n0raa 0 Posted ... I setup EddieVPN on my Nvidia shield with the most recent APK. and got it up and running no issues. But when using the app (Tivimate) I am unable to connect to my services ran internally. I assume this is because the Shield is no on the same subnet as the services or at least it thinks that? I tried enabling and disabling the "Exclude Local Networks from the VPN" setting with no luck. Any help would be greatly appreciated. Thank you! Quote Share this post Link to post
n0raa 0 Posted ... I have EdditVPN installed on my Nvidia shield and am unable to access services with the VPN enabled. I believe it has something to do with routes but I can't seem to find anything in the Eddie UI that relates to routes. In the OpenVPN for Android it is working perfectly but I am able to whitelist the address in OpenVPN settings. Is there a similar setting in EddieVPN? Checking "Exclude Local Networks from the VPN" doesn't work either despite the Log showing a tunnel created on the correct LAN/Subnet. I would love to get this up and running with EddieVPN as some devices in my house can't utilize OpenVPN for Android. Any help is greatly appreciated. If any more info is needed please let me know! Quote Share this post Link to post
Tech Jedi Alex 1585 Posted ... I merged both of your threads, the topic is exactly the same. Be advised, you are posting in the community forums where the community usually answers. Quality and quantity of answers may vary. If you need professional support with certain answer times, create tickets. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
