I'm using an unraid server with the deluge-vpn docker.  When using the config generator there's an option for OS. I'm assuming I should select LInux but just want to make sure.  Is that correct?
In most cases it doesn't even matter what you select as long as the OS family is correct (OpenVPN has got dedicated options for Windows and Linux for example which don't work on the other, respectively). If your unRAID server is running the Linux kernel, you can choose Linux.
