Not connected, Your IP: 216.73.216.85
When Eddie, version (2.18.9), tries to start with my computer I sometimes get the following error,
"Unable to obtain elevated privileges (required): Unable to start (No socket)"
Thereafter, if I manually try to start Eddie, it does the "Raising system privileges", I approve the Windows request for privileges and then it gives me the same error.
I've been experiencing this error off and on for the last two weeks and restarting Eddie once usually made the issue go away, but now today is the first day it took 5 attempts to start.
Could you try renaming the default.profile file in C:\Users\[username]\AppData\Local\Eddie and launch Eddie again?
I've done that now that I've re-experienced the issue. I'm not sure if it fixed anything as this is the first time I experienced the issue since Tuesday, but I'll keep a lookout. If it happens again, I will respond to this issue.
So first time restarting Eddie after that, I got the following prompt:
Profile is encrypted throgh a password saved in OS keyring, password could not be found. Do you want to rest Eddie to default settings?
Yes                            No
What is this? I clicked No and it started fine.
