Sasheca 0 Posted ... Hi there, I've downloaded and installed Eddie 2.18.9 on Debian 10 (Buster). I started Eddie OpenVPN GUI from the Applications menu. Then I configure it through Eddie's graphical interface /similar like Windows UI/. I've also include Eddie in the list of Start Up Programs. When Debian loads it asks me for password to start Eddie, I enter it and AirVPN service starts. I confirmed that with ipleak and everything is ok. The service is running.But I can't see the Graphical Interface. If I try to start Eddie OpenVPN GUI from the Applications menu - the OS says that there is already a running process /which is true checking it in System Monitor tool/. So, why is that? Why can't I access the GUI anymore? The only way to close the program is to kill the process which is not the point. Quote Share this post Link to post
OpenSourcerer 1488 Posted ... 2 hours ago, Stefan Tanev said: Then I configure it through Eddie's graphical interface /similar like Windows UI/. Where do you do that? General > Connect at startup? Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Sasheca 0 Posted ... Yes. Exactly. In General settings. I've placed a check in the boxes for: 1. Connect at startup. 2. Start with system. May be I can uncheck this through the terminal with a command. Quote Share this post Link to post
eburom 16 Posted ... Do you remember having also checked to start minimized to tray? there are some posts about it stopping to work. You can try removing your default profile for a fresh start of eddie. Kill eddie and run it from the command line. Find a line similar to "Profile path: /usr/lib/eddie-ui/default.profile". Kill eddie again and delete or move that file to a save place (eddie will create a new one when started). Try to run eddie and set everything up again. Quote Share this post Link to post
OpenSourcerer 1488 Posted ... On 6/26/2020 at 10:15 AM, Sasheca said: 2. Start with system. Interestingly, I don't have this. 😮 Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Sasheca 0 Posted ... On 6/28/2020 at 11:21 AM, eburom said: Do you remember having also checked to start minimized to tray? there are some posts about it stopping to work. You can try removing your default profile for a fresh start of eddie. Kill eddie and run it from the command line. Find a line similar to "Profile path: /usr/lib/eddie-ui/default.profile". Kill eddie again and delete or move that file to a save place (eddie will create a new one when started). Try to run eddie and set everything up again. Yes, @eburom. That worked for me. Fortunately I've found this topic and the same suggestion made by you but for Ubuntu. Once I've started Eddie GUI, I unchecked Connect at startup and Start with system. Everything is ok now. Thank you for your help. Quote Share this post Link to post
