rrgrrhrrh
Warning of expiring subscription in Eddie
I generally don't sign in on the website, so I never know how long is left on my subscription.
It would be great if I could get a warning when signing in on Eddie, that my subscription is about to expire.
In case you want to handle it on your own you can take a look at AirVPN API there's a usernfo service which provides the expiration days of your account.
That doesn't really help, does it? :) It only makes it more complicated. The same indicator for subscription days left is in Eddie for Android on the very first activity you are presented with after you log in, so Eddie on PC should definitely implement this as well.
Agreed it makes sense, but while it's implemented, if it ever is, API is a way to get that information, and even automate a notification when subscription is ending.
Just mentioned it in case the OP wanted to give it a try and play a bit
