::/8 On-link . 2020.07.31 04:09:53 - 22 259 ff00::/8 On-link . 2020.07.31 04:09:53 - =========================================================================== . 2020.07.31 04:09:53 - Persistent Routes: . 2020.07.31 04:09:53 - None' . 2020.07.31 04:09:54 - Elevated: Command:route . 2020.07.31 04:09:54 - Routes, added a new route, 134.19.179.163 for gateway 10.34.18.1 . 2020.07.31 04:09:55 - Elevated: Command:route . 2020.07.31 04:09:56 - Routes, added a new route, 2a00:1678:2470:eeee:2259:2a8b:386:4b98 for gateway fde6:7a:7d20:1e12::1 . 2020.07.31 04:09:56 - Flushing DNS . 2020.07.31 04:09:56 - Elevated: Command:dns-flush . 2020.07.31 04:09:56 - Shell(10) of 'C:\Windows\system32\ipconfig.exe', 1 args: '/flushdns'; . 2020.07.31 04:09:56 - Shell(10) done in 235 ms, exit: 0, out: 'Windows IP Configuration . 2020.07.31 04:09:56 - Successfully flushed the DNS Resolver Cache.' I 2020.07.31 04:09:56 - Checking route IPv4 . 2020.07.31 04:09:56 - Elevated: Command:wfp . 2020.07.31 04:10:26 - Above log line repeated 11 times more I 2020.07.31 04:10:26 - Checking route IPv6 . 2020.07.31 04:10:26 - Elevated: Command:wfp . 2020.07.31 04:10:32 - Above log line repeated 23 times more I 2020.07.31 04:10:32 - Checking DNS . 2020.07.31 04:10:32 - Elevated: Command:wfp . 2020.07.31 04:10:34 - Above log line repeated 11 times more ! 2020.07.31 04:10:34 - Connected. . 2020.07.31 04:10:34 - OpenVPN > Initialization Sequence Completed . 2020.07.31 04:11:15 - Elevated: Command:wfp ---------------------------- Network Interfaces and Routes: { "support_ipv4": true, "support_ipv6": true, "routes": [ { "address": "0.0.0.0\/0", "interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "gateway": "192.168.0.1", "metric": "40" }, { "address": "0.0.0.0\/1", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "10.34.18.1", "metric": "3" }, { "address": "10.34.18.0\/24", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "259" }, { "address": "10.34.18.223", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "259" }, { "address": "10.34.18.255", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "259" }, { "address": "127.0.0.0\/8", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.0.0.1", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "127.255.255.255", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "128.0.0.0\/1", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "10.34.18.1", "metric": "3" }, { "address": "134.19.179.163", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "10.34.18.1", "metric": "4" }, { "address": "134.19.179.165", "interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "gateway": "192.168.0.1", "metric": "40" }, { "address": "192.168.0.0\/24", "interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "gateway": "link", "metric": "296" }, { "address": "192.168.0.149", "interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "gateway": "link", "metric": "296" }, { "address": "192.168.0.255", "interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "gateway": "link", "metric": "296" }, { "address": "224.0.0.0\/4", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "224.0.0.0\/4", "interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "gateway": "link", "metric": "296" }, { "address": "224.0.0.0\/4", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "259" }, { "address": "255.255.255.255", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "255.255.255.255", "interface": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "gateway": "link", "metric": "296" }, { "address": "255.255.255.255", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "259" }, { "address": "::\/3", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "fe80::8", "metric": "259" }, { "address": "::1", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "2000::\/4", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "fe80::8", "metric": "259" }, { "address": "2a00:1678:2470:eeee:2259:2a8b:386:4b98", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "fde6:7a:7d20:1e12::1", "metric": "259" }, { "address": "3000::\/4", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "fe80::8", "metric": "259" }, { "address": "fc00::\/7", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "fe80::8", "metric": "259" }, { "address": "fde6:7a:7d20:1e12::\/64", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "fe80::8", "metric": "259" }, { "address": "fde6:7a:7d20:1e12::10dd", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "259" }, { "address": "fe80::\/64", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "259" }, { "address": "fe80::f460:966:8fd9:760", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "259" }, { "address": "ff00::\/8", "interface": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "gateway": "link", "metric": "331" }, { "address": "ff00::\/8", "interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "gateway": "link", "metric": "259" }, { "address": "2a00:1678:2470:eeee:2259:2a8b:386:4b98", "gateway": "fde6:7a:7d20:1e12::1", "metric": "4294967295" } ], "interfaces": [ { "friendly": "VPN96 - VPN Client", "id": "{2CBB5D18-06F3-40A1-BFAE-FE0687C6D5BA}", "name": "VPN96 - VPN Client", "description": "VPN Client Adapter - VPN96", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::602a:bec0:388d:6f21", "169.254.111.33" ], "gateways": [], "bind": true, "dns4": "10.34.114.1", "dns6": null }, { "friendly": "Local Area Connection", "id": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "name": "Local Area Connection", "description": "TAP-Windows Adapter V9", "type": "53", "status": "Up", "bytes_received": "162672", "bytes_sent": "549110", "support_ipv4": true, "support_ipv6": true, "ips": [ "fde6:7a:7d20:1e12::10dd", "fe80::f460:966:8fd9:760", "10.34.18.223" ], "gateways": [ "10.34.18.1", "fe80::8", "fde6:7a:7d20:1e12::1" ], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Ethernet", "id": "{5D29846A-28C9-4A31-A208-90C56266A50F}", "name": "Ethernet", "description": "Realtek PCIe GBE Family Controller", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::9006:9fe:5c0b:9a00", "169.254.154.0" ], "gateways": [], "bind": true, "dns4": "10.34.114.1", "dns6": null }, { "friendly": "Local Area Connection* 5", "id": "{A1F6AC17-5C77-4690-B3CC-722AB45D1515}", "name": "Local Area Connection* 5", "description": "Microsoft Wi-Fi Direct Virtual Adapter #4", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::2586:2944:f4ee:f301", "169.254.243.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Local Area Connection* 6", "id": "{E731BB16-67D2-42FA-B185-5E9A6CBE52C2}", "name": "Local Area Connection* 6", "description": "Microsoft Wi-Fi Direct Virtual Adapter #5", "type": "Wireless80211", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::78e5:4fd3:e881:7e3c", "169.254.126.60" ], "gateways": [], "bind": true, "dns4": "", "dns6": null }, { "friendly": "Wi-Fi", "id": "{D500A14A-E790-46CF-A3F0-71BF28846087}", "name": "Wi-Fi", "description": "Qualcomm Atheros AR5BWB222 Wireless Network Adapter", "type": "Wireless80211", "status": "Up", "bytes_received": "2306285457", "bytes_sent": "119914438", "support_ipv4": true, "support_ipv6": false, "ips": [ "192.168.0.149" ], "gateways": [ "192.168.0.1" ], "bind": true, "dns4": "8.8.8.8,8.8.4.4", "dns6": null }, { "friendly": "Bluetooth Network Connection", "id": "{18F00174-4165-4FA6-89D1-7D002635BD53}", "name": "Bluetooth Network Connection", "description": "Bluetooth Device (Personal Area Network)", "type": "Ethernet", "status": "Down", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "fe80::15da:f5ea:ced5:b7a1", "169.254.183.161" ], "gateways": [], "bind": true, "dns4": "10.34.114.1", "dns6": null }, { "friendly": "Loopback Pseudo-Interface 1", "id": "{7BB6606D-102E-11E8-B82F-806E6F6E6963}", "name": "Loopback Pseudo-Interface 1", "description": "Software Loopback Interface 1", "type": "Loopback", "status": "Up", "bytes_received": "0", "bytes_sent": "0", "support_ipv4": true, "support_ipv6": true, "ips": [ "::1", "127.0.0.1" ], "gateways": [], "bind": true, "dns4": "", "dns6": null } ], "ipv4-default-gateway": "10.34.18.1", "ipv4-default-interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}", "ipv6-default-gateway": "fe80::8", "ipv6-default-interface": "{EE3532F9-CFD5-4AAE-A4A5-2EF3EA1754BE}" } ---------------------------- ipconfig /all: Windows IP Configuration Host Name . . . . . . . . . . . . : rodnew Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : gateway Ethernet adapter VPN96 - VPN Client: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : VPN Client Adapter - VPN96 Physical Address. . . . . . . . . : 00-AC-45-D7-92-AA DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Unknown adapter Local Area Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : TAP-Windows Adapter V9 Physical Address. . . . . . . . . : 00-FF-EE-35-32-F9 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : fde6:7a:7d20:1e12::10dd(Preferred) Link-local IPv6 Address . . . . . : fe80::f460:966:8fd9:760%22(Preferred) IPv4 Address. . . . . . . . . . . : 10.34.18.223(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Friday, 31 July 2020 4:08:41 AM Lease Expires . . . . . . . . . . : Saturday, 31 July 2021 4:08:40 AM Default Gateway . . . . . . . . . : DHCP Server . . . . . . . . . . . : 10.34.18.254 DHCPv6 IAID . . . . . . . . . . . : 369164270 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-C8-8A-89-F8-0F-41-BB-D3-68 DNS Servers . . . . . . . . . . . : fde6:7a:7d20:1e12::1 10.34.18.1 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Ethernet: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller Physical Address. . . . . . . . . : F8-0F-41-BB-D3-68 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Local Area Connection* 5: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4 Physical Address. . . . . . . . . : 1A-E3-47-DE-15-E4 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Local Area Connection* 6: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #5 Physical Address. . . . . . . . . : 2A-E3-47-DE-15-E4 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Wi-Fi: Connection-specific DNS Suffix . : gateway Description . . . . . . . . . . . : Qualcomm Atheros AR5BWB222 Wireless Network Adapter Physical Address. . . . . . . . . : 28-E3-47-DE-15-E4 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IPv4 Address. . . . . . . . . . . : 192.168.0.149(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Friday, 31 July 2020 2:12:11 AM Lease Expires . . . . . . . . . . : Friday, 31 July 2020 5:04:14 AM Default Gateway . . . . . . . . . : 192.168.0.1 DHCP Server . . . . . . . . . . . : 192.168.0.1 DNS Servers . . . . . . . . . . . : 8.8.8.8 8.8.4.4 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Bluetooth Network Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) Physical Address. . . . . . . . . : 28-E3-47-DE-2B-E2 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Edited ... by giganerd Apply LOG format to logs Quote Share this post Link to post
