tangledSoul 0 Posted ... (edited) Hi I am trying to connect to AirVPN from an OPNSense Firewall. I have tried many different configs and the status of my openvpn tunnel is always "connecting". The log file shows no errors, there is just a entry state all and client disconnected. Is there any working guide for the current OPNSense version. I do not have any problems to connect to AirVPN from any Windows Client in my network. I looked at my firewall log and did a tcpdump, but i can not see any incoming traffic. I do not have a private ip address, because i use a 5G router. could this be the problem? why is it working on other clients (Android, Windows Workstation)? thank you for your help Edited ... by tangledSoul Share this post Link to post
Stack of computer parts 9 Posted ... I am also on the same boat. It appears that the differences between pfsense and opnsense are becoming more pronounced as time goes on. I am stuck in the same place you seem to be with the openvpn client not able to connect. Setting logging level to 11 yields no errors. It almost looks like the outbound request is getting nat'd wrong so a response from the server gets lost in the ether. I spent a few hours over the weekend trying to get it running and will try again this week. I dont have much time to keep messing with the internet since everyone is home using it 24/7 nowadays. Ill post up what I find. Unless you have managed to get it working yourself. Share this post Link to post
Wolke68 5 Posted ... Is it really so different? You donˋt have any configˋs to show us. I am on pfsense with this config....https://nguvu.org/pfsense/pfsense-baseline-setup/ max speed is up to 300MBit/s Share this post Link to post
Stack of computer parts 9 Posted ... I got it to connect but it will not use tls 1.2 settings from the config generator. I had to use the regular flavor tls. I was following the nguvu.org setup as well as their prior pfsense tutorials. The only thing I changed in the setup to get it to work was to swap the tls-1.2 key with whatever the normal tls version is. perhaps its an opnsense problem or the fact that I am using LibreSSL. Im using the LibreSSL 3.0.2 flavor, openvpn 2.4.9_3 It does appear that Pfsense does not use or plan to use libressl. I might try it later with openssl and find out. Share this post Link to post
Stack of computer parts 9 Posted ... I switched to openssl and tried to get the client to connect. It would not connect with tls-crpt 1.2 server and key. It does connect with the regular tls version and servers. I see from the logs that it sends the entry server a single udp packet and begins negotiating the key exchange. Then it sends three udp packets to the server and then times out. It will try this 1-3 times before 'freezing'. Not really sure if 'freeze' is accurate but the log stops refreshing and the live feed from the firewall stops updating... but everyone else on the network can still use the web on clearnet. Perhaps I have to specify something tls 1.2 specific in the advanced config options that is not autoconfigured in opnsense but is in pfsense. Ill ask over in the opnsense forums and keep looking because now it just bugs me. Share this post Link to post
Tech Jedi Alex 1585 Posted ... I don't think it matters if it's TLS 1.2 or TLS only – the only version accepted is 1.2, anyway. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Stack of computer parts 9 Posted ... Ok the problem is that opnsense does not have tls-crypt as a feature listed in the GUI. What it shows for TLS settings is TLS-auth, which must be what the standard air entry protocol is. The fix, is also what someone here found worked for a DD-WRT. 1. Disable TLS authentication (Uncheck the box) 2. Under "Advanced" <tls-crypt> [your tls 1.2 key here] </tls-crypt> and then add all the other client config stuff like usual Its being worked on by the opnsense team but is slated to show up in the GUI for a later release. 1 EpicNGX reacted to this Share this post Link to post
Tech Jedi Alex 1585 Posted ... Oooh, I see. But I don't believe it's not a feature because that's standard in OpenVPN. I think it's fairly easy to fix it yourself. You see, there are four entry IPs for every server. 1 and 2 is for tls-auth, and 3 and 4 for tls-crypt. The even number is an alternative address in case of blocks. Your fix with disabling TLS authentication is correct because it seems like the option needed for IPs 1 or 2, so you must make sure you use IP 3 or 4 to connect, and then it should work. Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
tangledSoul 0 Posted ... Hi your solution to disable TLS auth and add it under advanced works for me. thanks, that solved my problem. Share this post Link to post
