Not connected, Your IP: 216.73.216.102
DZ5TGW
ANSWERED macOS pkg not notarized
I'm using macOS 10.15.4 (Catalina) and I noticed that your .pkg installer is not notarized.
When you go to open the file it gives a warning that "Apple cannot check it for malicious software. To bypass this you need to right click on it before being prompted for administrator credentials.
However once the installer is loaded then the padlock (top right) indicates that you are an approved developer.
Is it possible to sign the .pkg as well as the installer in future builds? This would avoid the first prompt.
Thank you 😊
I see this has now been fixed in Version 2.19.3 (Experimental).
Thanks! 😊
