Since a few days I am not connected to the VPN server on 2 Macs. The software tries to connect, but then always aborts at the "Checking route" process and then tries to connect again without success. I can reproduce this with different servers.
If I deactivate "Check if the tunnel effectively works" in the settings under Advanced, then instead of "Checking route" the connection process now uses "Checking DNS" and then the connection process also aborts.
System on the Mac is 10.12.6
On the iPad the connection via OpenVPN works without problems...
How can I solve the problem? Has something changed with AirVPN
Translated with www.DeepL.com/Translator (free version)
Enable both options again, then try a connection. After this, in Logs tab, click on the lifebelt icon and paste or upload the output here. If you choose to paste it, consider using LOG format, it's the top left button in the post editor.
I 2020.05.06 15:29:55 - Session starting.
I 2020.05.06 15:29:56 - IPv6 disabled on network adapter (Ethernet)
I 2020.05.06 15:29:56 - IPv6 disabled on network adapter (Wi-Fi)
I 2020.05.06 15:29:56 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2020.05.06 15:29:56 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2020.05.06 15:29:56 - IPv6 disabled on network adapter (TomTom GO Premium X)
I 2020.05.06 15:29:56 - IPv6 disabled on network adapter (TomTom GO)
I 2020.05.06 15:29:56 - IPv6 disabled on network adapter (iPad)
I 2020.05.06 15:29:56 - Checking authorization ...
! 2020.05.06 15:29:56 - Connecting to Garnet (Netherlands, Alblasserdam)
. 2020.05.06 15:29:56 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [SSL (OpenSSL)] [LZO] [MH] [IPv6] built on Aug 13 2015
. 2020.05.06 15:29:56 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2020.05.06 15:29:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2020.05.06 15:29:56 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2020.05.06 15:29:56 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 15:29:56 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 15:29:56 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2020.05.06 15:29:56 - OpenVPN > UDPv4 link local: [undef]
. 2020.05.06 15:29:56 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.73:443
. 2020.05.06 15:29:56 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.73:443, sid=000199fc c49492af
. 2020.05.06 15:29:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.05.06 15:29:57 - OpenVPN > Validating certificate key usage
. 2020.05.06 15:29:57 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2020.05.06 15:29:57 - OpenVPN > VERIFY KU OK
. 2020.05.06 15:29:57 - OpenVPN > Validating certificate extended key usage
. 2020.05.06 15:29:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.05.06 15:29:57 - OpenVPN > VERIFY EKU OK
. 2020.05.06 15:29:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Garnet, emailAddress=info@airvpn.org
. 2020.05.06 15:29:57 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2020.05.06 15:29:57 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 15:29:57 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2020.05.06 15:29:57 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 15:29:57 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.05.06 15:29:57 - OpenVPN > [Garnet] Peer Connection Initiated with [AF_INET]213.152.162.73:443
. 2020.05.06 15:30:00 - OpenVPN > SENT CONTROL [Garnet]: 'PUSH_REQUEST' (status=1)
. 2020.05.06 15:30:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.17.88.1,route-gateway 10.17.88.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.17.88.189 255.255.255.0,peer-id 2'
. 2020.05.06 15:30:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.05.06 15:30:00 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2020.05.06 15:30:00 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2020.05.06 15:30:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.05.06 15:30:00 - OpenVPN > OPTIONS IMPORT: route options modified
. 2020.05.06 15:30:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.05.06 15:30:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.05.06 15:30:00 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.05.06 15:30:00 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2020.05.06 15:30:00 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2020.05.06 15:30:00 - OpenVPN > Opened utun device utun2
. 2020.05.06 15:30:00 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2020.05.06 15:30:00 - OpenVPN > /sbin/ifconfig utun2 delete
. 2020.05.06 15:30:00 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2020.05.06 15:30:00 - OpenVPN > /sbin/ifconfig utun2 10.17.88.189 10.17.88.189 netmask 255.255.255.0 mtu 1500 up
. 2020.05.06 15:30:00 - OpenVPN > /sbin/route add -net 10.17.88.0 10.17.88.189 255.255.255.0
. 2020.05.06 15:30:00 - OpenVPN > add net 10.17.88.0: gateway 10.17.88.189
. 2020.05.06 15:30:00 - OpenVPN > /sbin/route add -net 213.152.162.73 192.168.178.1 255.255.255.255
. 2020.05.06 15:30:00 - OpenVPN > add net 213.152.162.73: gateway 192.168.178.1
. 2020.05.06 15:30:00 - OpenVPN > /sbin/route add -net 0.0.0.0 10.17.88.1 128.0.0.0
. 2020.05.06 15:30:00 - OpenVPN > add net 0.0.0.0: gateway 10.17.88.1
. 2020.05.06 15:30:00 - OpenVPN > /sbin/route add -net 128.0.0.0 10.17.88.1 128.0.0.0
. 2020.05.06 15:30:00 - OpenVPN > add net 128.0.0.0: gateway 10.17.88.1
. 2020.05.06 15:30:00 - Starting Management Interface
. 2020.05.06 15:30:00 - OpenVPN > Initialization Sequence Completed
I 2020.05.06 15:30:00 - DNS of a network adapter forced (Ethernet)
I 2020.05.06 15:30:00 - DNS of a network adapter forced (Wi-Fi)
I 2020.05.06 15:30:00 - DNS of a network adapter forced (Bluetooth PAN)
I 2020.05.06 15:30:00 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2020.05.06 15:30:00 - DNS of a network adapter forced (iPhone)
I 2020.05.06 15:30:00 - DNS of a network adapter forced (TomTom GO Premium X)
I 2020.05.06 15:30:00 - DNS of a network adapter forced (TomTom GO)
I 2020.05.06 15:30:00 - DNS of a network adapter forced (iPad)
I 2020.05.06 15:30:00 - Flushing DNS
I 2020.05.06 15:30:00 - Checking route
W 2020.05.06 15:30:50 - The request timed out
! 2020.05.06 15:30:50 - Disconnecting
. 2020.05.06 15:30:50 - Management - Send 'signal SIGTERM'
. 2020.05.06 15:30:50 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2020.05.06 15:30:50 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2020.05.06 15:30:50 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.05.06 15:30:55 - OpenVPN > /sbin/route delete -net 213.152.162.73 192.168.178.1 255.255.255.255
. 2020.05.06 15:30:55 - OpenVPN > delete net 213.152.162.73: gateway 192.168.178.1
. 2020.05.06 15:30:55 - Connection terminated.
I 2020.05.06 15:30:55 - DNS of a network adapter restored to original settings (Ethernet)
. 2020.05.06 15:30:55 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.17.88.1 128.0.0.0
. 2020.05.06 15:30:55 - OpenVPN > delete net 0.0.0.0: gateway 10.17.88.1
. 2020.05.06 15:30:55 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.17.88.1 128.0.0.0
. 2020.05.06 15:30:55 - OpenVPN > delete net 128.0.0.0: gateway 10.17.88.1
. 2020.05.06 15:30:55 - OpenVPN > Closing TUN/TAP interface
. 2020.05.06 15:30:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
I 2020.05.06 15:30:55 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2020.05.06 15:30:55 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2020.05.06 15:30:55 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2020.05.06 15:30:55 - DNS of a network adapter restored to original settings (iPhone)
I 2020.05.06 15:30:55 - DNS of a network adapter restored to original settings (TomTom GO Premium X)
I 2020.05.06 15:30:55 - DNS of a network adapter restored to original settings (TomTom GO)
I 2020.05.06 15:30:55 - DNS of a network adapter restored to original settings (iPad)
I 2020.05.06 15:30:58 - Checking authorization ...
! 2020.05.06 15:30:59 - Connecting to Garnet (Netherlands, Alblasserdam)
. 2020.05.06 15:30:59 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [SSL (OpenSSL)] [LZO] [MH] [IPv6] built on Aug 13 2015
. 2020.05.06 15:30:59 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2020.05.06 15:30:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2020.05.06 15:30:59 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2020.05.06 15:30:59 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 15:30:59 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 15:30:59 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2020.05.06 15:30:59 - OpenVPN > UDPv4 link local: [undef]
. 2020.05.06 15:30:59 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.73:443
. 2020.05.06 15:30:59 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.73:443, sid=83b0b93a 5ebe9adf
. 2020.05.06 15:30:59 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.05.06 15:30:59 - OpenVPN > Validating certificate key usage
. 2020.05.06 15:30:59 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2020.05.06 15:30:59 - OpenVPN > VERIFY KU OK
. 2020.05.06 15:30:59 - OpenVPN > Validating certificate extended key usage
. 2020.05.06 15:30:59 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.05.06 15:30:59 - OpenVPN > VERIFY EKU OK
. 2020.05.06 15:30:59 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Garnet, emailAddress=info@airvpn.org
. 2020.05.06 15:30:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2020.05.06 15:30:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 15:30:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2020.05.06 15:30:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 15:30:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.05.06 15:30:59 - OpenVPN > [Garnet] Peer Connection Initiated with [AF_INET]213.152.162.73:443
. 2020.05.06 15:31:01 - OpenVPN > SENT CONTROL [Garnet]: 'PUSH_REQUEST' (status=1)
. 2020.05.06 15:31:01 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.17.88.1,route-gateway 10.17.88.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.17.88.189 255.255.255.0,peer-id 2'
. 2020.05.06 15:31:01 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.05.06 15:31:01 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2020.05.06 15:31:01 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2020.05.06 15:31:01 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.05.06 15:31:01 - OpenVPN > OPTIONS IMPORT: route options modified
. 2020.05.06 15:31:01 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.05.06 15:31:01 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.05.06 15:31:01 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.05.06 15:31:01 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2020.05.06 15:31:01 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2020.05.06 15:31:01 - OpenVPN > Opened utun device utun2
. 2020.05.06 15:31:01 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2020.05.06 15:31:01 - OpenVPN > /sbin/ifconfig utun2 delete
. 2020.05.06 15:31:01 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2020.05.06 15:31:01 - OpenVPN > /sbin/ifconfig utun2 10.17.88.189 10.17.88.189 netmask 255.255.255.0 mtu 1500 up
. 2020.05.06 15:31:01 - OpenVPN > /sbin/route add -net 10.17.88.0 10.17.88.189 255.255.255.0
. 2020.05.06 15:31:01 - OpenVPN > add net 10.17.88.0: gateway 10.17.88.189
. 2020.05.06 15:31:01 - OpenVPN > /sbin/route add -net 213.152.162.73 192.168.178.1 255.255.255.255
. 2020.05.06 15:31:01 - OpenVPN > add net 213.152.162.73: gateway 192.168.178.1
. 2020.05.06 15:31:01 - OpenVPN > /sbin/route add -net 0.0.0.0 10.17.88.1 128.0.0.0
. 2020.05.06 15:31:01 - OpenVPN > add net 0.0.0.0: gateway 10.17.88.1
. 2020.05.06 15:31:01 - OpenVPN > /sbin/route add -net 128.0.0.0 10.17.88.1 128.0.0.0
. 2020.05.06 15:31:01 - OpenVPN > add net 128.0.0.0: gateway 10.17.88.1
. 2020.05.06 15:31:01 - Starting Management Interface
. 2020.05.06 15:31:01 - OpenVPN > Initialization Sequence Completed
I 2020.05.06 15:31:02 - DNS of a network adapter forced (Ethernet)
I 2020.05.06 15:31:02 - DNS of a network adapter forced (Wi-Fi)
I 2020.05.06 15:31:02 - DNS of a network adapter forced (Bluetooth PAN)
I 2020.05.06 15:31:02 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2020.05.06 15:31:02 - DNS of a network adapter forced (iPhone)
I 2020.05.06 15:31:02 - DNS of a network adapter forced (TomTom GO Premium X)
I 2020.05.06 15:31:02 - DNS of a network adapter forced (TomTom GO)
I 2020.05.06 15:31:02 - DNS of a network adapter forced (iPad)
I 2020.05.06 15:31:02 - Flushing DNS
I 2020.05.06 15:31:02 - Checking route
This is not the support file. If you click on the lifebelt icon, copy it all, please, not just the logs.
Is this okay? Starting AirVPN ->Logs->lifebelt
I 2020.05.06 18:45:15 - AirVPN client version: 2.10.3 / x86, System: OSX, Name: 10.12.6 / x64
. 2020.05.06 18:45:15 - Reading options from /Users/xxx/.airvpn/AirVPN.xml
. 2020.05.06 18:45:15 - Data Path: /Users/xxx/.airvpn
. 2020.05.06 18:45:15 - App Path: /Applications/AirVPN.app/Contents/MacOS
. 2020.05.06 18:45:15 - Executable Path: /Applications/AirVPN.app/Contents/MacOS/AirVPN
. 2020.05.06 18:45:15 - Command line arguments (0):
. 2020.05.06 18:45:15 - Updating systems & servers data ...
. 2020.05.06 18:45:15 - Operating System: Unix 16.7.0.0 - Darwin Jan-Dirks-iMac.local 16.7.0 Darwin Kernel Version 16.7.0: Sun Jun  2 20:26:31 PDT 2019; root:xnu-3789.73.50~1/RELEASE_X86_64 x86_64
I 2020.05.06 18:45:15 - OpenVPN Driver - Expected
I 2020.05.06 18:45:15 - OpenVPN - Version: OpenVPN 2.3.8 (/Applications/AirVPN.app/Contents/MacOS/openvpn)
I 2020.05.06 18:45:15 - SSH - Version: OpenSSH_7.4p1, LibreSSL 2.5.0 (/usr/bin/ssh)
I 2020.05.06 18:45:15 - SSL - Version: stunnel 5.17 (/Applications/AirVPN.app/Contents/MacOS/stunnel)
W 2020.05.06 18:45:15 - Recovery. Unexpected crash?
I 2020.05.06 18:45:15 - DNS of a network adapter restored to original settings (Ethernet)
I 2020.05.06 18:45:15 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2020.05.06 18:45:15 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2020.05.06 18:45:15 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2020.05.06 18:45:15 - DNS of a network adapter restored to original settings (iPhone)
I 2020.05.06 18:45:15 - DNS of a network adapter restored to original settings (TomTom GO Premium X)
I 2020.05.06 18:45:15 - DNS of a network adapter restored to original settings (TomTom GO)
I 2020.05.06 18:45:15 - DNS of a network adapter restored to original settings (iPad)
I 2020.05.06 18:45:16 - IPv6 restored on network adapter (Ethernet)
I 2020.05.06 18:45:16 - IPv6 restored on network adapter (Wi-Fi)
I 2020.05.06 18:45:16 - IPv6 restored on network adapter (Bluetooth PAN)
I 2020.05.06 18:45:16 - IPv6 restored on network adapter (Thunderbolt Bridge)
I 2020.05.06 18:45:16 - IPv6 restored on network adapter (TomTom GO Premium X)
I 2020.05.06 18:45:16 - IPv6 restored on network adapter (TomTom GO)
I 2020.05.06 18:45:16 - IPv6 restored on network adapter (iPad)
I 2020.05.06 18:45:16 - Session starting.
I 2020.05.06 18:45:16 - IPv6 disabled on network adapter (Ethernet)
. 2020.05.06 18:45:16 - Systems & servers data update completed
I 2020.05.06 18:45:16 - IPv6 disabled on network adapter (Wi-Fi)
I 2020.05.06 18:45:16 - IPv6 disabled on network adapter (Bluetooth PAN)
I 2020.05.06 18:45:16 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2020.05.06 18:45:16 - IPv6 disabled on network adapter (TomTom GO Premium X)
I 2020.05.06 18:45:17 - IPv6 disabled on network adapter (TomTom GO)
I 2020.05.06 18:45:17 - IPv6 disabled on network adapter (iPad)
I 2020.05.06 18:45:25 - Checking authorization ...
! 2020.05.06 18:45:25 - Connecting to Tarazed (Netherlands, Alblasserdam)
. 2020.05.06 18:45:25 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [SSL (OpenSSL)] [LZO] [MH] [IPv6] built on Aug 13 2015
. 2020.05.06 18:45:25 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2020.05.06 18:45:25 - Auto retry with another port.
. 2020.05.06 18:45:25 - OpenVPN > MANAGEMENT: Socket bind failed on local address [AF_INET]127.0.0.1:3100: Address already in use
. 2020.05.06 18:45:25 - OpenVPN > Exiting due to fatal error
! 2020.05.06 18:45:25 - Disconnecting
. 2020.05.06 18:45:25 - Connection terminated.
I 2020.05.06 18:45:28 - Checking authorization ...
! 2020.05.06 18:45:28 - Connecting to Tarazed (Netherlands, Alblasserdam)
. 2020.05.06 18:45:28 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [SSL (OpenSSL)] [LZO] [MH] [IPv6] built on Aug 13 2015
. 2020.05.06 18:45:29 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2020.05.06 18:45:29 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2020.05.06 18:45:29 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2020.05.06 18:45:29 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 18:45:29 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 18:45:29 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2020.05.06 18:45:29 - OpenVPN > UDPv4 link local: [undef]
. 2020.05.06 18:45:29 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.132:443
. 2020.05.06 18:45:29 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.132:443, sid=bd34b8fb 03abf8ff
. 2020.05.06 18:45:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.05.06 18:45:29 - OpenVPN > Validating certificate key usage
. 2020.05.06 18:45:29 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2020.05.06 18:45:29 - OpenVPN > VERIFY KU OK
. 2020.05.06 18:45:29 - OpenVPN > Validating certificate extended key usage
. 2020.05.06 18:45:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.05.06 18:45:29 - OpenVPN > VERIFY EKU OK
. 2020.05.06 18:45:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tarazed, emailAddress=info@airvpn.org
. 2020.05.06 18:45:29 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2020.05.06 18:45:29 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 18:45:29 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2020.05.06 18:45:29 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 18:45:29 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.05.06 18:45:29 - OpenVPN > [Tarazed] Peer Connection Initiated with [AF_INET]213.152.161.132:443
. 2020.05.06 18:45:31 - OpenVPN > SENT CONTROL [Tarazed]: 'PUSH_REQUEST' (status=1)
. 2020.05.06 18:45:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.31.44.1,route-gateway 10.31.44.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.31.44.112 255.255.255.0,peer-id 11'
. 2020.05.06 18:45:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.05.06 18:45:31 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2020.05.06 18:45:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.05.06 18:45:31 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2020.05.06 18:45:31 - OpenVPN > route: writing to routing socket: File exists
. 2020.05.06 18:45:31 - OpenVPN > OPTIONS IMPORT: route options modified
. 2020.05.06 18:45:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.05.06 18:45:31 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.05.06 18:45:31 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.05.06 18:45:31 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2020.05.06 18:45:31 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2020.05.06 18:45:31 - OpenVPN > Opened utun device utun3
. 2020.05.06 18:45:31 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2020.05.06 18:45:31 - OpenVPN > /sbin/ifconfig utun3 delete
. 2020.05.06 18:45:31 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2020.05.06 18:45:31 - OpenVPN > /sbin/ifconfig utun3 10.31.44.112 10.31.44.112 netmask 255.255.255.0 mtu 1500 up
. 2020.05.06 18:45:31 - OpenVPN > /sbin/route add -net 10.31.44.0 10.31.44.112 255.255.255.0
. 2020.05.06 18:45:31 - OpenVPN > add net 10.31.44.0: gateway 10.31.44.112
. 2020.05.06 18:45:31 - OpenVPN > /sbin/route add -net 213.152.161.132 192.168.178.1 255.255.255.255
. 2020.05.06 18:45:31 - OpenVPN > add net 213.152.161.132: gateway 192.168.178.1
. 2020.05.06 18:45:31 - OpenVPN > /sbin/route add -net 0.0.0.0 10.31.44.1 128.0.0.0
. 2020.05.06 18:45:31 - OpenVPN > add net 0.0.0.0: gateway 10.31.44.1: File exists
. 2020.05.06 18:45:31 - OpenVPN > /sbin/route add -net 128.0.0.0 10.31.44.1 128.0.0.0
. 2020.05.06 18:45:31 - OpenVPN > add net 128.0.0.0: gateway 10.31.44.1: File exists
. 2020.05.06 18:45:31 - Starting Management Interface
. 2020.05.06 18:45:31 - OpenVPN > Initialization Sequence Completed
I 2020.05.06 18:45:31 - DNS of a network adapter forced (Ethernet)
I 2020.05.06 18:45:31 - DNS of a network adapter forced (Wi-Fi)
I 2020.05.06 18:45:32 - DNS of a network adapter forced (Bluetooth PAN)
I 2020.05.06 18:45:32 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2020.05.06 18:45:32 - DNS of a network adapter forced (iPhone)
I 2020.05.06 18:45:32 - DNS of a network adapter forced (TomTom GO Premium X)
I 2020.05.06 18:45:32 - DNS of a network adapter forced (TomTom GO)
I 2020.05.06 18:45:32 - DNS of a network adapter forced (iPad)
I 2020.05.06 18:45:32 - Flushing DNS
I 2020.05.06 18:45:32 - Checking route
W 2020.05.06 18:46:22 - The request timed out
! 2020.05.06 18:46:22 - Disconnecting
. 2020.05.06 18:46:22 - Management - Send 'signal SIGTERM'
. 2020.05.06 18:46:22 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2020.05.06 18:46:22 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2020.05.06 18:46:22 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2020.05.06 18:46:22 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.05.06 18:46:27 - OpenVPN > /sbin/route delete -net 213.152.161.132 192.168.178.1 255.255.255.255
. 2020.05.06 18:46:27 - OpenVPN > delete net 213.152.161.132: gateway 192.168.178.1
. 2020.05.06 18:46:27 - Connection terminated.
. 2020.05.06 18:46:27 - OpenVPN > /sbin/route delete -net 0.0.0.0 10.31.44.1 128.0.0.0
I 2020.05.06 18:46:27 - DNS of a network adapter restored to original settings (Ethernet)
. 2020.05.06 18:46:27 - OpenVPN > delete net 0.0.0.0: gateway 10.31.44.1
. 2020.05.06 18:46:27 - OpenVPN > /sbin/route delete -net 128.0.0.0 10.31.44.1 128.0.0.0
. 2020.05.06 18:46:27 - OpenVPN > delete net 128.0.0.0: gateway 10.31.44.1
. 2020.05.06 18:46:27 - OpenVPN > Closing TUN/TAP interface
. 2020.05.06 18:46:27 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
I 2020.05.06 18:46:27 - DNS of a network adapter restored to original settings (Wi-Fi)
I 2020.05.06 18:46:27 - DNS of a network adapter restored to original settings (Bluetooth PAN)
I 2020.05.06 18:46:27 - DNS of a network adapter restored to original settings (Thunderbolt Bridge)
I 2020.05.06 18:46:27 - DNS of a network adapter restored to original settings (iPhone)
I 2020.05.06 18:46:27 - DNS of a network adapter restored to original settings (TomTom GO Premium X)
I 2020.05.06 18:46:27 - DNS of a network adapter restored to original settings (TomTom GO)
I 2020.05.06 18:46:27 - DNS of a network adapter restored to original settings (iPad)
I 2020.05.06 18:46:30 - Checking authorization ...
! 2020.05.06 18:46:30 - Connecting to Tarazed (Netherlands, Alblasserdam)
. 2020.05.06 18:46:30 - OpenVPN > OpenVPN 2.3.8 x86_64-apple-darwin14.4.0 [SSL (OpenSSL)] [LZO] [MH] [IPv6] built on Aug 13 2015
. 2020.05.06 18:46:30 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2020.05.06 18:46:30 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3101
. 2020.05.06 18:46:30 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2020.05.06 18:46:30 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 18:46:30 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 18:46:30 - OpenVPN > Socket Buffers: R=[196724->131072] S=[9216->131072]
. 2020.05.06 18:46:30 - OpenVPN > UDPv4 link local: [undef]
. 2020.05.06 18:46:30 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.132:443
. 2020.05.06 18:46:31 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.132:443, sid=fa6265e3 5ac11c8f
. 2020.05.06 18:46:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.05.06 18:46:31 - OpenVPN > Validating certificate key usage
. 2020.05.06 18:46:31 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2020.05.06 18:46:31 - OpenVPN > VERIFY KU OK
. 2020.05.06 18:46:31 - OpenVPN > Validating certificate extended key usage
. 2020.05.06 18:46:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.05.06 18:46:31 - OpenVPN > VERIFY EKU OK
. 2020.05.06 18:46:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tarazed, emailAddress=info@airvpn.org
. 2020.05.06 18:46:31 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2020.05.06 18:46:31 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 18:46:31 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2020.05.06 18:46:31 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2020.05.06 18:46:31 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.05.06 18:46:31 - OpenVPN > [Tarazed] Peer Connection Initiated with [AF_INET]213.152.161.132:443
. 2020.05.06 18:46:33 - OpenVPN > SENT CONTROL [Tarazed]: 'PUSH_REQUEST' (status=1)
. 2020.05.06 18:46:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway  def1 bypass-dhcp,dhcp-option DNS 10.31.40.1,route-gateway 10.31.40.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.31.40.225 255.255.255.0,peer-id 10'
. 2020.05.06 18:46:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.05.06 18:46:33 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2020.05.06 18:46:33 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2020.05.06 18:46:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.05.06 18:46:33 - OpenVPN > OPTIONS IMPORT: route options modified
. 2020.05.06 18:46:33 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.05.06 18:46:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.05.06 18:46:33 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.05.06 18:46:33 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1561
. 2020.05.06 18:46:33 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2020.05.06 18:46:33 - OpenVPN > Opened utun device utun3
. 2020.05.06 18:46:33 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2020.05.06 18:46:33 - OpenVPN > /sbin/ifconfig utun3 delete
. 2020.05.06 18:46:33 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2020.05.06 18:46:33 - OpenVPN > /sbin/ifconfig utun3 10.31.40.225 10.31.40.225 netmask 255.255.255.0 mtu 1500 up
. 2020.05.06 18:46:33 - OpenVPN > /sbin/route add -net 10.31.40.0 10.31.40.225 255.255.255.0
. 2020.05.06 18:46:33 - OpenVPN > add net 10.31.40.0: gateway 10.31.40.225
. 2020.05.06 18:46:33 - OpenVPN > /sbin/route add -net 213.152.161.132 192.168.178.1 255.255.255.255
. 2020.05.06 18:46:33 - OpenVPN > add net 213.152.161.132: gateway 192.168.178.1
. 2020.05.06 18:46:33 - OpenVPN > /sbin/route add -net 0.0.0.0 10.31.40.1 128.0.0.0
. 2020.05.06 18:46:33 - OpenVPN > add net 0.0.0.0: gateway 10.31.40.1
. 2020.05.06 18:46:33 - OpenVPN > /sbin/route add -net 128.0.0.0 10.31.40.1 128.0.0.0
. 2020.05.06 18:46:33 - OpenVPN > add net 128.0.0.0: gateway 10.31.40.1
. 2020.05.06 18:46:33 - Starting Management Interface
. 2020.05.06 18:46:33 - OpenVPN > Initialization Sequence Completed
I 2020.05.06 18:46:33 - DNS of a network adapter forced (Ethernet)
I 2020.05.06 18:46:33 - DNS of a network adapter forced (Wi-Fi)
I 2020.05.06 18:46:33 - DNS of a network adapter forced (Bluetooth PAN)
I 2020.05.06 18:46:33 - DNS of a network adapter forced (Thunderbolt Bridge)
I 2020.05.06 18:46:34 - DNS of a network adapter forced (iPhone)
I 2020.05.06 18:46:34 - DNS of a network adapter forced (TomTom GO Premium X)
I 2020.05.06 18:46:34 - DNS of a network adapter forced (TomTom GO)
I 2020.05.06 18:46:34 - DNS of a network adapter forced (iPad)
I 2020.05.06 18:46:34 - Flushing DNS
I 2020.05.06 18:46:34 - Checking route
See? Such info is crucial.
Please update Eddie first. Current stable version is 2.18.9.
Eddie is the nickname of the AirVPN client version 2.x. :)
29 minutes ago, Jan-Dirk said:
Is there an update-function?
I'm not sure on macOS. In Preferences you can set the update channel, though.
