Not connected, Your IP: 216.73.216.215
360degreevision
ANSWERED Problem connecting with Eddie 2.18.9 in Windows 10
I recently updated Eddie to 2.18.9 and since then have had problems getting a connection via Eddie. It seems to delay ++ at checking ipv6, then I get this Windows error:
OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
It then disconnects, waits few seconds and tries to reconnect.
No difference whether I have network lock on/off.
I have tried using wintun driver - no improvement.
I have tried this webpage, using the "prefer iPv4 over iPv6 option (no better) -- https://support.microsoft.com/en-us/help/929852/guidance-for-configuring-ipv6-in-windows-for-advanced-users
Here is my log:
I 2020.05.13 16:23:32 - Session starting.
I 2020.05.13 16:23:32 - Checking authorization ...
! 2020.05.13 16:23:33 - Connecting to Alphecca (Netherlands, Alblasserdam)
. 2020.05.13 16:23:33 - OpenVPN > OpenVPN 2.5_git x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 23 2019
. 2020.05.13 16:23:33 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.05.13 16:23:33 - OpenVPN > library versions: OpenSSL 1.1.0j  20 Nov 2018, LZO 2.10
. 2020.05.13 16:23:33 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.05.13 16:23:33 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.05.13 16:23:33 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.05.13 16:23:33 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.05.13 16:23:33 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.202.107.7:443
. 2020.05.13 16:23:33 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.05.13 16:23:33 - OpenVPN > UDP link local: (not bound)
. 2020.05.13 16:23:33 - OpenVPN > UDP link remote: [AF_INET]109.202.107.7:443
. 2020.05.13 16:23:33 - OpenVPN > TLS: Initial packet from [AF_INET]109.202.107.7:443, sid=6856e49a 4ca65c3b
. 2020.05.13 16:23:33 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.05.13 16:23:33 - OpenVPN > VERIFY KU OK
. 2020.05.13 16:23:33 - OpenVPN > Validating certificate extended key usage
. 2020.05.13 16:23:33 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.05.13 16:23:33 - OpenVPN > VERIFY EKU OK
. 2020.05.13 16:23:33 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alphecca, emailAddress=info@airvpn.org
. 2020.05.13 16:23:34 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.05.13 16:23:34 - OpenVPN > [Alphecca] Peer Connection Initiated with [AF_INET]109.202.107.7:443
. 2020.05.13 16:23:35 - OpenVPN > SENT CONTROL [Alphecca]: 'PUSH_REQUEST' (status=1)
. 2020.05.13 16:23:35 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.7.78.1,dhcp-option DNS6 fde6:7a:7d20:34e::1,tun-ipv6,route-gateway 10.7.78.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:34e::109b/64 fde6:7a:7d20:34e::1,ifconfig 10.7.78.157 255.255.255.0,peer-id 4,cipher AES-256-GCM'
. 2020.05.13 16:23:35 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.05.13 16:23:35 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.05.13 16:23:35 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.05.13 16:23:35 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.05.13 16:23:35 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.05.13 16:23:35 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.05.13 16:23:35 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.05.13 16:23:35 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.05.13 16:23:35 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.05.13 16:23:35 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.05.13 16:23:35 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.05.13 16:23:35 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.05.13 16:23:35 - OpenVPN > interactive service msg_channel=0
. 2020.05.13 16:23:35 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=12 HWADDR=c8:60:00:c3:33:03
. 2020.05.13 16:23:35 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.05.13 16:23:35 - OpenVPN > GetBestInterfaceEx() returned if=12
. 2020.05.13 16:23:35 - OpenVPN > GDG6: II=12 DP=::/0 NH=fe80::b2b9:8aff:fe5c:3dc4
. 2020.05.13 16:23:35 - OpenVPN > GDG6: Metric=4096, Loopback=0, AA=1, I=0
. 2020.05.13 16:23:35 - OpenVPN > ROUTE6_GATEWAY fe80::b2b9:8aff:fe5c:3dc4 I=12
. 2020.05.13 16:23:35 - OpenVPN > open_tun
. 2020.05.13 16:23:35 - OpenVPN > Wintun device [Local Area Connection 2] opened
. 2020.05.13 16:23:36 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address Local Area Connection 2 static 10.7.78.157 255.255.255.0
. 2020.05.13 16:23:37 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns Local Area Connection 2 all
. 2020.05.13 16:23:39 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set dns Local Area Connection 2 static 10.7.78.1
. 2020.05.13 16:23:52 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins Local Area Connection 2 all
. 2020.05.13 16:23:56 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address interface=8 fde6:7a:7d20:34e::109b store=active
. 2020.05.13 16:23:59 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns Local Area Connection 2 static fde6:7a:7d20:34e::1 validate=no
. 2020.05.13 16:24:01 - Detected an OpenVPN bug (On-Link route on VPN range), autofix.
. 2020.05.13 16:24:01 - OpenVPN > add_route_ipv6(fde6:7a:7d20:34e::/64 -> fde6:7a:7d20:34e::109b metric 0) dev Local Area Connection 2
. 2020.05.13 16:24:01 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:34e::/64 interface=8 fe80::8 store=active
. 2020.05.13 16:24:01 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2020.05.13 16:24:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 109.202.107.7 MASK 255.255.255.255 192.168.1.1
. 2020.05.13 16:24:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2020.05.13 16:24:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2020.05.13 16:24:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.7.78.1
. 2020.05.13 16:24:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=5 and dwForwardType=4
. 2020.05.13 16:24:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.7.78.1
. 2020.05.13 16:24:02 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:34e::1 metric -1) dev Local Area Connection 2
. 2020.05.13 16:24:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 interface=8 fe80::8 store=active
. 2020.05.13 16:24:02 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
E 2020.05.13 16:24:02 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
. 2020.05.13 16:24:02 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:34e::1 metric -1) dev Local Area Connection 2
. 2020.05.13 16:24:02 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 interface=8 fe80::8 store=active
E 2020.05.13 16:24:03 - OpenVPN > ERROR: Windows route add ipv6 command failed: returned error code 1
. 2020.05.13 16:24:03 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:34e::1 metric -1) dev Local Area Connection 2
. 2020.05.13 16:24:03 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 interface=8 fe80::8 store=active
. 2020.05.13 16:24:03 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2020.05.13 16:24:03 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:34e::1 metric -1) dev Local Area Connection 2
. 2020.05.13 16:24:03 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 interface=8 fe80::8 store=active
. 2020.05.13 16:24:04 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2020.05.13 16:24:04 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2020.05.13 16:24:04 - DNS leak protection with packet filtering enabled.
. 2020.05.13 16:24:05 - Routes, added a new route, 109.202.107.5 for gateway 10.7.78.1
. 2020.05.13 16:24:05 - Routes, added a new route, 2a00:1678:2470:23:eaab:e065:ac57:b54e for gateway fde6:7a:7d20:34e::1
. 2020.05.13 16:24:05 - Flushing DNS
I 2020.05.13 16:24:06 - Checking route IPv4
I 2020.05.13 16:24:07 - Checking route IPv6
. 2020.05.13 16:24:27 - curl: (28) Connection timed out after 20001 milliseconds
. 2020.05.13 16:24:27 - Checking route (2° try)
. 2020.05.13 16:24:48 - curl: (28) Connection timed out after 20001 milliseconds
. 2020.05.13 16:24:48 - Checking route (3° try)
. 2020.05.13 16:25:11 - curl: (28) Connection timed out after 20000 milliseconds
E 2020.05.13 16:25:11 - Checking route IPv6 failed.
. 2020.05.13 16:25:11 - OpenVPN > Initialization Sequence Completed
. 2020.05.13 16:25:11 - OpenVPN > TCP/UDP packet too large on write to [AF_INET]109.202.107.7:443 (tried=1921,max=1553)
. 2020.05.13 16:25:11 - Above log line repeated 2 times more
! 2020.05.13 16:25:11 - Disconnecting
. 2020.05.13 16:25:11 - Routes, removed a route previously added, 109.202.107.5 for gateway 10.7.78.1
. 2020.05.13 16:25:12 - Routes, removed a route previously added, 2a00:1678:2470:23:eaab:e065:ac57:b54e for gateway fde6:7a:7d20:34e::1
. 2020.05.13 16:25:12 - Sending soft termination signal
. 2020.05.13 16:25:15 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.05.13 16:25:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 109.202.107.7 MASK 255.255.255.255 192.168.1.1
. 2020.05.13 16:25:17 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2020.05.13 16:25:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.7.78.1
. 2020.05.13 16:25:17 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.7.78.1
. 2020.05.13 16:25:17 - OpenVPN > Closing TUN/TAP interface
. 2020.05.13 16:25:17 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:34e::/64)
. 2020.05.13 16:25:17 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:34e::/64 interface=8 fe80::8 store=active
. 2020.05.13 16:25:21 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address Local Area Connection 2 fde6:7a:7d20:34e::109b store=active
. 2020.05.13 16:25:21 - Sending hard termination signal
. 2020.05.13 16:25:21 - Connection terminated.
. 2020.05.13 16:25:21 - DNS leak protection with packet filtering disabled.
. 2020.05.13 16:25:21 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2020.05.13 16:25:21 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
I 2020.05.13 16:25:23 - Cancel requested.
! 2020.05.13 16:25:23 - Session terminated.
. 2020.05.13 16:53:37 - Collect information about AirVPN completed
