hardcopymuse@100
Eddie keeps restarting and won't connect.
I have tried reinstalling and logging out. Help would be apperciated.
. 2020.07.11 22:05:39 - Eddie version: 2.18.9 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319
. 2020.07.11 22:05:39 - Command line arguments (1): path="home"
. 2020.07.11 22:05:41 - Raise system privileges
. 2020.07.11 22:05:45 - Profile path: C:\Users\ksr75\AppData\Local\Eddie\default.profile
. 2020.07.11 22:05:45 - Reading options from C:\Users\ksr75\AppData\Local\Eddie\default.profile
. 2020.07.11 22:05:46 - Tun Driver - 0901: 9.24.2; wintun: Not found
. 2020.07.11 22:05:46 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2020.07.11 22:05:46 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2020.07.11 22:05:46 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2020.07.11 22:05:46 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe)
. 2020.07.11 22:05:46 - Recovery. Unexpected crash?
. 2020.07.11 22:05:46 - Routes, removed an existing route, 184.75.223.211 for gateway 10.4.206.1
. 2020.07.11 22:05:46 - Routes, added a new route, 104.254.90.195 for gateway 10.29.238.1
. 2020.07.11 22:05:46 - Routes, added a new route, 104.254.90.187 for gateway 10.28.78.1
. 2020.07.11 22:05:46 - Routes, added a new route, 2606:6080:1002:8:3285:30e:de43:8809 for gateway fde6:7a:7d20:18ee::1
. 2020.07.11 22:05:46 - Routes, removed an existing route, 137.63.71.51 for gateway 10.31.78.1
. 2020.07.11 22:05:46 - Routes, removed an existing route, 184.75.223.235 for gateway 10.10.238.1
. 2020.07.11 22:05:47 - Routes, added a new route, 104.254.90.243 for gateway 10.16.78.1
. 2020.07.11 22:05:47 - Routes, added a new route, 2606:6080:2001:9:2679:addd:655:8142 for gateway fde6:7a:7d20:c4e::1
. 2020.07.11 22:05:47 - Routes, removed an existing route, 184.75.221.163 for gateway 10.9.46.1
. 2020.07.11 22:05:47 - Routes, removed an existing route, 2606:6080:1001:12:257a:8b87:f80d:7579 for gateway fde6:7a:7d20:52e::1
I 2020.07.11 22:05:47 - Ready
. 2020.07.11 22:05:49 - Collect information about AirVPN completed
I 2020.07.11 22:05:59 - Checking login ...
! 2020.07.11 22:06:00 - Logged in.
I 2020.07.11 22:06:05 - Session starting.
I 2020.07.11 22:06:05 - Checking authorization ...
! 2020.07.11 22:06:06 - Connecting to Tiaki (Netherlands, Alblasserdam)
. 2020.07.11 22:06:06 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.11 22:06:06 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.11 22:06:06 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.11 22:06:06 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:06:06 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:06:06 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:06:06 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:06:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]134.19.179.237:443
. 2020.07.11 22:06:06 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.11 22:06:06 - OpenVPN > UDP link local: (not bound)
. 2020.07.11 22:06:06 - OpenVPN > UDP link remote: [AF_INET]134.19.179.237:443
. 2020.07.11 22:06:06 - OpenVPN > TLS: Initial packet from [AF_INET]134.19.179.237:443, sid=d98bc73d 31b51d02
. 2020.07.11 22:06:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.11 22:06:06 - OpenVPN > VERIFY KU OK
. 2020.07.11 22:06:06 - OpenVPN > Validating certificate extended key usage
. 2020.07.11 22:06:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.11 22:06:06 - OpenVPN > VERIFY EKU OK
. 2020.07.11 22:06:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tiaki, emailAddress=info@airvpn.org
. 2020.07.11 22:06:07 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.11 22:06:07 - OpenVPN > [Tiaki] Peer Connection Initiated with [AF_INET]134.19.179.237:443
. 2020.07.11 22:06:08 - OpenVPN > SENT CONTROL [Tiaki]: 'PUSH_REQUEST' (status=1)
. 2020.07.11 22:06:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.34.170.1,dhcp-option DNS6 fde6:7a:7d20:1eaa::1,tun-ipv6,route-gateway 10.34.170.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1eaa::107e/64 fde6:7a:7d20:1eaa::1,ifconfig 10.34.170.128 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2020.07.11 22:06:08 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.11 22:06:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.11 22:06:08 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.11 22:06:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.11 22:06:08 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.11 22:06:08 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.11 22:06:08 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.11 22:06:08 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.11 22:06:08 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.11 22:06:08 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.11 22:06:08 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:06:08 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:06:08 - OpenVPN > interactive service msg_channel=0
. 2020.07.11 22:06:08 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=60:f2:62:89:2c:72
. 2020.07.11 22:06:08 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.11 22:06:08 - OpenVPN > GetBestInterfaceEx() returned if=4
. 2020.07.11 22:06:08 - OpenVPN > GDG6: II=4 DP=::/3 NH=fe80::8
. 2020.07.11 22:06:08 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.11 22:06:08 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=4
. 2020.07.11 22:06:08 - OpenVPN > open_tun
. 2020.07.11 22:06:08 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{1AC25C0C-91CC-413E-9963-FEC10EE837F6}.tap
. 2020.07.11 22:06:08 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.11 22:06:08 - OpenVPN > Exiting due to fatal error
! 2020.07.11 22:06:08 - Disconnecting
. 2020.07.11 22:06:08 - Connection terminated.
. 2020.07.11 22:06:11 - Waiting for latency tests (194 to go)
. 2020.07.11 22:06:13 - Waiting for latency tests (147 to go)
. 2020.07.11 22:06:14 - Waiting for latency tests (116 to go)
. 2020.07.11 22:06:15 - Waiting for latency tests (71 to go)
. 2020.07.11 22:06:16 - Waiting for latency tests (46 to go)
. 2020.07.11 22:06:17 - Waiting for latency tests (22 to go)
. 2020.07.11 22:06:20 - Waiting for latency tests (2 to go)
I 2020.07.11 22:06:22 - Checking authorization ...
! 2020.07.11 22:06:23 - Connecting to Chort (Canada, Toronto, Ontario)
. 2020.07.11 22:06:23 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.11 22:06:23 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.11 22:06:23 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.11 22:06:23 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:06:23 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:06:23 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:06:23 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:06:23 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.237:443
. 2020.07.11 22:06:23 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.11 22:06:23 - OpenVPN > UDP link local: (not bound)
. 2020.07.11 22:06:23 - OpenVPN > UDP link remote: [AF_INET]104.254.90.237:443
. 2020.07.11 22:06:23 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.237:443, sid=e4dce6af c6bf10a8
. 2020.07.11 22:06:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.11 22:06:23 - OpenVPN > VERIFY KU OK
. 2020.07.11 22:06:23 - OpenVPN > Validating certificate extended key usage
. 2020.07.11 22:06:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.11 22:06:23 - OpenVPN > VERIFY EKU OK
. 2020.07.11 22:06:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Chort, emailAddress=info@airvpn.org
. 2020.07.11 22:06:24 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.11 22:06:24 - OpenVPN > [Chort] Peer Connection Initiated with [AF_INET]104.254.90.237:443
. 2020.07.11 22:06:25 - OpenVPN > SENT CONTROL [Chort]: 'PUSH_REQUEST' (status=1)
. 2020.07.11 22:06:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.14.42.1,dhcp-option DNS6 fde6:7a:7d20:a2a::1,tun-ipv6,route-gateway 10.14.42.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:a2a::1069/64 fde6:7a:7d20:a2a::1,ifconfig 10.14.42.107 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2020.07.11 22:06:25 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.11 22:06:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.11 22:06:25 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.11 22:06:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.11 22:06:25 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.11 22:06:25 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.11 22:06:25 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.11 22:06:25 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.11 22:06:25 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.11 22:06:25 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.11 22:06:25 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:06:25 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:06:25 - OpenVPN > interactive service msg_channel=0
. 2020.07.11 22:06:25 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=60:f2:62:89:2c:72
. 2020.07.11 22:06:25 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.11 22:06:25 - OpenVPN > GetBestInterfaceEx() returned if=4
. 2020.07.11 22:06:25 - OpenVPN > GDG6: II=4 DP=::/3 NH=fe80::8
. 2020.07.11 22:06:25 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.11 22:06:25 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=4
. 2020.07.11 22:06:25 - OpenVPN > open_tun
. 2020.07.11 22:06:25 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{1AC25C0C-91CC-413E-9963-FEC10EE837F6}.tap
. 2020.07.11 22:06:25 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.11 22:06:25 - OpenVPN > Exiting due to fatal error
! 2020.07.11 22:06:25 - Disconnecting
. 2020.07.11 22:06:25 - Connection terminated.
I 2020.07.11 22:06:28 - Checking authorization ...
! 2020.07.11 22:06:29 - Connecting to Sharatan (Canada, Toronto, Ontario)
. 2020.07.11 22:06:29 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.11 22:06:29 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.11 22:06:29 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.11 22:06:29 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:06:29 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:06:29 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:06:29 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:06:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.197:443
. 2020.07.11 22:06:29 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.11 22:06:29 - OpenVPN > UDP link local: (not bound)
. 2020.07.11 22:06:29 - OpenVPN > UDP link remote: [AF_INET]104.254.90.197:443
. 2020.07.11 22:06:29 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.197:443, sid=d0d2beb5 8640c8c9
. 2020.07.11 22:06:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.11 22:06:29 - OpenVPN > VERIFY KU OK
. 2020.07.11 22:06:29 - OpenVPN > Validating certificate extended key usage
. 2020.07.11 22:06:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.11 22:06:29 - OpenVPN > VERIFY EKU OK
. 2020.07.11 22:06:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sharatan, emailAddress=info@airvpn.org
. 2020.07.11 22:06:29 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.11 22:06:29 - OpenVPN > [Sharatan] Peer Connection Initiated with [AF_INET]104.254.90.197:443
. 2020.07.11 22:06:30 - OpenVPN > SENT CONTROL [Sharatan]: 'PUSH_REQUEST' (status=1)
. 2020.07.11 22:06:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.29.234.1,dhcp-option DNS6 fde6:7a:7d20:19ea::1,tun-ipv6,route-gateway 10.29.234.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:19ea::1098/64 fde6:7a:7d20:19ea::1,ifconfig 10.29.234.154 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2020.07.11 22:06:31 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.11 22:06:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.11 22:06:31 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.11 22:06:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.11 22:06:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.11 22:06:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.11 22:06:31 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.11 22:06:31 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.11 22:06:31 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.11 22:06:31 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.11 22:06:31 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:06:31 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:06:31 - OpenVPN > interactive service msg_channel=0
. 2020.07.11 22:06:31 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=60:f2:62:89:2c:72
. 2020.07.11 22:06:31 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.11 22:06:31 - OpenVPN > GetBestInterfaceEx() returned if=4
. 2020.07.11 22:06:31 - OpenVPN > GDG6: II=4 DP=::/3 NH=fe80::8
. 2020.07.11 22:06:31 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.11 22:06:31 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=4
. 2020.07.11 22:06:31 - OpenVPN > open_tun
. 2020.07.11 22:06:31 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{1AC25C0C-91CC-413E-9963-FEC10EE837F6}.tap
. 2020.07.11 22:06:31 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.11 22:06:31 - OpenVPN > Exiting due to fatal error
! 2020.07.11 22:06:31 - Disconnecting
. 2020.07.11 22:06:31 - Connection terminated.
I 2020.07.11 22:06:34 - Checking authorization ...
! 2020.07.11 22:06:34 - Connecting to Tyl (Canada, Toronto, Ontario)
. 2020.07.11 22:06:34 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.11 22:06:34 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.11 22:06:34 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.11 22:06:34 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:06:34 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:06:34 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:06:34 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:06:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.205:443
. 2020.07.11 22:06:34 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.11 22:06:34 - OpenVPN > UDP link local: (not bound)
. 2020.07.11 22:06:34 - OpenVPN > UDP link remote: [AF_INET]184.75.223.205:443
. 2020.07.11 22:06:34 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.205:443, sid=1dcd6b31 25a08ce7
. 2020.07.11 22:06:35 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.11 22:06:35 - OpenVPN > VERIFY KU OK
. 2020.07.11 22:06:35 - OpenVPN > Validating certificate extended key usage
. 2020.07.11 22:06:35 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.11 22:06:35 - OpenVPN > VERIFY EKU OK
. 2020.07.11 22:06:35 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tyl, emailAddress=info@airvpn.org
. 2020.07.11 22:06:35 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.11 22:06:35 - OpenVPN > [Tyl] Peer Connection Initiated with [AF_INET]184.75.223.205:443
! 2020.07.11 22:06:36 - Disconnecting
. 2020.07.11 22:06:36 - Sending soft termination signal
. 2020.07.11 22:06:39 - Connection terminated.
. 2020.07.11 22:06:39 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.07.11 22:06:39 - OpenVPN > SENT CONTROL [Tyl]: 'PUSH_REQUEST' (status=1)
. 2020.07.11 22:06:39 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.31.202.1,dhcp-option DNS6 fde6:7a:7d20:1bca::1,tun-ipv6,route-gateway 10.31.202.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1bca::1062/64 fde6:7a:7d20:1bca::1,ifconfig 10.31.202.100 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2020.07.11 22:06:39 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.11 22:06:39 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.11 22:06:39 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.11 22:06:39 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.11 22:06:39 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.11 22:06:39 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.11 22:06:39 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.11 22:06:39 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.11 22:06:39 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.11 22:06:39 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.11 22:06:39 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:06:39 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:06:39 - OpenVPN > interactive service msg_channel=0
. 2020.07.11 22:06:39 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=60:f2:62:89:2c:72
. 2020.07.11 22:06:39 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.11 22:06:39 - OpenVPN > GetBestInterfaceEx() returned if=4
. 2020.07.11 22:06:39 - OpenVPN > GDG6: II=4 DP=::/3 NH=fe80::8
. 2020.07.11 22:06:39 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.11 22:06:39 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=4
. 2020.07.11 22:06:39 - OpenVPN > open_tun
. 2020.07.11 22:06:39 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{1AC25C0C-91CC-413E-9963-FEC10EE837F6}.tap
. 2020.07.11 22:06:39 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.11 22:06:39 - OpenVPN > Exiting due to fatal error
I 2020.07.11 22:06:39 - Cancel requested.
! 2020.07.11 22:06:39 - Session terminated.
I 2020.07.11 22:10:09 - Session starting.
I 2020.07.11 22:10:10 - Checking authorization ...
! 2020.07.11 22:10:10 - Connecting to Rotanev (Canada, Toronto, Ontario)
. 2020.07.11 22:10:10 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.11 22:10:10 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.11 22:10:10 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.11 22:10:10 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:10:10 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:10:10 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:10:10 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:10:10 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.189:443
. 2020.07.11 22:10:10 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.11 22:10:10 - OpenVPN > UDP link local: (not bound)
. 2020.07.11 22:10:10 - OpenVPN > UDP link remote: [AF_INET]104.254.90.189:443
. 2020.07.11 22:10:10 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.189:443, sid=da877ebb 94e9eb78
. 2020.07.11 22:10:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.11 22:10:10 - OpenVPN > VERIFY KU OK
. 2020.07.11 22:10:10 - OpenVPN > Validating certificate extended key usage
. 2020.07.11 22:10:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.11 22:10:10 - OpenVPN > VERIFY EKU OK
. 2020.07.11 22:10:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Rotanev, emailAddress=info@airvpn.org
. 2020.07.11 22:10:11 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.11 22:10:11 - OpenVPN > [Rotanev] Peer Connection Initiated with [AF_INET]104.254.90.189:443
. 2020.07.11 22:10:12 - OpenVPN > SENT CONTROL [Rotanev]: 'PUSH_REQUEST' (status=1)
. 2020.07.11 22:10:12 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.74.1,dhcp-option DNS6 fde6:7a:7d20:184a::1,tun-ipv6,route-gateway 10.28.74.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:184a::1046/64 fde6:7a:7d20:184a::1,ifconfig 10.28.74.72 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2020.07.11 22:10:12 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.11 22:10:12 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:184a::1'
. 2020.07.11 22:10:12 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.11 22:10:12 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.11 22:10:12 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.11 22:10:12 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.11 22:10:12 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.11 22:10:12 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.11 22:10:12 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.11 22:10:12 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.11 22:10:12 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.11 22:10:12 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:10:12 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:10:12 - OpenVPN > interactive service msg_channel=0
. 2020.07.11 22:10:12 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=60:f2:62:89:2c:72
. 2020.07.11 22:10:12 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.11 22:10:12 - OpenVPN > GetBestInterfaceEx() returned if=4
. 2020.07.11 22:10:12 - OpenVPN > GDG6: II=4 DP=::/3 NH=fe80::8
. 2020.07.11 22:10:12 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.11 22:10:12 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=4
. 2020.07.11 22:10:12 - OpenVPN > open_tun
. 2020.07.11 22:10:12 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{1AC25C0C-91CC-413E-9963-FEC10EE837F6}.tap
. 2020.07.11 22:10:12 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.11 22:10:12 - OpenVPN > Exiting due to fatal error
! 2020.07.11 22:10:12 - Disconnecting
. 2020.07.11 22:10:12 - Connection terminated.
I 2020.07.11 22:10:15 - Checking authorization ...
! 2020.07.11 22:10:16 - Connecting to Tyl (Canada, Toronto, Ontario)
. 2020.07.11 22:10:16 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.11 22:10:16 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.11 22:10:16 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.11 22:10:16 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:10:16 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:10:16 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:10:16 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:10:16 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.205:443
. 2020.07.11 22:10:16 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.11 22:10:16 - OpenVPN > UDP link local: (not bound)
. 2020.07.11 22:10:16 - OpenVPN > UDP link remote: [AF_INET]184.75.223.205:443
. 2020.07.11 22:10:16 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.205:443, sid=52aad529 c490a086
. 2020.07.11 22:10:16 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.11 22:10:16 - OpenVPN > VERIFY KU OK
. 2020.07.11 22:10:16 - OpenVPN > Validating certificate extended key usage
. 2020.07.11 22:10:16 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.11 22:10:16 - OpenVPN > VERIFY EKU OK
. 2020.07.11 22:10:16 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tyl, emailAddress=info@airvpn.org
. 2020.07.11 22:10:17 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.11 22:10:17 - OpenVPN > [Tyl] Peer Connection Initiated with [AF_INET]184.75.223.205:443
! 2020.07.11 22:10:18 - Disconnecting
. 2020.07.11 22:10:18 - Sending soft termination signal
. 2020.07.11 22:10:21 - Connection terminated.
. 2020.07.11 22:10:21 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.07.11 22:10:21 - OpenVPN > SENT CONTROL [Tyl]: 'PUSH_REQUEST' (status=1)
. 2020.07.11 22:10:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.31.202.1,dhcp-option DNS6 fde6:7a:7d20:1bca::1,tun-ipv6,route-gateway 10.31.202.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1bca::1062/64 fde6:7a:7d20:1bca::1,ifconfig 10.31.202.100 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2020.07.11 22:10:21 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.11 22:10:21 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1bca::1'
. 2020.07.11 22:10:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.11 22:10:21 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.11 22:10:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.11 22:10:21 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.11 22:10:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.11 22:10:21 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.11 22:10:21 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.11 22:10:21 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.11 22:10:21 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.11 22:10:21 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:10:21 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:10:21 - OpenVPN > interactive service msg_channel=0
. 2020.07.11 22:10:21 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=60:f2:62:89:2c:72
. 2020.07.11 22:10:21 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.11 22:10:21 - OpenVPN > GetBestInterfaceEx() returned if=4
. 2020.07.11 22:10:21 - OpenVPN > GDG6: II=4 DP=::/3 NH=fe80::8
. 2020.07.11 22:10:21 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.11 22:10:21 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=4
. 2020.07.11 22:10:21 - OpenVPN > open_tun
. 2020.07.11 22:10:21 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{1AC25C0C-91CC-413E-9963-FEC10EE837F6}.tap
. 2020.07.11 22:10:21 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.11 22:10:21 - OpenVPN > Exiting due to fatal error
I 2020.07.11 22:10:21 - Cancel requested.
! 2020.07.11 22:10:21 - Session terminated.
I 2020.07.11 22:13:12 - Session starting.
I 2020.07.11 22:13:12 - Checking authorization ...
! 2020.07.11 22:13:13 - Connecting to Cephei (Canada, Toronto, Ontario)
. 2020.07.11 22:13:13 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.11 22:13:13 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.11 22:13:13 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.11 22:13:13 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:13:13 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:13:13 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:13:13 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:13:13 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.214.165:443
. 2020.07.11 22:13:13 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.11 22:13:13 - OpenVPN > UDP link local: (not bound)
. 2020.07.11 22:13:13 - OpenVPN > UDP link remote: [AF_INET]184.75.214.165:443
. 2020.07.11 22:13:13 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.214.165:443, sid=bb432ec1 95242f54
. 2020.07.11 22:13:13 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.11 22:13:13 - OpenVPN > VERIFY KU OK
. 2020.07.11 22:13:13 - OpenVPN > Validating certificate extended key usage
. 2020.07.11 22:13:13 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.11 22:13:13 - OpenVPN > VERIFY EKU OK
. 2020.07.11 22:13:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cephei, emailAddress=info@airvpn.org
. 2020.07.11 22:13:14 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.11 22:13:14 - OpenVPN > [Cephei] Peer Connection Initiated with [AF_INET]184.75.214.165:443
. 2020.07.11 22:13:15 - OpenVPN > SENT CONTROL [Cephei]: 'PUSH_REQUEST' (status=1)
. 2020.07.11 22:13:15 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.13.106.1,dhcp-option DNS6 fde6:7a:7d20:96a::1,tun-ipv6,route-gateway 10.13.106.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:96a::103b/64 fde6:7a:7d20:96a::1,ifconfig 10.13.106.61 255.255.255.0,peer-id 5,cipher AES-256-GCM'
. 2020.07.11 22:13:15 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.11 22:13:15 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:96a::1'
. 2020.07.11 22:13:15 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.11 22:13:15 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.11 22:13:15 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.11 22:13:15 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.11 22:13:15 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.11 22:13:15 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.11 22:13:15 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.11 22:13:15 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.11 22:13:15 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.11 22:13:15 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:13:15 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:13:15 - OpenVPN > interactive service msg_channel=0
. 2020.07.11 22:13:15 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=60:f2:62:89:2c:72
. 2020.07.11 22:13:15 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.11 22:13:15 - OpenVPN > GetBestInterfaceEx() returned if=4
. 2020.07.11 22:13:15 - OpenVPN > GDG6: II=4 DP=::/3 NH=fe80::8
. 2020.07.11 22:13:15 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.11 22:13:15 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=4
. 2020.07.11 22:13:15 - OpenVPN > open_tun
. 2020.07.11 22:13:15 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{1AC25C0C-91CC-413E-9963-FEC10EE837F6}.tap
. 2020.07.11 22:13:15 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.11 22:13:15 - OpenVPN > Exiting due to fatal error
! 2020.07.11 22:13:15 - Disconnecting
. 2020.07.11 22:13:15 - Connection terminated.
I 2020.07.11 22:13:18 - Checking authorization ...
! 2020.07.11 22:13:19 - Connecting to Sualocin (Canada, Toronto, Ontario)
. 2020.07.11 22:13:19 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.11 22:13:19 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.11 22:13:19 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.11 22:13:19 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:13:19 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:13:19 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:13:19 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:13:19 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.45:443
. 2020.07.11 22:13:19 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.11 22:13:19 - OpenVPN > UDP link local: (not bound)
. 2020.07.11 22:13:19 - OpenVPN > UDP link remote: [AF_INET]184.75.221.45:443
. 2020.07.11 22:13:19 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.45:443, sid=d0aa016d 7d6bfb81
. 2020.07.11 22:13:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.11 22:13:19 - OpenVPN > VERIFY KU OK
. 2020.07.11 22:13:19 - OpenVPN > Validating certificate extended key usage
. 2020.07.11 22:13:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.11 22:13:19 - OpenVPN > VERIFY EKU OK
. 2020.07.11 22:13:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sualocin, emailAddress=info@airvpn.org
. 2020.07.11 22:13:19 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.11 22:13:19 - OpenVPN > [Sualocin] Peer Connection Initiated with [AF_INET]184.75.221.45:443
. 2020.07.11 22:13:21 - OpenVPN > SENT CONTROL [Sualocin]: 'PUSH_REQUEST' (status=1)
. 2020.07.11 22:13:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.30.202.1,dhcp-option DNS6 fde6:7a:7d20:1aca::1,tun-ipv6,route-gateway 10.30.202.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1aca::10ed/64 fde6:7a:7d20:1aca::1,ifconfig 10.30.202.239 255.255.255.0,peer-id 5,cipher AES-256-GCM'
. 2020.07.11 22:13:21 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.11 22:13:21 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1aca::1'
. 2020.07.11 22:13:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.11 22:13:21 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.11 22:13:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.11 22:13:21 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.11 22:13:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.11 22:13:21 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.11 22:13:21 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.11 22:13:21 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.11 22:13:21 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.11 22:13:21 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:13:21 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:13:21 - OpenVPN > interactive service msg_channel=0
. 2020.07.11 22:13:21 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=60:f2:62:89:2c:72
. 2020.07.11 22:13:21 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.11 22:13:21 - OpenVPN > GetBestInterfaceEx() returned if=4
. 2020.07.11 22:13:21 - OpenVPN > GDG6: II=4 DP=::/3 NH=fe80::8
. 2020.07.11 22:13:21 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.11 22:13:21 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=4
. 2020.07.11 22:13:21 - OpenVPN > open_tun
. 2020.07.11 22:13:21 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{1AC25C0C-91CC-413E-9963-FEC10EE837F6}.tap
. 2020.07.11 22:13:21 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.11 22:13:21 - OpenVPN > Exiting due to fatal error
! 2020.07.11 22:13:21 - Disconnecting
. 2020.07.11 22:13:21 - Connection terminated.
I 2020.07.11 22:13:22 - Cancel requested.
! 2020.07.11 22:13:22 - Session terminated.
I 2020.07.11 22:13:37 - Session starting.
I 2020.07.11 22:13:37 - Checking authorization ...
! 2020.07.11 22:13:38 - Connecting to Tyl (Canada, Toronto, Ontario)
. 2020.07.11 22:13:38 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.11 22:13:38 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.11 22:13:38 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.11 22:13:38 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:13:38 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:13:38 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:13:38 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:13:38 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.205:443
. 2020.07.11 22:13:38 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.11 22:13:38 - OpenVPN > UDP link local: (not bound)
. 2020.07.11 22:13:38 - OpenVPN > UDP link remote: [AF_INET]184.75.223.205:443
. 2020.07.11 22:13:38 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.205:443, sid=b0d6fc34 63066dfd
. 2020.07.11 22:13:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.11 22:13:38 - OpenVPN > VERIFY KU OK
. 2020.07.11 22:13:38 - OpenVPN > Validating certificate extended key usage
. 2020.07.11 22:13:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.11 22:13:38 - OpenVPN > VERIFY EKU OK
. 2020.07.11 22:13:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tyl, emailAddress=info@airvpn.org
. 2020.07.11 22:13:39 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.11 22:13:39 - OpenVPN > [Tyl] Peer Connection Initiated with [AF_INET]184.75.223.205:443
. 2020.07.11 22:13:40 - OpenVPN > SENT CONTROL [Tyl]: 'PUSH_REQUEST' (status=1)
. 2020.07.11 22:13:40 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.31.202.1,dhcp-option DNS6 fde6:7a:7d20:1bca::1,tun-ipv6,route-gateway 10.31.202.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1bca::1062/64 fde6:7a:7d20:1bca::1,ifconfig 10.31.202.100 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2020.07.11 22:13:40 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.11 22:13:40 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.11 22:13:40 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.11 22:13:40 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.11 22:13:40 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.11 22:13:40 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.11 22:13:40 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.11 22:13:40 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.11 22:13:40 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.11 22:13:40 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.11 22:13:40 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:13:40 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:13:40 - OpenVPN > interactive service msg_channel=0
. 2020.07.11 22:13:40 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=60:f2:62:89:2c:72
. 2020.07.11 22:13:40 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.11 22:13:40 - OpenVPN > GetBestInterfaceEx() returned if=4
. 2020.07.11 22:13:40 - OpenVPN > GDG6: II=4 DP=::/3 NH=fe80::8
. 2020.07.11 22:13:40 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.11 22:13:40 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=4
. 2020.07.11 22:13:40 - OpenVPN > open_tun
. 2020.07.11 22:13:40 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{1AC25C0C-91CC-413E-9963-FEC10EE837F6}.tap
. 2020.07.11 22:13:40 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.11 22:13:40 - OpenVPN > Exiting due to fatal error
! 2020.07.11 22:13:40 - Disconnecting
. 2020.07.11 22:13:40 - Connection terminated.
I 2020.07.11 22:13:43 - Checking authorization ...
! 2020.07.11 22:13:44 - Connecting to Sargas (Canada, Toronto, Ontario)
. 2020.07.11 22:13:44 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.07.11 22:13:44 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.07.11 22:13:44 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.07.11 22:13:44 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:13:44 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:13:44 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.07.11 22:13:44 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.07.11 22:13:44 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.197:443
. 2020.07.11 22:13:44 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.07.11 22:13:44 - OpenVPN > UDP link local: (not bound)
. 2020.07.11 22:13:44 - OpenVPN > UDP link remote: [AF_INET]184.75.223.197:443
. 2020.07.11 22:13:44 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.197:443, sid=ac38d9f2 aff4da65
. 2020.07.11 22:13:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.07.11 22:13:44 - OpenVPN > VERIFY KU OK
. 2020.07.11 22:13:44 - OpenVPN > Validating certificate extended key usage
. 2020.07.11 22:13:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.07.11 22:13:44 - OpenVPN > VERIFY EKU OK
. 2020.07.11 22:13:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sargas, emailAddress=info@airvpn.org
. 2020.07.11 22:13:44 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.07.11 22:13:44 - OpenVPN > [Sargas] Peer Connection Initiated with [AF_INET]184.75.223.197:443
! 2020.07.11 22:13:45 - Disconnecting
. 2020.07.11 22:13:45 - Sending soft termination signal
. 2020.07.11 22:13:48 - Connection terminated.
. 2020.07.11 22:13:48 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.07.11 22:13:48 - OpenVPN > SENT CONTROL [Sargas]: 'PUSH_REQUEST' (status=1)
. 2020.07.11 22:13:48 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.29.42.1,dhcp-option DNS6 fde6:7a:7d20:192a::1,tun-ipv6,route-gateway 10.29.42.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:192a::10a7/64 fde6:7a:7d20:192a::1,ifconfig 10.29.42.169 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2020.07.11 22:13:48 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.07.11 22:13:48 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.07.11 22:13:48 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.07.11 22:13:48 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.07.11 22:13:48 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.07.11 22:13:48 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.07.11 22:13:48 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.07.11 22:13:48 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.07.11 22:13:48 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.07.11 22:13:48 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.07.11 22:13:48 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:13:48 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.07.11 22:13:48 - OpenVPN > interactive service msg_channel=0
. 2020.07.11 22:13:48 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=60:f2:62:89:2c:72
. 2020.07.11 22:13:48 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.07.11 22:13:48 - OpenVPN > GetBestInterfaceEx() returned if=4
. 2020.07.11 22:13:48 - OpenVPN > GDG6: II=4 DP=::/3 NH=fe80::8
. 2020.07.11 22:13:48 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2020.07.11 22:13:48 - OpenVPN > ROUTE6_GATEWAY fe80::8 I=4
. 2020.07.11 22:13:48 - OpenVPN > open_tun
. 2020.07.11 22:13:48 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{1AC25C0C-91CC-413E-9963-FEC10EE837F6}.tap
. 2020.07.11 22:13:48 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2020.07.11 22:13:48 - OpenVPN > Exiting due to fatal error
I 2020.07.11 22:13:48 - Cancel requested.
! 2020.07.11 22:13:48 - Session terminated.
Edited ... by giganerd
Apply LOG format to logs
In Logs tab, click the lifebelt icon and paste or upload the output here.
